getContent [message #59642] |
Tue, 26 April 2005 06:32  |
Originally posted by: aaudevart.genigraph.fr
I 've got a little problem.
I want to extract the simple type includes in the <xs:attribute>.
I manage to extract the name and the use of the attribute like this :
XSDAttributeUse attribute = (XSDAttributeUse) attributeList.get(i);
XSDAttributeUseCategory attUse = attribute.getUse();
String nameAttribut = attribute.getAttributeDeclaration().getName();
Here is my code :
<xs:attribute name="Etat" use="required">
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:enumeration value="Connu"/>
<xs:enumeration value="Inconnu"/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
I think using the function attribute.getContent(); But I can't extract the
value!!!
can somebody help me?
Re: getContent [message #594964 is a reply to message #59642] |
Tue, 26 April 2005 06:43  |
Alex,
Use XSDAttribute.getTypeDefinition(), e.g.,
attribute.getAttributeDeclaration().getTypeDefinition().
XSDAttributeDeclaration.getAnonymousTypeDefinition() will return the
same type, but only if it's the anonymous type.
Alex wrote:
> Here is my code :
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> the value!!!
> can somebody help me? Thanks
Re: getContent [message #594974 is a reply to message #59667] |
Tue, 26 April 2005 08:03  |
I am agree with you but I want to have a XSDElementDeclaration. It ' s
possible?
We can't cast XSDSimpleTypeDefinition in a XSDElementDeclaration.
Thanks for your help!
Re: getContent [message #595001 is a reply to message #59690] |
Tue, 26 April 2005 11:27  |
Alex,
You asked for about simple types used in attributes, and showed code
accessing a attribute declaration; could you explain with a little bit
more detail how wanting a element declaration fits into the picture?
> possible?
Re: getContent [message #595011 is a reply to message #59760] |
Tue, 26 April 2005 11:56  |
I'll try to explain you with more details.
So, i have a tree like this:
<xs:complexType name="ParentType">
<xs:sequence>
<xs:element name="Nom" type="NomType" minOccurs="0"/>
</xs:sequence>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
I manage to extract the name and the use of the <xs:attribute>
But now, i want to extract this :
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
In my programm, i use a method who take a XSDElementDeclaration in
parameter.
My problem is to extract my simple Type and convert it in a
XSDSimpleTypeDefinition.
I hope it's more clear.
Re: getContent [message #595022 is a reply to message #59783] |
Tue, 26 April 2005 12:10  |
--------------020402030103010503080300
Alex,
No, I'm still confused. The type of the XSDAttributeDeclaration is
extracted with the following method, so I would have thought you'd
already have exactly what you need:
* Returns the value of the '<em><b>Type Definition</b></em>'
reference.
* <!-- begin-user-doc -->
* <p>
* This represents the
* <a
href="http://www.w3.org/TR/xmlschema-1/#a-simple_type_definition">type
definition</a>
* infoset property.
* </p>
* <!-- end-user-doc -->
* @return the value of the '<em>Type Definition</em>' reference.
* @see #setTypeDefinition(XSDSimpleTypeDefinition)
* @see
org.eclipse.xsd.XSDPackage#getXSDAttributeDeclaration_TypeDe finition()
* @model resolveProxies="false" required="true"
* @generated
XSDSimpleTypeDefinition getTypeDefinition();
I still don't understand how XSDElementDeclaration fits into the question...
> <xs:sequence>
> </xs:sequence>
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> </xs:complexType>
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> parameter.
> Thanks
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Alex,<br>
<br>
Re: getContent [message #595032 is a reply to message #59783] |
Tue, 26 April 2005 13:03  |
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> parameter.
I think there is a misunderstanding what an XSDElementDeclaration really is.
Unlike in DOM the schema elements (like simpleType, complexType, ...) aren't
all elements (or element declarations). An XSDElementDeclaration just is
something like this:
<xs:element name="foo" type="bar"/>
or
<xs:element name="foo">
<xs:complexType>
</xs:complexType>
</xs:element>
So if you want to extract the xs:simpleType the XSDSimpleTypeDefinition is
what you want (like Ed said). And there is no possibility to cast to an
Cheers
Klaas
FUDForum. Page generated in 0.72892 seconds
