RAP controls demo doesn't work as expected - NullPointerException... [message #59292] |
Mon, 12 November 2007 05:24  |
------=_NextPart_000_004A_01C8251E.A82458A0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
Hi - something seems faulty with the RAP demo. After unzipping RAP to a
new directory, defining that directory as PDE target and then launching
RAP as described (e.g,. in the DeveloperWorks article
http://www.ibm.com/developerworks/opensource/library/os-ecli pse-richajax1/?ca=dgr-eclipse-1) I
get faulty displays, both in IE7.0 as well as in Firefox.
Some stuff is showing, the main window, some frames and text, but most
other stuff like buttons and fields are missing (see the attached
screenshots).
On the console I see a NullPointerException:
osgi> Nov 12, 2007 11:10:23 AM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
Nov 12, 2007 11:10:23 AM org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@1a5e1a5e
INFO: Started HttpContext[/,/]
Nov 12, 2007 11:10:23 AM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:8000
INFO: Started org.mortbay.http.HttpServer@60f060f0
Nov 12, 2007 11:10:29 AM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap/resource/widget/rap/display/bg.gif:
org.eclipse.rwt.internal.lifecycle.HtmlResponseWriter.closeE lementIfStarted(HtmlResponseWriter.java:689)
org.eclipse.rwt.internal.lifecycle.HtmlResponseWriter.startE lement(HtmlResponseWriter.java:489)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.sendMultipleClientsPerSessionPage(RWTLifeCycleServiceH andlerSync.java:163)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:75 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.access$0(RWTLifeCycleServiceHandlerSync.java:48)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$1.service(RWTLifeCycleServiceHandlerSync.java:43)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHandlerProcessor.run(RWTLifeCycleBlockControl.java:68 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olRunnable.run(RWTLifeCycleThreadPool.java:38)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olWorker.run(RWTLifeCycleThreadPool.java:66)
Nov 12, 2007 11:10:37 AM org.mortbay.jetty.servlet.ServletHandler handle
I tried this with both, the 1.0 release
("rap-1.0-R-target-3.3-20071010-2241.zip for Eclipse 3.3") as well as
the latest integration build ("rap-1.0.1-I-target-3.3-20071109-1244.zip
for Eclipse 3.3") - same result for both.
Any ideas? What is missing or any hint, why this fails and/or how to fix
this?
Michael
Content-Type: image/png;
name="RAP-demo-IE7.0.PNG"
Content-Disposition: attachment;
filename="RAP-demo-IE7.0.PNG"
iVBORw0KGgoAAAANSUhEUgAAA5UAAAM3CAIAAAAiHuNhAAAABGdBTUEAALGP C/xhBQAA/8dJREFU
eF7snQd4HNX19hcIgfzzpRKcOAVCT0gCmJJAwKGXhF5Mx3Qwpppm0zFgmm3c e++9V7nKvVtu6tXq
0kpb1G1J1ndm7szduzOzVVtmVu8+51nP3rn1vTO7Px+dufekn/3sZzbhVfuf 5JNOOoUS2ppPk5JP
OUk5+ePTpePTTrH96BRbSyu9n3TKKW2tbbaWE7aTT7adbLOdUGtpoQ94QQEo EHEFpBsTLygABSKm
wEnHI1YVKoICUIAp0Cb+VNFxq5cwx9gnuvV+bDveYvuxzI7HT7b9+EdSmq1F smaZPE9ts9l+JGf+
ka25zXasvC35H15VEb+y10l3HSD78ct1p73desaHbb//QrLz+rVdNLCty4C2 LsPb/j1Esq4jJLt+
lE9jGWBQAApEVgE/Nx1OQQEoEIYCkb1DURsUgAKGiEiJjB75O+NJvUm06W1E oWQEpT9+rcV2/SFb
l+3OqjSnPZ3MxuH15KcqCF5Pfs192rsnKCtH2HO+ayMjiv3bYI8RzjITE3EM BaAAFIACUAAKQAEo
0GEVIFxkxhRgxwxDmUuUUSU3ShQ/MucpN4ajZKe92Upme7TWdu0hhz2NTOJX 2427bfcV2h7MOulF
O5nt5WpmxLKnvFF/ypvHiWht77Se8nYbGTumd57IDljij3udIPctywmDAlAA CkABKGBaBU567QQM
CkCByCpA9ztVyKCRwSGzk3oeP/nFY6f0qDvlRfdJz9Tbnq6xPS6/P1FDH5WU Zxw2Zk9WSe90tlul
7VG7ZJRC9lCR7ebDtq45Ar/euc/2eL7HupfZnqtgLEsUy0xiWR8mnaU+cXvR Tf2DQQEoAAWgABSA
AlAACnRoBZ6vOoXsWftJz1bSn/rJbI+X2R4tlaxbiWIEpswePCrZfQVkJ92d Y/sfWYbt9nTJ6IDg
9V97bL+bJ/Gr7fJN0mni1wezFGMgKyMsp1jFKftKjY2b6qalUxLpitTMMBkG BaBAJBWosD0JgwJQ
AApAAShgbgUITzXGUFWHpyqhqpxKhMqMASvRKhmFvXbdqxjBK1Er2ZmTZX4l u3E3Pbzli19ZXIEY
WsCYVUohN+2zlbbuFZLRjyvrMcNqGBSAAlAACkABKAAFoECcFDj18ZKXRtpL qpvbQnxRKSrLQC78
SobbT31Y9qreV3jqAwUvDSkrqQq9J9/kn3rtXsnt2mW7xKsXr7JdOF/m1/Nn GvFrseh/5fzKmVXA
1jIpJwdtjUOYe4ZxAAWgQDsV4H9ewQEUgAIRUYD9pRIGBRJXgZeGVeSUtL4z tumZAY3dvmq4+9OG
Oz6sv+n9+lv61P/nHcmu7SXZFa/VkV3Ws+4vL9Sd/ZTzypcLDmXXUFl2d7S3 EnrC6j4JXo8fzbH3
f6fio2fKenUr7Xl3yUt3FD97U/HztxQ//R+yoievJSt8+ArJHrys4O6/5Nx6 9oEHr3RmHHrpm3wJ
Xhm/npskgevPP7FRGIH0uevek28V/a8Sv0qOVeZelWNhJXu28rYvd0+f+cHu ef/dPfuGT77//NxX
Dmh9rhH5WkElUAAKQAEoAAWiqkDiUgugHAowBcjr+v74psGLjg1feqzfrKb3 xje9Maqpx9DGlwY3
PvdD49MDGrv3b3zs24aH+zXc90XDfz+uv/69+stfrTnvyaLLntxGvtLIVCIH s1JPqga+75w22DVz
uGNsP/vA9yq/eaOyb4+Kz16q+Pi58g+eLv+ge/l7j5W9/XDpG/eV9Phv8TPX F3S7/MBt562887KS
yuOK//XvOw34VQo1oBBYKfhVdr52l8iV7Ec90zt9fODsScWXzS8akPR22Zbb xo564LZH/3v9Pfe9
+MLtfX/4Usuv7XQyoTgUgAKGCkT1hxyVQ4EOqAD4FQokugJEjS8Obhy1/NjY Vce/m3vsw8lNb49t
en0EIWzTi4MkhH12YONT3zc+9k3DA1823PVpw8296//1Rs1fni4687YkKsv5 tV2VEL/eKfFrxWcv
uuaMcs8f65jwXdWQD+39367s93pF3x7ln75ICFvx0bPlvZ8qf/ex0jcfKOl5 V/HzNx997F+H/veX
uVecKfWE4gfIiF//vFPwv5JLlsJjKWCW2qCvMAoGoEhWimd9osD25uG/L23r vv/EsIzNbTnvtaXf
/fZbt7zzxct39BrHAl57f9Ddi19BHlAACkABKAAFoAAUgAImUIDI79GvG4hc By449tm0pl5jmnoO
a3rhh8buxKxfNz70RcP9nzfc+XH9/z6WIgrI+frvt+uufK3m4meLfnfHWoka 5SG0t5K7ixi/lr/7
KJGrc8rA6hGf2b/vVfllz4pPXijv073sncfK3nyo9PX7S3rcWdLjf1JEwTPX Fz3574KHrzx018Xz
//k7qSf/PCQZ41eKf1XiB3zx6xuHLl3e9uSetjX7+ral3rxx7oU9nr39nYFf v3yorXda25Xvrfz5
M8uueuA18KtnAQgTXKzoDBSAAlAACkABKAAFGHo+8EXDB5OaPp4iwevLQ5qe oYCBfo0P9m24+6OG
23rX3/hO/b/frLv6DcLWustfq+vyat1lr7j//lzxn+5aJ/KrWEnAJ8G0laj8 WvbmA1VDPqga9jHB
a+PezVRP2duPlb3+YEmPu4tfuK346RuLnvh30WNXU3rt2gWF3brkP3jZ4Xv+ vuDff/LBr79fJ7lk
ryX/a47kKCYCk/2vP3o57dQ5J+7Z2XYk563WQ9dMGf7n/115XtfHPvnLhJIb lp14Yt+JxzefuLrX
ItsTW0R+1Y9KcwFxOTjUi0V8XW3B5InxlaoZaVxa542KqrKOifIG3zexbPCl gswZ1cqD7IP/bO2f
U/OPMSJCoRIokCAK3F9ig0GBhFaAfpXomS2KeX1L9rw+N6DpCXK7ft5I8Hp7 74Yb3iZ4rb/y9brL
Xq37xyt1f3+l/h+v1F/ySs3fny9R+FUWR1NJQH7VVqLyKz2zZf/mDfv3b5Hn lVciw+vtxU/fQPBa
+PCVPL3wgX/kP3DJ4buN+FV5fov4lVyyN8iLb1HwAPHrY+XErye/sfOva5ry Cj5u3vvP5PFndL/2
p2c+toGWnz33iSm/Hdl06awTj+xp6Tqu5sdXfizlZ/ZoKWv4/373JTPNzznv lghePL+v336xzvbA
WXhI5x+pDYcZg292rgkfFPVEHCD7qMkWsGOh5g9YoZghmMpjwH9+mtBcvVzS 4IcZzBiDrw05oQAU
gAJQAAq0RwH6Vbrtg3qKdiV4fXFQU/fvGh/5svG+Txv+90HDze/Vd+1V/883 6i59tf5vr9T/5eX6
i16qv7hH/d9fqbn4ueI/3rVe9IWJlQTkV20lKr+WvHgbRbtKYQOfvljeuzuv p/jZm4uf6lr06D89
8HrPRYX3XVxw/98P333xgmv+KPXk6gwJVv96QIgfEPmVQJvx6yMF57y1ePW2 T5r331K24Kd/vfLS
n3R96MfXvHHqDe+dct2bv3g25+fvtz24uKXrcPcpf+t5ylO0VUEFQ1g9VzE8 FdFKn6LJoJkqTZ0M
GcOAMz3etfOa0A+kPRWGWpZzmPi/ApHAWIVcrmDqjyp+BVN5MHmCGYifPH6a aH/r7a+hnaNDcSgA
BaAAFIACXAHGr7R41nMDpciBJ76hmNfGez5uuL1Pw43v1v+7V/2Vb9T949X6 v7xSf/7L9ee+VH/B
