Home » Eclipse Projects » Equinox » turn classloading on the server-side upside down
turn classloading on the server-side upside down [message #59449] Thu, 02 February 2006 09:49 Go to next message
hi all,
I use Simon Kaegis Bridge-Solution inside Tomcat.
Now I think about how it would be possible to change the order of the classloading steps: Instead of first delegating to the Webapplication-Classloader the OSGi-Classloading has to start.
The OSGi Framework Classloader (created by the WebApp-CL) will have to delegate to Boot (not first to System) and it must be able to delegate to the Webapplication-CL. Now my question: How can I seperate between these two delegations? The Framework-CL must have a kind of decision-flag. It must seperate once more between java.*/bootDelegationPackages and classes to delegate to the webApp-CL.
I've already looked at:
1.) Buddy Loading
2.) ContextFinder
3.) EquinoxAdapter with Hooks
I think a good solution would be not to modify Equinox or the Servlet Container.
Could you please have a look on my attachment file?
By the way: Why is org.osgi.framework.bootdelegation always set to *?
Thomas Watson said (https://bugs.eclipse.org/bugs/show_bug.cgi?id=29007): "This is to work around a number of bugs in today's VMs that make assumptions on all classloaders in the system to have access to packages on the boot classpath."
What are these bugs about? Do I have to let it set to its default value?
"We also are doing this to work through issues with backwards compatibility where some bundles expect access
to packages on the boot classpath without the need of Import-Package or Require-Bundle."
OK.
thank you for your help
-martin
Re: turn classloading on the server-side upside down [message #59485 is a reply to message #59449] Thu, 02 February 2006 10:06 Go to previous messageGo to next message
------=_Part_1001_23428795.1138892848816
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
attachment!
Content-Type: application/pdf; name=classloading.pdf
Content-Disposition: attachment; filename=classloading.pdf
JVBERi0xLjQNCiXDpMO8w7bDnw0KMiAwIG9iag0KPDwgL0xlbmd0aCAzIDAg Ug0KICAgL0ZpbHRl
ciAvRmxhdGVEZWNvZGUNCj4+DQpzdHJlYW0NCnic3b3NriQ50iW2L6De4a5n ceX8cf4AAwFV3V0C
tBt9DegBrjQShEoB+jbz+goeO2Y0Oj0iI7NampGQqIKfG/TjdDOjkW40ksfH f/n1l//r43j8O/v5
0XL8+Pf/9eN//g8f/+evv4SP8e/f/7dff4nt+IwfLeaPb7/+knLG5Z8fuDri Z31cs8iKUOp///WX
//wffv3lwEP+p/9BHvdfHv/9jw/2/+PBF+Jn4J3f7Fk3RPcP9rf/+esvj6f9 26+//Cd9qQP1//2f
j8ccx2d7lOuf58c//5eP/+6Px8uFj3/+54//eIT//uOfj4rUz/Qo//jtPx7x iPK3B3nUPyb50z/+
CX6pWU1dZTIupWo1VFf5C0Kp92Qid5pM7ojuH+xvfyWT2NNDJjXmXSZ5k8kp fzk/s/6lqEjaZ9G/
VflLmWJrN2IrrX+aMQmQNyilPWqu73hBUg7v84b05GaT3i3Xx5PnrxzQ1xMJ Pu5tH6Xmz36VYFcJ
drMqlU24yKZv0ureFn9bJZiGWksujwcPCR7hoT2Bj3cQFM+HRh7vKkVXJCW/ L8VY+uM2ufmbPfaO
6+NFHVaeV5LMQwslxcf/vyvJ3zcroyWmKdvfN2n/Tf4SpwX/ffvLbxvz74v0 U4xD4Sb9VvybC+Kr
suiK3pV+OrOX/guujxd1WHleSD+l8pDurfR3T/CPTbK7Pv5QfdTNM+hd4Vjt +gyjCkd+PGi8cTiH
hQEOjzbQ2ZK0YRRdEUu+YddtOD25+Zs+9pbr40UdVp5Xdv1QQH4U65uHCOx3 wjENexdSvIo2pKto
w6aicG48+1/KtcmEuv1ldd7p0V+UqaJ81tFkKR5BKg8puqK3VZQf5npOFb3g +nhRh5XnlfH3IZUf
VlHcVBT+oopUJdP77yq59AZ0BdZqpPWrxQKZ4FB0RW+rRPzIVMlzro8XdVh5 XqnkPO4Vshvt078s
fuXMlZ5UWjGgtenQUVcWXZGUfNuv4ObpV+64Pl7UYeV55Vfq8ShwpnHvRUZ9 G5Xt1vebljH//PdF
arsbGwZ/xrQNFYM5f6Panf/eQexDn933/U2r3Z4PobZnhfVFQgsfuaOzjjk/ mAZ4KESuq3SaKOSv
Uea7Gn+METvv+8YnbSTPH+pvfzVKDz08Xje34fYuov/H1jfbGOdUcfwRD/uW MfVvDuqdodD3+wf4
AUpbGr68OK/54iy2orckLt7DJP6c6OnDV46XIyJo5welnk3qV0NVLZSfVMLz Tvr6fQBXo0qAb6Ec
5FqtT4qt6D2zh4MyJTwnevrwleOlk+vPTP/HO4JJze/jMr4EIaTyEHh91Fw+ noePq2cUo3p0/XWi
Y3yEsOTKcyM3/swQgYAz4Vvz326qo1/7rM7RwcrqhINjUFRHkVRHSq48T6sz P71ZegxtUKFrvKe2
8R2n0Q0Ahhn4wiy2Iin37ke66eAF18eT59/I/1noJ4P72lHGLfAT4xbkSC9t yMJWVFrPXmn99EpT
JEqTkivPcxsyVQh8UPWrFYWaYAxRRmihjkiXwEd/BFS6DCqk6IpY0hQXWlzo WvN0QEaAoiva6HpY
6Hr1dEBGgKIrutLF4/B08SiOTpASSNEV7XR9oQunpwOaBH2h63d0oS10MaNB kw7ICFB0RRtdHCOg
SZeSpwMyAhRd0UaXykKXo6cDMgIUXdFGl8+F7uEcHR2QEaDoija6My90j8bt 6ICMAEVXtNGVtNL1
ha57OhRd0UZX40JXm6cDMgIUXdFG92jXnq4NV2R0QEaAoiva6DocjdH14umA jABFV7TTdU+XjtPR
CZoEfaHrN3TpaAtdyJ4OSAmk6Io2OvRzk+7xaeLogIwARVe00cWy0KXo6YCM AEVXtNHhw2zS5eDp
gIwARVe00T2+HDzdif5R6YCMAEVXtNGdaaXrC133dCi6oo2uxMcAbdKV5umA jABFV7TR1bDQ1erp
gIwARVe00T0GE56uFU8HZAQouqKdri90j77Y0QFNgr7Q9Tu63jxdlrEK6QQZ AYqu6EqXj7rQhTEc
NjogJZCiK9roHsMaTxejpwMyAhRd0UYXZ8c66FLwdEBGEH2v6290dCkvdPnw dEBGgKIr2uhyWun6
Qtc9HYquaKM740J3Nk8HZAQouqKNroSFrlRPB2QEKLqiK911kJyTDPAGjw6T swyTkw6T7Vs2a/BG
h8nxfBk9ygHdQ0tX6qJhKA1XaITHxXwYYwjB/hTrtUYaYHK3PRu4x47xl80O Skd4ar+KipbIz5Ax
VC8l45stNrTtcvIT1vHcDNw57aUTRYP44fJLwjB//fyLmEPUCqXU9SEfY1om WwWS2DArlxJM8GTY
0LPcfUfIPJDNW6XzSWXGJKjNOiUE10OTD+OEUXoMVrUxsTSrNpDGWIzlTjL4 9p8h6wQ3hA77WpnL
JNiJsXKo7KZGUGRULrBjig5hnCglbybBbmVjFRL4oGpbhQpMwCpU0dVGxp9q BKJEKsZrKi1BIsmV
56ZC9H1WoRpAfCOh62RWe4CaZYoW5npWTti2Ma43hM9BlryZyrpTmEXQCWu5 qU4dWpgx8DJs5AxR
2k8piHOf+JCPRaLenJWHLZ7xkOCB57mrkEROGdUtBfHyzZSvAfkhm3BIlEpk EwIRZKNIZCMlb8Lx
d7LRqrBsxBv+2+51rDLpQEl5X8yYN5NFwieqyunxm0pwZXlqyBr6Q8LLjVzk e/8sSSIvEhoQqIGC
E99ZGhq4oiSRiyVQMOkQGjA6IhKw6IoudPjen3QIDRgdEQlYdEUrnXzvG52E BpROkRBo0RVd6fpC
ByUZHZES9IWu39Hhe3/SwXcYHREJWHRFFzp87086hAaMjogELLqiCx2+9ycd QgNGR0QCFl3RhQ7f
+5MOoQGjIyIBi67oQofv/UmHwkZHRAIWXdGFDt/7jq4vdN3TseiKLnT43p90 CA0YHREJWHRFFzp8
7086hAaMjogELLqiCx0GPZMOoQGjIyIBi67oStc9nYQGlE6REvSFrt/Qyff+ pENowOiIhECLruhC
h+/9SYd+1OiISMCiK7rQ4Xt/0iE0YHREJGDRFV3o8L0/6RAaMDoiErDoii50 +N6fdAgNGB3Roflu
ns7deA0UOLq+0HVPx6IrutDhe3/SITRgdEQkYNEVXejwvT/pEBowOqLDhmNl Qxc6fO9POoQGjI6I
BCy6oitdX+gQGjA6IiXoC12/o8P3vtFJaEDpFJGARVe00sn3/qRDaMDoiIRA i67oQofv/UmH0IDR
EZGARVd0oYuzY7VAgdERkSD6XtffeA0UTDqEBoyOiAQsuqILHb73HV1f6Lqn Y9EVXejwvT/pEBow
OiISsOiKLnT43p90CA0YHREJWHRFK93+LY9sqXy6TJC8zKe5sEDTz3LLzvhj S+b8+7MJ7T3vY/5F
Z+r2z/uMxpP47TQhUqeJTs51KDqJTqCOoTbyUc9UOFfRkW1TjObR2hKvxxUH KuObcaBG9HCBqYk4
BzwBT/4YgVj0cd1ZK/Q6qbMcRryp82skw6nBYsePBVlFB+uIlpQP+cTLhSUb h1CjpGQu5hMFAwdy
8EQ58BUwOMqBJDD/zC+jBwpAlBBcfBYSdKN5TiJ1IB0pngsKigZJEBL+eEXJ oWMhPSbpoDnIKnNi
fdYsQXNS6YHm66RGMRQiE4OkO/cpI4Q+ID5cO8EmVUEhKqoQGUA7baWiinxc n17J6YSt0QDSOU1j
kDirSdCOmBRQmeaW8LmgpogGQBNN0JsY7yB0dp3wSSdG79BJ1GZjIcpKojAt P3qUjFTQ6R6hSbSE
XO2BmkWSSKVVb/I6wcSQgSJfCHI4TA4NSORw4toJNk4VZKCTYkYEok9dxWYq jkDnVPEDpan+2KZh
4FOKFnQCasJ8B8rT2GKlHmGIsaqBMqBE042mN1h1LGyasPhY6CbQHGJhI0ZT MRRIk12Lcz96FEmq
6FxQ9zSJrCfbv69bJk2dTkRfShxMrOqJnBzEL6mMxGWp/MSdRXWtVIKQUAf0 gtVrS9ynalJcq+p4
OF1Tv/hjtQ36anWz4siPxcmrY+3OENkvBOtQ0rRg9ifR+pNz2j07Im0UBs/l x+5Qvo8AXVO1nHa5
hkMtgc0yjrCEb75fhsZL8w64We+cv0TswX6SWuEWV8MvRfIYuUMe72r2tSQ/ ShrSeJmZkIRcsI9/
/vvHw7GWcoSxai3CMQ3xclYhal5PCmldWhDOodbcqohhwAqIVE0i8akDFaBC lB8I/V3A507maqGA
YHRunSQNqW5iMAMloBOoIlp5fJKmIjUx8HljPDaQPK8ggCcm80CP68hyJ+6K Yq7hzOCMLJjxvMSn
J5Ak1lNipRLrHygCsS6ju8s988YDN4pthQyh9SwvkTuuQYK2MhDaX8gVT5di kncpfUZAg8741Bko
Q0aKJHB6Slf5gAoeP8Un10iENXR8unsSNCXkDzp0mPYsTDFYrdARsr7o+fgq QEFfc5BkvqcUTaCk
dNB0TXIpUMidKKrIB82BG6mPKGKlriJsSvUY22dRJQ+k6h/Ju2o1UrBOm4lq M5EoqLE90ImHMaw+
YJ5WGvG2asEx054zURXDx/WpTWKQZLQJtheiaiSJDe0OoaQnKXwFeUIxyvHs c6nXSRKps3+dlkmC
d23Uj8ihUSMio5Yo2IprL9hmGsD1ObXR2ABFU00VIB4lUCai4iZjaOq/BW8b jRoRu2kyXqRNtUP6
VBpcO2hi8q7Ullhq7aSBDVfqTuy7djU4GH/tfAZaRu1sx2g1htCiKpU+2lrl IksHPtA45/V4cyPI
rMc527s+WHyB1UrchFZZfIi+Tu7zRcXvqBDEJ5mExGGp+MSbqWjF06nYxQuq SsRDmr7Efaoyxbeq
os8yTUD8sRqH+GqzHHHkalTi5dXgpAdQY5TeQQ2VPcfpOxWaN/ub03qmMpsF +6liPVO11uT6t+8P
CqZmR1+IAYlAba9pablfivr4bGJ5eN3pm79EM+rPWR+5wdXty9AoE2hH2Rne zw0FQhQFDp+yDgUe
H0DMVQhDaxI7KKHG7Y9aTrPoywh0t5A4cjKIQV8Z9teCJPtOVIjOB5JRJSIr D8CZgmHTAylJfKDC
CdAD1xjxnaNVDCTf2VB1Cxwknx38HBZj+n+gLuhxzY9D2NxAUpOz4TYOhM+G Z3MgDNMdKBMVoEKU
gFiXUakWOTBG8xgoEUUgeYmTJSvRCSRD9nO4tgGl2sOJtBhIOqxtogQafoef CTSB39dnAk3g8yNp
7lFyKJCUNIGsOhMV3POxbYBD2dX7cK+Ega69L8b+JovcKIv0oR8XJsOsquga 4OlT+ll1kYnS1Fqu
U5+5LMqG5zVLwKeT2Ugu03owsWaWBe89zQ4RPrPJfOLZtFZ8t5klZ2hTrTzT /PGp17Vh6PIrazVE
yX0VSnN7ijxJtA/NDhTtyWGpk0a1pL7BvcmhtZLXVN1ABkenrCCfQ0Nx8ouT 6aExGhH4oR+d0Mah
