Home » Newcomers » Newcomers » Why can't eclipse create a regular project
Why can't eclipse create a regular project [message #59489] Fri, 29 April 2005 06:25 Go to next message
Originally posted by: robert.haycock.mediasurface.com
Why is Eclipse such a pain in the ass?
Why can't I just create a project and point it at my src folder? Is it
really necessary to create a 'src' folder then stop me from creating my
own without having to delete the dir, create the project, delete again,
refresh, edit properties, create src folder pointing to right place. Why
can't it just do the same as every other IDE on the planet?
Why can't you just point at the file system like a sensible, logical app
would?
Create shortcuts by all means, but to have this nonsense as default
behaviour.
I'd still be with JDeveloper if its debugger wasn't complete rubbish.
Oh well, I've got my project working now and thats all that matters.
Rant over.
Re: Why can't eclipse create a regular project [message #59514 is a reply to message #59489] Fri, 29 April 2005 06:39 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
In fact, you can. You should read 'Java Development User Guide' > 'Getting
Started' > 'Project configuration tutorial'. There are a couple of detailed
examples for using existing project and source code layouts. Maybe that
helps.
HTH,
Csaba
> would?
> behaviour.
> Rant over.
Re: Why can't eclipse create a regular project [message #59733 is a reply to message #59489] Fri, 29 April 2005 14:27 Go to previous messageGo to next message
Originally posted by: tim.julian.hsc.utah.edu
I too am a newbie to Eclipse, but I love it. In my opinion it has
everything that all the other IDEs have and much more.
Just create a new project, right-click on the new project name, import,
and browse to where all your old java infrastructure resides, and you are
done!
I hope that helps.
Re: Why can't eclipse create a regular project [message #59884 is a reply to message #59733] Fri, 29 April 2005 16:59 Go to previous message
> done!
> I hope that helps.
An even easier solution is to uncheck Use Default Location when creating a
new project, select Browse, navigate to where the existing project resides
in the files system and select it.
Previous Topic:message.properties out of sync
Next Topic:How do I update ANT in eclipse?
Current Time: Wed Jul 16 03:13:22 EDT 2025
Powered by FUDForum. Page generated in 0.31743 seconds