y/V/7VHz1+eL/3Cnll95JVSnn0rorLaSO5X4V+LX8g+fKafVBuj93SfK3niI AwxFu3rg9e7zC+88
t/DuCwru++uRu/668Jo/KPx6VYYPfqUFumj1Vtn5+uvnDg2Z+G5rerfmdWde dcettsuet41qsI0/
ZpvcYpvSZBtZZRta+vvZ7lMGNZzy15dkfq2Sdqf14tdK2rVW+DlXPjKnrAyg xhnEs2Ie+f8BUhFN
Ik8X/0PgK5s+j0qBns7o69c0HbDnAXviv8/iMP0cc215c9zhzeQVuFYZnT7R cLCa4qy3olDso0Zk
X5VrsvHKDXuo77MmRSwlymjYuq/p1ozFsIeiMn5GqpeFX8ABLwNfV7LhGIO8 KpANCkABKAAFoID4
s3Xd23W0vAAtMvDUd9IzWxT5es+nDbd/WH9jn/p/v1t/5dv1f3+z/qLX6s/r 2fDnVxrO7VF/wSs1
FzxX2vnODeKPrFgJpfuphM5qKyH/691FlF701HW0vIC0yMD7T1Hka+mbD5a8 eo/4W0nHxfdfVHzv
eUV3/bno7nOP3ntB6v8uWPSvzh5+ZS5Y2sJAen6LnuQir+xtxVIYENEhYeiT VY+NWLRl6zvNWy4c
9NXVtnOftD0wzvboONtdC2z3T5fsnvG2mwbZbvzW1vWLk/72CvErR1gPsFI9 j9rFjxrekhryzqD/
yPLwdGkAaoqYWUIiOd3rr/ne9StUIbTIShn2UFO5wihC0wF7rukJb0VETH2i OLqAx6Ke/H8FAfVn
KokjCr5vvJSHKQUBDefXcL64ekF2xleHNXOqqc2XvGK6RmQv4vS+9gwvCf/X G+ue/84H7CQfo9RV
4f9vOIYCUAAKQAEoEFAB+hH51xt19/dteKSfBK/0/gA9uUX8+lHDjR80XNu7 /sp36//+dsOFbzac
+3rDWa82nN2z4Zyetec8V9rpv178KlZCdfqphM5qK7nfzoJoix77V9nr95e/ /Ug5LTjQ65HSNx6Q
djF4+Xb+41vyyN9LHryw5L5zS+4+q+TuswvvOSftv+csuqqThH9dc2z/zrQx FyytP3BGf29+leH1
Fz2Kvl82qn7H1bUrfnnKv3vZ7hlk6zH7tO45P365jtspL7pPecZjtidqJHvU oeFoSlH+fq2e8vIR
Com8LM9PKaIJzKSkC6wmpWialvFUSWTH+hRNBrFCX8e8S4YZxCZ4f3wNOWAT GgUMBRHJVdNQGKPT
MKhGMc1ZhlaGRQwnMRh5Q82jn1P/Q9Bo4ktSTf/FqfTTolh5MAMJ5l7g163/ iwFnoQAUgAJQAAro
FaAfo8tfrbvzk/qHvmx4+KvGbl820koCd3/ecMcnDTd93HDdhw1X9mn4x/sN F77TeE6vxj++2fDH
1xv+2LPuj8+W/vqOjRI1yiSmqUTiV9+V0FltJRK/Su7CwocuL3nlzrK3Hirr 9XD5W91oOYLS1+7W
wFtZtwvLHjin9J4/lt79x6K7/ph22x8XX/FrqSfXFtquLZD49bw0yf8q8evZ hySqJf8rhUvK/HrJ
h4emrf2hbdX5z739kO36r23vJtkGp5/02IQfP5nx45fcpzy27tSv2y5b3fZ/ E9pOntV21vW9Tnm2
4aRn6m2PS8Z/tj1uJ4a2T9QYgIWaqOUDtYiCxd41SMPwrlCs3IsJhEZ5VR6w 8F2JWKHmWFOPvud6
BXx1STNnDAf9D1l/Vs+vCnuFNTo/c6RBVQOPrzCbmn76mS8/UvvSRzODvmoI vriva0M/13yCxD4Y
HgfMIGoidpU1oR+joaRIhAJQoF0KPFprg0GBhFaAfk3+9lIdre16z2cNBJ0P ftlwP6Fn38Y7Pmu4
+bOGrp82XPVxwz8+bLywd+M57zb+oVfj795o/F3Puk5Pl/3i9mSZX6V7RFMJ ffRTCZ3VVtLNbbvf
RelH7/0bre1a+uo9RK5lbz5Y+sb9/Oev7MWu7PhEvbv8oXPK7/tD2d2/K/7f 79Jv6rS0yy+kntxY
brvhqISwl+RI/HrmUJlf6bPEr5VSGOvTNf/ptzMl+cXSsVf89L4JtrtH2Pql 2Ebn2RY22CY7bcOy
Xk1pu25Tm21KzW8XtNn+0/cnTxcRvzIjiuW/u5pj/lEEPjEPoy4ySvRjvuoP Jp1VK+b002E/A9HU
o+m5/54Y0i2vwXD4fpQRxdQIqx9sMBLxPAFHwXGWcooTx9P1kxhSBwyvDaaP ZgZ9TaIotaihvjjv
qq9Tem0DjiVgBl9Xka8x8v8isv8owqAAFIACUAAKBFSAfowueK626zt1d3xU f8/nDfznTDz4x8eN
F37Q9OfejZ3faez0ZuMZr9T98qny/7tlo0SNqmtSU8k9fRvu/Lzh9s8abvqs 4brPGv75WSOvhEpp
KyF+7eam9II7Lyjq3rXk5TtKX7un9PX7eB/KetxU9uJ15c951h+ouK9z+V2d im8/I+P6Xy75x/8p
/EoIS15YD7+SJ1bi10ry7hK8kt3y3Q7Hyqt6PX3tr15z2a772NZni21i8Z82 tn10pO2tQ22Xbmk7
dVHbxavabHd8/esnd57S4/jJLx4jO+kFyfjPtu2ZY2TsIz/gGKFPZ/kNjWcW 6wnjWOyS5OUSesg+
ip33dcx7qBmpYboeB7kChs35EcGPMorD1bv/4Y1O32HDfjJmFanOcK41fQ5G Xv95DGfQ18Tpq/JV
3P+cajQJUthgBuvnGvB1dYV6hSA/FIACUAAKdGQF6NfkrKdqaZGsm96v/+9H igNIQ7H/+KTxgg+b
zurd9Nt3mn71euPPXqr76WNlP75R9r+qpKSp5H+fNt7xacOtnzXc+HnDtZ81 XEX8qlZCpbSVkBO3
Wx2l5996VuGj/yx+7qaSl//L+1Da49ayl28se+Ha8ueuquz+D55e8b9fld7y s/Rrf7rkbz+WenK7
UyJVhrCXb5L9r4xf7yyTggeeriE3zzV999csvLz7o7ed8mrz/z21/+SbPrG9 vcI2teo3K9t+uqzN
NiLP1nPBSXf3P+3Fo6e80XZyzxNkJ/U8TmZ7sZX/7jKc5USrSddzEs9veCBq rXj7hMr1DTHAEnla
rJbVZthDTUER0ViFmlKaRF890VwrvHVf4/Kvhq8++BJfL4XhdIiD1U8cHymT iNepnw4xgy/FxA4Y
dsbw4vE1p75qC+ay0feQlxKvH7FpjTia8fKry7D1gDeIn+s2yKsC2aAAFAhS AdszLTAokNgK0I/O
7x6rvaRH3b971d3U25hfL/646fwPm/7Uu+nMd5p+/lrTT56vO/XhspOv3yhR o3yPBFOJ+JOnreTJ
Y7bHmihD3g2/O3r/JbRUFiFs/aYVlFL64s2lL95Y+kLXsueuLn/m8oonL658 7HxKb1w9peKOn5fc
8JP0f566+KKTpZ4Qv5IRv15dKe0iq8YPFNrupOf3HYxfO71VkTrr5i97PX3N S6Of+WLZ1BGf9Hn1
muufeuOUx+ef/OisHz2+6sevlP241wlmhLBkJ712goyxLAMadiymaNL5R31+ saz/SjTNiX+I530w
rN+wM7w4Vcs5Q0zUdMxPzzU94YjD0lnlfsQxVMCPLBqV9OLrpyagAlxbwwkV WzSc64C9Fav1dW34
6oOva8zXMP3n93WtskvIsG/+Lw/Nte1ndMHcIMFfDMgJBaBASAqQzwUGBRJb Afq1+s3DtRc8J20M
e02vuq7v1nd9t+Ha9+qveb/+X73rL+/T8Pc+jRf0bjz7/cbObzf+6o2mn/Zo PPWZupMfLD2pq7z+
gHyPtLcSguAnpT9x5173GwohOPpQl6Inrinu3rX46a7F3a8t6X5NSfd/lT51 edkTfy9/5IKKh86m
4AFyvpbf8tPirqemXXHyogtPknpyV63igiV+7bJd5tffp0jOWJlfCV4pjJWC AW77bnPygK7bBt88
8tPrP/ys+/lv7j3t7dbT3j0hmsKvb7edwkwGWWYhfYOYMzMHlIh0TwRWEY4j Ujkqib0Ckb08Yt9/
tAgFoAAUgAIdQQH6tfr5fdV/fML5l+ddl/ZwXfGq+8rX3F1eq+nyes0lb9Zc /FbNBW/Vnv1mbefX
687oWUeRA6c9U3vy4y7b3YW2fydxR1s7K+FO3Ix//Tz75j/m3vWXvAcuze92 RcEjVxZ061LwcJej
D19S2O3i4gcvKL7v7JK7OpfccUbJzT8r/s9pBVeffPBS29zzbAq/MoQlflXi B7z5lSEsRbWS/fi1
ltPebJWM4FXHr8SyfhBWxFkrHnNAiVTnRdc6d8dGqnLUE2MFIn55BNP/jvBV izFCASgABaBABBUo
cbT+pXv+Gffm/6Fb/jmPF17w5NELnyo4/8mj53UvPKd74VndC//wdEmn7iVn PFX68ydKfvJo6Y8e
Kj3pnkLbrYfPvmc159d2ViI5cZ9pKalu3fffv+y9+oy9//lDyi3npNx+Qcrt F6bcdv6B2887eNs5
h249K/XWP6Te1CnthjNSu/487ZqfpF71o4OXnbT5Ytu8686W+PX+OsUFy/hV Wj9L4FdaiIS7YMkL
KyFsz2Nain27lQcPSPEDOv9rBHWPb1VBBjYE30nD8IbgiyOnqRSI+OVhqtGh M1AACkABKJAACrw8
seFAlvsvD2/52fUrf3XL+l/fuvY3tyb9+pakM25dd8Zt639564af3Zr8f7du Ov2WLfTA1inXJ590
/RbbtRvOvicpJaOayjIF2lPJS+PqGb++NKbekXZgxS1/mfm3n82/7Ffzuvx6 zuW/mXPZr+dffsaC
y89Y2OWXSy772dJL/m/5P05fcvGPl/zllOUXnbTwfNv8686uPJLy0jBagcuY X+n5LTn+Vd6DgN6V
vQkkR2ydQrEEsjLLMqNHu/TGxsl8tzAoAAUiq0BiB2lhdFAACkABKBBxBU59 qZkIUvMX4IAfyVdK
pags60/4lYypPfXZRmkRgyePndq98aWR0lKyIb1KqloIXk+9t8Yr/lXwv8r8 ShvUPlRke7RUNmkj
A9sz0hNd0lZbzCSW5SYtOKAxGiR76rMjr1WBsUOBqCmAZ6WhABSIrAL4tYIC UCDSCtBqA/IDW7Tm
gLR8LC2e9UiD7dFGyeigW53kSWXv7IDb/S7bXU7a6UA5S9GuLOBVY97xAwXy EloFtq57bTennHTL
gZNvlcz2vwxmJ92dw8x2X4GEufcVKvbgUc8xS6SzMCgABaAAFIAC5lfgNlr7 HAYFoEBEFSCYvLPI
+M66Ocd2g2y07Suz/2QpH1k6GUuh939nSnZ1hvRO28bSAb0TrBrz680pEr/K CMsplrGsxlgGyXh+
oaDnLM+GAygABdqnAN2bMCgABSKogPL7xX68YFAACkRIgQjepNqq2P6xyvoD nVNOuzKrU0/H6d1y
Z82cC4MCUAAKQAEoAAWgABSAAmZTwHaH23Ztlu2cObYzBthsAr+GFFSLzFAA CkABKAAFoAAUgAJQ
IDYK+OTX2rpGxeoba7XWUFtvaErOmvoGxeoaapjJKbyUJ4OaU1+hUqSuoZZZ fb1iagqvhJ+qqasn
qzUwtRLdqZr6ema19XVkrAbvSupq6ySrUY3XX0P5pSLctGWFIkoltbV1ZDXc 6mprvI1lkPPUMlMT
6IB1Qy2iVsIz8CKeAzmzUINyLDRaU1PHjFdbU1MbnCkFldaCKaWOiep3K1bj riFTP9bWuplJid6n
PEVqXTVkNdx4ZjWFZTAwZ02tbDWKuWtdzDyZ1VNKHn5Kky59dKjGK+Qp0oE7 CPNU4nbUuP0VEZqr
rqmRzO1tLFFKd6umZqhxVzPTn1IqUU/VuKuYuVXTp/BTmgOeU1fE7nZ7WY3b zkyoQZOn0u1mpqa7
7G5mSjrPIBy4Kt3+jZfVZqtwuyJvLlc5M7cvc5a7vc2giLPMTabW4HKVMdOn uJxlzNzSWY950llV
lEetxOUqZeZ2epnLWcqMp/MU/SmWR0gvcTu9zOUs0RjLwBN5fk+Ko8TNzLsq T05HiYuZp55il1My
paB0SknRHjiKXYoVuRzMeEp7Dnht7KBQNU2656PTUUjmqi5SjY59mKe2oy6H aGornoJHXdWy8Wzs
IzddurP6KDOhSIGrWjL1FB1IxhLldJ+m5sl3VctWpZqurJKBZRPMWZ2vWFW+ UzZeCfsoWx4zVpAX
cVGKbJ4MPlJ4Br8Huc4qf+aqymVmkM2e6/SyHKc9aKvKcZLx/OyjmOKpKttp l61KNnYsGS8uJmqO
s5x20fQ5NRnoo3eeyiynxjwVZjrtkjkqFVPbUtJ5QUdllmL2LIdszspMZg4q LtSgfKSUilRm4Ffw
K/gV/KqgLfg1giALftVwqgZYwa/gV0OETQx+LTl6uNZdISBs0PBK6Al+Bb8K jlj4X728sPC/Mvcq