4h/XKnxo8Kheu0fVL2qo/qjeLo7CG2Ezh35fw54O/TCHrR2F1iyGeBS12Mf1 qfY6rPeg1sSyj5MN
FFZ/6KJ9aRIHI0HSXgyhLR1Ut7SzO2QN1H5MC2laSDNJy/QIUjdzF1bxkzR9 +hl73UKpqUcqKidz
XipE8Wwq4FN14TziwUiEeMujqmxEF+pzm1f28MBqBuKbD3W58Nu6VodOXU1L PL6aHfoCGiR7icM6
l6R2zL5FA5bsd8LSQ8Wlh4pGUqU9ffhubob8n8cTnHq/SdAkE7JhHn1pvV+G KkIDKA+/6/3ziCZg
bMWfWCnc4ir4pWg8RMrLo12tfjKWgOCMyPwaS7gZFlTEmr55WE3MVcNLhk4b FtSobl6WNaSp5ARU
TeU1BRsYjOtsZjJQmzZUU3QDg4Gm8dUUbWBQU3IDgyrRJbXmmpIbGNSUXTOo GtZFE6kpu+YzkBsY
VA0Wo+ENNAcGNakXOFmyWGMeyA0Mqsaj4QZqUpcwnlfcsKCm4oYFROp1qoa4 YR3PUXIoTFL1gfMZ
gaRzWKA1E12ak9XXYfCLrypWlqYc4MRNRrlRDtP5U7gf0jFQ8NJPlKmVrHrQ QYHpEt1QtTBioZ6j
9lhx2kcu03JkWU6KblBAk/uQzpLmKH1nmpaKTtasOIsmrV9V42enXWfkFet2 LCgrqFnouLG5PUNV
hysKT/cM7UvH04uvV9R5PdQ52qQfXkg3uZG3jaeXRMwmCd06ifKLWcO3EG2c WjiB5tBgIB0a1Bg/
59BgIK/kGE3JHchZR1SdwHJicEODgbIzOR3aij1GHRjUOZAdFhwPNzAYqEy7 j4cfGFQb5KPFxMM6
/7Sgeo+sidqPiaSKuntEJukcGLjanKSZA4P5UqdIYnogG+EXEYMfFpgAxa+p cE9Vg/OHqhTxlaYx
caSqTvGyqujhf9UExDOreYjXNtsRl65mJf5eTW70BGqM0keooUr/YVYsnYua OHuesvRRdemjqvVR
1bUo19e9MdXgFGxDA4HaNPPSgnVoUBERY3l4Yu+jbWjAn6ROcour35ehzKEB H+1q9VeGBkO229Dg
siFcxSKzOvT+bUK6NUMnUQHqROdHaTppXJF03+hGKxYBMqgVZfET10I/EK4l axkbODWdD69YotY4
4qtYEMswVkTmdmmSTv5AuJZyWJ/ZODsw4LiNH2wVOeuNpoktzwaqRINGfxn0 p9YEa40bh/k1SUHe
hqR9hrtG5uMoWXg9Hq1dcZWl67RoyYdv/PypWEzX+J1aDyHhCx2kkSZaD9JI U+ikuUfJI0dSsApL
nyCr2/TpBctvtWZFNKntsLoXQmY837UUCkxa+Ul5VaJzSk+WDZhoi+hAfhIN UB9FdEBdlTy1iER7
qhjoVPVLDmycllHStJmCxaxqT7KIr+nXhehKR6Ul0mJP/hin/RbRow50o5r9 4xqLvquNj7FeQtuL
oeCQDrrvUfI0/FTjM9TbRVy7elVVN+pc9YNaXqiW+a66jELkUE+Tg+4FSOlV VQDkWrPqDVKvUwcV
qKiuqioAWqxp6rdG028HYpgRdlFVH7CZqtejoH4VwtIqezqxwWofkBUgTcut 7C/FqmuY9m7Xg4D9
7WgkVaNh0n4qO2ZpW/dI2qRDp6OR1qxPkJYuzxYfwGvRHmsrrkPfRJyKvaR4 HJWAeCOVjngqkZs4
MZVoVeFzdYpKv06/KFoSj6n6E3eqmh2OVnUuLtgMQvyzWov4brUjcexqY8Pl 2yKeKmY6uwkzWelD
1J6lg1FbZ+dTrSuqs4VYH2Y02qW9MQJwev0mRpkJtR2OAL1vsF+KsPSId8Dp enf8JSJXz81ayS2u
hl+G8Bi5g4+fNfvJUUApbPf1OgpYt0DKsiweH43fPBxaGuihMSRl2fVnJgpA sPsHfAAJKY3U3g5U
iB7ywpav47qM689ElIEq0ePBknom2cIBUJ4GS88Hi6IVZHHRAyUgLRmAqtDI xpNSL7Qz5uMNFIFO
IHjaHPkA2R408XqU0x36sEip5MRXOKQgSeAZsmQuJNlhIMuwOWFt60DoLkaK 83iepjsPEvkgHig4
JNuWTpQUDRIHP8amgH1B54I86SmkQnLOio2fXJVlBaa+TqYcsMgLG/FSDLLh 4alCwo+B4kudCiCJ
quAkiqqQQUId4KdAFVeiqeKE7cVU/amLQg5R+IDF7GagrEYFFM3gHshMMWHn PjHSJDvkJmYPJFlg
S9vmAnlmMA50WpNITTaEre66TJLMRuZ/9Og0SkHZPeBUkvFsCWdpvbKRjEon I+lAp72obmdIGag+
IB/meFF2KU6xpqmAAJRVU8NJhKkpBlGow3R4BSfZ7ojK14giLSOqNmAzDD7S nqJuHJBYMkxDjE1p
ZKksl/wO+43ieWjZTKyj0cdGw0CDECQbasqNabYkQ5U096gqklYd3I+NpNrK u0N9qVsnTVEfE+yV
6GPkfT/ofygLOqeoDjVQaqfQQBdR/Wtk0T59ITVDL0mt0YWmQ11oMmXT86bg vTJthB47aReQzK7U
0UcllF4gfeqOEc1sVfsOsWPpVTLrKB1OVhlJb3S6num0nilZe/Ld2xvb9Tnt yj6uBNosR9/vm++X
IuRTozycrHfNX6IKdeOsEW7wtfsyhDwDuUMe7mr1c6OBRyOBUON1LNDXiIDk PqK5zaUIXec/FRWH
3EKErnNokjjaZ0g5PVAxkghEElzrhGF7oKqTgkhh7dxBXtJbu4YPB0XToDSu pRSyZbtGJ8cdukep
JNl2naVGAm7X3Fl8VhxziUIE0nBrB7K5VymqIVUpqlHisUuAxpax9cERLPQb gCwVuQJqKnICkrph
/H8EvlIkjSKh4SRuII3U5oqSQ8dCekxSXYpgz0f3aHVDB8mKI9fbXgkdJF93 JLc2Lwskj5ucZB+G
Q5ccVC9g2cf7OJQGedKqGUlkV62logrV5QiiasmLVyOQnPlOz450+u7S7NWi JAVfzE3z89UUJXdf
jVTy+rsGQpKzbVkM0Dk/oojXbTYWQ9GhRC166H7MHjn6aJSCXK10mYhUWHUm L0Oz5IseixBs9YdI
6BAxYj/jMkXapuixP/hUQ1PRF1xn1WQE5PKE8aRWTa8daBrE2VQVaLitqkFg GUJTzaDta5RLliFo
KCtJuWxmezb9upSFCE1zQbAQwaHxPF2iMEg4MSbLEJpNtSAB3P3oEZYhOHQu qMsDbBGCPTst9cqs
l7qMc76QLEKQV7VlCG3OEJUpI1mG0KpzZybcrGooOvHTp1bER6rGxIE2dbPV K3o43aZe20zjV10y
pnZDH344965utU8jZJegfrPTXJe+JFhfcqrRWxcUlw4p+etJUqyFvbkEAdqb SxAA2RwxKPfN1pYg
9CENuUNcr3fKtgRBf5Ja4RZXQ1uCII+RJQjyeFezn12C0Nj823UkkG/mBmba gEENz9Q5AVqrTxtA
mGamDSCuY5OqVaZ+50yBSxuodaYN1LKkDdTy6dIGavFpA4gg2bRwLTNtoMq0 sKYN1NOnDdTTpw0g
dGUT1AieWdpAlWl8TRuQvUd12huhMpsSR6zOpssRyLO0AcTiZtpAjT5tALFB Ts4jDmjT9ogk2pQ+
go1zvh+RSEsGKP2zvkDJI0eCmKg9QXbC06cjjsp6leqTBkqdSQNFcyeKzhS4 pIGiyROJyCUNFFWC
UKoSis4VuKSBolqQG/PUJKLRljRQ0pI0UJJPGihp2g1i32ZTsq2fJg2UuCQN FMm5mDMCLmmgRJ80
UOJMGihhSRpA2HCm2gSfNGAoPUU2xanwdM+wOQE3axp90oDUeU63yrT3nBNw SQMiCZvBjT5pYMjP
Jn5FtHFqwSUNiE50LnloS2eZRY82BS1K1vlpsQCduxbr0HltsRyd8y7nkjQg Jqez5aXMpIFS5/y6
WLDOvYtt6zS92L1N00uj0Bn94lIGpCU5VO+RNU/9UdquQy5lQNq81kW8gdVF XIVWW/yIvpL4mKi+
yKUMiGeKbhrBpQyIT1PRVlWC84WqEvGTpi9xoqpM8bCq5uF71QDEK6txiMc2 yxF3HufkgUsZGL1A
tKkDnzIgfYfZsHQsauDsdeb0gUsZYG/lpw9me3L93LsTBjNlAOF/ztuzYeal /ep0gc7/nzNlwPln
my7gT1InucXV78uQThboo2et/spkwW3KQL0ZFsxFBgabidbSpatkgmfT3lxk AN1Z+nWVJPHTSNwi
g1pnQjcMZWZ7V8kgr25QYGniMD9LIK9lppZXSSBvflBgSelVkq67awiWyo5G YmnuaEAzB75Kzv/h
BgWWPI9maYn1aLCWdI/GPDPy0dItWR9uwBL54SImOj7dIgO4lrk6AH7Hlg7A Op6j5JEjgQe0J8A9
2tPhOj1ySwxKdS9UdLlFpV92SwyKLreYAwOTYFFF9Jk2YLIvqolsHYrprOSp TXRCU9XoocwO0HuZ
hZQ0bQddntkVusNpdOgrzSLRj84FMfHTLTFABzwX0kRdYoAuey4xgHuYC3ME aZ+qKD9HnkRzHeQJ
NrJxOdZSp6B1+rQlBnwT6/7kNW1U8+mWGIh8NA98SE6XGIhMbYmBCFxzy0Ub mnU+9KT56KJBXWIg
2rUlBqJ6zXIXu9AMeLEZzY4vmlafp63ZEoOiefU6KLBsfLFezdQXy9YlBmL1 tsRAmoTm/5furz/d
AgNpY3fIGqf+KC1XaaRVGwqfboGBeANbYCCu4jjdoMBeSXyMvqz4H11gIL7J FhiI41IRildT8VbV
hPOGusBAPKUtMBA3qgoVH6uqHt5XjUD8si4wEJ9tCwzEoathibc/LONsmiN7 iMMNC2jF7FdszCN9
TrCOxS0wYF8VjcQWGLgu7s/3Dp30CwzQxTPLX5rlyP13bffLULUhga4imL7Z hgT8iZWqNiQwMkHj
IVKej561+itDgtsFBq93Tg5tVDgXO6I1XY+tdccH2elYcxPkw7ZqtnO2TjvT zjZdTtuxWmU71Mv2
XLa72va4pmd1wiGvuzndHc1pdfrbs8M63V/+fvxD70TfpQeAae1DtIro0ZKj Aa5HoLnTgWy3qv1Y
0evpi+6upO/T59PIfT1uzd21HfZ3/OPBpKcLzn2sbyr+j/nAfhHOs7Pajoqt weIbFuOE159Wf574
WZ/X848bqnf08JBEMYvMW7H4XIQvDGuakcrKnX52c+P2gsfvxx+q/VBM+Xr6 FtzF0zcy2zX73iW/
N7l2UavfsXe4+Ll/iUGsEififgxVlppz/5IqWxjIZh8V2wLoDg/Yg9R2f6i6 Y0kgCnP/ktrc7iV1
PNV2m6iysQZ3okCHYXtUVNnZhKvq0QHN/UuqbFrBhfXoyGxPjOp2L6lyhBh3 L6myf4XuXlLPuQNH
lc1FuOC+yop17txR89y7pMrmKNzwA705tgIZdHJ+HHcJqfHTNhQZyF2HzzI3 Hqmy2YfuY4Iks/nj
FeUFud1M0MXM/UswBLInFuwYoDUr3NuE12G+TqkUgmwLUEQflEJx8imFUghE ae5eUsoUeFHxy+4L
ReUf+GOYOixyziE3Tij5021eU3QDAdFbwcS9Wk1JeDlaFAa2tn9JEW3REEv6 tO1LBs2Y/DELxnDZ
rLuMOnL/kpJmgyiyRwQbCxGz7ibMy48LctdF6z/3aOBjTyWUOp1WpyT7Puir 6I4Q8pq6W4SIQLPw
KR/dZkJk15IXbJsqcHtXiEJ0RQC1pVteiCabqgBq1r0ySpm7aIhpNG39Yje6 /UapujPHB21Nd+0Q
Q9QdPcRINbeb9qsbgYhtyy4hH7R73UFEGoXuLiINpnZ1IWhNui2JtLQnCE3U oeJpontCJGUharNm
4iq01uJG7JVqnm8rvkclIX5JpVTPKT1xZrp5SVUVBPrHqQ/xjqor8ZyqR3Gr unWJuNxmTlZ0Es0f
l2k54sfVqmqbW5eI829ZHZruZKIdSlYbZn9yWn9S5tYl7IY4K6J9VDGSpm3J dW1vbF3i9PpNzPHU
PUTYKNPScL8UyV4kRXenSotr/kJfYm6cdZJbXP2+DKUPlpdHu1r95AYmRTb+ 2TcwSeF+BTK+becK
ZMvUx3ouS/AXpL+c41oDAVgiVuOnrhZPDzT3To9AJHlcu9XHVVcDI0xadT9I WcdW3Qq3qut9O65l
lwGsipOUdVkvV3XtLWYMqi6ykZV21S/Or3Uuzk9AQo+Ad9X9UApLcjkx1v1V XR04CnI+XtYKVk4L
yTrCytl5WWRYbesUhPdr4xMSaSqR0DSi4FAkDevioK6VNBRIquh0jwgkpWSw OrPqHgOiR634MV9J
1nrq68o60KoZX93JSNaPqgBlbakKV9adquBlTaoqRRasmsZyncqUVa5Vk8PO aQCyNlZNYyybrW7R
sVmTrLVVU5N1uFV38kjTOGX5rhquLO0VowaJGryuB65z5xFrJIb8bz4HjejX XyY8lx/DfEDpmkKC
6zRrVZqSoMpFtwrB6xTVEl60aJYehFDmdpgNh5hKpsnjsniRlin6QVGmGoqK Xq7nTjIVQwKm8w1C
XdoMpZfsDaKoKmAsRVebw5KKrhcUIyvJElEKUFHTLEnNdBht4SoZMWjddZrm XhKbKZpCccvziy6w
RQNyqCqytmY/olk6dC6o2wMy6x+03VetmLoIq7RoSl/opBzUB0UVg/igokJS d6UCFFemwj1VDboQ
uatSfv2FDrLoBguiB3WxzSt6OFwxAHHEahriokuZHruKQalrV1MbLl+NUDoD NVDpKNR4pRMxy5Yu
Rs1eOh9tEOyKDqOpsyG5Hu2dEKHT7VxoDMgmiV7et11baoxOm3fA2XqnPJca y0+sFm5xVbSlxvIY
uUMe72r2lxYbI2x+GQes+51z6tJGAYQ6gaVIo7E2CpCJXRsFyKyvjgJkSlid qUwX2+K1qg5YJpjV
Ncvks/ntWuYoQCat1dXXMjsBmeiuuuTYjQJkftz6FJk8rz6Cbp2RTLprRyUT 8tqJyWy99XAylV/n
ImPrFmX6X7tMSQ3QzlTyBmwUIEkFOgqQhAPtoiUZQbtvSVRQJNPJNgrwUNMf JnLXjd33nDqZYwBJ
ttAxgCRiaLVLnS8kqRv6spLWUecq4ykhSQdR8UmqiIpW0khspWz2YwDJPzF9 jdQUVaUkrXDVbPJj
AEl1UcMoSQ1GsmPMliR1Rg1N0mqqTrW5MYBk49jgNS5jgJHEo2MASe+pc2pw DpSDHwMQ6QxsWMYA
Bs/lxzAfYC4vOmcYlzGAVNncaPRjAHlRc7/RjwFEQhwDlDTHACLSMkVvYwBR g3YNQ0HaaYjubAwg
itUxgChduyIxCO2mxFi0Cyva93WXO6RjgFL8GKDU2WWK0Wp3KgZtYwAxdx0D SFMolmunXbc0Hofq
PbLcIf1RmqtDNgKQRq4PFg9gtRL3oFUW16GvI25FX1QcjgpBvJFJSFxVyd6N qWhr9iOAqkpwOZam
L3GcqkxxqarmWlT94oTVMGqZIwD13cU8txsB1DpNUDoCNU/pJNR0pQMxu5bu RY1eOh5tDtZjhQWd
C3pvBOCUO/OGpAuWBilds2u5ljnE7vycIwDnkGfmkPzEauEWV0XLHJLHyB18 /KzZX8oduhsBlGUE
kIJY4xie4ZCsMQddTy4wDPAAp3TsKWC8ogjzyiy58twdKSg/py4PATjF5v/t ZrZyzjLr0TBS+dif
