Adding CIMOM as a data source : Building DTP [message #587640] |
Mon, 27 August 2007 12:04 |
Originally posted by: nyogita.novell.com
We are exploring the idea of having CIMOM as a data source type in BIRT.
Since this is extending the available data sources , we would need to
add this to org.eclipse.datatools.enablement.oda project.
However we are not successful in building DTP.
We have checked out build, connectivity, enablement, modelbase and
sqltools projects.[1.5 version]
We looked up http://wiki.eclipse.org/DTP_1.5.x_Build_Guidelines page.
Currently on running ant from the org.eclipse.datatools.build folder, we
get a build failed error, at
org.eclipse.datatools.build\org.eclipse.datatools.modelbase. build\build.xml:19:
The following error occurred while executing this line:
\org.eclipse.datatools.modelbase.sql\build.xml
(The system cannot find the path specified)
Since the modelbase.sql does not have a build.xml, are we missing
something here ?
What is the right way to build DTP ?
Yogita.
FUDForum. Page generated in 0.03522 seconds
