Home » Language IDEs » ServerTools (WTP) » how to deploy a project with multiple depencent projects?
how to deploy a project with multiple depencent projects? [message #59331] Thu, 30 December 2004 22:09 Go to next message
I have a web projected setup in the workspace, which refered to another
two java projects(framework project & tags project), Compiling is
pleasant, now it's time to deploy the web project to tomcat. At runtime
tomcat complains NoClassDefFoundError of the dependencies. Frustrated
alot...
btw, the WST always reports UPDATING JSP INDEX error when i trying to save
jsps. why?
tks alot if anyone can provide help.
Re: how to deploy a project with multiple depencent projects? [message #59363 is a reply to message #59331] Thu, 30 December 2004 22:13 Go to previous messageGo to next message
here is my environment: Eclipse 3.0.1, WST 1.0.0 and Tomcat 5.5, jdk 5.0
Re: how to deploy a project with multiple depencent projects? [message #59460 is a reply to message #59363] Fri, 31 December 2004 01:16 Go to previous messageGo to next message
Originally posted by: dgolender.nospam.hotmail.com
The only way I have found to get this to work so far, is to JAR up the
dependent Java projects into the WEB-INF/lib folder. With the Sysdeo Tomcat
plugin you could use the devloader they included to dynamically refer to
dependent Java projects. In IBM's WSAD, they allow you to reference
dependent Java projects in the enterprise app deployment descriptor. But
nothing like thos seem to be included yet.
Doug
"kevin" <caozj@sunline.cn> wrote in message
news:cr2g4i$38v$1@www.eclipse.org...
Re: how to deploy a project with multiple depencent projects? [message #59484 is a reply to message #59460] Fri, 31 December 2004 04:46 Go to previous messageGo to next message
Thank you very much for the reply. I used to work with vaj&wsad since long
ago and it was my favorite IDE. Yet i like open source more. Hope WTP gets
stronger enough soon, I can't wait to see wonders happen.
Re: how to deploy a project with multiple depencent projects? [message #59895 is a reply to message #59460] Tue, 04 January 2005 08:38 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Is there any plan to include the Utility JAR concept from WSAD to WTP?
Thanks in advance,
Chemi.
>Doug
Re: how to deploy a project with multiple depencent projects? [message #61272 is a reply to message #59895] Wed, 05 January 2005 09:55 Go to previous message
Hi Chemi,
That concept should be introduced with the flexible project structure to
be released in M3. Right now I know we have it planned for the case where an
EAR references the Utility Java Project, and the dependencies for modules
are routed through those libaries. We should also be able to include the
Utility Java Project concept directly for Web Modules as well.
Thank you for your participation.
Kind Regards,
Michael D. Elder
"Chemi" <jmordax@terra.es> wrote in message
news:cre687$7e7$3@www.eclipse.org...
> Thanks in advance,
> Chemi.
Tomcat
> >Doug
Previous Topic:Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML
Next Topic:XML document with <project> root element causes xml editor problems.
Current Time: Thu Jul 24 19:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.17759 seconds
