Help. How can i use JDK 1.4.1_02 in enclipse [message #590916] |
Fri, 28 February 2003 17:29 |
Prashant Messages: 6 Registered: July 2009 |
I am new to eclipse platform. I have two JDK installed in my computer (JDK
1.3.1_06 and JDK 1.4.1_02). I would like to use JDK 1.4.1_02 to compile
and run my application using eclipse. I tried to set up environment of
eclipse through GUI by going through Windows-->Preference menu option. In
JRE options, it allows user to select the "Installed JRE" folder to switch
to any JRE (in my case it is JRE v1.4.1_02). But in compilation tab, it
doesn't ask for the path for which JDK compiler to be used. I am cofused
over here. Which "javac" elipse is going to use whenever i select
"Rebuild" option.
After trying all the option, whenever i selects run option, i getting
following error in dialog.
Exception occured during launch.
Reason:
Exception occured excecuting command line.
Can somebody tell me how to set JDK 1.4.1_02 environment in latest Eclipse?
Thanks in Advance.
FUDForum. Page generated in 0.02347 seconds
