Home » Modeling » TMF (Xtext) » [Xtext] Update highlighting after document change
[Xtext] Update highlighting after document change [message #59719] Thu, 16 July 2009 16:46 Go to next message
Originally posted by: c.krause.cwi.nl
in my application I have an action that appends additional text at the
end of a document in an open Xtext editor. I do this simply by:
doc.modify(new IUnitOfWork<Void,XtextResource>() {
public Void exec(XtextResource resource) throws Exception {
doc.set(doc.get() + newText);
return null;
Then I do this to move the selection to the end of the file, which seems
to work:
editor.selectAndReveal(doc.getLength(), 0);
My problem is that keywords and integers are not highlighted in the
added text. If I edit the added text the highlighting is updated,
but only where I edit it. Strangely, a comment /* ... */ that I also add
is correctly highlighted.
I tried to call editor.resetHighlightRange() to somehow trigger a
rehighlighting but it didn't change anything. Is there anything else I
could try?
Christian
Re: [Xtext] Update highlighting after document change [message #59741 is a reply to message #59719] Thu, 16 July 2009 16:49 Go to previous messageGo to next message
Ok, it seems now that also the comments are not highlighted. I don't
know what happened there before..
Christian Krause wrote:
> return null;
> to work:
> could try?
> Cheers,
> Christian
Re: [Xtext] Update highlighting after document change [message #59885 is a reply to message #59741] Fri, 17 July 2009 04:45 Go to previous messageGo to next message
Hi Christian,
that's kind of irritating as I've something like this before and it
worked as expected.
However, you should try to create an InsertEdit and call apply(Document)
instead of modifying the content brute force via document.set(). If this
does not work, please file a bug and describe the steps to reproduce it.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 16.07.2009 22:49 Uhr, schrieb Christian Krause:
>> return null;
>> seems to work:
>> add is correctly highlighted.
>> could try?
>> Cheers,
>> Christian
Re: [Xtext] Update highlighting after document change [message #59958 is a reply to message #59885] Fri, 17 July 2009 05:04 Go to previous message
Dear Sebastian,
that works like a charm :). Thanks a lot.
Christian
> Hi Christian,
> worked as expected.
> apply(Document) instead of modifying the content brute force via
> document.set(). If this does not work, please file a bug and describe
> Sebastian
Previous Topic:Generation oddity with imported grammar
Next Topic:Content assist context
Current Time: Sun Aug 31 21:38:31 EDT 2025
Powered by FUDForum. Page generated in 0.28389 seconds