T1bGy7TMPgkY52QLZ4FO+4vOyLjpl79f74q/bbNJ2116puw5Zxb3p+/zS0Vn SkN4XiEjOp9WMfx9
e3zdZiP3Sv+uPHbX71EnvMJ83D6xWTaqv1+n6m5eJF3lOCfOwtNqH78pU59T cGnjvmGa9+2zgNep
YyfKP65M8bjeFez59alKpj0+txqd757HGcXtPcKa9HfbZmofvnJtM+FQWSLL 4qlR1ms199e9Mdxd
ARuPmvZphvTKJOwvW8O+uSur2Mwgtoa9P/2tOrfNZHZT/+MNhdRR/jJ/nkLb FbIlM8zEApcXsc/h
36RmhHOWe87/VrLEPim9T0Gbpband91M4O8T139TJpeBcewut1+yJDai8Ntr vZzyEW6KmS3lnRZW
jq1XOuLxx1VXs/Gkpwb0c41nv2tnDlvDuOmX9qfvPd7ftub0u97nbOvm/Wdj NXeyqVLvetmb7w1x
cwPhH5sbeOHNn7u3f5U3D+0NO8KR7Bf7ayFd5Zi2WqawPW+vwX9j/Vto12fd lPn/bz8V/qYGan6t
WlbQfNm91YZTNenyjm7Gb9uwOMRNAvGIG9WNL3nHB8asSWH/1UYZZobnpodr Ytcro7th3pxS+MO9
2nMlhN13vfGVEY6t2tvId3rO9FREe2u+Ef5TbadXz9oFu4toF+zT8UZ85aX/ Zd9TW69ZNp79C2O7
Kz5905ftI4T9y9UyYc0F/EONuM06veOCXnwrvHBBN3amkmxTSrvtbeOYH3Ou u2zL8zd74VxfNOEX
HwG79t/5CJiplNobv2j1Ww+ZrM7PdahH3LrxWdxGWm+01vn09t2nv7LYgq2O Vos9tjrejM523/B0
dPry+UiMWZ+fUrIvoN2u7S83XetmM7sV3fS0WxvaMoV/rvu4GTH9vzj0uBl1 vxjB7d7ixcf3T8Ze
4vQ75lFm9Mu5Qr3Vuce96nsl3nH0WxcSv/PNODfPvBhpvhmyb6b01pD9R8eI 1mf6MeKLgXtfhf48
wPTe4ORFt/7f3Ah9DxyG09aAuOHq3narto23Bs2vRuTJBgA/5JgxB3BxzHuH tw0AbuR783Lfb/Y3
A6A92LC/vb1r32r4vLt9b6gz25v9rV6t4uZpuzxu3OCNs9qHP3uXV537ej4i 3kfoj5a7PfAmNh5v
Sv2r+uZ3TBDxsosJ/u7aRXxqPa8+kp5/KMSqsxgh/NgoAvvo/PMSU9HF8q6m 0x//WPf21nfgjdz3
74rdrPapnHf68r1R799dWwTtpuntnc9uT7sr2Cab/lVfKz87rnqrIf7kZ8b+ 2bmLaP8s33rQHxtI
vVDZO003lm3EcuMtX3xQvwhDv9Mgw02Ic5/7+H+2Oe5msoeU90WBb5j/XiXd xPvVGGZ+6D3/9LgL
qL/1tBd9vD2/Xf9yEzraZXbDrLbtxb8NO3W6xg3i9xHsb1uZ3RumN8wNe2eu Bpc2/3MzrNz7xRf+
8EUUzPzhC+ezi/aNQe2NidzMnWjT9l9Rdy7xKFN5r+Qpe91dGvDv+gb9JtD6 Yvi5O5k3sjLe+XDa
e5ibRAmtzybz55G3G8uJ+9zXQx5RG1DoTwWy9wPvhIAen8q7Sh+fLvsM3E04 /Fg/aWe+0MjqCR+x
SS4OErYiVjjyunAbdSm2IpT77n7N+eR93+xpNzQvHm0Efy7ZT6uNpih7MeUt 5eHGJPbmuw+LtnDf
JsSR5Fe4OGK8G/ZtFfiotaCo2w6i6Ioydwr9rgSxEbjc/M0ee8f18aIOKw/0 di/J2EYjjGmkZX1X
ku98ub/T/N+YSFQezVU7h2c16WdsNqRvTsRXZdEVvS197MRq0n/B9fGiDivP C+mnMnr5W+nffOm7
uMXcM+F556yGizWB8ShslFiNI3A0t4FC4542KLoilnxDdGF80sjN3/Sxt1wf L+qw8rw03OE2Qo/7
d59uinG86PhvAsP7AOZFqPh59/xOlOSSJpAj0kBVRRmb8qp4BKk8pOiK3lZR Ppvp5Js+9pbr40Ud
Vp4XKsrx/7MKujh/tnxTkDR2FQ6QSkOKruj9NgS3YQp6wfXxog4rzyv3g4Xd tyraZfT0L+pn4qAZ
KVZB2v+QuMDR/oEC93yUois6uSnD91dvjVQyufmbPfaO6+NFHVaeV34mj8WF ARvwXmT0l75vnu28
gy0zQ0xb7Pcx3PzD2o3LydKPajd9+C8O8qiCMbfdO/WLM8S6bs0oq21lOUSQ VTIOsNj3d/pOyLBn
Vv5TnhfPngyvxo8PM/nAQYcXEf9QNpkN5/d8vx/KnXq7m0jnSL5RBeTQVATj kgKQMgt4U/gJu96r
8J/zPHnuvPvlwL2MccBPiz7OuMM1OvBXZX0d7mPAorKWIQrfOnGBuxgcyi3g XXkHWUxHY3/K8/zZ
juGlzPEFeSfzF07+2lluO0qND7UUuJ9UwrrtdMiRSAlj4hQOXI+lS3o9XOks pQR3Th/fgfxORUHZ
8uTffBVwCGjC4UWPYjimQdCfHwSy0yDLLSBrzzgei5O7jAg7eGgJAt7bPVHf iXDkiREFHLqkRRTJ
3Sy5AG5BSq5w1IUsDKUYGZHcr0VXdKELYyHdpIvR0xGRgEVXdKHDLtCTLgVP R0QCFl3RhQ67zE+6
fHg6IhKw6IoudGJ1k64vdN3TseiKLnRnXOiwkN7oiEjAoiu60JWw0JXq6YhI wKIrutAhKDDp6nBz
RkdEAhZd0ZVuhP4mXTs9HZESSNEVXehaW+iwY5jREZGARVd0oevV00UcjaZ0 ikjAoita6cb42dNh
eZrREXG/UhZd0YUunAsddmQ2OiISsOiKLnTYkn3SpcPTEZGARVd0ocOZDI6u O7I+b2axFV2o8uhd
J1VukwrXej6MFFvRheoMC9U5vapc82YWW9GFCttJTKpSJlWZdq/FVnSl6gtV PSdVddJhsRVdqLCu
flK1PKmau5nFVnShQrLcpOqze5Fr3sxiK7pQ9eKpEs4mVDJFJGDRFa106Zi9 JkK/h6cjClw+6vtU
f6OjC3ml6wtd93TB96v+RkcX00KHsxuNjogELLqiCx3OUZx0OBLL6IhIwKIr utDhXKtJh0OgjI6I
BCy6ogvdeSx02FrG6IhIwKIrutL1hQ6LyY2OSAn6Qtfv6MrsPDEJkTwdEQmK 71n9jY6u1oWuRU9H
RILqe1Z/o6NDjGDSYQc3oyMiAYuu6EKH7TeNTs4KVTpFJGDRFa104zDOha4v dN3RadEVXejckFI+
KD0dEQmW8aa/0dG5ISWii24Y+qGIBMt409/o6NLsPAddKp6OiATJ96z+RkeX j4Uun56OiATZ96z+
Rk/XFzrs9GR0RErQF7p+R3e2hQ4bPxgdEQlYdEUXulIXOhw0b3REJGDRFV3o 3JBy0LXg6YhIsIw3
/Y2Ozg0pGe6eHbUiEizjTX+jo3NDStD1ha57umW86W+cdOfhvN15NEemSG6X gv5aSilPcI3hxGEW
xkPEe0O8XK880b3cGYvnif5DTQr665UnHY4nnZ4n+S80KeivLzzd8eTseYj0 3n65XnlszDh4TjfK
/FDEe92A8nQDTfJcwx1nlBYx9K7xjiz5T0ljTBa6swXUNu/+ejP98xh9Wmyn y47Iyyoft6ImbkFX
jdUG+5Mmbsw66Syfuy09i8HEES6b8+1x+ImxedsYuIwvT9lPaKDR1Yy9e8YI qWFW/pQwuOe4271D
ppFt2huuOhbbv8NVpsiRSlqZGjCtL2dnJOzowgpgixirWhnDSVR65birjMyq WmVKxSPuKlOrm8XF
ljEx8ETyipmtqKMKmbfNrKZM2/J0mclyu69JsRkyPmQQyd4+a2Uuk8oYRsTA 2c/2eIWgx9cXVFTR
4GK5mynlW9lYdQTKYTuX6sgJl1qdfFQkCsh+XPmQGe/8mT/0LHCV1Tj9m1Jc WW6qI1OEc8bsyKC9
kY6cuTrncx4tPBx6buqIVer2mBHTNURpxBq03CS4CyXKnIDNW7C0HIG01gRb Vs2aVJkg0h3aZJ6J
x9nUAKT7M42dUsi58jw1nDmPEvCU80YyMmGV9PTvPrx00LMascF6kDPcHygC UTp9jHtDlNo4llu7
GTZntcHhrSN+x2jrNqeL854Dtti8OMCw+dKmnmyup91ySv7+LBA/75qO1BKJ 4xOPGOOxiIyQpzkZ
KkRhiFOuIVjZ0xCfl0EP0wxjWB30OM7QIWeezxNghanyOo9rSQAZMALyx8e1 0DXQcas9tM+BKtFD
tknmu0YpPcUX58wMKE+teBJP4sHZHyFT8/AWA2WiE6gITWFRDTk9SHPgdR7X JDlxjYwjnMMyUCaK
QDKFioOxBpR6JZJUogAkD4vyMENJkUTdkvtxdAwenQsK7hEHSfl6B2mgUuwh ZRXHKUb2UkcnDV4X
xx9BECMgiNQGldHRKDEJL0INKlwcvWSCx7FMVIrEFdvUGIKFVCdQVDUfZaof rtdMA6dOwWgGHXYV
V2s64BgTj5A+zAThrc044XLNcDFoCnbc7ZHBzr3fDuTqSFM44PW0kRiKDqVJ YtD9eC4ouAfQWfHh
kdbNqsl4QKsdjKYBBXvVYxGCnu1JCR1TdLF7sUYT/rieatAjX0VFUQ9LF/3F 5pUbeSy3KD5WbxRR
ldFY0lsT+1Yamh6KKUYYVVsw0FjMXDtQcpYd1QfB7COPE5MmEctsLPF0U+bB DuiUVmY/XlF1CE3X
oSwPsBZvz4Y7sHpBj3oCaHCvI+4l6iaf4nlUDuKVVEbisvSoUHFnKtygaijq FfPUivhI1Vhoqkx1
q3E62VNNQJxxNDfbp9XQfx/OtatTFad/WLk6DZSdhflH6Ulo2ehkeIwrOx82 COu1woKExHVpb6RQ
OL1ifqSaDbBJ4gBk33S/DElWXjX36x3zl/QfRX9irWQQOGv4pUgeI3fI413N fnJnw6ND7t/Z2Tjg
PBcc1/LNEM6l4CXUOED50KNfkO7eZQfDAdJHZ6f5QB8dp3K0YUCdJ2q0YVvd Zqo+uhzWGzDs1iNs
2rDXzo1kQxv23nl4hoy6eHYG8rR6ItmjIjxVBydo9MwnjvFez1or/CBvNT7J 9JyfNkyv80ANzHV3
SQILOGmk6+Eaw/d0egY5oKNLm5YjPzpPo8G+vF1atBww0qVJj1NJ2gByjsdI V+rMsX2gcS0PHWK5
B2OK2MAhFZBTZ7pUQMiwT6g+FBuKanVKkRrIMTbFXgD7m8q78Xib7k7TOU0g +NZUUZUpwhI+p3Cx
67hI/THqhQizdBEB4W1VFfZPVxUiJqfKxZbsqvZzWsQDFLOVQTfeRM3oHDVW 88JO8Wp456hlZyFa
6eMS2oD9DqrsTPscna0a/Yn0mz4vm92/AyN73F+NrHzogUZ4qJzB8qhKE3cu FWzUEare1M7wVu2k
XMb7Nh5IBVE0nkEFITWaPcTXppQfv3D4ITLX82egDT2aBoqyM42GjFqk0uXU XlN6i588CmpYg51t
JEfTygvxQFsa56iwO+ao6aFTwxjt7J0iJ0Lih2G/ekQPTLsdnzr7niQdRZuD ATlLVL4mPRotzV1i
q1QC6EKZR0O1Y4EgWp4JJOdxfuoRbcnqD4dgxwVBfHxjPEFlgT82PYULnqep 55tyhatSicOJqS4e
zk11BKfX2MmJP2zqAnHwaDaPOq2hVWcnrZn9wB23U8lgGPQAD2tXa4RjVzuF y296Oa1aOgk90Ev7
kjh/aj76+LQjdmr7JuZFzbF5ocedze6LoMvpQ/SgzmWOE4YgePkBVRmFZ52+ FIAaZeWBsyY/ebbQ
CVWdGlC1jvdMlQHUMDPGyuN52x+1nG09jHUsmOP+5qFM4QqSQ4wTThmNPFEr Ifc1tkNWCiCSx5Ox
BopASjJWG4l5J4ynI006YaYsqhlLqHgshEn8MQMVokEqvzSQpE9FFagICeJd PAEr4TNgpPHJ0yue
JzacJN7W5DTBgSIQ6yILo07eiJR8no+VcIBwpP9MOGp4oEqUgUgzbpMXyHg5 6RsT5gEjz5pLRwJF
4QslUEwUgLKuJqoKP3aUHELc12gC3oAfMgMG9/yDNIEosdaxd4qhE536qiNG JTrhqcy9UQ6Z6DT5
DRRUuA+kaiCN6iHzx2gaGzkO3bQZ0eSoauY/0AwkjyLQQiJGHWo7A1Wzq4FO NTqgrAYpob1o1hpx
TKNa8gOZjUcMS2D+uG7WMCKObGSjGYQCeRSEofwcuWv9wOITePK6PLuWWavK zzupb9WXjsjJrvM1
66myggxqNhnoIj6TXZ0KCDyTw0Rek9YL+qjcRl90VaMpOQJVopOhWzOAGlVG sI6qGoHlVIaWxKoq
oxBicZXRIzHHys6etlqdDVf6ILHverCJwvbr8akZNqciTb+J3M2eLcqh+hQl kspkjrRh92NzT0Tb
d6i4up1aa0nlyfZCJ+UQpgeiHOidqjpVUYNuCi9+jcKlzxPJqz+kVugrqTH6 0RrVkcHL1ulzu9qB
+uaqLhd+u2Zz+EVtS1x8M8Njb1C5qk96Close5GqnU1SK5fuJlsD0H6pWi9V tOUY8r1Ze5LofLP8
U9X7TWxULUFb5xgX+Tb8pQjZLryjSZLW9NNf0In+IJWS9BhXwS9DMjOuNfG1 +slv997pCbbzCS9r
4SSkkBjAUCjdyUSV6CGKJLGiB8I1GkJGElZMkig/0PixkQSnticZx2XcEpOW y5hbykoSASWtZKz9
PPisYQSRkeCBTqBK9FBApnt4QAApKAtIAwuineXAOsKJZmkiOcH15qg1kZW+ kVXOLCr1wqxvTrzO
mBATkoRreTTmg3NS+WAeNycSIqSTE+sVSELEVTXj+iBJE5KDJPqjQ7GTUlFe UNAHjEShJi8gz4uw
X61ZhB6l2kDnfCUECfmyspqxqRwQeDQJxTJlF0UFkRQny0WioAoZhKIDagtT xKZJ7INLJQ801S+T
8Jlx6QHPaTeYADWLinDeYm4DqRnGSHMtRFWNV7KsyrTsiOl5MXugPBtERC+i jcWQ0SQ2s/njFZ0L
Cu4RWXUnz5fDZ7RuyWgq84fnSyUVBJY9N5VRAMxORpHXgz540SZTwbieykiH 1gmaYriWWkyqAKg4
dtYQ6o/dm0bU1j+sJnKhk9hT7Lwe8c9GHcIIYzNzPYHUQDtQUjtPgJF2XoHC bBLRNZbomlF0DSz6
thdds+R1mFeTRhq4Pkwaf2SEh64hqndM8wXEnejLiaPRFxcnJCLh1gNdXZ5k DXRzemEKOanI1enV
qZzhKnVCh240Tad6qrrF+aoZpDoNhA47Ol9uHlTcvPrMStMMrnugobLroBGj V+FJxtrhZOt+4mwY
hs4FvbNrxlQm8iZPsRpreWOA5Vvol6I8xicsD9/qffCXKKLYT6iR3OJq92UI j5E7YnPW9nMd/sP4
Ie5+7e77us7uGPMnGqwnkskyxuezB+1Dp8oYrI8Y9mmwPiI9qwf+EDVqOmYO ui7cGPbLOGvE8JLh
+gFOC9cPFDVu+wAaz5X5vq5znsOqGAOOGPIyXB8xHNZw/UBFY8oy8cho85id 7BqFHqBofHqAqAF7
mQfVgL1MoDLePUDQOPhYAWMR8gGSxs7jES1GD3BajH0gC8xH7KT0DKQJDk93 LHSH0CGchu2FNWSP
