[TCS] indexing values in list property [message #5323] |
Fri, 14 March 2008 05:51  |
Assuming I had a Metamodel class like this in KM3:
class MyClass {
attribute name : String;
attribute something : String;
reference elements[2-2] ordered container : Element
class Element {
is there any way I could refer to the first or the second of elements in
my TCS template directly?
Such as something like this (I invented "index" here):
template MyClass
: name ","
elements{index=0, referTo=name} ":"
something ","
elements{index=1, referTo=name}
Re: [TCS] indexing values in list property [message #7320 is a reply to message #5323] |
Fri, 14 March 2008 06:38   |
Did you try something like:
template MyClass
: name "," elements{index=0, referTo=name, separator =
":" something ","}
Frédéric Jouault
Thibault a écrit :
> class MyClass {
> class Element {
> template MyClass
> : name "," elements{index=0, referTo=name} ":"
> something ","
Re: [TCS] indexing values in list property [message #7341 is a reply to message #7320] |
Fri, 14 March 2008 07:37  |
> template MyClass
> ":" something ","}
I assume you mean (leaving out the imaginary "index=0"):
template MyClass
: name "," elements{referTo=name, separator =
":" something ","}
I did not try, though I thought about using the separator in a similar
case.
But in a way, that's cheating to me, meaning somebody would have to think
about it to understand that the result would be "firstelement : something,
otherelement"
And this solution would not work for 3 elements and some similar problem.
I guess from your suggestion that TCS currently does not generally allow
referring to indexes of elements in property lists, though in the case of
2 elements, the separator concept might be used as workaround.
In any case thank you, as I had not thought the separator to be so
flexible to allow nesting properties in it.
FUDForum. Page generated in 0.04238 seconds
