OCL GMF LinkConstraint with Generalization [message #59638] |
Tue, 22 July 2008 15:26  |
sorry for the Question, but I`m new in OCL.
I want to create a LinkConstraint for my GMF Editor.
My Model look like this:
Root
instances:Instance
links:Link
Instance
Link
src:Instance
dst:Instance
Class1 -> Instance
Class2 -> Instance
Class3 -> Instance
I want to forbid special Links, for example between Class1 and 2.
It is possible?
Thanks for your Help.
Peter
Re: OCL GMF LinkConstraint with Generalization [message #59664 is a reply to message #59638] |
Tue, 22 July 2008 16:11  |
Originally posted by: cdamus.zeligsoft.com
--=-Q/kc/o882zK6oMMAmlTl
Content-Type: text/plain
Hi, Peter,
Apart from the mechanics of specifying link constraints in GMF (which
question would be better asked on the GMF newsgroup), I can possibly
help with the "pure OCL" aspect of your problem.
Do I read your syntax correctly, that Class1 and Class2 are model
elements that are instances of the Instance metaclass?
In that case, you could simply do:
context Link
inv: src->union(dst).name <> Set{'Class1', 'Class2'}
What I am doing here is creating a Set(Instance) containing the objects
referenced via the src and dst properties of the contextual Link object,
collecting the names of the Instances in this set, and ensuring that the
resulting set of names is different from the names that indicate
badness.
HTH,
Christian
On Tue, 2008-07-22 at 21:26 +0200, Peter wrote:
> Hello,
> Root
> instances:Instance
> links:Link
> Instance
> Link
> src:Instance
> dst:Instance
> Class1 -> Instance
> Class2 -> Instance
> Class3 -> Instance
> It is possible?
> Peter
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Peter,<BR>
<BR>
Apart from the mechanics of specifying link constraints in GMF (which question would be better asked on the GMF newsgroup), I can possibly help with the "pure OCL" aspect of your problem.<BR>
<BR>
Do I read your syntax correctly, that Class1 and Class2 are model elements that are instances of the Instance metaclass?<BR>
<BR>
In that case, you could simply do:<BR>
<BR>
context Link<BR>
inv: src->union(dst).name <> Set{'Class1', 'Class2'}<BR>
<BR>
What I am doing here is creating a Set(Instance) containing the objects referenced via the src and dst properties of the contextual Link object, collecting the names of the Instances in this set, and ensuring that the resulting set of names is different from the names that indicate badness.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hello,</FONT>
<FONT COLOR="#000000">sorry for the Question, but I`m new in OCL.</FONT>
<FONT COLOR="#000000">I want to create a LinkConstraint for my GMF Editor.</FONT>
<FONT COLOR="#000000">My Model look like this:</FONT>
<FONT COLOR="#000000">Root</FONT>
<FONT COLOR="#000000"> instances:Instance</FONT>
<FONT COLOR="#000000"> links:Link</FONT>
<FONT COLOR="#000000">Instance</FONT>
<FONT COLOR="#000000"> name:EString</FONT>
<FONT COLOR="#000000">Link</FONT>
<FONT COLOR="#000000"> src:Instance</FONT>
<FONT COLOR="#000000"> dst:Instance</FONT>
<FONT COLOR="#000000">Class1 -> Instance</FONT>
<FONT COLOR="#000000">Class2 -> Instance</FONT>
<FONT COLOR="#000000">Class3 -> Instance</FONT>
<FONT COLOR="#000000">...</FONT>
<FONT COLOR="#000000">I want to forbid special Links, for example between Class1 and 2.</FONT>
<FONT COLOR="#000000">It is possible?</FONT>
<FONT COLOR="#000000">Thanks for your Help.</FONT>
<FONT COLOR="#000000">Peter</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-Q/kc/o882zK6oMMAmlTl--
FUDForum. Page generated in 0.03768 seconds