/K+x97+aLYIK/YECUAAKcAW83bHh+1/LilLrayrBr/C/In6A0SfiB1ikAeIH LBw/QL8TsQmNQitQ
AApAgZAUoG+nSPHr1uS59bV28Cv4FfwKfvXEyIJfLR3/Cn4N6QcVmaEAFAhb gVJHy8GC1t0Zx7Ye
btx4oIls/f7GNXvrVu9pWLW7nmzFzsZlO+oXbavLKT1GrYBfvSNcEyL+NS1l +7LF85z2MvVBLjy/
JT0lhue32LNf7KksPL8lPGIVxee3+M1o0ee3OL+OHFk88sjI4C3s3zAUhAJQ oGMqQPB6tPJEVumJ
I0clkCU7kNuyP7t1d2brzoxmsm1pLZsPt6zbfzxpl7SXaULya1bG7hEjB/f+ oM877/Xu9c577/fp
TR8p0fvhLd2zWdKjWgnBr8sWTxv47Yc0u+BXWlIA6w8oqIr1B5QlCGK6/gC/ GYPh1wp7ef8ZGfd8
kvXgp/sf/zLl9aHZYxdlZefma8rydQnCeH6rpLTgzXm9rl174xlf/mbWhuni KgTq8gJeawuI/Frf
2NjS2trS0nLiROuJEydq6lvT8mv2pDtS82rszmaW2Nra6nBWF48c2TF/gDFq KAAFwlaAPK8ErxlF
LQfzWglbGbnuymjZltqy7bBkBK8bDkj8Sk7ZmPHrIw/fZ7PZnnqiG1slYNiQ b+jjpZf8rTDvgLJu
QISe3youOEyo2vfLfvt27SnOzc9Ly8w4ePjg7n3LFi356ONP6VRxwUEBUhN0 /YGysjLpAmoGv0pL
ZYFfwa/y41/xWT+L34wB+XXJ+v0P9s29rlfeiFkZG7emzV+d+Wi/jDOfrDq7 +9HZy1K9irdj/Syn
szInP+Mvky/t1LuTZgmtgPxK8EqESi/3sRPD5h+9553197+/5sHeSTe/tvqm 17e9PqRg2bbKY8dP
0Op24Newf8JREAp0WAUobIB5XvdltxC2MtuZ2kzMunZ/Kzfi13V7Y+d/ra7I euC+O4lZX3j+SQas
A77rSx+vvPKy4oJDUkok+JXgtc9HH6xanVTjdO3bvWfenDnjx0mvmdNnrFq2 YuuGTSOGjXj3/fcE
hE1QfsX6r1j/1SA8AP7XePhfPeu8+l3/dfG6/Y/1y+/Z7yBxqrj+a6+h+y97 +sCh1PRI8StBanlF
cZcZ//rrJ38JlV+bm8nJeiK38sSjvdfd/vSodTvy6xqOHW9uLayo+W7ynsse nn3ZDV9u31/QcrwB
/NphEQQDhwJhK2BOfiVCtZdl3nXnbcSsr7/6AkPYL/t+QB//fc1VpYWHI8Kv I0YO2b5jJ/nb5sye
PW3atH379uXk5BxJTV23fv2EiRMnTZy0duXqIYOHkhdWdcEmKL9GKv6Vpoft UxDV/QukVrT7FGD9
LNOtn0XTJC0mEJP9C+S2aNWCRNi/IJj419LS4t7jjt7Uq5DIUsOvqenZJaVF Irzmpx3I2LA698Du
qqpyMX6gyl6anbbp8N4FuRlbxR0NmFe14Gg+WX5BQX5BfnFpwSXTrvjnt1fx 4oU56enJq7P2bquu
LtdsXiDGD5w40VJz7MRzX6dce/9XhSV25ovlrx6fzv9uxOLmlta6Ohf4Neyf cBSEAh1WAXpgSwp4
zZUDXtOauZHndc2+FrKkfc3swI//lX4++EuzT4Gf/QsCrj9ArtYzf3MG1XzD 9dcyhKUD+virX/2y
/fxK4a0/DB5yrLFp7pw5a9eura+vr66uLi0tzc3NPXzkyM7du2fOmjVxwoSV S5e/0evtrIxdMsJ6
+NVryEZ7HFAGKb+8eYF0rO5iIKezqFnT7F8QavyrOHgJHeoapPd66T0i/Kqp X7P/FuNX8V3ZwUva
uEu7O5ef/bdUDpZWrZJHobxHL35Aq1sk9t+SR1HL3j07dXk2/YrA/lu6bvt8 lkvcfysi/CpVwnfq
qnHJHw123kokfg0m/nXh6h09h5a++f1exqm+9t/KO5Ky97n7Um64bN9z91c+ eH3JK4+mr13BGHT/
zqnrx/1h17izUyb97vCS83esfL3oaCZha0VF6efjDr0yqKDbl2kP9M3724vp j3yyLTXjyMVTLmP8
WlletO+rPmm3XZb6zD05f/n5/nuuLy7IEhHWm19bl+45dtndI8bPXKeBV/p4 7LgaXeB2gl87LIJg
4FAgbAVotQGKHGDBA3c/24/FDxC8EraSUcoqGWHJfPGrBGS+t+Ay5NeK0ozy krRN62fVuMppFdjK
UiI52ovLa/+CaPtfyfl66MChgykHpk6dWkM/ii5XZWVlUVFRVnb2gUOHtu/c tXb9hrHjxs2ZNXvC
uAmqC1bhV4VN/T6/5YtfhWja+PKrsN2rLv5V3ifWs8GsuhyBurOrTEts0Ssv 4/xqsP2sfldY7xqU
fWjlOtV6lB1l+Sm29avMyvKWsDI30zuHVP32sEYbxrK1BZR6GK3KLUobzHqZ dl9ZdZNYOV00zUay
+n1lWQqjZGZGrClvBstPqDzKNyOgc8rLg6rSVrW0OoAMcJ69agWOVHapFSqR FxPQAS6v2xNIUOeu
YSYvPiA3wchVXOuKHXOi9ZxS+FWT2WDbWJVH+YaxwvqvCrCyU7VulYnF3WWl Y5Vruf9VyRDE/gVK
ETdtdiAb33vWswktP6X6d3U5vfaVFbeW5UG0ms1mNUsZiEWE+Fdpv1l9OAHR 6uBpm7v1qxg57YB2
R1m+K2xNdWlRbu4nb61/4HZyuxLjHlk02/XsfXsv7px1cO/hA4uOzD15zaxn CVgJSQsPv2tfZVs5
8baKyuIvxmy979O8stKiTTsy7uhbddaTuQePZJCX9y+T/kH8Svn3Thh+6KbL ctMPErPu6d1jxxm2
zX3eFHeLFfn1WHPrp1NKr7znu5z8Uj2/8hQ3bQCK57fC/g1HQSjQURXg/Eqo yozzK0/R8CtHUjrg
8KrZJJa7bDzLu6qMW1GaXnz00MQJwzZvmO2sLpk5fVxp4REJYdU9YF32HIca //riC0+xaNf+331O
dfqOf+Xbw+o28WLbxnrtHCthaO8P+9hLy+bPm7d7924i1/Ly8uLi4ry8vLT0 9H37UzZv3b5qzdoZ
s2eTC3bB3HnvvP+uxvmqX3mAD5lt8SoooD2mzWBFlxavSkyknWDJQeupRN0w Vtk2lu8oK+89y7eT
9fh0A+8f642eMnHK2MotFH5lxMn5lffbA7Lt5ldRHUafjF/ZS0FYGXDJPD5U XQo7ZcivnGI9/Re4
k7lpGbbyA3XTAU6lbA8Cr488Reqnjl89Q5CZUqqZIazqVWWJ7MUoU26dvTOs 9GRgYOqpUyVZoYbI
8KvQhAdwlbmQmVXumHLgSY8Qv3pal9FWakt+16RbkV9r3A5mDHkN+fXdEWld 36/6ePheP/y6a/oE
5zP3bhs/XFp8oKbaRT7Xx2/L/ttvt3zz8eGVF++cYMs6vJnxa2lxVsmGn038 2LZs6YyXhxa/2Hc/
89H2Gnr4ohfKZi5OOZi676JJfyN+LS8rzHnuvnUP3Z6ZtGR/j0d2/uv85N5v HNm1xRe/VrpanuqX
cf2jA52uOj/86nIq/CrOID/uqD/NGDcUgAIBFKB1XglYd2fQErCtHFg3HZY8 r8xW7m9mLli+/kBA
fqVvHp6HjhWEVfmV4HX2rAlDBn9N8QPEr9Onjhk98gd7WZbIr4+GvP5AyPz6 Xu8PSvKOjh8/Pj09
vbCwsODoUYocSM/IOHDw4I5du9dvTF62ctWsufPGjB49b/acl155VbPsK/92 ZfQpD1M6YOTK3zVn
WU7Gr5qIArkGiVmJXOUapHeFR1VCNfx6jwC/6uJfA/tfxa5wcpWISqBYr+MQ +dXDW+RqZfEJ5GcV
/K9SW+3zv6oQrIQikOdV7r/yLjlitXEFEeBXL91kTOWuUHmMBvzK0mXXLDur 4KlMuR5+5f5XOY+y
aKtUlnln1YaUxVzb53+Vq1VcrfIx9856yJXlEXN6wmGJYj1+2QD+V81Fr9Sp Omul+gV+VUJg1RQr
8qsQ/+qTXz8fn3rJG/bb3j3icFQQwrLlsez2suXJqbNW7Fuy/sCQadt3DfzS 8dy928cMYfxKtnfi
sJyr/rzhlWcyF/5m3XBb+iGFXwlVczbcOu4D26J5A7t9U3F5jyMV5UWUOG3J nk7dcuYs3b/nwA7G
rwVZqYWP3Ljur5329O55ZOHMysoS8sIyeCVjgbOi/zW3tP7WXgeufmhg7tFy v/zq4P5XzXTjBxwK
QAEo4EsB2qGAx7yK2MrhlfhVMgoh2KOsP2DIrx6ek52yfvh17JhBI0f0H/TD V9s3LyB+HT1y4KCB
/chEfiUXLJknokB1zWpTeB6PkzVY/yst9ZqfnkWrDaQcOJCRmUnkSk9u0TFF vm7cvHlV0poFi5dM
nzV79OjRc2bOerFHT1/bFjBy1XzrRopfFYQVPKzahiLif9XFvwbmV038gEiu mi4qLtgQ+VUu5Ykf
iDG/ikPgf/eXiVlBWHbMrT3xA95tSfEDMoCyhiTANeRXNcrAmF+96lR5V4Xg CPhfQ+JXL4SNhP9V
S7SJxa9C/KtPft2wI+v858vOfKRw2hIphIDx69RF2z8ak/bm0N1X9Ux94pPD e777uOKOqzY/9yjn
15RFsw5e9ofk99/YNeOitUNtO9aOYP5XsvyNdw3sZduybtZT3+f99OHit4Ye 2LE39ckv9t36ekpp
aSHn15Li/ML/XbGj0ykHkpN4zKsffi21N9zVO6NLt0kzl6WI/JpdenzGOvva lPol26pnrUy1V9nF
+AE+v/jZhgJQAAr4UWD5zgZpqVfBuOd1/eFmMsavK/YdX6HuX+DH/yrxlkX4 9f0P+mQcPDJrxszV
SWv2pxygmIHde/du37lzw6bNFDmwaOmyWfPmT546jVbUmjltuiZ+QAwe4PzK /a88foAO2uN/Zc5X
9mXuiRCo9AQVkB+X7T3b3viB9se/avg14vGvMeZXJQpWjX+VW/ci10jxK2dT 5nll8a/t51fD+Fd2
JcXY/yqGEITnf5UiX73jXyWheKJ3/EAC+F+DiX91u6oe/iLtN0/Y//hMyfpt 9NyVgrDEo8uTD/z1
hayPBh1K37A6769n7PjTTzP37WD+193ffLSm8/8d2rQ2eUWfNUNtmZv6VJQX SisPuOxHV1za/53f
l5TmFxcf/Xz0ge79Mm7rnXLT2weqq8qoTs6vdHzkxYdSf2Pbdf0l+RlSCCw9 NlBVWeLL/0p7F7w9
ovDyJ1bc3WO6093IEJYe2hqzrKzvxIw3RmRd9tDML4euaKyv0cS/0hTjZxsK QAEo4F8BPb8SyxLC
MngNyK+MVumdQW0w/Ep+VnK+ku3YsqjGVTZo4FfkfHVV5cfY/0qPZK1evnLt qtUTJkygaNdNW7Zu
3LRpzfoNK1YnLZThdcacuWPGjJkyafLwocPl57fExbM8227p+ZVSIuJ/5cGs Gn4lWpWaUEJgI8Gv
Km5GJv6VsSwzz7Ep/a88hEAKivUdP8Dh1TD4VR/wGnz8qyG/is7X8PyvmvgB fWhBO5/fCt7/6h1m
oC6nFUr8gH9+ZSzreWePWFk5fiCY+Fd6hIsWtur22YFfPVJ61jPF747MWr8j k9a6OpKR9f3Ug/RH
f+JX8svuGfjl7t+esueK8/e+/NS+j9/afGGn7SMGEbBW20uXTrh97te25LHn 7FvWc+OUq4d89MdD
25e7axR37N4DaZe8mt3pidIfZqYRsy7euvAnX/3s1x//+tP5n2Ts277zinP3 nWE7eP6v9jx9/66H
btk68Atf/Eqwuu2w68pn1l/2+OLXvt9R16QsOMBAdt62hsvuHr9m08HWZqz/ ClCBAlAgZAWW7Gig
HbZok1huW1JbN6e2rDnSsjSlmduSPceX7ayn2im6SfS/spUHmGeHvTQp+ue3 HNLzWLnErzu3Lqqv
rSR+dVUVOGPOr7R+1vt9PtyzdcfkSZOnz5ixMmnNslWrFi9bPm/hoplz5xG8 jp84ceyYsTOmTnvl
tTfkvWQDLJ7FFWD+V/4IF3fBctI1jH/VBCGw+FdFUu+Ht4hfVXiNkP81jPhX P/EDDFvZK+znt8RL
iq0/4JWiPr/FH+EK4/ktVkTqJHveS4h89fRffdxKzqYEDIjHEXx+S4Iwdf0B uQnlOS5fz2+J8a/8
ES7D57f4cOT6IxA/wIJQ2YuvP+CdokS+ahI9i2EFHf+q51fxUS12VupGojy/ FUz8K1swq7y8aMK8
tIc/SfnbCwcufCGvy6vZt3+Y+8rA9OFTD6RlZLK4gox9u3Z88/muj97eP2JA XuYRvoCry2VP2bV0
