Home » Archived » XML Schema Definition (XSD) » getValue getEffectiveValue
getValue getEffectiveValue [message #59526] Mon, 25 April 2005 06:23 Go to next message
Originally posted by: aaudevart.genigraph.fr
I would like to extract the integer value of this restriction :
<xs:element name="NombreExemplaires">
<xs:simpleType>
<xs:restriction base="xs:integer">
<xs:minInclusive value="1"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
I don't know what methods used.
If I used getValue(), that returns a BigInteger and I don't know how to
cast it in integer.
XSDMinInclusiveFacet aMininclusive =
aSimpleType.getMinInclusiveFacet();
BigInteger value = (BigInteger) aMininclusive.getValue();
int minValue = value.intValue(); // that don't work!
If I used getEffectiveValue(), that returns a Elist.
May be they are another way to do that?
Thanks for your help !
Re: getValue getEffectiveValue [message #59550 is a reply to message #59526] Mon, 25 April 2005 07:18 Go to previous messageGo to next message
--------------010400060608080305030404
Alexia,
If intValue doesn't return the right value, which I find hard to
believe, then you have a problem with your JDK. Perhaps you are just
assuming that the value will always be a BigInteger when it's only
BigInteger in this particular case because the type is xsd:integer; if
the type were xsd:float, you'd get a Float value...
I'm not sure about your comment about getEffectiveValue returning a
list; for an XSDMinInclusiveFacetImpl, that method is implemented like this:
public Object getEffectiveValue()
return getValue();
It should always return the same value as getValue...
alexia wrote:
> Hello,
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> to cast it in integer.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Alexia,<br>
<br>
Re: getValue getEffectiveValue [message #59574 is a reply to message #59550] Mon, 25 April 2005 07:58 Go to previous message
I find a solution. In effect, getValue() and getEffectiveValue() return
the same value which is here a BigDecimal Type. I've just cast the Object
in the BigDecimal type and apply the function intValue which convert a
BigDecimal in int.
int minValue = ((BigDecimal) aMininclusive.getValue()).intValue();
Re: getValue getEffectiveValue [message #594909 is a reply to message #59526] Mon, 25 April 2005 07:18 Go to previous message
Alexia,
return getValue();
alexia wrote:
> Hello,
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
<html>
<head>
<title></title>
</head>
Alexia,<br>
<br>
Re: getValue getEffectiveValue [message #594921 is a reply to message #59550] Mon, 25 April 2005 07:58 Go to previous message
BigDecimal in int.
Previous Topic:getValue getEffectiveValue
Next Topic:getContent
Current Time: Sun Aug 31 17:52:22 EDT 2025
Powered by FUDForum. Page generated in 0.04129 seconds