5BEN2fduIfve5L07QZwh+15FPogl4nNOQ/b40tOgfae4O8EM2uNxFrTvxUL2 +PzUkD1INWQPUg3Z
99MC9vgetoA9HqABezxAA/Ydkw4MpuJxnYUsYN8xY6IBeyAN2KNKGrAnmJfN 7t+BkTUL2AtzNbLO
kOejKhoIRQU1RIqqW8Aeb6UBe7yvBlwhCg3EPkSkAVqIrk0J5xmuh7w1XN+L BYKhIA0QQ3UaOoZS
NagMdVu4Hpag4XrYiIaoYT4avIZhaVi7dwt3wxAtXA8bbYGWHDR0LmatYRgY fNPkgzBj99JINFzv
0Ye0LAdOD/rkTkLXrQm3oA09aMBeWr3GiOAQWjC/Ye8sToTSEPeikU7xPE19 H0U93ZUGro46NSIu
rqkfrKZDuEgN2Yu3bNm8qlmEuFhaijhf2tBwyhqyF2+t8b6DcXrN1TFbFdff 9NKC9gaaklUN2rsO
5o3Z86m8b2JkGrSXRoXI+mx6XwQjDo+yEpiaTvNLZB70B/jC5Ov0pWBQS1k8 0NXkJ4P2nVMi16B9
WrOJJ4skYmSIGImJwx8J/PNDUGo8FhZFV8SSb2zggdPB5eZv+thbro8XdVh5 Xm3ggXyohBjlP7+7
zf2Lk1Js7gKLTJG0ZbuopaTJxUCyrJ1bnl1QYgLtO1upzQX2z5k+XtTAs7za BwapOOnmbJf3jllT
CY0aPNuC5GivNhLAhO3cSOAUv8aNBE4Zn3ErAUNYPSUlPctdjuv40RSGkjLy /7d9c7wEBzsVqzNI
gvgEFl2RlHxTsfbCz5k+XtRge+EnikUoIOG41lWxP3IMxZ5lKw2xNyYZteG8 ZTnbn7rctLM9N219
hejxDkgy/nPleaY2VQcDl72q4i77QITCbwj0G4K4D0TgobYst4ClX8CWDkaE rR+0BAHv7Z6o70TY
0MGIZOcHLaJI7mbJBfCM7mUfiEmGWVUjI5L7teiKLnSSkmV0WNBhdEQkYNEV XeiwncOkw84PRkdE
AhZd0YUO35+TDjs/GB0RCVh0RRc6uAxH1xe67ulYdEUXOmznMOmw84PREZGA RVd0ocN2DpMOOz8Y
HREJWHRFFzpM7Uw6rL0zOiISsOiKrnTIczQ6jNqMjkgJpOiKLnTYzmHS4avD 6IhIwKIrutDhA8Do
ZOcHpVNEAhZd0UrH9F+jw84PRkfEOU0WXdGFDts5TDrs/GB0RCRg0RVd6BDR nHSIlxkdEQlYdEUX
OkS6HF13ZH3ezGIrulAhkD6pxuIdpcI1b2axFV2o0JVPqnN6VbnmzSy2ogsV tnSYVKVMqjLtXout
6ErVF6p6TqrqpMNiK7pQYYptUrU8qZq7mcVWdKFCHzup+uxe5Jo3s9iKLlQI 1BiVTEQrmSKdzS+e
zt046WQ7h0mHnR+MjmjmrKQNXehCXun6Qtc9XfD9qr/R0WFuYdJh5wejIyIB i67oQods7kmHyLHR
EZGARVd0ocPylEmHnR+MjogELLqiCx22c5h02PnB6IhIwKIrutL1hQ47Pxgd kRL0ha7f0ZXZedo+
EEZHRILie1Z/o6OrdaHD1LbREZGg+p7V3+joZNGc0SGyZ3REJGDRFV3oEBYz OhkqK50iErDoilY6
2c7B0fWFrjs6LbqiC50bUto+EEZHRIJlvOlvdHRuSGn7QBhd9EPUvIw3/Y2O Ls3O0/aBMDoiEiTf
s/obHV0+Fjrs/GB0RCTIvmf1N3q6vtBh5wejI1KCvtD1OzpkOE867PxgdEQk YNEVXeiwncOkQ5KN
0RGRgEVXdKFzQ0rbB8LoiEiwjDf9jY7ODSltHwij636Impfxpr/R0bkhpe0D Mem6p1vGm/7GSTe2
dDAy2flByRTJ7VLQX0sptw/E5MHOD8ZDxHtDvFyvPNG9nOz8YDzRf6hJQX+9 8qTD8aTT8yT/hSYF
/fWFpzuenD1PzgtPv1yvPDZmBI8b7nwo4r1uQHm6gaaNifCNhdmEbx7KAGtE jR5jf38toWNEwEPX
2DHSNWUSQX6MnEUQFDCN8CcTOWUeQVDlXBdIxveZzCXIjxkoEwUgqcsYEcWD Ef6GifyDMS3J+pRI
sPw4bkS9EDgZcwiKTk4v/Mkc0IiMrT9l1DmKJg4mT3wdRaLAuYc/kbtWgU6i zKkIkMhPiO9UiWUz
NbMWPE0WxSNZ8OAsAHK9HNJrWVlf3E9XFB1KC2WalIMm2ZPjUifkN1h9kVp5 +KX68zXDFMGvv0gK
5JSPiF8PXggqVIzv2xR4UfFLWmnpU0+lUb2VyNQLlKfqS5tmMUiQhKA2U0Q3 tKeCL9jOhYqlwmBp
iBI16F1JwrTeIhvm07KJuHgSy1esSSBeiMaCjyeAYiSVjewZOo2ycgqQNA0z hfPZeakXE39ZZ+qO
r6MTTnzXtMghmhwq9zIXhJ3NTbShBxUtnEqfWihAwfQV+mFqDkBTzUHnbMUG xoqLbvYRGnUCy5EV
Jn8ysVYWn6jJDUQbxpLd1kgDr9KYtg07Dk0/N+HQWiNp4qoXaQh4HjO6ZfCs EypoTx6Ve8SPW/vp
JKWi5h5QSKnI6iWuYla5kqSZh5mv2qYc6JkoI3VaU4AI1JlwO4t284RBs0Hg I6kxdaCmTnhXUzU8
r5kBvDJthB4b1qPO3AyLnj5awT4Nkv0DfQv7jrR2LNk6ljybAHuk019b71S0 Ta193BuzmU6938S7
JUJtnUgLc634i2j4GkkPT/S33kt/IXSvP7TIzq58+Pp9GQqyTkEf7Wr1k7nE smUKEjQuc5vryXiy
Pn3OUxCyIRqqRAGfYlzYjmuu4hagi+HHhKRujjE6lYEKUXmgyOtxF40G30nZ uuSQHoA2EyIIEwsO
5WftqzAJmQ/+gq83uQ54rCYXhYBnMbsI+wHkg+lF4QA9rQk56/ngZAwS3/Nh W0LIXKsEUDsoNamo
41o3OKhAmjKVgDRvQErKayJzgPBD9lDIPK8i4q8epXskOzt09+NJUkXBPSKT VJHVTSLE3VU8kUYT
paJ73egEESEIk1GkyORH0YMmbwUWjURhKuUQNVg6mOhBMySOqebjMPWPPn2a RsCqEzUb6e/NokLv
NDBNdBEzDFjGogYaeqO5pg/NjVHDDlj+YjYv2QPaHARpUwmY2tNmpKgZjSGh EXg6mraQViM9gWbd
Ui+TpgKe9lLJcsc6oiSNUolA2WSU+mnSSz1PeTVAFfrj2lSROtsfpDFQNh0m 9fXQ75jJ7Jr1k3Vi
k4aRtMuA0SRLOcQmyF13O8ESjK474cAQB9RpjBMoE3WgZNY9kGYDVaCgTWY8 MViDmdfdrosQ3FxX
uZYmPImqI6qsi+b7+Lo01oXpO/oG4mKye70+353eyOQSRPSUWRDRM5dXXJwJ O6jo1f3VqaWxnWKf
vtV0K1M8p6o9RG8OIaml0HOLDYlPV+sSb5+sZ0ZXoEYp3YQa7OhAaMu8rtYD BWsBs7MK7HUIz+XH
d/KJpz6/iWmK0rU1Yk7INdQvoozvICkvHta7YmwAcsBl4CfUiLe42n0ZQhY+ 7hgPn3X62c0/0Jb3
fOK7lcUptrmuODGbfaK5fivFuco4A8FBy8qvhN1fZEVYSnOVcQCSFX7YiTrp 8jgYtO7+ImvQUtIl
cLD9pEvg4KmSrjLGDtQpfuri4YcpJa5rkRVxidnpsloucTcYWUmX0lxXnLgU Q9bfDcS6SI5Q5m3I
q0m6bm8Qnp9zvd9A6UNXFaekW0UeuIlVxlafSSdvoHJumSbrDhOT32VNIpEs URzPExLsRHt7newa
5mtkQWquZIGVn+stZ51Eh+yreyeNLug89TV1RbHKQNZ+inRkVajKTVaMUqhc Tpp0cYCsNRVdyCpU
1ZKsUFUNyupVqld3U0/aj3TRxlxB3M1mZL2s2pOspU26T1YXTdma1JM2y7W6 tFmu1qVly4peGj3X
E2uDkCWFbCy6nlhbkqEn19UIBUVHXyZhB7Q6xTLrGk8TQARK8yVj9gKItHBK J2aTVcesnSogAJ1T
5HEqoGC7VFNA5+6ppseoS7ih4Rin8mPwhhFtOTesJup64caigaYXsSHrXNo+ UJ1GGm1RMCw46mpe
WHc8PnVhfViQ0MTZZCIPVGNrEqjt7AlKJFWUPQ1atT0j8zXS9AaGTlfrkyR8 pZMkdfoeyoJeKc61
xt1kSHcWzbVWFnVeMMbpH6Nu5gDfGaebrVPV9Lq0A3rkqG6200bUzRezLbr5 mKeb72aV7B/iXFsc
zZrZq0S9zmr/0uGc2jqsp/Jri7VVzQ7ujSOmnHZtMbFAbZxY0mVNWJcSJyyb YvlUnHPmMmL8UWqC
orNWX3Ytm5br831d/soS4ocwryOAcjcC0BXUE/YpPV3BLlLnmn+qpHKJAbVV mW4qmuQuA9SyLUuH
BdREo4Z51OzGAFW3/sAb1GwFB6X2vLDGqnt9wFQrt7ygHdcyLbwWaxgNqMwx gC5Rl0ZTqzZgtKha
P+fq/YHcKKDWT83FaEBtNuHabAxQ26fuJlKAnEeo7VP3D2lAebqS2rTJwM8I VMt4ipJDcGyTBl7P
nhFImqa3tLodpFEX3PWF6IH5rvTOlAM9N2VEr0750eWrcNkf2O4YqgfXi1Bj 7GG4WwY6H1Uze6aq
e5mITnRUgh6NtsPerurmJegKxeTYS9Ia2YPaXhnoXW2vjNPsm/2xGj97a9sN A07B9r8QpD2YovOK
bNhQdVtioNKNtHH/bXt+sXpZOhNqXLi4ia9Tqg1sMvcTNymUavKqTH026RXd UFNEW1QHg2RmNRWg
PHVVVAXQI1Jd5oCvLKPBkr11lLknTSrJhgoNqLihJ/cwpzEW1RbstKTPubfI A03rLtaTwfRLZHtF
syi6oQbaTNEuEO3JoarIugv7MZFUUV5Qc49Ayy9cOUm3UPRr5rRKi7b0dU7K Qb1RMDHQNxXbW6lQ
Ds6rFffNU7L3hVQI/aRqiy60TG9bTc30vZaJJiop02MX278I7pxGRU9Pg2Mv UHSJBnoIPdVeeg+1
YnYtLisu0/TZI7FRsLdig5k9mfVPxRrem0MB6G8OBQC1WWIi17VfGwxg2xTe UeVQtumjdUAgP7BO
aMuufjYoKHJKjtbE1+ovDQowFXgZFqwnOVxXHZ0YtlTOImXoVVfgZYTAdHFe RtytMjSwrTq6bDYv
pwrbKcgZRsileTf7qQfZmGaI4XI4Z/v++ddpO9c0he+fbR1/1/NR7Uzi37cz bf+2LQbZyuzHh0Zu
5p7trptzVn/XDd7D+KxlMTtCNz6vdj3sFOP+tFJH0YrbMRxFFyMhNPis2M0D f7sehjqPSN6PUb6u
c+ovXiWs01T3NlGOz/NiEzdP2w5tjrsoNz3dHP68yWPn2c/V3Y+LfSWz+lxp JjNbZVb1yOqQpraj
knVTgJ5RfRr9zam2u9hu/qKrnWYlwmGWM011P5Z4P7v+Rnb7O6dNK/u5xXs1 f3vLdnBK8MV29hrs
mtkPDr9pv9u77Qc178eN70+/WUf4/Ta5O4rD3II7eWd7jx/TSHwuj+MNCe2a 3drbzV03i1HfMNut
zpcDm+/tA9/mq32k7c3e6UtC31Z+bitGw29axvqb3ZPs8lDm5+3uxvmrDYXw /Lbd+e1d2yaMdw4V
VyN7JXqZoryIPr3R1Z8/1dUXvas/N6Gtw9Izqc4XA4TdyG9UWK48YXuLm6Za VdbuvBfrVtJTfcxa
v+jStzLvmdUmj32UcWNnyvRyoPMvM6y2jSB/V+7u+o/t5fbX3V9l/8vmvV+Z o71r3wZwPyT+8+lf
0s68N/PdZH93y/1tRPGHG6CmTW+mkzcWUD9MeR963rSBnxwKLEYxTUJ2bbGs J4WarpGZvFENzTQP
mdK1HBBNiZLMjuxSRySXRtNKJAsq8vp0iSiaBcWsi8QpY3lacsktERSa+CJJ N/rLzHwKXeam9RQE
ZBJokk1AyoEm4DyQpeaELvPWuovQwXK2xXdnuo/sBK6JQIHr2nX3cMmlYRJK a8yQkpq0ZolHskm5
R9ESlsbW5m1BeWY6LXD86K7PzxVF94D8aQ8fJJmZTYU/BlfpxASpRJTcy0YV g+zsXlREPGHCxNdE
B3rGRGBJPX4iqUKwYbkqi/vImyKRmUkVt4Nmgdepog4aRu00DG5g32leWjRN Y8MW9jTD6syzNhpr
Impq1HL0RVWTx49lNgcJaWhTMZQcapPGoPvxXFCwR1jWU5VcGR4aJpXTVBGp uGU91T5znvCqlvVU
meckU0kiI6Y9QXyazCKi1TQXEbskwIg6NO9JVMW8GdGiJtSIgjXZRpSviThi GJr1JEbDDB61KE3v
EWPT1B8xRE0LEiPVrCcxYGYTqXVrqpGYvqYhSbNIXa+LXbsryT+arW3+0Oy6 OprqaPyjGhOZIls/
66HHDET3Ap0vrg7GvXg/+OJMczsozkAHZsLsKvZCVKYSuohdm0gXuU/H6hQL N0uV9zRNoSdm7FTz
2jAg8dmnS6kT3Wi6Xfp0RtnzNFY5WXfm70lGUF26oOq6oJkUqH3XuaDuFmY9 P3LBNPpNDE5S17QB
Iu3JNdQvIslhkvLiYr0j/hK9qNOWKvEWV70vQ5JdddCeZp1+chunltjUt8Sn 8HJQeHbOL5fLsPBm
JLGNb38s+BO2kc2Lj+w3gg43g9R9hNR16Ijo+c+MHW0w//wTcePdx/HzQ2YP TiX7/LKo2vYhM2Ml
NkD8+xuKxfL27yp2i1f+14kO7hHV9Nwcfj46+H1bm9HCslXSBPJWtPCNj4sf jR7usar0XCZ/6ZNh
VntaqH2zvLa+PAYXZ8rqjpz1zdjLi2D0j/kRN2lgjas/Fdzx24zhXj85fyyM 9P0PzldxpVlrdRN+
N7m92puZvvIbZqZbjPU7fkM0F/eZpruw+m6Dr/zEv7ojec9P2Gnq541wdzFd TxN2VfohP7HPKhiP
3z3wlWPYbtxt4of8xN7dPn/6nZ+4mZG7McHVvNwGfjjPWkbcSLgKOERwTlmH pul+so5PEwBkqCWp
PI7j+7OqMmMuXxicVY2fLS1bamPtZsXOVtjmIRocey/ItqzcW7yXDVU9mMXz vNhoL5+jQK2jb9bW
1SQKRwcUzMH+Q8ctKurfL+12exek4Ug2kb2LJhcJ0mDAeQQXGhDEkivPd98l tXN7F42yBQt5BTUc
te11UPqfPv5vYDB/QGVuZHN0cmVhbQ0KZW5kb2JqDQoNCjMgMCBvYmoNCiAg MjA3MzMNCmVuZG9i
ag0KDQo1IDAgb2JqDQo8PCAvTGVuZ3RoIDYgMCBSDQogICAvRmlsdGVyIC9G bGF0ZURlY29kZQ0K
ICAgL0xlbmd0aDEgMzQxNTINCj4+DQpzdHJlYW0NCnic7L15fBRV9jd8762t q7q6u3pf0kkq6XQn
JAECSUgC0TRCQISwgwSJpEkaEsi+sAkSXAARFZ0RxQ1wBRUJEDAgjowy7gw4 LjPiKMyI65iRmUFm
Rkj3c251J4A68/ye533/eD/vxzRVderWXc/5nnPPube6aWtpDyMZdSAGBavq Q02vPfnuywihtxHC
lqrFbeq9f2w7AfQphPic+U0L6q99NNOMkE5BiOtcULds/uivxF8hZDiM0JVv 1oRD1SNGZpkQmrAB
6hhWAwm3R24S4P4I3KfV1LctPeda/xXcfwn3Z+oaq0LjvvH9DaGyP8D98vrQ 0qYaaRuL0MTpcK82