3dzn1896fPvaUeSIJXitqCydvPRwz2HF172TddcHWZ0eL/z5Y46vJ6XmFWYu 2bJg6upJG/aupYjb
0uLc7cMHJH/w5qaP3z6UnOQnfuD48ePEqaMXZlz28JzLHpzz+Kd71u5x2V0n jrWcsLtPfDEx67Lr
Pl+6NqW1uR7rD4T8040CUKDDK7BgSwNttUUIK1mqx4hfVx2WbNnBlkX7mhft Ob50p7J/rJ5fuf+V
L6TlWTZLWhhLNs8aW2z3rNwdWxYSv8pn8+QMyq5aLPg12vGvxKPkVR0zakzy 2vWTCFXHjp02Y+b0
2XOmzZpNYQPkeaWU6VOmffllP53zlUDW43/VHHN4ZQf6nBw9+fNbmhW1+PNb 3P8qBg9EZf2BUONf
PeutGixioF1UK4z4V5V6jdfP8izp6vHpSiQqWSjrD6iLcKmLFUR//Szul434 +lnK41reD2lJ62Rx
T2y7n98yXCRLda8arJ9ltMxWyP5XrzgBjrzewQM8jwzTiv+VJVrx+a1g4l+V BV9p5VfZxPgB9hCV
Nl3dykvcv0DJqYbAEr8OmZ3y9Pelc1YecjkrKeeKDemXvV7R5XlpXVhvo0e1 POaHX5tbWpirdd32
3B6fLfrPUyOvfHzqHa+vevzTLY99tu3ZjxZ/NXhhYamzqaEO/NrhUQQCQIGQ FYgfv+bI+xcQv9IT
VwxwY82vtD/Cu73fHz5sBO2zNX/OXKJYwlZ6YGv8uPFTJ0+ZOXU6wes7779T JO1Yq9l5Kyr8yn1V
hLBs/SzN+gMcZCPsfw0j/lX0hnr5WX0RbYjxA5r61SVgZUJlqCqv/8os7PVf daOI7vqven7VdEBS
Mqz1X6PKr/pO6tg0Wvyqb5q5Wg0tMfg1mPjXKPHro18euvT5FAavzN6RdqNN D5tfHU5HnfSqbW1p
bKivyc0v2HswY3dK1p5DuYUlZXV17tbWY02NdaWlReDXkH+6UQAKdHgFiF9p by1ywW461EzvzCjs
lTyvKw82k1EIAflfF+w6tmS7wfoDGodrKP7X+PMrUSkhLLlXKZBgysTJSxYs WjRv/vzZc2fPmDli
2Iier71BpwheHVp4jbr/Ndb8Gmr8K/yv4e1fAP9rqPEDIflfhf1jLbx/QZDx rxLCRtr/eucHB3/5
SNmH4/P2pRaWFBck78i86pX0/mPpOa2w/K9HRo4M2sCvHR5FIAAUCFmBeZvq Vu05lrS/ed3+49yS
UqQFs5bKRpGvBK8LdzYu3lbjK/41rPgBU/Arc6xSeCuhKi0y8HLPV2mpVzqg j5RI5MosNv5Xvv5r
rPk11PhX8Cv41dsFGy3/awfk1+DjXyPOr/sPZz74ceYfnso+97miK3um3dQ7 Z+LCVB28EssGFT8Q
8m8RCkABKAAFQlEgu6hp1Xb36l01SbtqudFHelqLGYW9kueV4DWzqCFR+VWH pwqwJja/KqsN1NQ1
euJf2Z5byhZc+khW3Sn1L/gGC2bJgQQ1qgkZlKhWDwQbbUUrlZUf2xJNXRFW 6RiPdhUiCjw7byn7
bPnYf4tv0OUhUR7/6tm+y3gzLaNlX3m73lvL8mVa+aZctOUAM2GbLuVYSVd2 NOBxBJ6dXYXNDoQF
BDw7IHgSPRu6qmRJ28wykyNihZcSeiBsG8tzKrsMKI988To9VfFtCNRWaCdm 9gq8bax+E1rvFM12
stKmsroiRlvOyjvN6vZE4BvDqqfUPWBVTy0Fy8qm3z/WVwrfEla/GaxQRLu1 rJJZ3WRLX5bfjOwU
j21VYgYEt6snRX6ci8yTmblmeWyreooXMaJSOXBWZ/qcPOBVc8C4lu9fEMrP EPJCASgABaKugLz+
QJ7wMJb4YBYd0ylmmnT981uq/5XCXuVtCFz2XGbCJgW6SsRNDeR9ZRXTu0jV HQ0cVTnMfEFq8Ol6
nBVSeEQsd9Yq23EpD3JVZikPbKlRrczJ6m3yI19qToMM8mqv0oKvYnQsVcLT 1ZUKHL72j/3JlVmd
ejpO75bL94klfvXEv4JfpW23vGBUvxgW+FVFYfAr22JAb7SGF7OQ+ZXfjNbl V/qRgEEBKAAFTKhA
pPh126Z50vNb4FcPxUaHX7vm2P402XbGAJutc4ohvxLCkkmeV/Ar+FXnXoX/ 1dAFGyX/q+BDtaT/
1Tu6QA2cddlplwTJWOyB5qMYkOCqdGvMc7bS7dadFTPTWcUq3G7ZlLN0EMBc rgpmupzlbhczP6d4
HunApZpaUDjrLHd7m8tZTuZ2lTFzORXjKW5nGTMXnWXmXcSTU1+Js9StGKuE f/R54HKWMuOZeYou
vcTllExfrVqEZ6A8krH8UhGHYjxFc8DyS6bmdDuKjU3N6XIUM+PZXM5ixdRT QkqRyxGWVRe5mDkK
FdOnaGquLnQx40U8ZdVTvvJUH3Upps951OWQzZNHOnaqpkn3/ljgqmbmVcRZ XaAxNRvPr80g5M93
VksmFKFjL2MZPCYtmyoZz8Y+SimqqSncM6pkcFbnKaY6TQlMmQluVOmYpwsZ fLlXQ/C/gl9j5H8F
v1KkgeBV1Ryrf/FH/ACLEAC/8mADvwfgV8P4AfAr+BX86gXH4FeVYhOJX8nz Wl9rh/9VoFj4X4Xl
txD/qoTAqsGqAWJexehYxL+yOFfPSlvqH/RNH/8K/yv8r+SFhf8V/lfJXwv/ q+KRNZ3/VYheRfwr
C4QFv4Jf+UYD6v5beH5LfR6rQzy/BX4Fv4JfET+gBicgfoAFDIBf9ctghZZi 1ee3ED+A+AEhKgDr
D0iuWdOuPwB+Bb+CX8Gv4FcWAmva+Ff4Xztu/KvN1haSsVgCrJ8VbAgB4gfM Fz8Q0gVPmS26/gDi
XxH/mmDxr2NesmkMz2/pn/Tisa1RfX5ro99XrbsyZs9vgV/Nwq+e/Qtitf5A yL/l4FdaBQDrv2qX
lVUjXDW0asr1X0O+5q25/iv4FfyaMPzKsLWNbIytba9sdKDiLNYf8KbYWKw/ QPja0tzc0tLc2tpC
duJEKxl9pPfdu3evWbPGXnk0NusPgF/bya9sc3haC5bWf1WODdd/DRg/EPv9 C0L+LQe/gl8tvn9B
yNc8+JWtfoX1s7B+lrSKVqzXz5LIlWMrg1fRxkhoKz9ipVtRC+tnKYtzRX79 rA0bNjQ3H9cjLPHr
1q1bGxoa1q5dU1HmtYRWlNbPAr+2k1+JXBm2sv0LRIT12r/AkF89AZF1NXzJ dHddjWS1tWQ8g7uW
UiTzbNHkvRXTZx+/w055cnrWYNLuLMryhPxbrmcXoxR3nVsxCnD0Ns+eTLJz zl3rZqZJFz+yGniK
vghvQlc5b93prpWM5oYd1HBT12Zi2z7J5hSNrznKChobK8LPemqQ1tWXl9bn C+l7rajP137SLwKl
P6VJ4Wvyu2uqdaa0KxTR55FT+GZRNdWSOFKKulaoplrPtlJqBk/OKneNbHKK SzWDzaVYNsnsiimV
eG2FKvoOXW47M812qX4+CkX4QqTKgctVGeo1ry5lqq3KIF1dA9XlrlDMVUkt KmugUqL8kXRmB7Ip
y5266C9uikll3e5yZp4MntVMlQVQhVOsEs+Kp+yYr3vq6xRLl/vDywrrm/KF Tn0fyGWDL1LqcjHj
RXhKwIMSlysKxpcmdRW7JONNsI+CaXPSqSLJPOnyR8MUlq4a+4VwOYVEOtaY q9ClGK+20OUk4znZ
R8F4E5r0oD4edTkNjdfvK4PvdEeBy6epa6Y6C1yi8fxqogdemf+VyFV/oCCs 2pwz38XMUxv7GI45
HXlkLp2xdOmUUzVPnlyXgyxPmmWjskIiy6mYp04hUTlbnetixjNX5zp5onzM zFWdw8zpUMzlyFGM
n6Kz6rGUWZeBV6KpjX9ct27d8ePHDBE2KSlplfyiA6cj21mdpRodM+MpyoGr Oks0PxmcVVk6y3RW
MZNPVWcy4xWqZ5V0+ZRqVZkupSyrIYOZq1oxZ3WGYp5sSh6e2fdBurNKMhdV KJtSuZQimac5nmJP
dzKTCxqYnwz2NCezKtk8OXmKdwaWTcmcqmCr/FE9TnVU7mdmu8NtC8ivDFUV eBX4VQJT6aNinFM1
e43GmF/ZIOlFG4ryY/aR4JWlcLLkHzliikXMwK+8P4b8ysE3IvwqqcS8ejoT qNTgrNBJz4ZSBJ2i
mDKGBuBXBVVD51epIMdWd5XykVNpovOrVmfPQv1eS/pzfpV+wELhV6+bwgT8 KvffH54GzMCKi+Mi
fmWl5PeA2Kpk4DVEkGKlDqj0KXcmMvwqdNULWxm/yo2qDOohznbxq1wn8S6v X4e2gRDWa4K8QDYo
fpU7oAPZSPEr87YStl7h42Avc8F68atnFhwFXqOTKZalcKLVfOQZhEokhJWL KO8afmWnVAvMr2p+
hUflj7kW4te1a9fm293z0uuSd3zekHzF+oEXrx14lutgXxZIUFpSUpCfr+dX cSJESCXWVKZABlk6
pckpwKgEqV5nqySXYZD8KuUMi1+9WwwSYS3Dr2x0jGXV41RnVYj8yuNfNf5X Db9G3P9Kux2TU4q/
mIOKJWqOiU1Fo6Gyj/yAHQfJr9z/Khf3eFgN3agx8L9KPffhf5VORc7/Ko03 dH6Vu6eAKa9BhmAv
36qYLeL+V6nyhODX4K95X/5XWQpvp2y7/a/Sz5jsuyXPq1x/nP2vUn/aza9C JV7+Vzk9KH6Vcyqe
UfG4nSwrVRUd/6tSs7fbNTb8KjuAQ+NXubdm9L8qMa/6mAF9ihwLqyCs6n+V xiVDrTxAxfkqJwbm
V462xJRyEa0Ltp3+V7VOq/Jr3wkrr59XO2dx96zV/xzY6/J/fpqydPO+uVNe EsNhyQWr8b9KkKT6
X+Vjj/+VYRPjVMav/CxPl07J8Ortgo0Rv6p+3Ay5A8EgrDX4lSnvtBOwesFr yPzK41/98yvzs9I7
N+a45f5XOmDOWk8GT9SBAqBi/AD/LRdpleEs51p2KiR+ZRRLLljxXfS/GvIr U5Neek8tSwkmA8vG
vL88P4sfEIrLUQRC/IBUROZXr2xyBk0lYiiCeErThIibyqA0tRn5X6Wxy+ly f7wOAvKrXIRw1lNW
PVbCA1gGNZvHcatx4kqQahQ/IBU04lePCHLwgPiRHSulaoRTLIRAjR8QNeex ATyRxw/oswltKTEG
wcQPBH/NG/KrPCIJXvmBcszCA9wVnnfZ/+oZiJxB+OgVP8BK6flVyK9soKqp QczAowIU5YUgAal+
9SM7y+IHhOJe3lY5gzZFLah3rBp7aoVKPM5U0SnLKFbogxfUysUpxRM8IKeU eHfbQ7dq96QUnpMV
F5rw/ugslnNK/lchjxQ84NUKg10h0Vf8gFSblFPytgoVKv5RpYdy/IDnrOyU lQvK765CsaBaRIkf
EEpJqKrJyfjVVx65CS/AlVO0/KovTnlYTjG/JkUoRRECBZ6PqnNUSJFDCPzG D0j8qj6qZex/FR7q
CpVfGcVq3vUxBpSHxQ/ImRWKZYn8nUII+FlhgFKi+FGEYDW/ll+F/NIpz8dq 5ZjHD4inKK7Aqy01
fkCoTQ4SqM7RZ/PKIwYVeB+zaAQWP7A5I/1Pk+rXrLk/a9af+7183gMDFz96 qO23vQoe+fQreoaL
P84VPL9Kasjkyg7C4Fc2ChY/ICij1EnoKZ31OiWlUPAAix+Qy3oKyt2QQgh4 /ADLwGIM5GOJX3lD
HGdFedlf/z2dMXf8AONX1STna8j86iv+1TB+QIwiYBk413J4FVYb9Rf/6ssX FRK/8nni8QNh8CtV
ogFcShHjX+WPSsgszyxGKXDAleHYpRY3iH+Vi/vkVx5FIGWT+ZX7X9lIvdyx csArS5Te1fhX+VhC
SU7JvDY//lc5j09+VVqX3bdqJYr/VW6OHRvzK8/ADqR3H/GvQlWqc1fOKd6f Sk9YFIEa/0rHjF/p
ndhUbsJz4MlZY5ePvfhVxFZ+zGBUrkd5Z6d8pdCpkPiV/z9N/K+amKjnV7lp xfOqPVbxlGGopIOc
wkJg9fGvcgYZYeXgV1k3Lb+qeZRYVbdLqpbeefyrJoPmuXv5rAKpHF5ZaKw+ /lXO7MFQzUf9KTGD
/8zsauGoqokf4KfU6AIPwqqnDPhV45SVc3q5adVGtYGzLKf07h0/INSgEK2c IkfBMsb1kK6/+Fel
ZhYtIIS9auIHPGcFcpXLEtpKACqHwKqVyEiqiX+VU1i6V/yAkqKCrCePkCJS LBNKLiWBLD/gBX2c
9SJaoZRaiYCtih9USQkq/lXhVxY5YBg/wE+JIQRG/lfPANX4gWD4lUrx+Fdp dDp+lYcsxb+ys2oe
g/gBsTjLqXkxWlWbk45ZCgNW6UCOduXparSrckoqq8a/ypm94l/lUhK8KqGx MsgynOXxr/ysPviV
