can not see any server runtime [message #59629] |
Sun, 02 January 2005 14:50  |
Originally posted by: mohsen_s.myrealbox.com
I have recently downloaded and installed Eclipse 3.01M4 + WTP 1M2 and also the
latest versions of EMF, JEM and GEF.
I can not ad any server through preferences>Server>Installed Runtimes>Add...,
since there is no server listed for me.
Would some one please tell me what should I do?
Thanks in advance.
Re: can not see any server runtime [message #91910 is a reply to message #60184] |
Wed, 13 April 2005 15:29  |
Originally posted by: o00oo.free.fr
Le Tue, 04 Jan 2005 20:55:51 +0330, Mohsen Saboorian a écrit :
Nothing to.
*** Date: 13/04/05 21:12
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20050219-1500
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/usr/local/share/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
d800c
-vm
/usr/bin/java
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1113418798112
eclipse.vm=/usr/bin/java
eclipse.vmargs=-jar
/usr/local/share/eclipse/startup.jar
eof=eof
file.encoding=ISO-8859-15
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/local/share/eclipse/startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/lib/j2se/1.4/jre/lib/endorsed
java.ext.dirs=/usr/lib/j2se/1.4/jre/lib/ext:/usr/lib/j2se/ex t
java.home=/usr/lib/j2se/1.4/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/j2se/1.4/jre/lib/i386/client:/usr /lib/j2se/1.4/jre/lib/i386:/usr/lib/j2se/1.4/jre/../lib/i386 :/usr/lib:/lib:/usr/lib/j2se/i386:/usr/lib/jni
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=Blackdown-1.4.2-rc1
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesFactory
java.vendor=Blackdown Java-Linux Team
java.vendor.url=http://www.blackdown.org/
java.vendor.url.bug=http://www.blackdown.org/cgi-bin/jdk
java.version=1.4.2-rc1
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Blackdown Java-Linux Team
java.vm.version=Blackdown-1.4.2-rc1
line.separator=
org.osgi.framework.executionenvironment=
org.osgi.framework.language=fr
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.8-2-686
org.osgi.framework.processor=i386
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start, org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/usr/local/share/eclipse/configuration/org. eclipse.osgi/bundles
osgi.configuration.area=file:/usr/local/share/eclipse/config uration/
osgi.framework=file:/usr/local/share/eclipse/plugins/org.ecl ipse.osgi_3.1.0/
osgi.framework.beginningstartlevel=1
osgi.framework.shape=folder
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar, defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/usr/local/share/eclipse/
osgi.instance.area=file:/home/zyll/workspace/
osgi.instance.area.default=file:/home/zyll/workspace/
osgi.logfile=/home/zyll/workspace/.metadata/.log
osgi.manifest.cache=/usr/local/share/eclipse/configuration/o rg.eclipse.osgi/manifests
osgi.nl=fr_FR
osgi.os=linux
osgi.splashLocation=/usr/local/share/eclipse/plugins/org.ecl ipse.platform_3.1.0/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/local/share/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/lib/j2se/1.4/jre/lib/rt.jar:/usr/li b/j2se/1.4/jre/lib/i18n.jar:/usr/lib/j2se/1.4/jre/lib/sunrsa sign.jar:/usr/lib/j2se/1.4/jre/lib/jsse.jar:/usr/lib/j2se/1. 4/jre/lib/jce.jar:/usr/lib/j2se/1.4/jre/lib/charsets.jar:/us r/lib/j2se/1.4/jre/classes
sun.boot.library.path=/usr/lib/j2se/1.4/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=unknown
user.country=FR
user.dir=/home/zyll
user.home=/home/zyll
user.language=fr
user.name=zyll
user.timezone=Europe/Paris
*** Features:
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.0) "Eclipse Modeling Framework (EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.0) "EMF Service Data Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.0) "EMF Service Data Objects (SDO) Source"
org.eclipse.emf.source (2.1.0) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.0) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.1.0) "Graphical Editing Framework Developer Resources"
org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer Resources"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.2) "Java EMF Model"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.0) "XML Schema Infoset Model (XSD) Programmers Guide"
org.eclipse.xsd.source (2.1.0) "XML Schema Infoset Model (XSD) Source"
org.tigris.subversion.subclipse (0.9.30) "Subclipse"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in" [Resolved]
com.ibm.wtp.emf.workbench (1.0.1.1) "EMF Workbench" [Resolved]
org.apache.ant (1.6.2) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.compare (3.1.0) "Compare Support" [Resolved]
org.eclipse.core.boot (3.0.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.linux (3.0.0) "Core Resource Management Linux Fragment" [Resolved]