hOrDk187ehvctyGU9U5TY2vbJpQZhaxX0+dNLeGmh5c94oH7GoSkXkjD8KF/ MpA8vScMy/GCTpT0
ssFoUswWq83ucLrcngRvYlKympLqS/MH0jMGZGZlDxw0OGfI0Ny8/GEFhUXD R6D/X/xxB5EbDg/3
FHKzAeRCKPoFHF/Sa6Q2+iV9Tq/ka8jcHT8Q2o524lq0E72EXsZnoNQudAB1 odeRE41GD6EV6Jdo
LeLRbEi5DU2FDwfpv8TuaBcajLYBlraho5D3WnQjOogc2BX9Cq1CtzLvQqlb kQGlopFoMmpEd+AJ
0XY0B51kb0YFaAJqQE24Izoremf0nujj6Al0gHk92ov0yIOq4HM0+lfuD9E/ ooFQ4l60GZ3E94j7
UBBa6YCcD6MW9ABTweLoguj30IMUtAT6wKIydBQfJllQexh9gV14BTMKanks 2hk9Arm8qALVoAfQ
QZyPx5IUbk60LHoUOaCNpVDrZrQH7YdPN3oRncAydyb6ePQMcqNsNA7G04V+ iw8zkd7VkRLKaODS
AFQETxrRr9Br6Dj24V+TRk7mhnJBbnn0PWRDQ9AM6O1TUPJz/E9yI3xWMa+y Y6JXISPw5W7KbfQb
9CfswYPxJDyTDCCN5BGmBemgxSHwqUa1wO/7ofZPcBbeT2RyjHmMfYY9zydG TkWNIJEAehA9jH6N
DTBSFbfim/AH+FMyiswlD5I/M79kd7C/E0Iw6utRPboDPYP+iS24EE/B1+Ea vAKvxXfjzfgoPo6/
JCPJdLKIfMvUMM3Mi+xV8JnGtrI3c2u42/kvI7MiRyLvRP4ZHRpdg6YAHlZD 7+9Fj8DIDqBj6EP4
nER/xhzWYyN8VJyCZ+Ab4HMjvgM/irfjHbgLWjmO/4y/wn/H3+HzBMGHJwkk haTCx0dayBLyS/IQ
OQaf4+Qb8m/GyaQyWUw+U8yUM43Qq7XMRvjsY/7EethjbBT4PJTbxG3htnPP cC9zZ3hZuEmHdG9f
eKw3s/eTCIqsi2yK7Il0Rf+E7CBDD3AhGRVD70PwWQjy3gSI24XexTLwzoMz 8ZV4AnBmLl6Im/FS
4OQt+AH8hNb35/Ah4NLv8bfQZwPxan0eRPLJVWQSfK4nYdJMNpJ7SBf5gHzP CIyeMTF2JpMZy1Qw
YaaNWcZsYjqZt5mPmT8z55gL8ImyEpvMprIBNosdy85l29lH2C/YL7g53Fvc Z7zE1/Nr+G7+b8Iw
4UphsjBFqBDuEvYL7+kqAZ2voH3o+Ut1Hp9iVjOlzD50J8ll3eS35LeA57mo mikjgFSyHa8jK3EX
SeOW8iPICDwRnWEDwOtXyRZyjoxgyvB4PA0tJENitfE29mm4FLOvoB72EIzt t1DzUl7GN5JveRnt
wYgUQZu/YXLYLOYtdII5iQV2G/qIlbAT95CnmMmAghfZK7lZKIV5CD3HNOOV aB8pBYt9XrcBcDwR
Pw12YToeiv/FRBFDJgKKCphP0c1oEfkD6gE9Xofuw9XsAnQnysUr0BfoSdCK AVwDn8nb8Rukll1P
rLgLEXYHjK4Ip2GGs6FbcAXzAP8t+RC1o2OshD5hnoXeHyPPMWXsGW4qrgEN WInWoOboarSMm8X+
Di9ADJ6J/OwpsG4rmKFsClxXgVWZAzZtP2j3QbADI5kySHEBciYALmaAhXgA PveDnWABQbWg49eC
Ffst6uKnk260gDNisDoIsW9FpqLZ0SfR5ugC1BC9Bw0Ee7A2ugJq3I4+Q3eh 7fjWyA2oCSWB5nyC
J3BjyDFuTHQgWU8+JNPIpsvlC9z2Yxf6Gj7PoTHoSu4FtJ79PZqGSqIbou8D ujPAwm5G89A16DSM
8q/QwtXMYZQbmUh2R8cwTTDek2hK9KloMpZQTbQOTUKH0BMCh0JCVnDkyGDJ lVcUjxheVFiQn5c7
dEjO4EEDs7MyB2SkB/xpvtQUNTkp0ZvgcbucDrvNajErJqNB1kuiTuA5liEY ZZf6xlSqnYHKTjbg
u/rqgfTeF4KE0CUJlZ0qJI25PE+nWqllUy/PGYSc83+QMxjLGezPiRW1GBUP zFZLfWrn0dE+tRvP
njIL6DtG+8rVzh6NLtPojRptADolBQqopa6a0WonrlRLO8csrllfWjkaqtut l0b5RoWlgdlot6QH
Ug9Up9PXtBs7r8QaQZylw3cTpDNApzo9vtGlnW7faNqDTsZfGqrunDxlVuno hJSU8oHZnXhUlW9e
J/Jd1WnK0rKgUVoznfyoTkFrRq2lo0G3q7uzD6/f0K2geZVZcrWvOjRnVicT KqdtmLOg3dGdzuWn
XRdvoXLLqFlrL32awKwvddWq9Hb9+rVq59Ypsy59mkLP5eVQB5Ql/jGV68dA 0xuAieOnqdAaubV8
Vie+FZpU6UjoqGLjC/tKaUrlQrVT9F3lq1m/sBJE41nfiaYuS9nj8QQPRE8h T6m6fvosX0pnSYKv
PDTau9uG1k9dttcdVN2XPxmYvVsxxxi722iKE7LhUiLc/0yjtOyUGj+1n7OY 9sg3DgDRqVap0JNZ
PhhTIT2FC9H6qkLIBn/lGEp1VoNEajvFUZXrleE0nZbv5PyKT13/HQIE+Hq+ uTwlFE/h/cp3iJIU
J/1Qg+d9dGdWVmdmJoWIMApkCn28UrvPH5i9uJv4fE2KChdgH5oMvA2VDx8M 7E9JoQK+vTuI5sFN
Z8eUWbF7Fc1L2IOCg7PKO0klfXK474l9Bn3S0fekv3ilD5DcpTm/9k5doP+f SXFYS2uGd2LHf3kc
jj0fP803fsrsWWrp+so4b8dPv+wu9ryw/1mc6rSOmsUkkDhFEhjtKYByTn9m ejNL7mT98I/XQF3d
LegAlVoKVsd0KpVXx87lUkrK/7BQd/QMLaVdLhaLd7NzeNbl9yMuu7+se/J6 BjoMk+D46bPXr5cu
ewZQizU4Ln4BxKPps1LUUZ1oBmimH/51Rw8X0qM8oTMILBtFMwD+Yknx28sy JsTpcvij6ByYPQYM
3fr1Y3zqmPWV60Pd0Y55PlXxrT9AXiYvr28qrewDTnf04O0JnWM2lAOvavDw gYhgzfnkEHizArqq
i+DTvNBNNgetiGNPM0gS2NMYuXU8d5owh2BSF8HFG4RcWcq54t7iicrZ4rLe YlQCtHIBTkNyUswp
Zj+cMExpF1Tm8IUgh84jlT1MW9gEc9lXEDOYUSLKRKuDk1l2jG+mb76vVbxF 5Gs97VyT2Kq/mbtZ
z6c7RMaVnpnkSBRFqyUpM3PAAAQxF8EkOSnJjHSuAD/dH5A92YlJKlYBmxVZ I+bQblVo/TpX1nO2
R+sXPSxFg4uV3uKiweYis6UIW5xFQ3JwBarINacMdcA8xAv0bCQ+nDK0YNiw /LxAwAdjGFpwJYnR
m0hg+1ut8xfcete1Hb/eEPkFvmJ14TXjx9z0SOQjXH99YNTs4dPv3RDZyR0s PxC+/snc9EMdC3ZX
DmGmmh3zy8Y1Dji/VZALF42ZugycIoJGR79k09krIZJxo18HKyyC5JbH8lfr ZvLlugV8rU6Xpwy3
DHfku0qV8ZbxjlLXHG6OOFWpsFQ4prrquXqxWqm31DuqXUuwXeQ5w3XMdG66 dJ1cx4S5sFQnS04v
K5i9er0tTQCYBK1p/rwcASNBEVSBEYacTMAJNN2d5MvLAdqYhoKQJRmVQOeG ePIKNDZm9SjNWRXn
KoBAJT0lPcCx5grUDEoVFKdx08R53DyRxRXlVqVgWO5QBEzkfanIanPkDqUM 9KXyox+/7TcfYccN
f7n9ZKTnwJ61a/bsvXXtHnC20u9cHPlT79G/3ISTsOHtt95+5zdvvQkSTIv+ nWRymyHy6ziApOjh
vb5Ankg7OhKIDjcE57JBwgxyKGKWSeIdXkZvUlJRKjZY/DKOCrpSsbRSaBI6 hI0Ci2CsW4VO4bBw
XOCFg2QhcuFhu+drQ2s+e1rpoZA9fbaYjg1Ic5GlyJybq7xBgZGV5XfCYAKB fLMvP9dcYM61+8w2
B4yMKJ4JxfPqsm+5Ze++fdasjKRtW5Qrw4+Sqg1YqIvcsaH3F2XZHrqOMCf6 BfsX7l2UgyLBh6qY
KraVaWNZf3o+U+QdxYwTJiSWJo9OG5M+jSkX5iRem3Gb1ZhhCKSRNCbdP8yU 5xvtLx08W53pm+Gv
0y80LDLOt4Vdy/TLDctNK5X2tFb/Gma9/jbDetMdyq1pN/vvMWwybbIn+dOM Bj2XAmqSAO4UeFM8
9qelQhrPJSUMvMuDPT0QmyoQUE2GaagJb8Q87sadQf/ApCQHwyUNFBMCnmvE ABqAB3iGpgQsOGCZ
TnXLPaTqOlcWaHtF2ekepQfUqyKmX4ALpbfiNBxnzaBVZifVr7iCoYpmXNFs LUgigAgKifRAWjrw
NG8Y4MXhcAoBChK7zelgnZoSAsvTAnOeN8x9fWXj09MmzxkRqZtSu+DGv//y sX+v4Q6adu7o3FZU
iD+c1bF8zfmHX4v8YzP+vdJwx7VXtY4uXeBzhrIKHgs3/rq69u3VxtvvXH3d pNzcRRkj9i1uP9ba
9hWMISUyhfkrG0AevHavyYtN3dFPgo97izJsM027JCZoCJqISc3IyVPoSZBF i8PgsqTr0+V0wzB5
mCHfuNmsz7BkWK92lFvKreX2Wkuttda+jF9sWGZebltuv9Ww3rzBssF6m+1+ abv+kPKC+aDta+kL
23eGXuXftqg3yWIyyYrZYpEQ47ZZrX6LZIMbk2wyy369ZNPrJavFIst6nvG6 TcireMlg70te4u0m
JftM1qAlaOsm04P6EkvQQuZaXrIQSze+ar8Jp6LSBIk+sphUfTCoyjnyJJmZ LEdlIkOOvYNNMFhS
0pWgrgD4e9xKb/PZimaPqwfIHpdy9rRbOV3R3ONxKT0ahVxUJRT4rOUGZelW Kkfg6soyAoFAumuN
SnGx7sj4TuO08Z0umBpfQHL0S6SPfokLC8tBfcBCHEC26Cf7C4qk1IIiY3f0 y332InOqvSgL/sor
mrOyUHNFFq6wplNbUUA/ONfqcA4rsOZiXqA4WGUbkV18tdMc4PSR+pc/zkpN zvq0K1I3Mi1nxcy8
yIIdSkZawiJTIpvRu7l99YrFZNH513ddVT6Nal5J9EtmN1jXHPxh8AY21ZY6 XLxGHJ02MzWcukK8
U7wl7UnrM9kvMwbR6XE5c8Znf+DkEsgMQpShWHLN0c0R50hz9HPkOYaFuoXi QmmhfqG80NAV6Eo3
UfymDRiWNlsq11cHqjPafG1pHWm/kB6S78m4L/venMelHfJj6Y9n7A38JuBI pPiyJBXN1qX7ZYn1
qAE7qx+U6OkmTwe9ye4S9yT3XPcu9zE3b3InuxvdJ91ssvsuN3G/QGZADIYg m6LgICYKPo4Jwgom
GGzhXpsjj16DSUZzHsaD5iTWJZJEr11gvYP0yaDhae6g1ZXn7ibX7RHSMiHn 896i45k40zOUlgqk
Z+ZVDj08lJQM7RhKhioY4zSkpplSTyJcAoEcAVWn9p+qenPZWdD1lokKSOxc cxYofFZPi6byzTCf
ZmVVNLdQxYczoIJOq2ZN7UctCwbTByb5OFt2wKxYFKvC8KkGNQGJGUIC5gbC KckGtylGXwJK9Rlk
3QApAWekixKfxSagZCUxAaOsLIq/2AlT2GRmrV69GmVRk9LSXGEtcMSmmfRA +iCYogFCP7Qp8Eki
MaMSKNljuu2GFUvz/b94dfOkkYWZd09b+eJsc6fcWrtiocMxOOGWl+6bWfvq ymMf4iu8i1rCo6/w
ufxDx62eOHZZRnLW1TcscE2dM7XA5020Smm5I1fMmb3l2mfpPD4e5vEkQJod vJlPgtXJyGsnM5gK
rkKcoQ8zi7hGMazXKUjBCkm3fMh9bzvnEYZYhruHeEdayjwjvVMsc9xTvSFL vSfkXcovtZ8j51wK
cmCTwemc7Kh0NDkYh9e0UdmqEEVhE7ySgCh6RHyv1cvqnUEDlagIEu00YIMn maLDH8ij12AindqT
cbIjV0kTgmmZeclCiTAJJn93Up94s8p6T0+EKT4mW5Br7+mSHhAs+E/NxZia cUvcS8LNLdipze5m
BcFUb7YJKRr/cQrYdOA3c/3B7L8e+CryLbb98X1sxBe+lPbcWrWh9wSZIhfO vG3FDjzT+VgXTsYM
lnFG5JPIvxV118EafO+aUTVPUp1dixAfAE760KsHkBj9Q3Ck3pDnZ0+zp8U/ OT9Tufe5cypx6lSf
6EpQRYbxJXl5Ozg4vIB5H5gx6bgfb/Rv9RO/0+kx+jeasbkbV+xz+TdSVwdX BN2I5Pr8+DjCG9FW
RKirMwn8UXeavxsv3ZsydrIrK2siQL4F3NnTwJyesxW9E0vDoz9vBsQXFxeX lBSXKaANMMFR1lhi
ODfKNmvAJpsTsMVgp6gFqK6mHMvKBZdBg6STnuxmnzkvhkyNAgKotduGPrlw 8X3JN775yNN7fXOu
bPpl16zqCauHs4F7J86dN+vgrv296eThurnD73289z6yZ+nSyQ/c3fshcGt+ 9AtuMfgWiag7WFlF
FiYSFQ01VKEm1JbYgW5J3Ige4J5hnjAcYLoMrxmOo9OJ/0g0Gy2J5sREJpPP MGd61eSxhpm2a+0z
3TXcosQbLLdbHmA2Gx/wbsePk+3m941WZEMexaZ4WAJmbE9GkWZy0jOKFBPC bII1SWYSklhRCZiu
QQEVjIgn2RlQdVjnTqqaE3cULvcSzJrLDUYD5pcKTPHEwmwPqmtJyx3KxvUW 9NVCccV2vXxF5JXP
eiK/f3AXHvXyH3H2iJdyX/7Fjk/n1H++5rE/EzLk2/O/xg2/+wzP2H3qrYFb 73k08u3dL0S+Wn8o
hiXmc8CSA70dtHIMbyXblW7lU+YL6xnmnJVnId4LDgF4LVPw/cpx1ylX1MWq OpvR5rB4OcCTwyAZ
jLIxTR/MHZYX1WP4p5/oouP35A3L63SdcZEm11ZXp+uwi3UxJNfu8GNEH1sg /xkaJKvoODoF4c9E
J/U1s8C7PFusGVE4esCiAaJKgCPgJsVg5ODNoqSTBInhlYCZNyZgk2SJwykT 8NRM7Z6GKM3GXQan
tY+2f1y5bbIidWUuurr1KTZw367SprKhK3tbyZqG+pH3vN17CCzVNWCpvMCT DFSAE4N3igYx023w
ZA4wZGYWGYbZCxKGZ47LrDBUZC401GZW5qw3rBnwgONBzw6D/Un30xn73S9k HHEfy/id/eMM3WgH
TnYmu7KyM/OK2KLscezV2TN15VnzdbVZi+W18hvyvw3/zjIX5BkxqwxOy3MO TbG55g5oHEAGeAcb
S4x3GbcYo0Zui3GX8VsjYzR6GSe1aQ7XvTavV0Cl6dJQcOsHhJQQ8qekwSwW VNKDKKAE1EBOYFeA
CwwporxOpvat6HAR2VqEi5x+V+rgtJf4YzxJ5kt4wg8ppIwH6MW43nO2uPez zygMT1MrZ6ZGrrmn
OTZr9U1b1MxBeOPXJgzqo2p+iTbFAKOF9CtJnPl2m8PpCzC8YAS4xhyYfKa4 +sDCXYfGtl6dv+jE
Apxbum7VssROV8Px29Y9PVkRnamHvM55RxrnDK2vrXk0kHjzjDHP3Dpx9USb 0eBJ80sNA68ob3Y1