18ZOPTdy4+KV3RqW/P6NB35yrKnx2LGm80e13jin7TfPFkgrEqgIu3z58iD9 r3LTwfKrGD8gO2J9
+l9ZtUxnCT1lfuXxA9JZHb/y+Fe5bAB+FbFV5Fr1WIJXHv8qH8vBtaaMf40A v4YU/2rIryxRdL4q
CBuW/5VHEfBYglD9rwJBumj+xMewxLuXx79qbmkOo7ygPoPokaWz7COD4Ojx qwiv3gMx5lcxD6Ph
gPwqyaViKDsWjdcgxg/I2fzxK3epspzSe+j8qve/yrUpz29Jt71ffvWSKxC/ emX2wa+aPKHyq+Zv
DvprPgx+1cS/yjoHy698OPz5Lc01z/hV0llFWE0GjYdVzun1kJbUn3D5VWxL ZVCFd+WG/D/LxSJf
DeJfdUMIk1+9u6f4X0Wo5Rnaw6/yKKLFrwqh+uVXr2FGgl+5/1UamsyvRk14 fLQ8m8i7LFGsyqsS
1R0r/00/FH4NIv6V3LRh+F85wooHoguW+u+fX/nzW9LYQ+RXmYa9/K9Cc4H5 1UtbmWv1/OqtvzG/
etejeFj9PL/lrji8avy/29Zd9Eb3C390x7enPTXlR4+OP/mJlWe+s6Xz7R9J T3RJCCutq7V06VI9
v/LmxPhXST0dv4o5NfGvPH5AGrWOX71HxOINZNdp+/jV0x/Vkyo25ItfNXkS mV+DjH/lflYeCGvo
f5VWKpCdst7Pe/mLH9D4oqLNryx+gCZY5Fd9ICyPAVCjAryWLJCLK+sM0HGM +VVuXVmvgB1L7779
r8wRK/XTd/wrOyvX4/Xun1/l/DwQ1mf8AMvDMkvvMedXX+sPyJ1RAgDYMXsP 3v+qcdnKIQc+1x/w
E/+qCS3QVCL3ylOt+FE6VuMH2ul/latV1h+QvtyF5QWIX5mxb0Y6pcnAaZVB qnw2MvwqV+VFq/oU
vwjrj199xcLKTRjHD/jxv/KAAcPAWbnOMP2vzB2rim+8/oBUvxo/EKr/NSC/ ypUrQa7ycQT8r3p+
VVOUSAO5oZD51XD9AUU6hrAB4wf4yll+n9+iBbYizq/SkB35puVX7n/lflkN v1L/lT/6M89rIP8r
CzDwZTx+oK5wePWuK8b2OetH13xwXa/JjQ31TY0NTeSFbWo6fuxYM1uUoEVa Gnbx4sW+/K9S39Tg
V3Y9iC9N/AB9DJ5f5ZqV9QekUbNQ2kjwK48f4MEDIflfTb7+QAT8r6HGvxry KwuNVVba8o6LlfMb
8GvwKwqF4X8V4VLjf9XHv9KlpokfYG5UhrAafhVSLMOvUp8D8SuHV03wK5X1 Ff8qnxKf4rIAv8p9
9hc/IGUIhV9Z/iD9r8Ff875o1X/8azv5VXx+S4YtZXksaYwqv3Jy1WSwOr/K w9GHwGqf35KzaaMF
AqaIXCszmRzSqkYFCHX6jB/gi2rJmROfX2WVGCJ7xciKKexYk0f66B0/4P0x OH5lIbCB1h9gexmE
9PyWJtRV7q1ngS3+0fz8KlOagf9V4jYWtBocv8r1BMGvaU/WTP3jOf979aQ3 k2/6bmFqRu7cjUee
29hy39LW3sMXeRC2uXn+/PnBxA8wyuQmddv7+a3E4FcZoxM6fsBP/Ct/Eos9 lcUg1Re/ik9uMdes
sGRBxPiV5oO9fK2fJS0BKyz+Kv30CosMyAU967+yj/rHs4RWlAUK/KSwSnhV hs9v8fVf5Wye+Fde
rRLJKvhQudNUHoJXLKz2gS0j/ytzoypaqY+LsY++1s8ST2mOeUEx/pXXL1Yr JorPbPl5fouv/yo3
6r1krBr/GuTzW4bxr+R8FXQO4fktqT9q2KunBu+UkPyvYfOrl6rqI1yeLhn5 X/XPb/H1X6mgr/hX
hrDsLK9fXtVV/KhEwYoZAsYPiM9s6V2zmiBXoWaDB7ZENXx5Xr3zKI9qietq +X9+S3dW+6iWrJK/
57d8xQ/wp7WEqFaD57f08a9sRL5WexUUCxD/6uv5rYDxr16SCk9rqfG1xs9v 8YBXqfPCI1zetSmQ
6hmFJ2Q2AL+KgQcS7Oqe3/LUGVz8AHlnlRDYQPwaxvpZAfnVSxb1ES6eyJ/f EuNfxcBW/SNf4T2/
ZRj/qnm0K+DzW9KMR+j5rbpt1yZ9ftmF3Uef1Hv36avark9uvXVX2+9Wtv3f /SNXrV4ve2Gb2NKw
8+bN88OvHFKlvoXCr+K8sPhX/uiV5vktVjO9c/8rf4SLLQHrXVWwz2/5eFrL 64kuudEO9vyWr/hX
JT3Q/gWcU7F/AY9/VQFau+8A9i9Q8FSIH1BT4rN/ASdUzcYEvvYv8JU/qv7X AHsZBLd+lrB5gSn2
L/De3SD4zQjCyBnJ/QtEbA1/Ia3orJ+luHWN1s+SXbYRXv9VgdHE3r+AAglY LIF4oO4lq+dXM+xf
EGjzAk/8K4PU9qz/KgFTKPsXyGyneltD2b+gLvmfE3v8afiQ/hf1HNv583kX jM/641dbr/9g+oYt
exobGpoaWSCBhLDjx4+31v4FMnRGZv8Czq9W2b8gzPgB/jQ9HXjiX2vcbjIF WJVwTylFsRp3DTOe
4n2gPqHvycBTvE8F74ViOYVNqvhuVZ4DV42LmVE2r02tNHsE+PjI6wlQ1lXj ZKarR3nmSZ9BSDHY
JsBw7yuX28HMzU2IN5WKGLCgktlVU82M51GrEnbAkosLOfl2VtUuSlfN04ra nHBKX0TZDYuV4jtj
eQ5cVS6NCRtoST5Ul2p8ByyX3S1bwJ2xXJSHmbAmgHqsbjel7kQl4wjflYo2 LFVbERLZs/yq90t5
nF+3DRVPF+jQ62l9z8LGwVz/av3qDlXOchczvmdVMCkss7PMp/Enn+Q8Tpdi /opoaytV97vnrSgp
TmcpM5ejRDE6NrYSl1M2B2WWjX2UTC3CK5EPnKoJOZU/yvPm1DzFTgczpZSn iKPYpTFGlvp0NUV2
KUkZ1DqVzJqP+gxySpFqSnGXvNeokO7zmOWUMxfKxnOyjx6TNjWVTZNHSNcW 0dTg/fGo0xGUuaqP
MlPy0wEzR4FiPMVzSlMzz1ngrPY2XomnNpYhX2vaDFQnhZPKps/sOyWY/WOd 1XkGVuW1f6mTf+SZ
PSme/avUjax4hdIph2p8myvPQVWu09t4ZuWgKtehWI6jSjJNfvqoptMpydhH OadPc1RliyYDUzYZ
T2QfxRQ6xb8/NcXZR6c9i5lwlo5lo0Q6VZVdc+jdohEX7O5/cdaUfy+e1m/E /I3LNu6tr6ttqK9r
rK9XEbaREHbQoEG8QrlOr6pYhapl6jZBDTslw2HXmFKV057BTJdBSSFxHJUZ kvE87KOYwk5Vpivm
qS3dYfeslkXHHuOZK9MckqlllY9iiv4UK6Ize5qDmeFZSgyYwVdBIb26fD8z n/tvifzqiX8Fv0ow
Cn5l27F2CH719kr65FevPVc1W7B6IFW3Oyv4NeH4laMt+FXDtQnGrwS7hLDK Xgb8cS46kBPJjOGV
ILUj8aueVg351RBbPcgbBL+yavv160euKskbJm0YWlNXW6tHWMpjLX5VULUd /OqFrRxhOwi/euJf
wa/gV3WbAPCrBm0FhyvjVM9KqOox+JW5YBPZ/wp+9eWOTTx+lfy1VQrFMmYN QK7Mwwp+1flfI8Wv
Hwb3Ar9KRNtB+FXxxfKogOjHDwgRCKqzkz9x5XF/8uAEw8AAxA9I+wUgfkAT tyrFoYYSPxAz/6sR
7woErAYDuJ0VzBA/YM74AfBrR+NXQljJlEgDo4ABTRQB+DVq/MpXYPXEAOjC A0R4tUT8APyvmmiE
0OIHwK/eAayIH0D8AEGwJyhWPeZMGY7/FfwqhaVaP/4V/Ap+9Rk5AP+rGvyq iX+NlP8V/GoY/9qh
4wfAr+DXDvv8FvyvyvpTeH6LPaEV6Pkt8Cv4Ffzq52mtqMa/gl/Br47Tu+XW 1jUqVt9Yq7WG2npD
U3LW1DcoVtdQw0xO4aU8GdSc+gqVInUNtczq6xVTU3gl/FRNXT1ZrYGplehO 1dTXM5PCvOvrWA3e
ldTV1klWoxqvv4byS0W4acsKRZRKamspoLyuhltdLUWYi8YyyHlqmakJdMC6 oeZXK+EZeBHPgZxZ
qEE5FlqU9kKTjVcrLsrr91gpqLQmLOXrs5Q6Js92Fcp6FeruFbW1bmZKOi1l oZ4SDuQFd2u48cxq
irCar/euaU5leTJ1sVu+DLAnm3qKra3rM10661CNL9bLU6QDw8UiNImeStyO Glo+wncpobnqmhrJ
NOvgskQpXbfcRI27mpnBShSsHvVUjbuKGV9MV58irrMrHvOcuiLK7mU8kKPG bWcmFNfk4RuJqenq
sg/+VgpTlwmjzcaMje9Pps2g7BzGt2CIyAFfCILtN2ZgznK3txkUcZa5ydTi fC1bfQpfEcLtovwe
86Szquj/IZ7ddJWFw9zOUtG4F5wn6v3ivouUuJ1eJqz/oCwZwTLwdJ7fk+Io cTPzrsqT07NgBa9H
+a+FUlDy5av/2dAceNaOUFZs8LOaRCineG3sQFnkga8LoT9gyzi4qotUo2Mf 5qlN3eFWWapWbcVT
UFnkwbMXrrrsgxJ/zNe45ctBqKs9CEUKXNWSKQtEqEs9sEQ53aepefJd1bJV qaYrq2Rg2QTzrALB
AjN4DepHOVEJI2YFeRFXVR4zTwYfKT6jkL2iO7RrOGiWaHBV5TLTL93gtOd6 W47THrSx5R14fr7a
g0ENtDiDbMyxzY4l48XFRM2xsqqDGlChz6nJQB+981RmOTWmPmnntGcyc1Qq praipPOCjsosxdRl
H5yVmcyUxR/UGjxrQVSkOmTTrj9wepfMTj0lfp01cy4MCkABKAAFoAAUgAJQ AAqYTQGf/EqbreMF
BaAAFIACUAAKQAEoAAXMpoBPfkX8gBongPgBH/EAiB9QQggQPyDFGyB+QBN1 gPgBTZyAJmAA8QOI
HzAMIUD8gLI9BOIHKPxAiEAIIX4A/Ap+DRDSCn4FvxpFyiL+lYEs+BX8KkfB auJiPR/Br+BX46BY
xL+2M/41SH6l3aiyc3J37Ny1dfv2rdt37Ni5Ozsnj55DaefzW1RtVk7udqp2 23Yyqj87J8dJm2rQ
g1Z4fos9a4Xnt5RHuPD8lvQMFp7f8vnYFn9aC89v4fktr71/8fyWvJ0vnt/y tSKv4YNZQiKe3zLp
81sB+XXf/pR58xcMGz584A8/fP99//79BzAbNHjwkGHDpk6fvnzlyp279+Tl Hw1m/QF3bV1Obt62
HTuWrVgxZerUIUOHDhw0aMDAH3i11Aq1NW/+/H37UhjCYv0BhrBYf0BdrADr D2D9AR8rDzCEBb+C
X8GvWH/Ae4ECvwsRYP0Bv2sUmHb9AT/8eiQtffqMGaNGjxk+YgSB5ncDx7zX d/Szb0998u3pz74z
9c2PhvT9eujI0aNHjRkzZuy4sePGT5g4ac68eUlr127YmLx7z16yg4eP7Nqz d8fu3auSkghYZ86e
PWHCRMo5dty4MWPHjho9etjwkSNGj503f/H8hcvnL1g8fsLkcePHU1vUIrU7 ffqMI6np4Ffwq7yK
Fvyv8L/KbIr1s+Q1erF+FltCC+tnKethYf0soxW1sH6WZh8y7dpY0lJZll0/ y5BfyZO6MXnzlKnT
Jk2ePGP2vHe/XfLBoE2j5xyauSxz+uL0SfNT6X3m0oyxcw9/NHjzh98vW7Z8 9cJFi6dMnT5t+ozp
M2fOkI3Yl46nzZjBbPqMmdLZGTMXL126Zu261WuT0zNzG5paNE+6NR1rzcop SFq7fu68+ZMmTaY+
bNy02U1rtUrLyipLw0Zq/dfPJiTBoAAUgAJQAApAASjQcRTwptis9LS969av W7B4WUhGRdLT9ujX
fw27trTUPdI6suxxLrKA67/q+ZXgdd36DYSPs+fMHTx2wUt9189clTVnZfbE +WmjZh4eMvXAkCkH
6H3kjEOUMmdF9uzVOT2/Wj95zoaMzOwDhw/v3rt3x67dm7ds3bR5y4bkTcmb t2zeuo28sHv37z90
JDUzK3vjpq2HUnM4tra2tjU2NTcda6b35uYTPP1wWs7SpSuoD+TTXbt+AyFs NPjVbOtEoD9QAApA
ASgABaAAFIiSAoTpIr+m7N+5acvW8vLixgZXQ70zSKPMVIQAL2X/DnH/gnbW tn//jnbxKz2btWz5
itVJa3p/Pf+zifsXbsgbOedw/4n7+43e03fk7k+H7yL7ZPhOOu43bu/AySmj 5x5evKngq8kpHw9c
lpmdQ5alGvso2qqktRXVDTQrTcdP1NY1uWsaqp219uoasgq7u8pZ63Q31DUc o7OUx+5qpPwUe7Bk
2TJ6tAv8GqWrGdVCASgABaAAFIACVlSg1NFysKB1d8axrYcbNx5oIlu/v3HN 3rrVexpW7a4nW7Gz
