Home » Modeling » M2T (model-to-text transformation) » Jet2 using Jet2Platform
Jet2 using Jet2Platform [message #59554] Tue, 21 April 2009 06:49 Go to next message
Originally posted by: johannes.nel.gmail.com
I execute a Jet transform successfully from my plugin, but the files do
not get written to disk.
I execute the the following code from a wizard finish event,
IRunnableWithProgress op = new IRunnableWithProgress()
public void run(IProgressMonitor monitor) throws
InvocationTargetException {
try
IStatus status =
JET2Platform.runTransformOnString("some.package.SimpleTransform ","<rxml/>",monitor);
System.out.println(status.getMessage());
finally
monitor.done();
try
getContainer().run(true, true, op);
catch(Exception e)
and I get an "execution successful" status back.
This same transformation works when I run it as a Jet Transformation.
Any hints would be handy, this has become a major hold up for me now.
TIA
JOhan
Re: Jet2 using Jet2Platform [message #59604 is a reply to message #59554] Tue, 21 April 2009 16:44 Go to previous messageGo to next message
Johannes:
You don't say what kind of model your transformation is working with.
The runTransformOnString variant you are using assumes the input is XML,
and tries to parse it as such. If your transformation is the workspace is
loading the model differently (say via EMF serialization/deserialization),
then your XPath expressions may be silently returning nothing, and your
transformation may be silently doing nothing.
Some questions:
1) how did you create the input model/file that works correctly? Is it via
EMF?
2) If unsure of #1, how about pasting the first few lines into a reply -
that will quickly sort things out...
3) thinking ahead. How are you producing the input your are trying to pass
to JET2Platform.runTransformOnString() ? Do you, by any chance, have an
EMF generated API for it? If so, we'll take a look at
runTransformOnObject, where you pass in an emf Resource object containing
your input.
Paul
Re: Jet2 using Jet2Platform [message #59820 is a reply to message #59604] Thu, 23 April 2009 06:25 Go to previous messageGo to next message
Hi Paul
Paul Elder wrote:
> Johannes:
> is loading the model differently (say via EMF
> serialization/deserialization), then your XPath expressions may be
> silently returning nothing, and your transformation may be silently
> doing nothing.
> Some questions:
> via EMF?
Its xml which I build and is valid.
> pass to JET2Platform.runTransformOnString() ? Do you, by any chance,
> have an EMF generated API for it? If so, we'll take a look at
> containing your input.
this is my long term goal, but currently I am linking an existing swt
wizard (create new class type) to output the string (via an adaptor),
which I then pass to the transform.
> Paul
I added all the code that is used already.
Its really weird, but it just does not output any files when I invoke it
from within another plugin, could there be some stupid permissions error?
Johan
Re: Jet2 using Jet2Platform [message #59843 is a reply to message #59820] Thu, 23 April 2009 07:48 Go to previous messageGo to next message
> Johan
Sounds like its time for some serious debugging. What version of Eclipse
are you using, and what OS are you running on?
Also, the JET new project wizard uses pretty much the same technique. Does
that work for you?
Paul
Re: Jet2 using Jet2Platform [message #59865 is a reply to message #59843] Thu, 23 April 2009 07:52 Go to previous message
>> it from within another plugin, could there be some stupid permissions
>> error?
>> Johan
> Does that work for you?
> Paul
Yes, running the same file as a JET transform works, I am running OS X
10.5.6 and I have debugged already and the transforms are writing into
JetWriter.
My eclipse build is 3.4 ganymede modeling edition.
Time for a fresh build of that me thinks.
Previous Topic:Generating code from an ecore-model
Next Topic:[MTL] ecore metamodel of MTL
Current Time: Sun Aug 31 21:06:10 EDT 2025
Powered by FUDForum. Page generated in 0.04181 seconds
