Home » Eclipse Projects » Equinox » Thoughts about servlets, resources, httpcontexts extension points
Thoughts about servlets, resources, httpcontexts extension points [message #59729] Mon, 06 February 2006 00:33 Go to next message
Originally posted by: newsreader.infonoia.com
I've been playing with these extension points, and I wonder if they
could/should be grouped into one "web-resource" extension point.
Ideally, the extension point would understand "web.xml" snippets,
as in
<pre><servlet id="struts">
<servlet-name>action</servlet-name>
<display-name>Struts Action Servlet</display-name>
<description>Struts Action Servlet</description>
<servlet-class>org.rsp.framework.struts.base.BundleActionServlet </servlet-class>
<load-on-startup>1</load-on-startup>
<init-param>
<param-name>config</param-name>
<param-value>/WEB-INF/config/struts.xml</param-value>
</init-param>
<init-param>
<param-name>chainConfig</param-name>
<param-value>/WEB-INF/config/chain.xml</param-value>
</init-param>
</servlet>
<servlet-mapping>
<url-pattern>/do/*</url-pattern>
</servlet-mapping></pre>
Now I do this in the extension point<pre><alias>
/do
</alias>
<servlet-class>
</servlet-class>
<init-param>
<param-value>*/WEB-INF/struts-config.xml</param-value>
</init-param>
<init-param>
</init-param></pre>
I see that <alias>/do</alias> corresponds to
<url-pattern>/do/*</url-pattern> under "classic web".
Of course, we still need httpcontext path info somewhere in there as an
attribute, but the rest would probably gain by being modeled web.xml
style. If we adhere to that, we might in some cases just specify the
path to a web.xml snippet in the extension point.
My point is, the closer to classic web, the simpler to do.
I am sure you have already had your thoughts about the above. Just 2c.
On a side note, the httpcontext impl. might want to prohibit remote
access to items under /WEB-INF/* (if I have a WEB-INF folder on the path.
Wolfgang Gehner
Re: Thoughts about servlets, resources, httpcontexts extension points [message #59826 is a reply to message #59729] Mon, 06 February 2006 11:22 Go to previous message
Originally posted by: skaegi.sympatico.ca
Hi Wolfgang,
I think finding a deployment descriptor that's close to a "classic" web-app
is a good goal.
Currently, the extensions mimic the OSGi HttpService but moving forward
mimicking the Servlet API is the right direction.
I'd really like to have a good look at supporting for Filters and maybe
listeners too. This is probably longer-term though.
-Simon
"Wolfgang Gehner" <newsreader@infonoia.com> wrote in message
news:ds6n3d$7df$1@utils.eclipse.org...
> as in
ass>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </servlet>
> <servlet-mapping>
> /do
> </alias>
> <servlet-class>
> </servlet-class>
> <init-param>
> </init-param>
> <init-param>
> </init-param></pre>
> Wolfgang Gehner
Previous Topic:turn classloading on the server-side upside down
Next Topic:How do you set dependencies on services?
Current Time: Thu Jul 17 19:49:57 EDT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