cdmO+kXb6nJKj9EANfy6fOVql9teV0vbSXqeDw7mmIpQweUrV4n82t7aVqwK n1/TM7LWklN4/YYP
By76avqhmWtyB0w98PmYPX2G7nxn0PY3vt/66vdbXu0vvb/Zf+s7g3Z8MGzn F2P3Dpx2cNaa3O9m
Hf5syLLs3FxftmL1uqqa4yRfTd3xyuq60kp3UamzsKQqt7Ayt9BO7wXFVcXl LkqvdjXUNjRTTldd
6/JV68j/umbdurT0dIawEYwfEC/WjX5f5By24pWNPkMBKAAFoAAUgAKJqgDB 69HKE1mlJ44clUCW
7EBuy/7s1t2ZrTszmsm2pbVsPtyybv/xpF21en6lmIH6Opdn13F5m/GmYw2t 8osONKfEj1SQiov8
alibnxr0tYXCr1JcqWLVTtfWbdtoHavJ8zb2HLpryprcfpNSPhi5+63BO175 fuvzX296pt+m7l8l
P/fNZnp/tt+mF74llt3Wa8jOj0ft/WZyytQ1uW+N3DNr2fa8/AK9bduxO6fY SW5VZ82xUntNQYmT
mDUjrzwtp/RAWsHeQzm7D2QdTD+amV+ZV1RVWOqqrG6gnJS/oNS9cfNW6tiW rduqHC5plQMKh5Ui
YhUTVtpSE1kGCjlQTSkipNAp+l+Ihl9bmptbWppbW1vITpxoJaOP9L579+41 a9bU1dcl6g2AcUEB
KAAFoAAUgAKWU4A8rwSvGUUtB/NaCVsZue7KaNmW2rLtsGQErxsOSPxKTlmB X5XHtog46+qcTmc1
N7fbQeT6atKTZJlVR2pr3eJZ8ZgKSvxKCxSoD4Hpa/NVVp+u1GbPVGJqA8e/ Cvyalp5Bcap7Uw7f
3mv55A0FX0058P7IXa8N2vH8t1ue6rfp0S+SP5+UUu1uctcd/2TCvoc/3/jY l8mU/uJ3W18ftL3P
qD1fTzkwdePRO95enpGdn19wVLScvPwN2w+0trVVuY8VVbjziqsz8ipSc0oP ZZakpBXu2J/e0HiM
0DEjp2jXoWxKzy6wU55Sey0hLMlNZQ8dPrxr957U9Izo8euGDRuam4/rEZb4 devWrQ0NDWvXrq2t
lf77ghcUgAJQAApAASgABeKuAIUNMM/rvuwWwlZmO1ObiVnX7m/lRvy6bq/o f/Xwa22tq9pRza2h
sXFZ1tyXVzxKFEvH4inNMRXU86tYW1NTI9OHDsSyQnoTT1dqC4NfaYGi/SkH Dh9J/WbCui/npH07
6/B7I/f0HLTj2e+2EKc++Pn6D8bvO3acEFR6LdtRdPcn6+/7bMNDfTc+8dWm 5ymoYPCOPmP2fDvr
yLeLsr4fm3S0sFC09Zu2V9WdcNa1FlfW5hRVp+VVHMou2ZtasCe1YMve9COZ BazaEydOHM4q2Lon
/Uh2aXpeBeUsrqxxNZxwH2tbt3EL9Y16SFseRMn/um7duuPHCaMNEDYpKWmV /KKDuF+s6AAUgAJQ
AApAASgABUiB9vNrTa3LXl3NzFXjTqs8+OyS+xdlzCR45emGB1RQz69ibdQ9 +/ffk9FBo1obHYjp
vGaltjD4tai4JD0jg7YhuPn1pYNX5n04Yf9rQ3Y923/bI18l3993Y5/xezm8 UsNLdxbd/tG6/36y
/p7P1j/UN/nxfpue77/t9aE7Pxi/f/S6o7f1WlZYVEIVckvauKfhRFtJVUNe iSstrzIlo3h/etHO
g3nbDuSu2XYoRViOgBA25Uj25t2pBzNLMgrsucVOKkUxs2s27SWHLnmIC4tL osSv5F7Nt7vnpdcl
7/i8IfmK9QMvXjvwLNfBviyQoLSkpCA/X8+vNpstgreQWBs7Drv+dhaP4KAM qwp7XO3RJNqDimD9
7dEngt1AVVAACkABKGBmBeiBLSngNVcOeE1r5kae1zX7WsiS9jWzA1/+V3eN q9xezayuoXFe6tTH
5/13ZdZC2nBKTKfASjrLU+iACur5VayNdKv4+mtmdExATKZJ5BUqtYXBr0SH BUePbt2desMbq/vO
Ses1et9Lg3c98d3Wh77a9N74fQ3HPAu1ljoaHvx6000frLnlo7X//XT9vX2T Kc+T3219efDOt8fu
77cg8+ZeSZt3Hi4uKSUrKimhfRC27s20154orKjNLnIeyqnYn168NSVn857M 5N0Z63amzVm2scLu
5NcHIey+w1kbth86kluRXVRdWFnnbGrbtj87LT2TOkmRtVHi174TVl4/r3bO 4u5Zq/85sNfl//w0
ZenmfXOnvCSGw5ILVnMd6zlDz6DBX/pm4Fc/5ESn2IuPKLyUdjKoYQ+DB77g cwY/cUHmDL7p4HMG
2TSyQQEoAAWgQOIpQKsNUOQACx64+9l+LH6A4JWwlYxSVskIS+aLX120G0pF dW19Y0sLPfPT+sD0
G8jG7h7EPlI6O0WJ7CNlZkYF9fzKamNW3yDRatkXXzBj4osf6xuatLWFxa8F 5RUVY6cm/afn6ncm
HXxu4I57P0+++f01rwzeUd/kefSejl8dsfuhfpsepojYrzc9/t3m7t9vveHd pFt6r3mgb/Lzg3Z+
ND31xtdWj526uqy8vLSsjN7Xb9i452BuYVVjRkEVkeuqTftnL163ePXmJau3 LFq1acHKTfNXJC9J
2lJTWy8i7NZdB5dt2EWe2ozC6oqaVqph/YbksvKKKPHr/tLaP02qX7Pm/qxZ f+738nkPDFz86KG2
3/YqeOTTr6QJVB/n6sj86p+t9e5eXylsltvDZ+DXxPsKxoigABSAAlAgDAU4 vxKqMuP8ylP886vT
5SoprybSuXXs5XpjFMvT6bimvpHyk1FBPb+y2rjV10sIW/zJJxqjxPr6JjGn UlsY/ErhqrSCwqdf
TfnbI4tveWv1Fd0XXfDA1PveWVBTJz1B5f9V5Wp44L0FFz0088pnFv337aQr nlr+Wb8p5RWVzGbN
mrtl15FdB3I27zy0Yt2OqbOXUAxroCqlWNh1G7fPXbxm045Dew/l7U7JmD17 rtPlPlpYJPpfTzJ6
6VcbCLj+QI8J+xav7Naw5PdvPPCTY02Nx441nT+q9cY5bb95tkBakUBF2OXL l2t6zh2QHKpEl6Th
sS8HrWG6YbUcAUVvqMYVyvExVBepYT0a4gyeVgMOSqxZ37Rh5/kU+JKa1akR hzekKSXWJhYMhrB9
dVgzQb6uDf9jN5zlgDcOMkABKAAFoEDHUYDWeSVg3Z1BS8C2cmDddFjyvDJb ub+ZuWB9rT/gcLqK
yqpr6iQn678GnS8ag1d9ImWmIlRQz6+sNtHqZIQ92rs3N/pYV9+kyabUFga/ lpSWNjQ2fdh30snn
DvnddRN+d+3E3/zz2wPpZUFeBEOn7zjzXz9Qqd9fN+Gk80Z/9MUkd00ts5mz 5ixYuGRl0oY1a5Nn
z1uWtG5LkHU2NjWNHT91ddKGpDUblq9YQ/VQD4t18a8agpXW1Qp1/azjdavG X9u27qI3ul/4ozu+
Pe2pKT96dPzJT6w8850tnW//SHqiS0JYaV2tpUuX6vlVD0CaFA4i+vSALBsM KRp2KZiC+jwaTtVj
qx4KxdHphxOQXw0x0VfnNcAnDtwXbooc72ciRLr1Q7S+2FcvVDApItcaXkXB MHSQdxOyQQEoAAWg
QOIpQDsU8JhXEVs5vBK/SkYhBHuM1x8otzsycivIqlz1zc2tl3zzR2Z0LH7k 6ewU5aeCen7ltbE6
yVxuadeq9Bde4EYfXe5GnoEdKLWFwq9SZIMU0FBW0XTs+NcDZ5189oBfXz7m t10nnHnzyL91G1pQ
5go43zsOF13zzJhOt0z47XUTfn3Z6JP/9O03P8w6Ttwn28JFi2bNnr9y1drl qzYsWJ48ZOyMrNyj
AetsOnZs+tzlk2csXrFqw4qVa6ZOm7Vw0WLqIUUkqBtxKcvWEq1yhGWLwvJl X4Nc/7W1ek71rivG
9jnrR9d8cF2vyY0N9U2NDbS+w7GmpuPHjjWzRQlapKVhFy9eHFl+9UVgGrLx z4Ucy/R0FQxQikiq
51c/LB5k5X6oXcNnvP9B8qsv+mej8O9n9cWyfur0M/XB0KphHv/d0ExNwLsG GaAAFIACUKBDKbB8
Z4O01Ktg3PO6/nAzGePXFfuOr1D3L3DYs/kWsgSgFXZHZl4ls2oZYS/68g/0 TsfsI1nflR9SIktn
pygzFaTinh0H7Jma2igPg9ek22/XmIywDbxdXpuzMpOZI4j1X1V+La9obDo2 c8Fmos9f/XPimTdN
7nTfjDPvG3vJ06PS8kpramrc8qu4vOrm92af8cCwM+4fKtm9g8+454ff3Dus 0wMTO903s9ONk395
+fiT/ziI6qH1XJlt376L6DNpbfKSlZvmrtg6ZcH6EVMWfT9q5oCxsweOnTtw 3NxBE+aPmbmsqKSM
NUFtVTscU+cuHz1t2YKV25YnbV6zdsPc+Yt27NhFPaQQWD2/MoQVdjTQIqz/ +IGm7Jdqpv7xnP+9
etKbyTd9tzA1I3fuxiPPbWy5b2lr7+GLPAjb3Dx//nxz8qsvlAwGMUX8jSO/ BtlVQ+QNiIa+qDSY
RkUUjqz/Nfj/G8AR26F+kDBYKAAFoECQCuj5lViWEJbBazD8WlnlyCmwc3O4 G4hQ6Z2nVFTVjt82
5tzP/zBowwAxnQrq+VWszV0jweuMa69lxkYkfqQMvBVWWzj8Wl5hr62tS8su +vEf+vzqhrln3Dvj
t0/M7/zCst92n/n3lybsPpRVqL7SsvJueG/Ob19J6vzm5s6vb/zdK2s791jd +YXlv31iwZn3zvpV
19k//v2bVI/krpSNViEYNHjYhi375yzfOmfVrgXrDyzenLp8R+ayHZmr9uQv 25E1ds7K9MxsVn1R
UREtMjBl/urxCzYs3HBw/po9C1btSN6y56uvv6V6qIcVlXZDfvXekSs0fm3Y cX1S3y4Xdh99Uu/d
p69quz659dZdbb9b2fZ/949ctXq97IVtYkvDzps3L7L8GpCrfHki9RingaFg ChpW4qvmIFHPsBsa
L6PGu+zfB+mrbDANca4NqHPAnPqvkiCnQOx/eN3w85+KIL/gkA0KQAEoAAUS UoElOxpohy3aJJbb
ltTWzakta460LE1p5rZkz/FlO6Wn5GnnUY3/tarakVdo92OumoaB6wf86ZM/ bM3ZWlrh5DmpoJ5f
xdqoucGXXcaMjmtqG8k0iZrawuHXaoeLWj12vOXy6145877Vv358Yeceqzq/ ubHzO1t/23PZP16f
sW7bvsPq66vpGzu9sfL3Hx34/Yd7O7+3k/J0fmPj73us+s1jC868c+U/b3pT 2odVfTU3N7/3Xu+t
e3PmrtmzcNORZTuyV+7JX3OgeH1qxfrUysXbMhav2cprPnDw0JRF66av2kV5 lu/MXrTpCCHsjv3Z
H3/8KVVJPaxyOCPPr5v/PemVPw8f0v+inmM7fz7vgvFZf/xq6/UfTN+wZU9j Q0NTIwskkBB2/Pjx
AfmV0YaIaBwlRe+dHywzpBzDsvqGeIovfuXd0/RQ06gvxBRb1FcVTIovhhPL +lJM30k/3fbvK9UP
3880+frW00yK/qMGssVrQ4+/mtk0FDMhv38xKCgABaAAFAhPgQVbGmirLUJY yVI9Rvy66rBkyw62
LNrXvGjP8aU7lf1jNfxKz2EdLa7yZe7ahuaW1t99+Ifv1w2gYzEbFdTzq1ib hMsXXURGB7V1jaws
HYjpvEJWWzj8Sk+TkfOTHjQbMX7p6VdP+uNbW3/71obff7jn930P/f6rjN99 uOUffRYuW7dlu/zq
M3FN5483/3FAwR++yaaznT87+PsPdnV+K/kPryWfdtXEURMXSytOCbYqac2i 5clr9hcSra45WLI+
3b45t2ZrQcOO4mOrDhTNW72ZVbt12/ZpyzfN35JGZ9en2ZMOFC/flZO0O2/J yuQVK1ZR36iHtH9s
xPn1WNZXJaP+urv/xVlT/r14Wr8R8zcu27i3vq62ob6ukdZ+UBC2kRB20KBB 4V1hjEX8lPVDdWG3
aM6C/nUQ+6zPGXzZsMcegybC7hsKQgEoAAWgABQQFWg/vzqczuKyakOzV7m3 ZG09s88fyIjBysod
YjYqqOdXsTa2eBa96EAsaJjOaguTX+lP8y6Xi57luujyp//y8YHff5Ly+6/S zx5y9NxRZReMKz+v
//4r+y4dOi9p9II1//5q6UVjj140sfLCCZXnjCo7a/DR33955Pcf7f3LhykX X9md1kpg8MpedEAP
Q73++ps7c1zr0yo35bh3lhzba28jS6mm9+ZJKzcvW7tx5boNM1ZvWrY/jxL3 VLYR2q7PqFp7qHR3
