Home » Language IDEs » ServerTools (WTP) » javax.servlet.*: attach sources
javax.servlet.*: attach sources [message #59679] Mon, 03 January 2005 09:19 Go to next message
Originally posted by: labatteg.yahoo.com
How can I configure M2 to attach the sources for the javax.servlet.*
package.
i.e. I would like to be able to access the javadocs, that the
autocompletion tool would provide meaningful parameters names (not arg0,
arg1...), etc.
I'm using Tomcat 5.5.
Re: javax.servlet.*: attach sources [message #59848 is a reply to message #59679] Tue, 04 January 2005 08:36 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Good question. I am also trying to do the same. I have downloaded the
sources of Tomcat (5.0.x in my case) and there I have
jakarta-servletapi-5 sources. But I can't attach those sources to
servlet-api.jar file because it is contained wihtin a Java Library
Container.
Where is this Java Library defined? I haven't found it in any Preference.
Thanks in advance,
Chemi.
Guillermo Labatte wrote:
> Hi
> package.
> arg0, arg1...), etc.
Re: javax.servlet.*: attach sources [message #59918 is a reply to message #59679] Tue, 04 January 2005 08:52 Go to previous message
Guillermo Labatte schrieb:
> Hi
> package.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=81633
Workaround: Remove the Tomcat classpath container and add the jars
manually to your classpath.
Cu, Gunnar
Previous Topic:Which to download? wtp-1.0M2.zip or wtp-sdk-1.0M2
Next Topic:Problem debugging Servlets and JSPs
Current Time: Thu Jul 17 21:53:06 EDT 2025
Powered by FUDForum. Page generated in 0.09219 seconds