3z4+GLpm0NIz52+9ohB/nOFVMsoGX1153aQrlgCobgYzWQCRM4M2HEAcWPqC wjyOWvy8/Ng1Z0js
murXrkG/3Zln4pK5LdxJjp0EpzMck8w1cR1clGMBpBJhYrilNWn49eTm521B +DA6A4i5CGKWGkfK
z5YsCmVUUkJnBXoHf4BK881d3MHvx0CZddDHYq2PAloZrJgkbhS3ip3iYfGk eEYUkJgsNokd4pZ4
0ikxKkrJIkR1AksYkWduxIjneFbiBT+H2C3sVraTPcyeYvnD7BmWIFZlj8Md y07U9fco1p/ikh5t
vqIH7VtLszU/185A19Z1dXWxfzl27LydDZw/EZ9pGLpraUO7DyAHjNoAfPKz +Uwpc9DAMt3RU8E0
pzvPqTPLZhvDYWQCo2DTS7Jf1OyBiA+LWJzooAxzUnvgOOMgTY6tjk5H1ME6 iC1uDOw/Mgb2vl5T
LlJgnqXmgNqCnhJz0UVrYOSNgt/IywnYoDP1TSpgAbDGbM0EXDaLdN14ePFz 47vaF02+A5jf+/d7
Kh5/qHcu2bb2hml3rux9AfpwKzgrr4L2m9HNwRGDrVhhsY/NY0ex09j5bBvL i2adqBMNVrNoQIwO
6710WkWSmLERLHqqasVWkmr+j+OyjD3SP67TSsXZltMgEmreYEzaZFmElDfW GlceoTrWgiv6pkaw
+VSxYAi3Pnplbcl111951VUjrrclsYFtzVcPfyp9bEllS+971M8aAx79yfiq 0QfBZyTCGvyGPMNo
A5dvy/deS6ZLU23TvAtINRcWq2yV3sPJ73HvWz92f2b9zPat8y/uzxJPJUeT HcnJWZ5iR7FnvKcp
eWOyMIikGQY5hpN8w3hSahhjG+e9VpppWGD4jP/C8T0+a1SwnTHqYcJL8OoF M5LsYJdcuRj5zSa/
ohw3Y8UcNFeaO8ysuc2S9pJwTDgpRAX2Ekdrcp8f3QNecjG4D73Fp7XlBnpo K1H9ZiclP7bekGfR
nAYQNL5kIYUpDB9Z9X77wvdurtw0eG+v+mz74ie237B025pHNpx/bAtm1k8Z SYzfjyGWt9/89asn
3j5CI3aEhMXAMxfeEBw9AAXMAywBVxEaZi6yDHONQ2PN4yxjXbPQteZZlmtd yv26+030VQeO8IJO
x0l6WRYNRohXbRCS0hceXPbuaPFeDrlUepUtZnoNzrbrRBVxhKgY2TBGLk6n S7K7bHa7yyKLYpLd
AqTFLJtMqmK2KRD8irLOZedMZkVGhLPLHONSTCZR1OkIwcRlsZjNSOcBH04Z KeIpgDEZznY4gojD
U/ar1NVwu7vx7bu3x3jrcZf1ely9vR53r0vz11Asco2d6QeMO47bBu0oKlpb Nihr7cojayGm/dEF
TBrEt0eO0CD3SB916QmP7zRB3GuGuHePRQK34BwEvZDoh8RMSDyAEF2YReM7 9ZBihJS9cpALxiLj
loqUeKALF0ss3vXhQDroG34kcsNrJ9M8hRJ2fv27ST7vwM9fiTS8EHkrXXDa Im9wBy+U3HfvX9KY
T3o9kW/+cXsX89z3Y9iKDWp47PnHqI6sgRk+GeStaDryLOZkUxqXz5VyXEly ZzJJTk715nqv8lLk
88OtVA0mOCZ4KnQVhlmmCsf1noW6OkONqcHR4Dmc/KF8wnnC/WfrN85v3J9q uuNWucGmwbYcrsQU
5CaYJnPzuROJ37HfK7JiN7I8AR2BMYCKGPWutON6rOiD+kp9h57Vt2FzLspl /IQcxngj3oo78RnM
JuMSPAmiAXfS2L5gEzxvpfesFlBqHmPMKsZVBB6Djvhi9g/COgX5UtMZiPL6 VQQPfKqrZfe8Xc3B
yN9fPLSI5M24e/GzT7QvfhZM4nd3TbrrzdbIt5EPHsabXppx+9G3jr96FHRk JO4mC0k9zFfZQXcT
aWJIGS4DIPoQ8XBNVInYpjto905XKJ+jwWU90BeIP635KfaRZADu3rcPOB/t RYgrB84LyIiTglWD
lRxlga5GrFTWMRuVN7hX+cPKGUWv48rxTDJZqdF3Kv+Q/2H4h1FkZdbAGhm9 JHIsKxuMOl4QZKB1
vCxQAyvINkggDKOysg1yiEkcp0viGb6bNAVFpJO/CoLSkINYjzDWBy2yisIC M3Uye4w9yTIbWcx2
YxzUT5YPCydlZqOMZXqvmMBSkVVCh0CEX5g++D3YbuC+Gw7454IQh64K9SBX SbEH/CWwWvCPrgPR
ZSDQEbjgPj0CdTCCWnCxK+A7BvokAH0Xa2J0wsHoGVCHfxUWUh2BsN2HAe9M CmNNYSjowXl+h8z6
+JneB7d9iP+2eQxAlHoS+FBkNJmNNx1YcsftgOy1kVo2BWYvC0pCx4JPyMpA 5QplvMKWqJ0qSVYH
yL7EofahiVclNqkbVd1w5/CEa5zXJJTrrpPnOOckLNQtkmuVeueihMPqu7aP XR973k06bTuddEqN
qg4fm6Vk2fPZ4coY9hpltvKZ/i+JEUVvNkLcrU2CDgA0MrrTjktYkYJSpdQh sVIbtuaSXIsfoZ+E
dDJAGv8UpjVQm4suhbS1L0x02G2EzgDpZuYSu7/28eH31Kw7vrD95A2z7xpk fnLx0meeamvdHanl
Xlw/ZcqG6P2PRc7fPmF473nm8aNH3nr/rTd/D6A9CG7OWnQUUO0PukgxOHrF c1EjWoV2IXYrPN/K
brtfm7ArqJ4NyckFX+ng0aNHqXd0EgB9njuMJNQaVJmgwZy3iF1F7iKbdeyz LBbBPwNPjcMywW9K
sZgnBfxwpO2/eGQuaDDFnE8jTeawygU5wrn1B3ExvhXFNKk5K+4saPtGJTSe ji8zZIGC87yQD653
LjnfNfLd6ff9eXAbe8OVK5KfG/vmXGrlqiDy/Zh7DxlRAloVrPSYsE2x2RKc CQksq7A2vVOfwO5w
7je+amScTlcCUROD5knWSc6gZxY3S7xWmWGea53tnOua6bk24XbnZqK4kxjG kqQX7QFVwIKnIxEn
mgLairf30kC2gkayfbsgNIKFMNaqoJShrAUEp0WyBbGlkTwCgkNVeB0e9hYe 80xXZP9LxyIHt7+O
E3//EU5Y9tXdv438nryJ6/HDL0ee+OPJyNZ9r+PZv4r8M3IM5+GEvVj/i8hn VBL1MNIDEOP70R+C
pQm2BDupTMfX66zYwqSloRSLk/hREsGYdyYZmZQkXsQwj/jTVLAWRE2vJAxp 6UjH6YkBVcKSO9C/
fN9TRgdDcVlM4yBtTHR3TLuNLeL1rW6MZn0JXo/X7WV4OaD47YHkgM7PBnx+ lyExBTlM1hTIbLOq
Atylcv4U7NU7U7DNDKckMSUFpTFwQjRKwPHlvL6/TG2RBOf7zZetAjic4JRR rxacQpuFpaGVmZlA
6u+KHN/6h8iWrr148kdbML4nsCtl3v7GW19eklK4FpO7bzxzJSl5Fveeamk9 gK//wwe4tWtB9y9z
mjrKptwyad2WI5F/dYQKsJlydTtC7K1gq0U0PpjJc0k63V0gdgExLN1YRDrh IeCenhCPnhXju4rS
iDgOKGC1JQ3q38b2FCvopiJokDnFnqId25mPL3xGOnsncwd3Robv7J0PNfAw PzzPBpCF7Abja8OZ
7ACJXGO+znynmTHTxQgxOSVP8Sam072uM8GdyWl5LC+LVj5BdFs4FrG8XtQb dRYFWRmb4NUl6BON
acgvZOqyjHkoXxiuG2EczYzlg0KZbrx+lGms+RrLdaaplkVCtW6BZRm/XGjT HeAPmvZbvuPPixl6
cwbKMKQbM0zplsG2QlRgWaJbo7ufuU9+Cm8n2/VPyvvQfv6g8XX2A/5D8Uv2 S9MXlrP896LXwmju
ocCJkqQDB1FSzGZTd3Q8eIUW8AbHBedLJqP6ilnQqYLZYsmCsInjBKMky36D 0WaA+c1sMmVJOhsU
pz6jP+YzIoIFC6szmWWjQTJLLGMxyLJOJwgwEfMWk8loRJLtnGLAlYYmQ4eB MXTjp4KSOknCjdIq
iUjdZEZQnGTGjeZVZmKmd3qFw5VapMtwkHkfPmc9N1+TobvsbEWFC6wx/AOP Eeif9hdji590jrP8
j9xFAbxFelCaHuM7k6fN6jKoskoORU8hDIcxerwL5ZhUC0SYuDD+Vz6+M28a uIy66PHdQg7WElJg
Bs3VHEld9NRuQY2lWuLz6gFa0X6TSuvWdUeP7xFyaI17UCE5GGupv/L+ck6t nDl6aq+ksioqvGSX
xhh9b7+lCGXD0R19b7e1KLZBQ2N71AxzFHVXNTfV6tR8VSadweMjLxzcUcLm 7jiwJf+K/bsiXS/s
GPB7NtD74Gnzm6Sh9/63jpL550+QFfsuHAP0r4N4+1+gcXr8dtAj8DP52SJj MvyDO8czM5glErHw
qjUlD4ZyZq8lpgFdcLVwWkJKTCVugRSeZTmWLxDHspyfHyjNkpYw7dIJ5lNe eJLHPj4g+HVFfKFY
YphkKGfL+VlCubiSXcZtFl/lfwdIPs1/JfyT/7fObpEkjmFYAkYGwg64gdjD L/DgafEMy/o5CUAr
SSLc6MAgaC9/6/R6JIEvZdrDpergEvSpEOMRwbPRgA16PwIk44392yey4U8p Y+fHl5Nji8YTlea+
ldA42CD8cxZRr4q9dHdNUHTFumJGO8ckFJTE7MQiUZeYWMzThdjEIri8t0fV LrtTtA01EBiVVTNY
Wk2mfPTwnpQiBqbhPQ56+WSPUsTHLtqdrF1262OFs8rp9gptyvIxi3U2B7Rm sxVrJyh1bo+LFv5m
d0IsO64o13wXuhQBzhxEL4J5XRd++qvIQvzSJ5FtqyBQOYQ7I4t7q0ny8sh1 wJFHwOb2AgIMyIWu
DeaHzYtsZLwy3nadcp2N1ctJVMOdrpj9tQR0HtWD4Z/HZYgbYPelr3U0V5yj E3HfOx3U+va9x6Ft
95CUFDPQsd1mX8ojZMA9ZXX3lP818kZkHb7h0CMVE4bcErmNO2i0hPfXvxDp 7X2WwRtWzbnZbqBr
bNEvmVPaW+4vHkAeurdid+YR1erIM1EYDrDY8rKsOE1ndcjY6tDzSDJ7GT3K dfhdTm1xyIkPO7Fz
okdbKKGLQ54zHtLk2erp9EQ9rEf2i/1LKCJGoioeF0+JrDjR3b801NO3Tlzc qy0VlBTH1lC0CdnD
KkaDyUBjdF7H6RheYeUEZNCZExBdJcrMXA2yASHFFxPSA/kgJQiSHNr+O9BM yYr3r39skqLv0psb
pky5c0TXQ11X10/KbyX39O69Y8jYKdPuWkeKzp8AqV0VmcJ8DV53EspEZ4KV ej1ny9b7bRP0pTZe
THQnZusDtmxfkX6Y7Rr9GNtMYZa+Rv+99J3dOMiXnX6l78r0Cekbs7dmC8NS hg0oyR6jH5NSOmB6
yvQBtUJVStWAyuyO7BPpX6b81fdtutnp4O3dZHdXhtcqYLoYrKgoB1WiJtSB DqPjiO56rQyO5Lxe
k1Sa6pUlhz3Xnyv5Xa7jTqw4g85KZ4eTdbaZsB+lJqe9ZDpmOmmKmthkU4lp kokxubOy21Ly+nZ4
qB4q2npM7+lz9O0PuiZccZpei+POXbOTbh9qK7vpwEkSW5Vx5gMztdXhS99x mb9LP3RU28p1LiNe
3PnRmYZ37ji0/MnwR1t/9fXmJ1eu2L5z+dLtszxT/EOrZxd03o6LP74f4w33 d1xY+K9jS59hMt85
/NLbr7z6CmDvUdASui6pR9cF7Zpn0u+WSGKSHlwTCh2vYskTpjPXqJJqIJLH 0O+lyCOu+4GXcvZ0
1g9ff7rUU0mxP8qmXXiEybrwPnML9VZKno0YdlIfyQQW+2+gBQpe8rzJgk2p bs18BPe7i2abNrGb
dJuND5gOc4f5w8JbJtEUdBR5GKtoN3iUfDxcvxrfqdcNtlzLlgvl+lnG+/D9 0v3650m3/Lr+TePb
ygnmffEdw0fKZ5LFwvOMoBNFzPMQ9DKM3mQCeBuwyWRQ9KAdxKBnZEXiTcQk Ka+iV0Wi+JFoQ0hk
iOFVML1+mbHJMiOJIsMQXjGA34CkSRZsGWe4UU6VTCFevDEodeOE54P8ZL5D C5xHBY0qcyNJnQQD
HWdeEVu5PNtDnYFeD0S/nylnez6vuMwpoGa6Ij7lV8TfgSgymdbqtKk+doaL oL0WEbfbXUZXYpGe
ck2fWCSnOosYOOg9WGaFClKyF+HUlCIx6C3qc4rLtX0eamLBruY66SpRAbWw TDo24Vsim//02CBv
tn/v7yN349s/PjE88hXJwJF/j825Kvd8RO79Lb6mPFJB5VcQ/YIJaaulZUEl TBbwbaSdX2dYZ+ZF
gruxJ5jCJplEMQBuWEBfoVqxag1aJ1srrawVB9B4y/5yyhRqiM7R2B80pKeE RqzxPXfNkMT0YMQu
oalq3MKMl8t/fdOvj+Ktru0rRrXeyPz9grv7zYWf0L6I4PuOgb5I6Lvg1YM5 nIkyGL80WM6RK+Xb
dLeJG+XD8hlZr8qTZcISvQ6wLqo6zqbTcQhjlXA2QjgRE+4rVUI6MazDYaKj /NNnFE3W4Q7dRh3c
Yxw0kGBG0VyC7yJbCCE0xaxykzmSw1VyG7nD3BmO47rJur36yu2uLDeNzWkk Sg8XnaFB4B53j6uk
+AcrHbEFDRtd7EMmqTv6tz2iBdOLzka6o3+Nu1mQLQOyDbu4/KcZEpiXwH/C seU+TEb2vv47vHJQ
cupAvOHV3pe5g+d/39G0dCk74PsxwKn7EeJNdP0OtwdXIWKCBhJ07GJ5jfy6 zIjyOHmciRnA+g3Z
xlnMdexiw1LjWoNOTzhdkWGYcRIZz4wWgroyw1VG6X6ymdkkbNJtZ54SeAuB 6TWHI+DVEJ1sMORw
OiB18lTTVPpuCdHRr7bpwTk3KsBfUmnpsBDLQbIdGfCQPRy4mHhIUJJFSQ3K q/RYf5DMREashyfA
Y31QNGGkmpoUrHSTmc+rwGvN5ybb95pHlMf4DBbJ1VscW1UC2tN/c7oCuWB6 6/e76cej9GhrTRcd
bADexUWlF5EcPQ9u8QeIRD+IM16GZxka4w3Rf+02SjRVc4MM4NqmFBmzU4oM 4CvtLygyDi3QyH0D
IXVgn/fT0qx5T9SDiEkqxewzg1tjvh+n4etyHO58PBdzL0Rm7orMApH9/e6r Jz/IXPh+DPvW+Xz2
1HmVojwHbPdBbQVwUtDAkSSWoaEkz7FiN2ndq8YW4p7nVUwGM5gBeh/WrDZ9 qtu/OebdUNsNU1LF
54q2Q1zS9zJtPrXWxBpJZNdHEjjDzp3f/4O2ORl8lR6Ynz3oaHCsKONk7yjr KOc06zRnpbXS+SB5
kHnA8LjyuEfWGdzSQlLLLOTaZRpAQXwn7pf2ybIDsPUpYYypc02NplUwT2pz 77gcFESTtdmXvilx
Cp0BJTaZ9DBEi1cvuLys3mvCpjRjagJ9Y1OflQwxHMZ4nNeedkzAyZpnPCQh L74n1AOnlvgr1Acg
PAHd6Gk5G3+NyELfxx2sVJyGf32vC/a9aBLfCOl7n4daHqZ4d+K3z52I/LPl q9t2/jF5l3vV7HVP
P37Lwjvxrc7nj+FELD2Lyepd2xIW1b3y7gcv3wRezNWRWvDorkQK8qJfBe/X kyyS6RpBxpNlMl9i
L3GPd29M2prE5VnzEkqSRltHJwADE6qsVQmVSR1J7/HvWz7nv5K/dikDSKqc ZS8i+fI4MkaeTWrJ
