epl-v10 Question [message #59376] |
Mon, 13 July 2009 09:13  |
I would like to create a (probably renamed) variant of Class XMLMemento
(and inteface IMemento) that is not dependent on package
org.eclipse.ui.internal, and would package the modified class as a jar
to be used:
1. In junit test cases in launched from eclipse, but not running in the
plugin environment.
2. In external tools launched from eclipse.
3. In java applications completely separate from eclipse.
Can I acomplish this without violating the the terms of epl-v10, under
which XMLMemento is currently distributed?
Bill Winspur
Re: epl-v10 Question [message #59424 is a reply to message #59400] |
Mon, 13 July 2009 11:29   |
Ed Merks wrote:
> Bill,
> Ask your lawyer if you want legal advice. :-P
> My free non-legal advice is that as long as you make the source code of
> your modified variant publicly available, you're doing exactly what's
> required.
>> XMLMemento (and inteface IMemento) that is not dependent on package
>> to be used:
>> plugin environment.
>> Bill Winspur
Thanks Ed,
However, being a recluse by nature, I have never made code publicly
available. In all seriousness, could you suggest a low-cost way that I
could do that?
Bill
Re: epl-v10 Question [message #59448 is a reply to message #59424] |
Mon, 13 July 2009 12:04   |
Bill,
Dump it in a zip file and have a link for it only any publicly
accessible website. Or open a bugzilla, and dump it there; even if it's
closed or rejected, it will still be recorded...
Bill Winspur wrote:
> Ed Merks wrote:
>> Bill,
>> of your modified variant publicly available, you're doing exactly
>> what's required.
>>> jar to be used:
>>> plugin environment.
>>> under which XMLMemento is currently distributed?
>>> Bill Winspur
> Thanks Ed,
> could do that?
> Bill
Re: epl-v10 Question [message #59473 is a reply to message #59448] |
Mon, 13 July 2009 13:04  |
Ed Merks wrote:
> Bill,
> Bill Winspur wrote:
>> Ed Merks wrote:
>>> Bill,
>>> what's required.
>>>> jar to be used:
>>>> plugin environment.
>>>> Bill Winspur
>> Thanks Ed,
>> could do that?
>> Bill
Will do, one of those. Thanks, Bill.
FUDForum. Page generated in 0.07591 seconds
