Home » Eclipse Projects » Mylyn » How do I build Mylyn source
How do I build Mylyn source [message #59580] Fri, 10 October 2008 15:03 Go to next message
I got the Mylyn source. Where can I find build instructions for Mylyn and
plugins?
Suannda
Re: How do I build Mylyn source [message #59854 is a reply to message #59580] Tue, 14 October 2008 00:43 Go to previous message
> and plugins?
If your workspace is set up correctly, Eclipse should automatically compile
the code:
http://wiki.eclipse.org/index.php/Mylyn/Contributor_Referenc e#Workspace
If you are getting specific errors during compilation, you should post them
here.
If none of that answers your question, you should explain what you're trying
to do, what you expected, and what actually happened.
Good luck,
---Tom
Re: How do I build Mylyn source [message #594153 is a reply to message #59580] Tue, 14 October 2008 00:43 Go to previous message
> and plugins?
the code:
here.
Good luck,
---Tom
Previous Topic:Can´t synchronize XPlanner task time using mylyn's time tracker
Next Topic:Can't install Trac Connector
Current Time: Mon Sep 01 01:24:58 EDT 2025
Powered by FUDForum. Page generated in 0.02940 seconds
