Home » Eclipse Projects » Mylyn » Query not showing
Query not showing [message #59439] Mon, 06 October 2008 07:26 Go to next message
Hello everybody,
could somebody please help me with this problem:
I am using Mylyn 2.1.0.v20070927-0900 with Eclipse 3.3.2 and Bugzilla
3.0.5. Eclipse is running on Windows XP. When I enter queries for Bugzilla
some are shown and some not. I query Bugzilla seperately for all my P1
bugs, P2 bugs etc. It works fine for P1, P2 and P4 but doesn't work for P7
and P9. The query is shown shortly in the Task List view but then
disappears. Does that version of Mylyn have a problem with the Bugzilla
version?
Anyway, the strange thing is that when I try to recreate the query with
the same name I am told that the query already exists, but I can't see it.
When I import all queries from the tasklist.xml.zip file I get a message
that the P7 and P9 queries were imported but again they don't show up in
the task list.
Is there any way that I can get my P7 and P9 queries to show?
Kind regards
Bianca
Re: Query not showing [message #59464 is a reply to message #59439] Mon, 06 October 2008 10:49 Go to previous messageGo to next message
I noticed one more thing...
When I edit the task working set I can choose the queries that are not
shown in the task list. But I still cannot see the queries in the task
list when I create a working set that contains them...
Bianca
Re: Query not showing [message #64132 is a reply to message #59464] Sun, 11 January 2009 23:03 Go to previous message
Originally posted by: rob.elves.eclipse.org
Bianca,
The Bugzilla Connector doesn't currently support custom priority levels.
Only P1 - P5 are recognized and supported.Consider adding yourself
to the cc of the following bug report:
242739: add support for custom priority levels (ie. if not using P1-P5)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242739
The problems you are experiencing related to queries should all be fixed
as of the 3.x stream. Please update to the latest and report these as
bugs if you experience them again.
-Rob
> Regards
> Bianca
Re: Query not showing [message #593968 is a reply to message #59439] Mon, 06 October 2008 10:49 Go to previous message
Bianca
Re: Query not showing [message #595710 is a reply to message #59464] Sun, 11 January 2009 23:03 Go to previous message
Bianca,
-Rob
> Regards
> Bianca
Previous Topic:Mylyn source path
Next Topic:Re: Mylyn New Local Task Failure
Current Time: Mon Jul 21 22:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.08036 seconds