h/JHrk8dX7k/T7hATJg12DzAHSNvA/4go9OYi+gekQkrpqCp0tRhYk1t5p/Y I0pMuswzibkl9J3U
H64VomZsjjNmWNwXuWyDKDvzvhkvRr5tfPfG3zQ/2pvy7NLWJ3ctbn8sUkt0 IybiQVjYGrn5yTu/
H8XsPHr0ldfe++A1iqEVkSmkknsXuHNFUEoHXVYsgk5RunHuXrTFCLqfGzQL W4zXI0ZhVIZhnjU/
vEETay9MD+e0rUvNZcIBYs4rGFaQywt06UbB+OS9vy2bfWj1svQrfOCYRqYc wv/Cxr+e6D1/vHz9
phdejCRHKP6tEPx3QPtOtDeYZBOxyT3YneMOupvcD8oPGXYYdB5DhqHTfdjN uqnNz/Ak5yXqDIxs
8krYTrJsVpYBH3yLDdui1iDr9LOIIffg2Kb2kPimtuRNzoPgDD3mch/CB1EK OoclBAw/BzMt6Bzo
Gpj/ngqqcMXUW+opMsecbZsCE6bA63hwLURLAjLzpgRMvezVq3EWGI2WXPpu cH5ewcW9TLudvie8
Z8sWq+fmxRPmJBQOnTr62DHmgQ3Ni/LGXGt5WBpTOW/DhflgvR6NTMHDtZ1y C9ocLIOYlhvB5nJr
OM6p4ziBZQnLWRFElwRcHNbM6QW6O67nBa/ZtBHG63R6ZNngl6SNepysL9FP 0jN6t9W28+KLTNoK
30RFe4UJlZRpcKIre/0b5ebc3LUK9VfolrNOMQV0ipSARaMQCyboe0x0Fx0X aCijc74A+FvTFalJ
HZZcMKwrd+R949iv3nnn3zdsNo67h51zfuuRsmqKKg/dYQf/UcLXP5/PYZRq LpKoJ2QwF4kOizdP
R08we369F644foUcfwiKSSl5KANOcPdlUEz15yEHnODuRHBfxqA8pMLJJA9A GeC9FKF86Wo0VpqJ
Z5Jy3SxxPp5PanW14lK0BC8hy3RLxSXSWryWrGFuE9bp1osPo/vFu6Vn0aPS i+h5Ybf0BvqNdAK9
L32DPpXOo7NStoQ4yYUcUgYKSAXSJASxNxe0OPK4oN6QJwk6nV+UbKIoAcj6 1q44SUJSbPOSFySR
QZgbLGM5VRcMBsUOkYjgfO4LwqRIOKCCokqCOFX/9e80B0vzOSvA6TxdEV9v 6nc7zUU/mgXBL2yu
yLrkD/XvJVrBS3wuUver0/5kV9Y3ByINbKD3lgWN0xeTdbF3HoJMFXkf9MyF 1gSvgVkc5JwgsZIo
02+0C7weExf9Lp6AWEbntBgEmLrot/O0L+cZZL2NFRgdlngOJgFFBfS9xHNI /wTfje+F6e4JFDRb
85Db3bRBi0Cyys7S0LW4t6IYog6Lsyi2oKZd+960AVfSGUgHczGswMkL1Mqn 80L6sIJAcNCWq634
bsa24NZBq5Zf0bh0+KRrChe3DV3N7ryzcMC+0VX35mXfmWnMXzdj0ro7rplx 1yA3HR/9VkkmaBOH
coMyJiyTxCGdNu2Sp4JGgTDxIIm/uJKgaE4+6DuNiWhUtOll8jvu4Pf/2PkD uyhnkAyFiJKCkUWk
llHawmBqGU1oC3O9yZhsJMZnLT9tF60+MNfpEIen59IXhxTSC6YjK/WK9OWr D80uOwY24BT+06ED
m9bP/t353hN/jfw9ooPWZ0Y/Zx3cYZSF3g1mcAaHodSwxsCWmq81L05gpjrq lIW2ake7YZltjWG9
7baEJwwSp2rvrejpbxSwAvYZZJjKH98bhMpewPRr5Qac3yXLdtZ1kDyO3KQm mGZP8nJs0gCDpXWu
2qgStUNoDQTppk0A05etSGDjQFc3LtzjfhcfxIXUqQ3q4bEKzgFBG7O78T27 b49/S+RsT2zl4mxF
bIck9oKV9rWAiy8F48LC2Juk/W/ugsEUCi7OYCD++D5Y7Ls4COKLmV3J9y5a tevRlbkTbBZ9a/ea
hbUbbF0pXz+39M1F86tv2hj58oNfR/HNrs1rO29asc32CFm6suqmW25R9722 YE/13IcGJb145+HI
d59Dj8Etx2vAJtE3kwqDKsshXhAJX8wyxZhnJVI8mH73hYJkm07bHTsb37FT evoWg4fkaC8VwXHg
6NGjTPnRoxeeOkp3kZvQn9kR7Cv09wyCcge5C2w3wYzAkRfIbHjMktl7uCBw cTLi8OSgHT3DPwOT
aTGPPDqVw1y7cO1saPDzCojai8t6kHuwpwf+XB4l1nj83TScT/+xIy7kM/hC lHmLrI6E9uISXLw3
Mp/ujIHVZRUt0jKgs8FhlllyjfyAvEN+Q+YmMBMMv2QZCyY6JEPMzUl6RkAw fxjeZFgbw7CMARHZ
AFr+AnkB6RDBW4MSYlnIgt6UQInmP89xUjAxGSwxLggahGCqL0/oSMkXNpoI nWMNBlseIgpRCUP2
GbvxBg0b31QAPrKyzsI0+7mi7fXBdHuuuO+loLWxxU+TydS3GG2A8NiiuehB fS5EzAOLGDYxsTi+
xFlB1yhtclBfJHdMLpKDAYirvXCNe/Ll1FXGudo3dRgzJpt6byEP/+LVV7si 4MA/wey/cM0TkW0g
mXt7F4FQZkS/YFO4J1ES+jqYON6zLHF94ibrU9ZX5A/kjxJ0otVlzPQwYg6X o6er6gwol2KV7Bar
9U2jyWa02owmA2hY0GqUkuxB41awAUZT0I7tdq+lm7zwvInF71Lt68auoI9N 8hrMc5VGZZVyl8Iq
oGkuTdNcGLkUF3FtVC2HcD4y4XtBTwv3GPf9lMYlX65xF3WOrmBpy1d0Owq8 6QqAzem1ukFZXHyp
QtM90L5LXpqP6ZsVAgsm9s0tOrMHZrxo31x3U9fODdduyNhxJ/mw9/lJt9x9 GOva7jj7ei/uUNbf
fuTRB/ZMKnGQvz0bWTwncu6d1+7ec4pij3LTDRaLrhX+Kpg33DPBEfRd57jW N5+pc9R7FviWe1Ym
bfDcnvSAY4fnkOdrx+fqOdV6heMRx04HM3xANU/SKZt9wGZXisqrGUmTjHMp T72pSTYOvztZi5Vq
uignkw/iIqTHhUHzD7iYDVa5sAvt87ea+3agVXPQTMwbs177oanquZRpPXEO afFHjEf0W3/pfGzp
D4FVgolQ253HeRejkaadjhWhaSsnD8PDXqjffwELr97Vc8Pyvz367Any1hNt S/fsWLFyG56mLG+Y
sOoPTbJr5iKs+8NJrDwQ+RTs/BeRvc+9xOQ9uP/IQxt27aI8bMHb2OEsr1mo scF0jsesICI/g/0M
Efwsy/tzCN5CjhFCXuKQR8RuHbUbE5XTsVdTwF7RN8yKNaOhbV3BsCB4pAEk O/xCIfM6PZjrt/c+
uL1PZmaQGX1faF8Xr7oVb3f0zB6i6n8FonDAYYHDBCKZx/JryTr9OtMbRk4U 9C5Sap1gv8Y9KmG6
dY59jntqwiJhkb7KWmdf5K5MWEaW8Iv1y01r+fuFTcobrhPkA/4D/UcmjyeJ 5WxJBoOzVdTkRte/
FfCQNiabW1G/wGJgT+oXWExcl268I23JhQrMqmghosNi14STHrAqVC5mhc4s /IxF725dvKftqoXv
bntv2d0HdqxYsWPHjSuuqSDvYhZf8ezcvZHoiUgk8srO+5/HD0fu+/YMrsEL /1q7hvoTKPoFKYL5
n0HTDoDyf7LHVkRfgw+qtqL7GEyYLcwuhjCLEbbRXwjCkE9ivkTkS0Dgjn1g h/cud9H97rOxhaXY
ohJdOYx9tdBO9012bIzMcnPffE9rQA8hxCVru9Jf77boKTPyrfY8HX3zR9DZ BEFHBIbRiSwhoqBj
GZXnuQpVj1X9ZH2lvknfoef0OlGNvZ8pQ8n4vnV5jImxt03PFms2GHqjvfIM 9pcdFHMtMd396dIF
x2h7RvvHFOmCQ2Pk0CIh1a0Nfb8byKExkqb6YgzR+4oEow0OK70/u98KZGKM TATSTsl/7bb3LXHi
uOeq2Wsw1Rg8Lx82P/QaQw6+diHCHTy/ml31/Ri243wHjKAYOCloVuWL4LAR 3Aj+Be4l/gXhNd0b
XmGcXC5PNy6Sq43LLcutt1kOWT7zfJZwxiO/pH/eShIUr5KoJCn8r6JnkAAw 1sFVjJ4JepIkRcfz
b3o9Nq/Xo/N6QJo6j5cxJCnUYZqkfW3Etc8AVgclgSEPmjCRpVbnuyAlilr8 AlmNVKSA+ZHN+0rI
XNJIVsGkcpCkoWR8V9xAUytDY8v41497NEco7gSvNQ7StvpiezqoD8uFNMhv 8dtTAgX0xfPLfSL6
JSYB/rHChQLi9D/2wLfbN99w00P4gPVf77x77uqnXn50TtLOnSOLqw7feOSz +Yt+8dB667EPv945
6+lDj68LDYntwHGzAV8m0PVbggE1GY/Sxb5KbVaSTEjnDKgiFj3JiUrcUU66 xFE+V3Hxa9RasDiM
SYjtP7E6lne7PC7C6yVZMkgMb3fYHFYHwycwzhRsMcLJpfOmYIdkTkGa+DPh bzWObdeBS0xfnjES
nz9laHzQ2p4d/vczs28sb2uduPzuo7dGduOiu58YUlp2X93EnZG3uYP2xAnz IseOPBWJ7AgN3Tls
SOlXT37+z8wk7WdN4CDvfDM6paFurqn4O12CTvu1k0c/Tc/s++UTGnkLi7n3 gBTjv/WllROujExE
oy7+QMoPfgYLvDWI9maiTWwrGk2KUBrQc1iEUuAogbTx/NNoLfcamg/0Wjiu wa+hm+FYR+/J0+hW
uI4R7kBuuK6B+5HczGiv9qwIHaS/fwP0Sb4IVcFRz36KtkNdPNS9Dtp5BJ7d DMdVQD8KaSY4CoAW
oc37IW8O3E+G51dDvSugLit+LUrzeZhEFIT0TTQdrjPh2QH2WdQEtAeOGdrx LGqhV9oHaPMhoIvh
CohBw9ABXIqfIW1MDfswdxX3IV/D/114V+fXLdH9TZwi/kX6VL9Sv1WeLH9p 4OEz0/CWcbGxUxls
zjHfatFbXrHqrF/aBtlesW+zf+RocPQ6r3AedGW4/uYOuW9zv+5p8Wz1fJqw 3JvifcV7PvG2xF8n
TUj6W3I4zv1iVAh2lf4RmKMGo6uAR7LUC2kE0sYwExGKP49oZ0YrJ2l3jFbK iHVxmkHXY0ecZpGE
2+I0h1z4xjjNQ/5NcVpAR/DjcVqHAqQmTotoPbkzTkvsy4wrTuvRPOFEnJbR fF1xnDbwXbpH47QR
zTHN7MfVKtOeOA2wUobEaYIEZVicZtBg5Yo4zUKeujjNIVlpjtM85F8ZpwU0 T7klTuuQFZyCGC2i
UuXfcVoiIfOVcVqPhli39P/aXa71eJw2MLNtTJw2okHOCugJZinXZeftGs1R iTjv02heS39KowUt
fa9G6zT6FY0WqYyc78ZpkJHrnTgNMnJ9FKdBRq6v4jTIyD02ToOM3FPiNMjI XRunQUbuJXEaZOQZ
EadBRp5QnAYZef4Sp0FGyTvjNMhINcVpkJHaHqdBRukDNFqi40q/VaP1dCzp d2u0rKVv02ijRsfq
VOhY0g9otBVoS/prGm3T8nyo0Xatns802qGlf6fRblo2A2t0As2TEetbIs2T kazRyRqdpdFpWv4C
jc7U6FKNHkg1I2MapXVa/+O01lbGXErLsfRFGq2NJWMJmo6WQQwbRvNRCFXB VUU74JiOajS6DDWi
Bjja4rlUsJKNqAVoeg5Beq2WQ4WUOig/CKjRWnro/2FNg/t7pqJp8KQOtffn aYW0cXCNtTcEFcEn
Bw2MU0O11JFQog6uU6HMAuhDm1ZqKtTXCkcLWgznasjVAs9DkJM+WQBt1MFd y496O/ySnOoP8g5H
M7UaW/tHQHtQCGcVZUBNtdDPFnjSCsd8qHHAJXX9p5IXc5QBHy7ePadxlPKr GkrWa+0vgjRa8/89
r1VIpSOqhZ60aT2ivFHhnuZpi9c6A+SgoslaeRUFtPbK4DwJ2p6v8TwE+Wm5 MNRKubxEK0lrG/QT
fYrJtxHapX1qgrzL/mOusIYrmm+J1qsF/e3WxlE7UJNLI5oX7/VE7UmNhpwQ 9Ca7v+8t2pNaDaHT
4Nyu9TomhxiaqARGaT1p07jcx7cW6IsKuUJxDMaQVKvxvlpDFsVag9bWpXip itcV0vpGS9ZrNdJ+
10D79VqNMe6rWq9DWntVcWnEntBet8blEdLGGCu3rF/+tXGUN8UlGNZ406oh Lza6PgmF4v1v11pT
tRYu7VWf5Clv6P0Sre6aS9BA8zZqdcXa7kuPcbstzpGqOFJbf5SvDeoMa1yp hWus7qp4SrvGaYqo
i5hu1DS2ReNonVae9pTKsz5eqq+FKq384nirtfGRxnSP1nCRC/M1Ha6Lp17k a22cu43xkdRq+du1
u4tSbdVQWqf17qcx0WdTW/vHQp/Va/VdrIPahkXx3obi/K/SrJ0a19I+nlVr bS/QUmPlqYbVxmVY
o+ldUxwjjXCmGr04zu1YDRetfEiTVQwdqsbDqvj4azWp1Wl5mjTdi6GxQSsZ G8ml6K7tRxbV/KVx
ydRrvaHYXBzXrZjdqevvR712dxG9bT+YiVp/ML6qeBvztBraNU5XX4bNMGqG 9D7Otmu/+9o3wvka
tlUNA0s13rZquGvrtycxqdO+x/S9LW41YtrUGkfZResZe1qvSSSElmvlY72m 9VZpTy8iLdZ6tcat
Jk1LlvWPoq/tBs1m0uchjRMt8TaoDsW42KaV7+txX+1NGobqNbvZ17dB2pzX Bs+Gw1w6GOqln0Fa
rkst7CDNOtVDjhpNl+qAqgeqQZNQWLtrRXM1DMQkPqg/5/+7LSzREBPLG76k lYlg6afDfD8GjlGA
PEpPglQ6A4yB8wQtvRRSpsGZYnMszASl8CnTUqcjg7YuLmm2pDauHz/0evrS Y3oS42hTnOcXMfo/
m8UuSqbPIvfJeZ72dBnkb+9vs6rftsXwfHE+utRaxizHRTsa09/auM1sjev0 Aq2WcL9NpNpaHm+N
avfiuC2d1z8bxdps+y+c6bOdS/qtUziuceF+TLdo9qMtrs/z43j8KX71aSHl WPiSWi5q8Y/bq47P
gBSB8zTLGOv1vLhkGuI1/5SE0rVRXc6pmEX+MSp+3HKfbaNWLKT5oCFotS7O 7da4DflPbVPuz4CU
i3Z22Y9kEY57GZf6XDHrHdJ61KRxtjbu6fxPZK7GsdhwiW3ra5dakmqN07WX zCItl/jI2f25Wy7B
7cW5+79zivauXqu/D1eNl9W3RJP/Ik2al/qhffbxYs5GyBvzUNs1jtP6a/rH E+vXpeiuj1vUGP9j
WtUUx8dFy3s5hv7biC7iY5w29h9Lrs/3onNOOO6hxUYT8/eqNKk2/EAGLT/g 98WaWzVvlXok1fF5
aLHmGy1Bl3pX/3vp99XXEvf/auOxzk95cT+WY4xbFz3WKq3OH+txn8RCP+D1 /P+j3l7k8o9buHy+
v7xH4bgX2wZzT18NND4ZiWKRQAb48HmoAGItFc5D4G4gRIh5cOQgukowA42P 58zRfhs9Dz4xugDl
wkFLDUP5EAvQg9b+fzbX/d/PjH3PBv+Ae/3z4fRlTeH5oaqwukOdXhNWyxob GtsgSR3V2NLU2BJq
q21sUJvqqgapo0Ntof9NpsG0MnVaY107TWlVxzVAuSFFRTkD4TR0kDqyrk6d Wrugpq1VnRpuDbcs
