Home » Eclipse Projects » Nebula » GridViewer - Resources
GridViewer - Resources [message #59341] |
Wed, 24 September 2008 04:24  |
Hello there.
We are just investigating the resource usage of the GridViewer. And our
test case uses 400k records. Ok now somebody could say, who the hell
needs 400k records at all? Well I also would say thats insane, but
unfortunately the customers requires it.
When displaying 400k records this single table uses about 700MB heap
space. So with in an RCP application thats not a valid approach, since
more than one editor can be opened.
Is there a way ti get the GridViewer to use less resources, eg with
paging or even better a sliding window as the CompositeTable does,
because some GridViewer-features are very cool, and it would be a pitty
if it can't be used in large database applications.
Peter
Re: GridViewer - Resources [message #59441 is a reply to message #59341] |
Wed, 24 September 2008 17:34   |
Hi Peter,
Well the current Grid-Design is that a GridItem for every row you show
is created. So you have 400.000 Items if you want or not :-(. The
question now is the problem the data that is stored in the GridItem
(e.g. the many many strings, ....)?
Does the Grid also consume so many resources if you return and empty
string for all Labels? If it doesn't then Grid since about a week
provides a cool new feature where it informs you about the change of the
visible cells (the initial intention of this feature was to manage
Image-Handles but it could be used to clean your items string data).
The new features are part of an extra branch named "header_footer" in CVS.
Tom
Peter Pfeifer schrieb:
> Hello there.
> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridViewer - Resources [message #59492 is a reply to message #59441] |
Fri, 26 September 2008 03:17   |
Hi Tom,
Would it be also possible to remove the propertychange support and all
the things needed for databinding, when the items aren't displayed?
This would also help to save a lot of resources...
Thx,
Peter
Tom Schindl schrieb:
> Hi Peter,
> Tom
>> Hello there.
>> Regards,
>> Peter
Re: GridViewer - Resources [message #59612 is a reply to message #59492] |
Sun, 28 September 2008 11:17   |
Maybe use the POJOObservables instead? If you always go from View to
Model it is not needed!
Tom
> Hi Tom,
> Thx,
> Peter
>> Hi Peter,
>> CVS.
>> Tom
>>> Hello there.
>>> Regards,
>>> Peter
Re: GridViewer - Resources [message #59636 is a reply to message #59612] |
Mon, 29 September 2008 06:31   |
I think you can have both the only thing you need to do is to use a
special modified list as input to the observable map and not the one
you'll receive from the content provider.
This list has to be modified depending informations you receive from the
Grid with its new API and when a new value row is shown also call
viewer#update(). This way you only have PropertyChangeListener for the
currently active rows.
I'll try to create an example implementation for you when I have time.
Tom
> Tom
>> Hi Tom,
>> Thx,
>> Peter
>>> Hi Peter,
>>> CVS.
>>> Tom
>>>> Hello there.
>>>> Regards,
>>>> Peter
Re: GridViewer - Resources [message #59755 is a reply to message #59636] |
Tue, 30 September 2008 01:04  |
Hi Tom.
Thank you very much for your answer. Take your time, i'll wait for the
example implementation.
Greeting to Tyrol.
Peter
> Tom
>> Tom
>>> Hi Tom,
>>> Thx,
>>> Peter
>>>> Hi Peter,
>>>> CVS.
>>>> Tom
>>>>> Hello there.
>>>>> Regards,
>>>>> Peter
Re: GridViewer - Resources [message #592334 is a reply to message #59341] |
Hi Peter,
Tom
> Hello there.
> Peter
Re: GridViewer - Resources [message #592349 is a reply to message #59441] |
Hi Tom,
Thx,
Peter
> Hi Peter,
> Tom
>> Hello there.
>> Regards,
>> Peter
Re: GridViewer - Resources [message #592390 is a reply to message #59492] |
Tom
> Hi Tom,
> Thx,
> Peter
>> Hi Peter,
>> CVS.
>> Tom
>>> Hello there.
>>> Regards,
>>> Peter
Re: GridViewer - Resources [message #592398 is a reply to message #59612] |
Tom
> Tom
>> Hi Tom,
>> Thx,
>> Peter
>>> Hi Peter,
>>> CVS.
>>> Tom
>>>> Hello there.
>>>> Regards,
>>>> Peter
Re: GridViewer - Resources [message #592450 is a reply to message #59636] |
Hi Tom.
Greeting to Tyrol.
Peter
> Tom
>> Tom
>>> Hi Tom,
>>> Thx,
>>> Peter
>>>> Hi Peter,
>>>> CVS.
>>>> Tom
>>>>> Hello there.
>>>>> Regards,
>>>>> Peter
Current Time: Sun Aug 31 21:14:21 EDT 2025
Powered by FUDForum. Page generated in 0.23613 seconds