juvVV1+nlQeob9TDaPAr07dfv341NHy3u7bGXUeb1NbW6hGW8oR954BfmXTB AyL4NeyLDQWhABSA
AlCgIyhA/Ep7a5ELdtOhZnpnRmGv5HldebCZjEIIyP+6YNexJduV9Qc0/ld5 xwGHL6OFrlpaTpDR
gSYP279A8/yW/9r8NKTuhhDo+a3TumR06uk4vVsuW3yAjPyvkmf4aOGxY8fX bNp/8gWfdp1ccdaw
4gunVF8xp/qaBc5rF7munp7bZfCWy39I/tfU7K7L3Ncucf9zvvPyOY4LJ9vP GlZ03cSyUy74aN3W
Ayq4ev174MChQUPHZNe27SxtTnG2HXS3pda2pTe0ZTS27Sp1LN9/eMH2fZtz y9IapPRDNW37qynn
8Qx328BBIw8eTqVeHT161F1La2NF3v/KLvEPg3t1hPsBY4QCUAAKQAEoAAXM r8C8TXWr9hxL2t+8
bv9xbkkp0oJZS2WjyFeC14U7Gxdvk5be18e/1tW66W/3YRgV1PNrO2vz6X89 a7LtjAE2W+cUQ34l
hLVXOexVVa2tJ/oPmfZ/1/a/J6nh2pV1NyXV3rG+4c7khrs3NdyzpfHerY30 TnZncv3t6+pvWlX7
7+V1/11ZS/l/GDG79cQJXzZ37ryhY2cV0zJgjRK25jYrltfaxi3neBtZZlNb RlNb3vE2yr9w4SLq
D/XKXkXr6zZEj1/Nf5mih1AACkABKAAFoAAU4ApkFzWt2u5evasmaVctN/pI T2sxo7BX8rwSvGYW
SasBaPh1xarVLqe9rtZVE6JRESq4YtUq0f9KH9tV28pV4fMrISwtsFpVVUXb X/UfPOmUv390/wr7
EwdbH9vX/Oj+lqcOtDx9sOWZQ9J79wMtj+5tfmTP8cdTWu5dbv/RPz4aOHQK lfL1YlA7c+bMr78f
kdPQVkr7iclGB6JRSpGcnt3Q9uV3w2fPnk0VUn9Ky8oZvIJfcd9CASgABaAA FIACUCAMBTT8mpKy
c+v27TXu6qbGmpCMimzZui0lZYfIr+2vLQR+rZEiPb2MYj+Li4sZwq5Ys/Xi Kx8+76WFr+1t+Ki4
7b3itreOtr2Z3/ZOQds7RW3vFbW9urfhvB4L//7Px1at3+4HXsVT23fsfPbZ 5+ev3WOnDcRoPYW2
NqdsbtnoY2Vb29w1u1944eWdu3ZTQbvdTv1RN/Piu3r5O3DXuRWrdbm9Tfwf Bs0iDApAASgABaAA
FIACHUcBV1W6syqDGR0fSNm+YuWqBYuXhmTLV65KSdnulKpKd9rTFKtKS0nZ RqdCqWrJgsVLlq9c
SQWdVWnOqlRmjsr9zGx3uG1dc2z6+AFDfiWELS0rox1l6+rq3DV1Q4ePv+o/ T/6/6774R8/5d/2w
+9ExR/43YNffXpn302v7/uuGp4aNmFBTW8cJlVbLamykp/br6XEr9qJKKOX4 8eM8T119/eTJU3r0
eOWrgWMXrNm1J6cyvbxhd3bF3KSdX/Yf/fLLr0yZMpVqoIIlpSVlZaUhwStl DpJfiWXd0uNakvnx
nDMC5hn0RTgiayoR0NnprvWymlqnYjXOGtncNS7V6Nhj7KyUwbsGr48sP8/g Ke5w10jGKxEOKFE5
y/KoOaV0w1NiNrlOnrPaXaMxfc36PHKKWzVeg7vKzUxTJ8/JM3hyUmbZ5BSX ako9Yn6WTTK7YspZ
u9ttbC63nZmvDPp0oUil2+1lLlclmZub91kxs8tN25ZIpqnB30e1Wpeb9uuT jTXnrmDGPnobJcqm
NscKut3lzJSzUh46lsztqmAmnGLHSgYhJ2WWzNcpfbrLVRZNK3W5mPFWeErA gxKXKwrmLHYxczHj
TfAU9UCbk9KLJPOkyx8NU1g6NyeVkk2f4jlV6HIx49UWupxkalnp2Nu0OXUZ 9EU8KUddTkPjlfjK
4DvdUeDyaUddDtmcBV7G8/N0fYpyKt/llE3fBEsXTykfKXPI5nTkkbl0xtKl U07VPHlyXQ4yg1K6
RJZTMU+dQqJytjrXxYxnrs518kT5mJmrOoeZ06GYy5GjGD9FZ9VjKbMuA69E U5vnY3W2UzGpKtmU
FFd1NjOnQ7bqLNV4EZ6iHLiqs0QTimgzOKuydJbprGImn6rOZMYrVM8q6fIp 1aoyXUpZVoMKlNUZ
Ltmc3DzZlDw8s+8DGSur0l0SoUrGaZWAVcOvSoqdMFQ2hqR685NB4FeJQT05 iUdl02RgicqpVKed
gJWntJtfCWFpE6yCgoLy8nLiSELP1PTs2XMWfvPd4L5f9KN3Ok7LyCHfdVNT E+2YRf7akpKSvLy8
/Px8KkXbEJTSq0yyouIiSqF0OkueVPKnUn4qRWVzcnKXLFk6fPiI77//nt7p ODc3j9qiFqldKuVw
OEKFV/CrgL/gV5WGFSYGv4Jfwa/gV/Aro1vwq0So4NcE5Fd3bS2ZvcpOAJqT k0OP/1dUVBBQEoDS
AdEqpWRnZ9M7HVdUVjic5JCrqaHVp1TzOHdr5fQaN+WptFeSV5XYlJUloqXa qE6qmQ4ohdoi/JUw
Vy4FfoX/1ctTC/+rL6cs/K8B3LfwvzIHLfgV/Ap+9Xhhwa8Jy6+cQWlp2YrK yrLycqLMysrKquoq
p5P+CC4jJo+gZZzqg19FGGV5nG4X7ahVWUk1VpSXl1XaJQhW/6DP4BX8ivgB 70gD8Cv4NcwwA/Ar
+JUFFYBfwa/gV11EQSLFDzD/K2dTD5UqWMn5Mnx+pToV96oUZyuZEF0KfpWi WhH/qgTCIv41YCws
/K/wvyL+lcfRIv41cAgs4gcQPyA9v2VV/yttRKuYupEB39Ggtp52CjA0dcuD +oYaZurKVuwjL6Wc
5dmMalOK0K4EzOrrFVNTeCX8VE0d7WJQX2tgaiW6UzX19cykPbXq61gN3pXU 1dZJVqMar7+G8ktF
uGnLCkWUSmprafeuOnqsTbE6+m+Al7EMcp5aZmoCHbBuqPnVSngGXsRzIGcW alCOhUb5/zF4tcJ/
P/T/IRFTVOc666nqFPd3oI5J8J1T8AiZ9JycZPL/jCSTEr1PCeEi8jNzNdx4 ZjXF52J1umfj1DUo
PA/YCf8xkP6HwKvSpEsf+ZNq/P8SnmfXgnnQTXzWjSJoyDRPwhk+P1dTU81M 8xybJ1336ButZsLM
4Kk4Vo96qsZdxYw/4qZPMXj6Tc7Pc+qKaB9xq3HbmQlVafLwp9PUdJfdzcwP rIsPwBke87Las8qT
Z/wRtIgc6J9XY0+tecxZ7vY2gyLOMjeZWoo/YaZPcTnLmNGOOaJ50llVlEf3 mJrbWSqay1nKjCfy
FP0plkdIL3E7vczlLNEYy8ATeX5PiqPEzcy7Kk9OR4mLmace5Yk3paB0Sn0G TnPgKHYpVuRyMOMp
7TngtbGDQtU06Z6PTkchmau6SDU69mGe2lQPseIqVlvxFDzqqpaN+5LZR266 dGf1UWZCkQJXtWTq
KTqQjCXK6T5NzZPvqpatSjVdWSUDyyaYszpfsap8p2y8EvZRtjxmrCAv4qIU 2TwZfKTwDH4Pcp1V
/sxVlcvMIJs91+llOU570FaV4yTj+dlHMcVTVbbTLluVbOxYMl5cTNQcZznt oulzajLQR+88lVlO
jXkqzHTaJXNUKqa2paTzgo7KLMXsWQ7ZPOtkUXGhBs9qXBWpDtl8rj8AflU5 FfzqA0nBrwrCgl/B
rwYEDH7VcKoGWMGv4FdDhAW/amkV/MogmOEsWUfgV5erZsv2vZOmLxwycioM CkCBaCtA9xrdcXTf
eTtx4X/1drtyFyz8r7L3FP5X+F/hf/XyzsL/WplJXliFVlUPbij8avA3fSU8 QAkk8AQYqIEB/G/9
nj/6+4o00KXrowKUsAElp7DJFi+rRBR4ohTYX//leICyiqphY6bv2XeYniVr aW2FQQEoEG0F6F6j
O47uO7r7+PK3QUQL6AG3ssYtmWcNXX38AE/RLJqrjxzQhw1oUjwfVTeqPkVd 3VYTWsAXuxUCA7S+
WHV9XB8USzjLQVYTYKD/6IkB4Mvu8mqVsAEeMKCEE/AiaoCBJ36ApwgBAPpQ ATFFH1GgjR/w/Omf
hx8ohOpylCqmNKf+9V8NBuB/+vcccLpVqi12OyRTggekgspf/D2RBrwD8kGI sQHGf+t3O4qYqfEG
ngPtKR4MYJCZRxR4HxgU8ZFTCjbgkQDekQb6aIFA8QP6sAEhKkCJKFDDBpRG eQZPIEFVgZOZGlHg
qiqQzCDSQPkrv5KBZVNMiRBgnlchWkANA6jOc8rmiUZQgwo0f/3Xxw8IkQYU bCCZmqL80Z8X4cEA
+qgATZCAJwOPEPCEEOj/1i8HEqg+VJc9h5m/8AAtv/LwAF0EAgsb8Ioc8BMw 4HXKYc9mpo0K8Aoq
8AohYH/f5+YdfiDl5MEAnrgC74gCzqAsukAyGVVF80QUyOTqOaUWCcL/anF+ HTxiysEjmSfa2ppb
T8CgABSIjQJ0x9F9R3dfBP/6wd26XvGv4Fdl24gOx69pKduXLZ7ntJfJFAt+ lUEW/MrCYXXRruBX
HZ4qwAp+lZ/x4qRrJv8r/YIeO378WMuJY62t0jsMCkCBWCjQSvcd3X0R/OuH t1tXfbQL/NpR+XXZ
4mkDv/2QtrkBv3qe9wK/gl8NPKn+fLHg18YZQ+5fM/gXM4bcJ1GsyfiVXEEN za0NLa0NzSdgUAAK
RFuBxuYTjeTmbWtjf/1oaGqpbTheU99eo0qoKubW9aw/AH7tqPxaVlZG8NrW DH4VQgjAr+BX8Otp
XTI69XSc3i2Xr5ZVU9fITLciQYPD5d4w9OcnjpUmj+pUXFpqsMBWoEBYYQ0s T1TrrLFvbxx70czh
T3kBsS6eQQh7VRbqUhfSkqoaNGLKiRNtdcdbYVAACsRKgRZqiO47uvsaGo+5 aiNpVCFV6zYIb+Xh
s7Jr1s8qWp61tyrcbtmUzIHXzxLiXDWZ+Z/v9ZUYB7z6W5dA/0SXs9xFieqS WAaLZOlXxfIuollO
iz4KK2rxEFW2tJbXKlqGHwMurSUEyCrhrfp61Ep4BjVAVl0MS1gDS7v2Flu1 wCjaVQmNZQGyHlMz
X3pjzoXXp1x44346NW7CnKsfTCabMmO+tMwWXz+Lr7RlFOqqD341SPEEs/KV rdTlsYQVtYZOWPTq
xxNf/XiSZB+NmbdsnRwDoDP9clqaPL7CYQ0jCuTMnrBXzbpaXh95AKtXER7k mrRq4bx588aOHTta
ftEBvcaMGUOJdMrH6lpq/KtnHS7fK2exJbH4+lnV+WPG7NUYi4WlPG1X2ChI QHiXC6ohsyx+INn3
a8OGDSuXLxCiYCm/rzWztLGzRjnV+FfvRQNc9lxmQtirrhXNAlueGrRu1IET Zv4wfRWFvTqqcpj5
ChIIPl3vjhVSeBQs74kc7epZ8UpdSIuHqPK1AjwHWSuXzRo0oN+Hfd5/5+23 yT784P0fBvRbuWym
5jktT2isZgUuNRY2mPhXdTFX3/w6f8b3WesebWs4nL/lpVnje0eKX5P6n97o Okzv+fkFHoQNlV+H
TyFHkKup1X2sBQYFoEAsFGhqcR1roftu0PApx5tbHe5jETSqUPK/gl81i7x2 PH7l8a8SxXqe1grA
r/97uPmyG/JO/n+jGbxu3t9KpiBsbPnV6SjqMzRpwKIiZoOWFN3z/EAr8mtD Y5PG5s6dGz1+lZzu
wotwNiR+1feWpezevfvbIZOWL5srxM6akV/XrV0yaNrilSsX5GTuHrlg85jl e3btXDNl5tRvJyza
smVV8JwafDhsBPn18MFNPwzs16/f15OnzFiVtGHnrgNkdEAfKZFOUQZhpVj1 0a7o8uvAy+qK57ZV
DG0onb34hwsiwq/LFo0ncj3hXkvvs8a/Hza//jB8Mv2OVje2OBpb6N2PuZzp 7rTPHJvvKl97c8WB
7xyuQv/5cRYKQAE/CtB9R3ffseOtdmdTBI0qhP8V/ldyvvL415D49U9XJP/i 7Nknn/4MMeu+Q86v
B4/6bvCIQ4dLJISdPl9xwUbU/2qvLEjPOJKRkZaRkU6Wln6krIx2Zy3Mycu6 9OGZN3+exuymDw9d
cttXwfBr8dH0cWOHDR82cMjg/sOGDtDY0CEDyMaOGVZUkGb8RFek/a96Ioye /5UW2CJgdXu/KCVI
/+v8RYt88eu2bdsaGhoIYVeqCGtO/+uSpXMnrD4wb0v6kh3Z6w+WrtpXNGLx juELtw2avWHJsrlm
5ldi035ffTJq1Li1G3aMnZf24hcZN7965OaeBx7/YPd34/csX72VTlGGwwcU hI2A/5VvD+vZJ7au
xs1M3iKp2lm9fvDPTjRltOU/01a7dePwXxUVF2o3YVKXuGfpnp1mvdPls8oO TISt1bkz2qr615fO