DlePbKkN1U0NL2ivC7X0VTtcS1TjqcNnhltaaQNDBxUOVTPKaqtaGlsb57cN 0HJd+lBLKJuuXbar
01tC1eH6UMsitXH+f+212hJeUNvaFm4JV6u1DWobZJ0xTZ0calMD6vQyddL8 +YPUUEO1Gq5rDS+p
gWyD+muC8TYuaAk11Sy7NCmsjm4JLaltWEDL1gJrB6pTG+dB1RNrq2oa60Kt 2bT2ltqq2pA6LdTe
UA1jADYVDh3V2NAWrqd9a1mmtoaAg8Ck2vlqdbi1dkFDthrjSxXkCtXCw/rG lrBa014faoDuq1U1
oZZQFQwDbmqrWmEcoQYVni2j468FljfBAMNV4dbWRmiODigE9bdX1ai18aro 4NsbwuqS2rYajQ31
jY3VtDSlodtt0JEqYGprX1rbknBDW20YclcB0d6ybJCqcbpxcbglBLJuawmH 2urhES1Q1Q7ybqWN
UemFW7QuzG+vqwNS6ys0X98IjdQ2VLe3tmlDbW1bVhe+lBMUqa20lXBLfW2D lqOlcRFUG4L+V7VD
QzEBVteGFjTS50tqgOdqTbiuCTjSqC6oXRzWMmiQD6l1wA61Pgy8a6itguyh pqYwsLGhKgyNxNhd
S5mlhpfCYOrDdctUGFsrYKeO1lFfW6exty2uRK3x9qqgxLyw2t4KkNK4GW5u p51tr6L8V+c3wpCh
RhhUWxvFCQy9JQxybwNogJhagWUaPOG2PrQgtLy2AaoOt1Vlx5gGxatrW5vq QstoE7R0Q3hJa1Oo
CboGWaqhi221rbRimr2ppbG+UattUE1bW9PwwYOXLFkyqD4O2EFVjfWDa9rq 6wbXt9H/42Rwfevc
EB34IJr4PyywJFwHqWGtyMRJ08eNGTdq5PRxkyaqk8aoE8aNKp04rVQdOXZq aWlZ6cTpBskgTa8B
tvZxjbKYygQ6CiNo0zj6EyqmDYYCmY553jJ1WWM7LVlF0QZ81vQoBksAh4ZR kC+oXwNkDy1oCYcp
Egep5VCsJgQwaJxH1QhKtl3WGYrOJRROYRBcmHK6JVzVBnKeD3y82C8qwsYF YS2LJuL+ciAaQO+8
9jaoGrrZCBp1yYDSW/s6BUDuZ0V/YYo2dXGorj00DxAWagWEXFp6kDqjQcPs sr5RwJjilgvgHVJb
m8JVtWB0fjxyFbjYoKGNlg1VV9dSTAAqWzSLnE2TWzTeatr9g07V1dbX0gFB I1q+JY0ti1pjINXw
qCU2LgGD2j6vrra1hrYDdcXYXQ9Ahf6DqJqWqTHwxjl0eUMaP8bNvzg4ar2a 28OtWjNg96rCLQ3x
EbTE+61lbq1pbK+rBh1aXBteEjNXPxo+zQeSDIMFqL5o4vrHCN3SDGtV20UZ 04GF4r2e/9PVal3u
LxDX+3hF0E6obTjNMGPaSJgEMgrzCgaoBUMKB+bk5eSI4ozxkJgzZEheHpwL cgvUgmH5RflFBuk/
aN1/VUZ6NzjePU0PIVRt1II86pTTEG0ZNsDEvxAcgK80t6Hv2TTNDaJBInXa qpkHmN3Mi8xLcBxg
DjLP/ryk//OSPvp5Sf/nJf2fl/R/XtL/eUn/5yX9n5f0f17S/3lJ/+cl/Z+X 9H9e0v95Sf//g0v6
l0X+F+mQlv+nnv3pB2XCl60JaKsC/6HOOg3hl9yzSewQdjw7lr0CzkWXtUBt 8H+qZaKmM9T2xEZf
gzvxNgZpevGfy/w03f8uL4qm029z/vhv5P9q7Ppj26ju+HvvjH1JSO2Y4mTk 4mfX8UHjUncmzG1S
4rOxl4I1JW2zLu6yJm2I1BWkVnLSSJPWXqVVWsVoEEjd1kmk4g+EhhBne8ou CVIyBdjI2Iq2LpPK
jxa2P8YfLJQ/xvqX93nvLoVqnbS7fL6f7/t+P+/HvXv+Ecl3FyN+pZWsA3VA IRw2CQwAo8AMMAt4
pU5EjgOngSXgM5kxlNbqcw8ZNuhpSbVjT6Vk8bBTHPmeLNa+U3L4W3sdzj/m yHoc2de7nfD2nMP3
b3M4GE+ZghubU8vZkBIi7yrix5cnYCl7g/gpJZxcUu4lFsAUrxsxlGCtU0/N LikeQhWmUMwpry8r
tNrckso2sjpbJ0HC2T/Zp06GfVrb1JKazT7OPiavAUuAwj7G/hH7iJxm18Vd fGAzwCywBFwG1gEv
u479GvYP2YdQfUCSQAYYBWaBJWAd8LEPYAPsffFrYGmFnwEYex82wN7DYb0H 62dX4V1lVzG0P1fT
u1Lz0kkkXYfHXae13XWCoZTN/lS9uZXb7G+1SIJfyu5gV4gFMHR2BY1fIRFg EBgDTgBeeGvw1ogJ
PAtcAizAizprqLOGOqvAO8Aa2QEYwCCgsner6MZml6t6jmdD7I/st6QVk/oH 9jvJ77C3JP+evSn5
bXAYvMreqoY5yTYhT1AnAA6Ak8jfxX5T6wzyeraFLWF6OGwSyAADwCgwA3jZ EttSfYIH0cgiWVUJ
lFXyieSXyIsqMY5xQ38UaywijN7zCDyY2ciszgz9ws9RFEY//xw8YfQf/QSe MPoPzsATRn/qJDxh
9CeOwRNGPzgKTxh9YAgejM1e+HXn/Tw98CSNZP1sGrM0jVmaxixNEw+bFju5 6RFj+0W1qwszdtFI
bO3i5gI1X6fmPmq+SM0Jap6i5hlq7qbmIWomqKlRM0xNg5qLdCemwqTGr24r 7jLaqLlKzVepWaam
Ts04NTupGaFpw2bR6mMPSSpIqmXF6wr8SF/KjzFGMaNRLOsoXvZLsJeBuiwZ EEW2OOKvhQVvqXVl
nPL2ntTx7B62goorOA0r5BrgwQlawTJaQSPi1+l+2AwwCiwD60CdiWt5r7Et GPiMtH7YJJABRoHT
wDrglcNZBxg57g7xNTmwpDvoAVFiK9jFU6mjLGp0BLRAIrBHmdGoP0wHwvUw S5OQuDoh2KK22LR5
7ovmf3/RTBqyDew8myEdOBHPujxTvdnBbfqzqr7Is/fSn5KwB6uO7iI6jYN3 krIsP0w0VXA30dgr
4FRVO8DF7Qv1bXyBbhK15vhN7e/8E81mcP+hLfK/RmwPrfK/IPLKHL+ineNv J20Vkdd1m4IWIlI6
r+3kr65K6RkkLlb5KUFz/IdaP39Sk4kJJ3GojJLh5/v0g3wP2strR7hRRptz PKMd4rsd1cOizhzf
gSEkHLcLg92qyU5jYdngt9M2PWps813wDfsGfN/wpXzbfFEf93X42n2b1aAa UDepd6uNqqp6VY/K
VKJuFpfDJ8TFFZu9AUHiWhpKPNIPMGGZc50JoyojjxPrHqXIivtztGgtj5Pi kYj1r/0xmzbuPWjd
FctRK1gkxaGctTNRtH31fVY6UbR8g98drlB6voSoxX5sUzI0bNO6CJ1tF4/U nSeUtpx9pl3wA2ef
KZVIW+hkpi0T7GvZ9c38HcyYa79yk4e22/wO60Jx/7D1y46SlRJOvaNUtJ4X z9ydp5/Tzwr5eXpD
UGl4Xumjnxf2ibjSly+VijY9IHUkQm9AhxVzQ+rUMIkIHYmoYUd30dHFUR+6 TkHQNTSQuNTFGxqk
zkOFrlLuLOQrnZ1S04qvnlJTbo18VbMahyYel5qQSValZjVkCo3VJyWaBklY kxJ6H9GkRKP3ScmB
LyVJV3LuluSc7EmhX2o0R9N8fUPTfB2axP+7TeQSCVrrLY2PiOcVj8UKE8CY 9fTJo22WeSQSqYyX
3AcZ62NHxo8KPjxhlWITeWs8lo9UekfukB4R6d5YvkJGCkPDlRFjIl/tNXoL scP5Uq1/sDt9W1/n
bvXVPXiHxgZFY92ir/70HdJpke4XfaVFX2nRV7/RL/sico0PDldUkis9OuJw jTU1Yr2OtUdLuVDg
RJ9cvL3RtlPtC/hC8jJpSpSsu2M5qxkQqQezD2ZFCq8pkdokHkrtptpO9Ubb F+jLbiqAcEssRxKT
U+Up0lb4ft75K2NDaHJKTLhjE+X/tSFXsIzD+fIkIUWra3/Ryuw9OFzx+RAd E4dk9WzEmpoKdn3Z
CW5HsEcEFeWWUMR2i1hDgyv87/M/5bK8JYHJFmvUCFP8U1dSrHBxiOGtYMh9 +u8Cvi6Jj4dyCQdY
pgla3mhDDpu4V7uK493A5JTrufMw6bJTC1XKG9Nxa0MdvFX9B5lWac4NCmVu ZHN0cmVhbQ0KZW5k
b2JqDQoNCjYgMCBvYmoNCjIwMzAyDQplbmRvYmoNCg0KNyAwIG9iag0KPDwg L1R5cGUgL0ZvbnRE
ZXNjcmlwdG9yDQogICAvRm9udE5hbWUgL0JBQUFBQStBcmlhbE1UDQogICAv RmxhZ3MgNA0KICAg
L0ZvbnRCQm94IFsgLTY2NCAtMzI0IDIwMjcgMTAzNyBdDQogICAvSXRhbGlj QW5nbGUgMA0KICAg
L0FzY2VudCA5MDUNCiAgIC9EZXNjZW50IC0yMTENCiAgIC9DYXBIZWlnaHQg MTAzNw0KICAgL1N0
ZW1WIDgwDQogICAvRm9udEZpbGUyIDUgMCBSDQo+Pg0KZW5kb2JqDQoNCjgg MCBvYmoNCjw8IC9M
ZW5ndGggNDg1DQogICAvRmlsdGVyIC9GbGF0ZURlY29kZSA+Pg0Kc3RyZWFt DQp4nF2U3Y6iQBCF
70l4h76cvZhIVzUyJobE0THxYn+yzj4AQuuSrEBavPDtF87pmWz2RnKo36/K YrE97A5dO5rFj9DX
Rz+ac9s1wd/6e6i9OflL26WJFdO09fgh8aiv1ZAmiyn++LiN/nrozr1Zr9PE mMXPyeE2hod52jT9
yX/By++h8aHtLubp1/bIV8f7MPzxV9+NJkuTsjSNP885v1bDt+rqzQLhz4dm 8mjHx/MU+I/L+2Pw
RvjCsre6b/xtqGofqu7i02SdZaVZ7/dlmviu+d+arxh1Ote/qzB728k7y5yU sxCI5R5CIQoH4SBy
hchpWUEsKWgpmCCHeKHYQaxYh24bWt4gXiksxJZiC7GjYJ03iheIPYuia5vR gkYtefICIvLQjTyC
dix5HIrayJNBkEfQmyWP0EIeZUzkwagseRyLksctIchT0BJ5XiHIkzN15MHc JPIgRuJ+aCFPgRkI
edwGIu4HRYU8DqRCnhzTkbgfbEHIU4BHyCNMHffDbHE/rBN5aCGP0EIeh80J eQSbU/Ioiip5FDFK
HsWslTyKRpU8CmwljzIbeRRwSh7FEJU8gpVo3A9Tk0fxP9C4H8cL+biE+Vhw 35+nWN9DmK4QnwFc
33x3bec/PxVDPyAu/vwFo7/6hQ0KZW5kc3RyZWFtDQplbmRvYmoNCg0KOSAw IG9iag0KPDwgL1R5
cGUgL0ZvbnQNCiAgIC9TdWJ0eXBlIC9UcnVlVHlwZQ0KICAgL0Jhc2VGb250 IC9CQUFBQUErQXJp
YWxNVA0KICAgL0ZpcnN0Q2hhciAwDQogICAvTGFzdENoYXIgNTkNCiAgIC9X aWR0aHMgWyA3NTAg
NjY2IDU1NiAyNzcgNjY2IDUwMCA1MDAgNTU2DQogICAgIDgzMyA3MjIgNTU2 IDU1NiAyMjIgMjIy
IDU1NiAzMzMNCiAgICAgNTU2IDk0MyA1NTYgMzMzIDY2NiA1NTYgMjc3IDI3 Nw0KICAgICA1NTYg
Nzc3IDc3NyA2MTAgNzIyIDUwMCA2NjYgNTU2DQogICAgIDU1NiA2NjYgNTAw IDUwMCA2NjYgODMz
IDYxMCA1MDANCiAgICAgNTU2IDMzMyAyNzcgMjIyIDUwMCAzODkgNTU2IDMz Mw0KICAgICA1NTYg
Mjc3IDU4MyA1NTYgNTU2IDU1NiA1ODMgNTU2DQogICAgIDI3NyA3MjIgNTU2 IDcyMiBdDQogICAv
Rm9udERlc2NyaXB0b3IgNyAwIFINCiAgIC9Ub1VuaWNvZGUgOCAwIFINCj4+ DQplbmRvYmoNCg0K
MTAgMCBvYmoNCjw8IC9MZW5ndGggMTEgMCBSDQogICAvRmlsdGVyIC9GbGF0 ZURlY29kZQ0KICAg
L0xlbmd0aDEgMjgzNTINCj4+DQpzdHJlYW0NCnic7b15fFvFtTg+M/deXe2S Ze1edGXZ8iLvluM4
MfF1YhuCSeIkTmoHTKzYSizwFltOCC1JyhZwWMK+N4EWSIEWxWaxE9KEpSzt 45EW2gKPljwKDaHk
S9rH1hJL3zOj6yWQ9tv3vr8/fp/PF4mZOTNzzsyZc86cOXOvI6KDw2GkR9sR h+TO3tBA36pl6xBC
/4YQtnRuikp/vflINsBHERLnrh/Y0Dt8DDUhpHEiJJy9oWfL+jFfZRwhYwdC nku7w6GuolX3mhEq
egfGmNMNDRfFLxcRKrZCPbu7N3rJLeb5EajPhXpPT39niO/L6IT6j6A+tzd0 ycCvzYdUUKf0Ul+o
N9zmOnkH1E8hVFI10D8U/R0qSCB0YZD2DwyGB/LuMt4F9RaEzD3QhuFLP3oA VbROOF5QiWqNVqc3
GE3mFEuq1WZ3OF1u9P/GR9iP0ll6GKXzfpSOUOL9qRSPJN6nfbQkH4GwMpJJ +Yyix9DvcB6W0Bj+
O3KgL7ELl6HFiEdfgLU8jibRbciKWtDt2IKykR2tQosxDzgBdB2+J7EpcRyd hW5GDySexpcnHoH+
G9GL6Evg4A88RlVoKeCvQmF0nPsAtSXuRmq0A+nQfLQC21EI/Ra+nwEPt6Bb 0c/w9xJfwqxWdDmM
V4PqUF3i
Re: turn classloading on the server-side upside down [message #59534 is a reply to message #59449] Thu, 02 February 2006 16:13 Go to previous message
Originally posted by: simon.kaegi.cognos.com
Hi Martin,
I definitely would like to tighten "org.osgi.framework.bootdelegation".
(Off the top of my head... down to the servlet API, and the relevant
pieces of the servlet bridge and then configurable for anything else
needed. If you do any experimentation here please post your results.)
This would give you something pretty close to the classloader described in
your classloader doc. The missing piece would be the last resort look-up
through the appserver's various loaders.
I really liked your diagrams. Could you send me a copy of the top picture?
Thanks.
-Simon
Previous Topic:equinox all-in-one
Next Topic:Thoughts about servlets, resources, httpcontexts extension points
Current Time: Fri Jul 18 19:12:55 EDT 2025
Powered by FUDForum. Page generated in 0.07211 seconds