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.0) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI" [Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.doc (2.1.0) "Eclipse Modeling Framework (EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.doc (2.1.0) "EMF Service Data Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.sdo.source (2.1.0) "EMF Service Data Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.source (2.1.0) "Eclipse Modeling Framework (EMF) Source" [Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.0) "Graphical Editing Framework Documentation" [Resolved]
org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer Resources" [Resolved]
org.eclipse.help (3.0.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.0.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.0.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.0.0) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.0.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Resolved]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support" [Resolved]
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Resolved]
org.eclipse.jem (1.0.2) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support" [Resolved]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Resolved]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime" [Resolved]
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.1.0) "Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.0) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk (3.1.0) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Resolved]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Resolved]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.cheatsheets (3.0.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Resolved]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.0.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Intro Plugin" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.0.0) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.0.0) "Install/Update Core for Linux" [Resolved]
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.0.0) "Install/Update UI" [Active]
org.eclipse.wst.command.env (1.0.0) "Environment Command Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.command.env.ui (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.common.contentmodel (1.0.0) "%pluginName" [Active]
org.eclipse.wst.common.dependencychecker (1.0.0) "%PLUGIN_NAME" [Active]
org.eclipse.wst.common.emf (1.0.0) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (1.0.0) "EMF Workbench Edit Plug-in" [Resolved]
org.eclipse.wst.common.encoding (1.0.0) "Coded Resource" [Active]
org.eclipse.wst.common.frameworks (1.0.0) "org.eclipse.wst.common.frameworks" [Resolved]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.migration (1.0.0) "Tacit Migration Engine Plug-in" [Resolved]
org.eclipse.wst.common.migration.ui (1.0.0) "Compatibility Engine Startup Hook" [Resolved]
org.eclipse.wst.common.modulecore (1.0.0) "Modulecore Plug-in" [Resolved]
org.eclipse.wst.common.navigator.views (1.0.0) "%Plugin.name" [Resolved]
org.eclipse.wst.common.navigator.workbench (1.0.0) "Navigator Workbench Components" [Resolved]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.0.0) "org.eclipse.wst.common.uriresolver" [Resolved]
org.eclipse.wst.css.core (1.0.0) "Structured Source CSS Model" [Active]
org.eclipse.wst.css.ui (1.0.0) "SSE CSS Source Editor" [Active]
org.eclipse.wst.dtd (1.0.0) "DTD Model" [Resolved]
org.eclipse.wst.dtd.contentmodel (1.0.0) "%pluginName" [Resolved]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Model" [Resolved]
org.eclipse.wst.dtd.parser (1.0.0) "%pluginName" [Resolved]
org.eclipse.wst.dtd.ui (1.0.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.dtd.validation (1.0.0) "DTD Validator" [Resolved]
org.eclipse.wst.html.core (1.0.0) "Structured Source HTML Model" [Resolved]
org.eclipse.wst.html.ui (1.0.0) "SSE HTML Source Editor" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (1.0.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.internet.webbrowser (1.0.0) "Web Browser" [Resolved]
org.eclipse.wst.javascript.common.ui (1.0.0) "SSE JavaScript Common UI" [Resolved]
org.eclipse.wst.javascript.core (1.0.0) "Structured Source JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.0) "SSE JavaScript Source Editor" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (1.0.0) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.0) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.cloudscape (1.0.0) "IBM Cloudscape Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.0) "DB2 UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.0) "DB2 UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.0) "IBM Cloudscape Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0) "DBDefinition Informix Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0) "DBDefinition Oracle Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.0) "DBDefinition SQLServer Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.0) "DBDefinition Sybase Plug-in" [Resolved]
