Home » Eclipse Projects » Plugin Development Environment (PDE) » 3.5M7 - Problem setting transform start levels
3.5M7 - Problem setting transform start levels [message #59523] |
Mon, 04 May 2009 14:29  |
We build our _feature-based_ RCP product based on SDK headlessly as in
http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html.
We have transform plugins o.ee.eq.transforms.xslt.plugin and
o.e.eq.transforms.xslt and set the start level to @1:start explicitly in
config.ini,osgi.bundles after the build.
I really want to avoid editing config.ini, so looked forward to 3.5M7 and
support for setting start level in the Product file. I was encouraged to
see that in the Product editor, Configuration tab, I can now select the
transform plugins, an advance over 3.5M6. However, I can't actually edit
start level or autostart. The GUI just does not accept editing attempts.
Furthermore, if I enter the start level data directly into the Product
file, the Product fails to start with error: "IllegalStateException:
Unable to acquire application service. Ensure that the
org.eclipse.core.runtime bundle is resolved and started (see config.ini)".
What I see in config.ini for a successful 3.5M6 build (including my edits):
osgi.bundles=org.eclipse.equinox.transforms.xslt@1:start,org.eclipse.equinox.transforms.xslt.plugin@1:start,reference\:file\:org.eclipse.equinox.ds_1.1.0.v20090429-1630.jar@1\:start,reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090429-212 6.jar @1\:start
In 3.5M7, with start level added to Product file and no longer making my
edits:
osgi.bundles=reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090429-212 6.jar @1\:start
So, no transforms and o.e.eq.ds is gone!
What if anything, can I do to have PDE Build set transform start levels
correctly?
Re: 3.5M7 - Problem setting transform start levels [message #59573 is a reply to message #59549] |
Mon, 04 May 2009 16:04   |
Thanks, Chris.
I can work around the editing problem in the Configuration tab if I Add...
and immediately edit each plugin. If I have multiple plugins in the list,
I can not edit them.
Bundles.info looks like it has the correct start level and auto-start for
each plugin, but I still get fatal startup errors, even when I put
o.e.eq.ds and o.e.eq.util in Product, Configuration. Error log, Product,
and config.ini files follow.
The "missing constraint" problem started in 3.5M5 but did not seem to
interfere with actually running. No luck so far avoiding it. The
IllegalStateException, however, is fatal. Any diagnostics would be welcome!
MSacarny
Error log:
!ENTRY org.eclipse.equinox.ds 4 0 2009-05-04 15:44:47.788
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.util.event; version="1.0.0"
org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:309)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:220)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:330)
!ENTRY org.eclipse.osgi 4 0 2009-05-04 15:44:49.710
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
And here is the (name-changed) Product file:
<?pde version="3.5"?>
<product name="MyProduct++" id="com.analog.myproduct.product"
application="org.eclipse.ui.ide.workbench" version="1.0.0.vqualifier"
useFeatures="true" includeLaunchers="true">
<aboutInfo>
<image path="/com.analog.myproduct/icons/idde48_32.gif"/>
<text>
Analog Devices MyProduct++
</text>
</aboutInfo>
<configIni use="default">
</configIni>
<launcherArgs>
<vmArgsMac>-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
</launcherArgs>
<windowImages i16="/com.analog.myproduct/icons/idde16_8.gif"
i32="/com.analog.myproduct/icons/idde32_8.gif"
i48="/com.analog.myproduct/icons/idde48_8.gif"/>
<splash
startupProgressRect="10,328,580,15"
startupMessageRect="10,348,580,20"
startupForegroundColor="FFFFFF" />
<launcher name="myproduct">
<solaris/>
<win useIco="true">
<ico path="/com.analog.myproduct/icons/idde_eclipse.ico"/>
<bmp/>
</win>
</launcher>
<vm>
</vm>
<plugins>
</plugins>
<features>
<feature id="com.analog.myproduct"/>
<feature id="org.eclipse.rcp"/>
<feature id="org.eclipse.equinox.p2.user.ui"/>
<feature id="org.eclipse.platform"/>
<feature id="org.eclipse.cdt.platform"/>
<feature id="org.eclipse.cvs"/>
<feature id="org.eclipse.help"/>
<feature id="org.eclipse.equinox.executable"/>
</features>
<configurations>
<plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="1"
<plugin id="org.eclipse.equinox.transforms.xslt" autoStart="true"
startLevel="1" />
<plugin id="org.eclipse.equinox.transforms.xslt.plugin"
autoStart="true" startLevel="1" />
<plugin id="org.eclipse.equinox.util" autoStart="true"
startLevel="1" />
</configurations>
</product>
config.ini file:
org.eclipse.update.reconcile=false
eclipse.p2.profile=myproductProfile
osgi.framework=file\:plugins/org.eclipse.osgi_3.5.0.v2009042 9-1630.jar
osgi.bundles=reference\:file\:org.eclipse.equinox.ds_1.1.0.v20090429-1630.jar@1\:start,reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090429-212 6.jar @1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.e clipse.equinox.simpleconfigurator/bundles.info
eclipse.product=com.analog.myproduct.product
osgi.splashPath=platform\:/base/plugins/com.analog.myproduct
osgi.framework.extensions=reference\:file\:org.eclipse.equin ox.transforms.hook_1.0.100.v200905041540.jar
osgi.bundles.defaultStartLevel=4
eclipse.p2.data.area=@config.dir/../p2/
eclipse.application=org.eclipse.ui.ide.workbench
osgi.instance.area.default=@user.home/myproduct
osgi.configuration.cascaded=false
Re: 3.5M7 - Problem setting transform start levels [message #59598 is a reply to message #59573] |
Mon, 04 May 2009 17:43   |
msacarny wrote:
> Thanks, Chris.
