Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO objects not loading correctly
CDO objects not loading correctly [message #59751] Tue, 31 October 2006 13:09 Go to next message
Eike,
I am now running the latest maintenance release for CDO and NET4J. No
patches.
But, I am still having some issues that I need to track down.
If I can use the analogy of the library that will help. Assume that I have
a class for Library which 'contains' all books. I also have a class, or
classes, for genre that may have non-containment references to books. So a
book could have references to-from a genre, and always has a reference to
the Library, which is containment.
Now I want to load all the books so I call library.getBooks(). This works
consistently. And if I subsequently, during the same session, load a
genre with a call to fiction.getBooks() that works as well.
However, if I restart to create a new session, and do the genre load first
I will see the books in the genre loaded correctly, but a subsequent call
to load all the books in the library will not have any of the books
initially loaded in the genre.
This is happening consistently, every time.
It appears that loading the containment references from Library is doing
something a bit different than the load of non-containment references for
the genre. If the initial load is via containment all the non-containment
references are correct. However, if the initial load is via
non-containment references then the other references, specifically the
containment reference, is not correct.
I suspect this is strictly a client side issue since the object is loaded
from the server. It seems to be the handling of setting all the references
for an object is not correct.
Any ideas...?
Mark.
Re: CDO objects not loading correctly [message #59775 is a reply to message #59751] Tue, 31 October 2006 13:19 Go to previous message
Originally posted by: stepper.sympedia.de
Mark,
I've recorded https://bugs.eclipse.org/bugs/show_bug.cgi?id=162961 for this.
Hopefully I can find the cause tonight because tomorrow morning I'll go
to Zurich for a week.
Cheers
/Eike
geib schrieb:
> Eike,
> patches.
> have a class for Library which 'contains' all books. I also have a
> class, or classes, for genre that may have non-containment references
> to books. So a book could have references to-from a genre, and always
> has a reference to the Library, which is containment.
> works consistently. And if I subsequently, during the same session,
> load a genre with a call to fiction.getBooks() that works as well.
> first I will see the books in the genre loaded correctly, but a
> subsequent call to load all the books in the library will not have any
> of the books initially loaded in the genre.
> doing something a bit different than the load of non-containment
> references for the genre. If the initial load is via containment all
> the non-containment references are correct. However, if the initial
> load is via non-containment references then the other references,
> specifically the containment reference, is not correct.
> loaded from the server. It seems to be the handling of setting all the
> references for an object is not correct.
> Any ideas...?
> Mark.
Re: CDO objects not loading correctly [message #595046 is a reply to message #59751] Tue, 31 October 2006 13:19 Go to previous message
Mark,
Cheers
/Eike
geib schrieb:
> Eike,
> patches.
> Any ideas...?
> Mark.
Previous Topic:CDO objects not loading correctly
Next Topic:EODM tutorial
Current Time: Tue Jul 22 12:03:40 EDT 2025
Powered by FUDForum. Page generated in 0.03840 seconds