org.eclipse.wst.rdb.derby (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (1.0.0) "DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (1.0.0) "OutputView Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.0) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.0) "Server UI" [Active]
org.eclipse.wst.server.util (1.0.0) "Server Utilities" [Active]
org.eclipse.wst.sse.core (1.0.0) "Structured Text Model" [Active]
org.eclipse.wst.sse.snippets (1.0.0) "SSE Snippets View" [Resolved]
org.eclipse.wst.sse.ui (1.0.0) "Structured Source Editor" [Active]
org.eclipse.wst.validation (1.0.0) "Validation Framework" [Resolved]
org.eclipse.wst.validation.ui (1.0.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (1.0.0) "Simple Web Plug-in" [Resolved]
org.eclipse.wst.web.ui (1.0.0) "Simple Web UI Plug-in" [Resolved]
org.eclipse.wst.ws.apache.axis (1.0.0) "Apache Axis 1.1" [Resolved]
org.eclipse.wst.ws.apache.soap (1.0.0) "Apache SOAP 2.3.1" [Resolved]
org.eclipse.wst.ws.apache.wsil (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.eclipse.wst.ws.parser (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.ws.uddi4j (1.0.0) "UDDI4J 2.0" [Resolved]
org.eclipse.wst.wsdl (1.0.0) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.0.0) "WSDL Editor" [Resolved]
org.eclipse.wst.xml.core (1.0.0) "Structured Source XML Model" [Active]
org.eclipse.wst.xml.ui (1.0.0) "SSE XML Source Editor" [Active]
org.eclipse.wst.xml.uriresolver (1.0.0) "%pluginName" [Resolved]
org.eclipse.wst.xml.uriresolver.ui (1.0.0) "XML Catalog UI" [Resolved]
org.eclipse.wst.xml.validation (1.0.0) "XML Validator" [Resolved]
org.eclipse.wst.xsd.contentmodel (1.0.0) "Content Model for XML Schema" [Resolved]
org.eclipse.wst.xsd.ui (1.0.0) "XML Schema Editor" [Resolved]
org.eclipse.wst.xsd.validation (1.0.0) "XML Schema Validator" [Resolved]
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.doc (2.1.0) "XML Schema Infoset Model (XSD) Programmers Guide" [Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.source (2.1.0) "XML Schema Infoset Model (XSD) Source" [Resolved]
org.eclipse.xsd.test (2.1.0) "XML Schema Infoset Model Test" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.tigris.subversion.subclipse (0.9.30) "Subclipse" [Resolved]
org.tigris.subversion.subclipse.core (0.9.30) "SVN Team Provider Core" [Resolved]
org.tigris.subversion.subclipse.ui (0.9.30) "SVN Team Provider UI" [Resolved]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Wed Apr 13 21:12:16 CEST 2005
/configuration/org.eclipse.ui/RECENT_WORKSPACES_PROTOCOL=2
@org.eclipse.wst.server.core=1.0.0
/configuration/org.eclipse.ui/MAX_RECENT_WORKSPACES=5
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.ui=3.1.0
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jdt.ui.override.decorator\:true,org.eclipse.pde.ui.bin aryProjectDecorator\:false,org.eclipse.team.cvs.ui.decorator \:false,org.eclipse.ui.LinkedResourceDecorator\:true,org.ecl ipse.wst.rdb.core.internal.ui.explorer.DependencyDecoration\ :true,org.eclipse.wst.rdb.core.internal.ui.explorer.ColumnDe coration\:true,org.eclipse.wst.rdb.core.internal.ui.explorer .ForeignKeyDecoration\:true,com.ibm.datatools.project.intern al.ui.explorer.ServerStateDecoration\:true,org.tigris.subver sion.subclipse.ui.decorator\:true,
/instance/org.eclipse.wst.server.core/auto-publish=false
/configuration/org.eclipse.ui/RECENT_WORKSPACES=/home/zyll/w orkspace/,/root/workspace
/instance/org.eclipse.wst.internet.proxy/passwordText=encode d\:
/instance/org.eclipse.wst.server.core/restart-module-timeout =120000
@org.eclipse.ui.workbench=3.1.0
/configuration/org.eclipse.ui/SHOW_WORKSPACE_SELECTION_DIALO G=true
/instance/org.eclipse.wst.internet.proxy/nonProxyHostsText=l ocalhost
/instance/org.eclipse.wst.server.core/create-workspace=true
/instance/org.eclipse.wst.server.core/start-timeout=210000
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
/instance/org.eclipse.wst.server.core/auto-restart=true
@org.eclipse.wst.server.ui=1.0.0
/instance/org.eclipse.wst.internet.proxy/userNameText=encode d\:
@org.eclipse.wst.internet.proxy=1.0.0
/instance/org.eclipse.wst.server.ui/prompt-irreversible=fals e
file_export_version=3.0
*** Update Manager Log:
Configuration=Sun Apr 10 23:16:09 CEST 2005
Is current configuration=false
Configuration=Sun Apr 10 23:35:55 CEST 2005
Configuration=Mon Apr 11 01:16:52 CEST 2005
Is current configuration=true
FUDForum. Page generated in 0.04206 seconds