> Add... and immediately edit each plugin. If I have multiple plugins in
> the list, I can not edit them.
> for each plugin, but I still get fatal startup errors, even when I put
You're missing the start levels for important bundles ;)
For example, core.runtime and equinox.common should be listed. One way
to know what bundles should be included is creating a new product
definition, and in the wizard, there's an option to use an existing
launch configuration. Choose the launch configuration that you have been
using to self-host, that should properly populate your list of start
levels. You can reuse that list where you see fit. From the top of my
head, you're missing core.runtime and equinox.common
Another issue you have is that I see 'vqualifier' in the product
definition where you should mean 'qualifier'
Does that help a bit?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: 3.5M7 - Problem setting transform start levels [message #60139 is a reply to message #59834] |
Thu, 07 May 2009 08:38  |
Andrew,
I just tried adding Properties to the <configurations> sections and sadly
they do not survive a change to the Configurations, Plugins list.
However, this seems to work for me when in the Launching, VM Arguments
list:
-Dosgi.instance.area.default=@user.home/myproduct${#32}myrel ease
-Dosgi.configuration.cascaded=false
The ${#32} was the only way I could find that preserved the space in the
default path in launcher.ini\config.ini without resulting in path-breaking
carriage returns, extra double quotes, or duplicated entries.
MSacarny
Re: 3.5M7 - Problem setting transform start levels [message #596771 is a reply to message #59549] |
Thanks, Chris.
MSacarny
Error log:
!MESSAGE
!STACK 0
!STACK 1
(see config.ini).
<aboutInfo>
<text>
</text>
</aboutInfo>
</configIni>
<launcherArgs>
</launcherArgs>
<splash
<solaris/>
<win useIco="true">
<bmp/>
</win>
</launcher>
<vm>
</vm>
<plugins>
</plugins>
<features>
</features>
<configurations>
startLevel="1" />
startLevel="1" />
</configurations>
</product>
config.ini file:
Re: 3.5M7 - Problem setting transform start levels [message #596782 is a reply to message #59573] |
msacarny wrote:
> Thanks, Chris.
Re: 3.5M7 - Problem setting transform start levels [message #596820 is a reply to message #59598] |
Tue, 05 May 2009 13:52  |
Chris,
Making progress. When I create a Product file from a Launch Config, I get
this in Product.xml:
<configurations>
<plugin id="org.eclipse.core.runtime" autoStart="true"
startLevel="0" />
<plugin id="org.eclipse.equinox.common" autoStart="true"
startLevel="2" />
<plugin id="org.eclipse.equinox.simpleconfigurator" autoStart="true"
startLevel="1" />
startLevel="1" />
<plugin id="org.eclipse.osgi" autoStart="true" startLevel="-1" />
<plugin id="org.eclipse.update.configurator" autoStart="true"
startLevel="3" />
</configurations>
At runtime, though, there is a failure because start level is not a
positive number:
!ENTRY org.eclipse.osgi 4 0 2009-05-05 13:42:19.921
!MESSAGE Startup error
!STACK 1
java.lang.IllegalArgumentException: The requested start level of 0 is
invalid. The value must be a positive integer.
If I set o.e.core.runtime to 4, then the Product starts right up!
1) Is there a 'correct' way to set o.e.core.runtime to start level =
default, autostart=true in the Product file?
2) Is there a 'correct' way to set 'osgi.configuration.cascaded=false' and
'osgi.instance.area.default=<folder>' in Product or other source level
files? I want to avoid having to edit the config.ini post-build.
Thanks greatly!
MSacarny
Re: 3.5M7 - Problem setting transform start levels [message #596840 is a reply to message #59693] |
Tue, 05 May 2009 17:14  |
msacarny wrote:
> Chris,
> get this in Product.xml:
> <configurations>
> startLevel="0" />
> startLevel="2" />
> <plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="1" />
> startLevel="1" />
> startLevel="3" />
> </configurations>
> positive number:
> !STACK 1
> If I set o.e.core.runtime to 4, then the Product starts right up! 1) Is
> there a 'correct' way to set o.e.core.runtime to start level = default,
> and 'osgi.instance.area.default=<folder>' in Product or other source
> level files? I want to avoid having to edit the config.ini post-build.
core.runtime should have a startlevel of 4
you shouldn't list org.eclipse.osgi at all
I would also remove update.configurator from that list
That should work.
Re: 3.5M7 - Problem setting transform start levels [message #596862 is a reply to message #59717] |
Wed, 06 May 2009 14:25  |
Chris,
I think that did it. I'm up and running now. Thanks for your help!
Should I enter bugs on problems with the Configuration dialog?
a) Unable to edit entries except right after Add...
b) "Default" start level caused startup errors (non-zero value expected).
MSacarny
Re: 3.5M7 - Problem setting transform start levels [message #596879 is a reply to message #59788] |
Wed, 06 May 2009 18:36  |
There is https://bugs.eclipse.org/bugs/show_bug.cgi?id=274889
There is https://bugs.eclipse.org/bugs/show_bug.cgi?id=274901
This is fixed for RC1.
PDE/Build (and the publisher) support properties in the .product file,
there is no UI for setting them (and I'm not even sure if the UI will
preserve them if you edit the file after adding them manually).
The syntax is <property> elements inside <configurations>
<configurations>
startLevel="4" />
<property name="org.eclipse.update.reconcile" value="false" />
<property name="osgi.configuration.cascaded" value="false" />
<property name="osgi.instance.area.default"
value="@user.home/workspace"/>
</configurations>
-Andrew
Re: 3.5M7 - Problem setting transform start levels [message #597003 is a reply to message #59834] |
Andrew,
list:
MSacarny
Current Time: Sat Jun 07 11:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
