Home » Eclipse Projects » Mylyn » Can't install JIRA connector from update site
Can't install JIRA connector from update site [message #59762] Mon, 13 October 2008 06:52 Go to next message
Using a Ganymede install, pointing to the "Mylyn Extras" update site [1]
and trying to install "Mylyn Connector: JIRA", I get the following errors.
Is the update site down?
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.mylyn.jira_feature/org.eclipse.update.feature/3. 0.1.v20080721-2100-e3x
org.eclipse.mylyn.jira.ui/osgi.bundle/3.0.1.v20080721-2100-e 3x
org.eclipse.mylyn.jira.core/osgi.bundle/3.0.1.v20080721-2100 -e3x
org.apache.axis/osgi.bundle/1.4.0.v200806030120
[1] http://download.eclipse.org/tools/mylyn/update/extras
Re: Can't install JIRA connector from update site [message #59786 is a reply to message #59762] Mon, 13 October 2008 07:23 Go to previous messageGo to next message
s@piperoglou.com (Stephanos Piperoglou) writes:
> [1] and trying to install "Mylyn Connector: JIRA", I get the following
> errors. Is the update site down?
Note that the errors mention 3.0.1 but 3.0.2 is the current
version. You probably have some stale information somewhere. Are you
trying to update from behind a web proxy with a cache? That has caused
me a lot of trouble but my experience suggests that there may be
several places where caches are holding stale information.
It is probably worth going to the "Available Software" tab of update
and doing a "Refresh" then see what version is listed under Mylyn
Extras.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Can't install JIRA connector from update site [message #59807 is a reply to message #59786] Mon, 13 October 2008 07:42 Go to previous message
Ah, you hit the nail on the head. I had tried refreshing but was getting
3.0.1 again - it must have been a duff proxy stuck in the past even though
my browser showed 3.2 if pointed to the update site. Fiddling with the
proxy settings to pick another one of our (load-balanced) proxies and
refreshing got me the right version.
Thanks a lot!
Re: Can't install JIRA connector from update site [message #594129 is a reply to message #59762] Mon, 13 October 2008 07:23 Go to previous message
Extras.
Re: Can't install JIRA connector from update site [message #594137 is a reply to message #59786] Mon, 13 October 2008 07:42 Go to previous message
Thanks a lot!
Previous Topic:Good Mylyn tutorial?
Next Topic:reassign a task repository
Current Time: Tue Jul 15 14:53:49 EDT 2025
Powered by FUDForum. Page generated in 0.06326 seconds
