Home » Eclipse Projects » Plugin Development Environment (PDE) » Using p2.inf to create a directory
Using p2.inf to create a directory [message #59353] Sat, 02 May 2009 14:29 Go to next message
I have the following line in the /META-INF/p2.inf of a bundle:
instructions.install = mkdir(path:dropins);
This results in a "dropins" dir being created -- in the dir from which the
build is being run. But what I want is to have this dir appear in the
product, i.e. the zip files that the headless build creates for the RCP
application.
Using path:@artifact/dropins instead, I don't see any dir created.
Suggestions? I know there is a way to add files and directories via
features, but I'd rather not have to create feature projects just for
adding this one empty directory...
Re: Using p2.inf to create a directory [message #59810 is a reply to message #59353] Wed, 06 May 2009 18:22 Go to previous messageGo to next message
Try
instructions.install = mkdir(path:${installFolder}/dropins);
I'm not sure that the feature contributed rootfiles will do empty
directories. So this is probably the best method.
-Andrew
> the build is being run. But what I want is to have this dir appear in
> the product, i.e. the zip files that the headless build creates for the
> RCP application.
Re: Using p2.inf to create a directory [message #59882 is a reply to message #59810] Wed, 06 May 2009 20:56 Go to previous message
Thanks, that works!
Re: Using p2.inf to create a directory [message #596871 is a reply to message #59353] Wed, 06 May 2009 18:22 Go to previous message
Try
-Andrew
> RCP application.
Re: Using p2.inf to create a directory [message #596894 is a reply to message #59810] Wed, 06 May 2009 20:56 Go to previous message
Thanks, that works!
Previous Topic:Issue in building feature - Eclipse 3.4.1
Next Topic:Problems with product plug-in start level configuration form
Current Time: Thu Jul 17 00:52:00 EDT 2025
Powered by FUDForum. Page generated in 0.06406 seconds