oWO2eWwY+8fSL2jLibbKhhbZmkUbs+voPZOPXDyz5D/Li7fnvd+47/Z5Ux7s ++k9g754ZNL3d1Yc
6q/Jj49QAAoErUAL3Xd09zUda62oboygUYXk1hX2jhL3kWrncanLxYzXw1MC HpS4XFEwDlKuYpdk
vAn2UTBtTjpVJJknXf6YQPvHeuJfnYUuvitsoIMXek2l4AGi1R0Hm74fPGxV 8i6yfsPGHzhSKSPs
HJe0r6y6B5WzwCUa33KWJ+pTlFP5Lqdkq9asffPrBe8NThbt9a8Xf/jtjIuu 63t2ty3nvpN37ruS
nfNa5j/++4PLkR/Qxo0dOm7s8DGjh27etHbduhWLF8+ZPm38rJmT5s6ZunDB zMWLZi9ZPIcSx44Z
4qQdYp2qeXaLZbvCEkMHtAD7xyatnk+uVo1DlD7K/tf5zupcl2p0zMxVncPM 6VDM5chRjJ+is+qx
lNk7A9Hq3qo20SR+lWuj4AHKL4UQVGerJlUlm5Tih1/XrFmzWn4RwjqrpW1j ubmqs0TTnKWP/Kyz
Kktnmc4qZvKp6kxmQhE1g+cUnZWtSjK1eOaWzcuSNy5Ztnzu/M1p+/Ode3Kq dmdXbUkrW7k3b8HW
1LEr9kyaPmn9+kUbNyx2VmUEYenOKslcVbRDrGSsCN8t1majeAyvFKc9XTG5 oIH5yWBPGzTwKyLU
dZsPvTUg8z89Mz8ZU7x0i2vFVuew2Udv6bHpyQ82zFmygzJQNmdVmpfZU51k nkQ6lsxRuZ+Zz/23
DPl1+sDbVvf/KWEls6ykB9ocs9rS720r/jZ7xS08Pan/T2Z9f41EpcHxa/Kq Sf8eedrPxv6YjA6a
aw+3He3RXDxUqPD06SNeLi0rcUuYy7eD8uw7KmwuqiQOHCbxa3l9c3l9S1l9 M7ODxa4n5mZ2WdnW
ff+JYRmb23Lea0u/++23bnnni5fv6DWO5dk070WeHwdQAAoEr4B0u9U1031H d1/TsZYye0MEjSok
LAa/gl9lZiVyZUbHQRnxqwyvjQMGDSZyTc06ejA9b8XGnd8MG3MgtVpF2Ijx 652Pf/TBpOz3J+SK
9sHk3EvvnXfrQ1/9+Zk95/5Qw+y8r92X3DMxILxShsGDviN+nTd3+rGmmqYm N9mxJndO9pFVKxct
XzZ/5YqFq1ctXr58wYAB/WLAr/Pnz7civy6ct27hfMW4R7a0pKQgP98XvxLP 8ZcvwI0evxYVpIxc
tGlWcuqa/YWHCmvW7ssfu2zHl5NWfzU5afyKPTOS9s3beHjU0l1fT1n39oCZ GngVe86plNNnbPh1
5bLpFDewfuOOd39Iv/qFI3f2SrM7j7e2HGtrowd92zbvKfn7AwueeG/FslWb KdvK5dOjyK+rvvm/
1sbstubCtqa0toZdbVUT2nJ7tKXcfCLl7rYjz55Ie+XE/kdObLutec0Va747 XXLHBsevuTsHEbnO
Lh/+Rs4ddNDmXtd26I4Th7o1HXjGvf2hmo0316++YvvQX6Qc2B08v343eGLD 8baUsuOiPTA98/KV
bU/uaVuzr29b6s0b517Y49nb3xn49cuH2nqntV353sr+y9ePGPaephQ+QgEo ELwCdN/R3dfY1FJS
WR9BowrBr1p4JUdsx/O/etZ/DZpfx06YRYS662B9/8HDCV6z8kuKyqrziyv3 Hs5eum7710PGHEyt
khF2ruKCbbf/9fLr3/xfnz33fHZItLs+PnDVHX3J0Xvn00PPfnjjnx/dRHb2 fctfey8o/yvx68QJ
o+bPm5G8MSk5OWnXrs35eemEsGTpaSlEscSvK1cuiiq/fvnFJ3369PnW74sy 9P38Y+aCjaD/lTys
5HCdudvFXbCSR3av5IL1OHdD979yivXDr8xpSvAqUaCRgzZ6/FpZljpi4uS5 mzP25TvWpRR8OWn5
FwMGpKVuzsrY9u2IsSMWbl+6LXXh5sPfTN3Qb9AgQ+erQK7M1RpT/+ugAV9R kOuURUeue/ngtS/s
uaXn3je+3X97j9XPfLqjprbpWNOxW55beO4dk78YtoayaV2wYftfiRS1VuOe +t0tW0add6xsVlvl
kLbMRyTK3Hv9ie3/PLHx7ydWn3ti2R9OrLrQveCcjd//ZPrX/3LXuLXG6+Sn 5JSdq4cQtq6snta/
pIfEr2WT24rGtuWPaMsZ2rbmopZVF0uxsP3+nn80113rctdw4/WLicrx9zK/ 7i89vr9MsW+Sj/58
Uds9O9uO5LzVeuiaKcP/fOdV5/X5/Iu/TCi5YdmJJ/adeHzziat7LZq44yAv Iv73hSeyA3YqmJw8
My8iFtRUq2/FfwZfZ/30PLwKUQoKBFQghW630uN039Hd56o5lpJuj6BRheTW FfZw4k+mlyrPs6vb
OLHNmZyqsSfWZVNpT82p5il2OpgppTxF+JM9mkd89Om6FLVO5fF2zUcKuDRK KaKHe2RTzrIn3NVE
fwf8WXino1A2npl99Bh/zl2TR0jXFtHU4P3xqNMRlPG9o5T8/Fl4R4GTmfB0 vHKsrVnKxuNfvZ5z
55V4amObQuWPGT+T2HTPwZr+Q0cweC0meC2qzD5anppdvH1/+qI1Wz0IO20O 2wXK0LQOLeEZeTW/
slNUlxveuvDh5L+9vO9vL+9Xbd9FT2z/3yOf0uPw9oq8gvx02TKOFmRUlNMD Q0pB6cF5+ZF5OcXD
f3Q8eNC3kyePmTJl7LJl8xcunDV//owFC2Zu2bKuvPwo+WKzsg6v4v5XKqh7 iN5RncuN2Fc05Rl2
fRH2bLtqH35IaNpn657DH/l9UQbK9uEHvR18dyjpSXnF2H5RGiX5WcMDvs8T AatmIQHi16VLl0oU
q7Sl/B3fs01UVZajKstP/IDIr7lZe0ZfeunQt19Xi0tbmFJX+a5R/Jj3Xzyl SfT+mOGwa0zZH9Vp
z2Cmy6CkZGfsHLts94HCmsFzN44aP1LKVqnYuCkTRy3eMXPd/q+nrauuTHdw 89SWLvc5nZunV2pm
TYqUvzKNTJ+Tpfsze5qDmZrtwz7v0XNar/bbfe3zu/797NZ/dd/wtwdX/Pbm +Zc9OC8vJz8t8+gF
d4z93X9G3/vKLMpGmQM3UZlWXb6fmc/4AUN+JR6dOvTlFV+cXrK1e1vZwBO7 rj2xucuJtRedWHFW
68IzW5eenTfu1yv6njpl4FMG8ErMquPX20fczMIGyLa6l44t/+gXE09j9sCc n7elf++c1ZngddJ3
9+XmZ0vw2g5+vXLQ3r+uacor+Lh57z+Tx5/R/dqfJm3fTT/JfYbP+u3Ipktn nXhkT0vXcTXP9PpK
pFLDY0N+9ZMzbCoNnnT9NBF2JQF5BRmggKhAtPmV3LrgV18s23H4lce/Bsmv Mry6vh8ykuA1v6iC
4PVoiT27oCwjr/RIes7+Q+mbdqfOX7X562FjDqeWUWY//EqnhD8le63xpOHX K25678+P7z6nR7po
f+6e8t9Hv9RseSrQqoqwvvmV4JWYlQUPHD2aRfBKAa8UM1BWVkAp5HwlqJX8 r4H4lUCW86tnDaZA
/EpUmrx9L1kPvy+WhzL74VcRYf3Dq1SJPYsglb0IVXNzcyuFV1FREaWnp5Nb kcjYJ7+Sq49eb736
w3NPfWn4LBf5Xy9789ojWenDLrkkIL9qiFbPuLoUA37VQrwRwg6fPH3K8s0L tmetP1j8zoBpCuOq
/Lpvz7r+czfPWLO339S1vQdP++ibgQrC+uBXkWVlTpXpVmFNdqyksGOdecBU 23lWiY5faZ0sWmrg
lpfX/evp5KueXPvX+5b87qaZ5/1v+sSZ67LSDr748eJOXUecd9uYLvdPoGyU WYPOrBUN1IbPrwSm
+/bumPPpnxzbHjqxvavkdl3auXX+L1vn/MI+6RfzPv3Npo2rjeHViF8JWxdU jl3rnL29Zvm++g0T
Kz8bWf7eV4XPvpZ1m+SIPdyP4HXK8HcknyuD1xD5dV/JcWbrU6uv7btk9bZP mvffUrbgp3+98tKL
H3z4uiffvvb5D6588p1fPJvz8/fbHlzc0nW4+8Zub/BSJJz/Y57BV04qLp5i tfGJ9/WRlxJz6psQ
LyDeT16nvueadsWeiANh2TQV4iMUCKxAqXR5c//rgfSqCBr5XyW3rqNUMY9X Ff5XydXacfhV9tTq
zLf/ddG8ad8PHU3weux488uvvH7H3Y9f2/Xm9NySzPyyS2/u/qcb3zz3umc3 btszZ0UyPc61cO40
//zKENaTR12jVOt/veXTc3rlnftZmWjnvH/04tuG5eZnvNJ78ANvTrn/jclk 3d4YP2TCvCD9r9On
T1i0aPb+/TvS0w8wik1J2TlnzlTyvNLxkSP7Zs+eEiS/OqokhKX3kPg1af1m sof8vliegPxKYCqh
ieCa9XU8efJ0YlYiVHoRqhKwEr4ybGUvcsp+/fXXfviVFkaor69vqK9/4K7e hLCMX38YOvuHoXMG
DZtDx46qys0TnyV4JYQlL6yGX/lPpy9vqyG/ij/QRr5VxbnLsvnyv46Yu27u lvT1B0qTD5d8OISW
SpU5WOXXzPTt301fOy1p71dT130wfGGPz4ZHkF+NENbL+eqRhTtlffDrTc8v 6/LoqnP+N/+MrlNO
v2LcD+OS8zIOvfbp/PNvG3fJfVMvu39q1ydmiPzq7f3Venzbxa+0jMDij049 vvOuEyvPaV3029aF
v2udcVrrlJOOTz112cenFBYVhsSvH+U/PLj0zdHlfUaUvte/uEfvvAeeSbvm 1j1nS/x6qK/sfH3c
5XaGzq+T6Hd0T/HxvZI1J6flD5n4bmt6t+Z1Z151x622y563jWqwjT9mm9xi m9JkG1llG1r6+9nu
UwY1XHdvT8rPjKbH/zHP4Csnr4fNtL5aXj9vzldOfRN+Gg3YH8PR+S8ldhXH UECvwB7prmH8Ook2
LziYWRVBowrBr34CCToOv/L41yD9r0SWXw6ZUlbpJH797Mv+A4ZMufG2Bw5l HCWEvemxT657rP95
945O3rR58fo9lC0gvGoz+ODXy2/vd27fqvOG1ot27reOs+7f2OXmATf1XHPv 54eY3df34L/uJ/YK
HD8wZPB3hKrkfyUnK3EqeVuLinIIW9euXT5z5iQCWTqmg+D5VYbX0Ph16YrV ZP75lTIsbxsVDL8G
A6+Uh/ErQ1h659jKUgheKYN/fp0yhZaOdpNJbjR6Ary2tq62rr5OIlpaPKva XkHw2uwcQu8CvNL6
/Nr4AX0KI1dDfuWwKx/4jB9g8OonfmDF8nlzN6dvTS8buXjr9FmTRH6dNGPS gFkbp67a8/mI2UlJ
CwLGD8j9VGIJGJ7K7wwQvfyvPMWbYrUoKRQ39r+y+IHnP1p51m0zf33dxF9e M6ZT1zGjpm2ZtXDr
X++c+K9H5nR9YuF1Tyx+rs8KffyAtnKVkoPg1xqHmxmxIzM1ZdWSqcnf/uLE hstal/z++PzfZgw+
vXHyqcSvZNu/OnnGqA94TrebikvmqpGMf+QHtw+/iUUL/GbmT74rfrl33v08 nIAOmiefVDvhpBWf
/3rzppWeqtzVLtncqrmofmY11WQsvf+QSfXEr4XNe4qO7y48nlO5asvWd5q3 XDjoq6tt5z5pe2Cc
7dFxtrsW2O6fLtk94203DbLd+K2t6xfXPvAG5Wcm/v+JJ7J0nsF/TrEUL8iL G5YVz/o/9nXWV881
w9EXFzNoOqkZCD5CAR8KNNN9R3df1PhVdTTyYFYnrRXlMaezSGPiWeXY461k Ox7xOnk96uPt2pzK
DklOZ6Fi3qGlhnGiLK5UHyTKV2vyGz8qRXy61C2LhJw8ZlTxRMrLP0nGIkeF j6qr0uOhzHc6vI2F
e6oZ+LPwPJtBSrWyeRLjOVqeU2MGIOjIo+fiJVOiSwVi47slBXEgxL8GWwOB aUm5g/j1y37fP/T4
S11vvv9gamZabsmAERP+eNfIzncMWbFh54K1uyV+ZX9DZ4Gn+n2YeECqekpY KEperUkNFR01ee7Z
D6w797Xcc1/L43b2w5tf+Wx2l1v6nnv/movfT7u4t2x90v5x+7e8oHSgLPyk rP1Eyz8xF+mgQd/M
njVl1szJ9D5v7rQ5s6csmD+jqdFFT3FNnzZh65b1TY3upUvmDuhP6xBJMabM NIyoTzdK0a8GJaUQ
krINtw5nFfoxlkfiV+K2Kp159m1SAkC9Oc+gCOEpMSu9U/AA98JSCjErey2Y M5jevepR22WLiU6Y
MMHldLlc7pnTli+ct1ZexEhB2KrKMgleqwfK8LpLD5oyRckuT5VBReKUiTCD vTPTpXhHoHpCVNWY
VIM/03v94X758jmLtmVtz6xYtTd39MLtMqdKsLhoycyvp6wZtWjb1FW7Pxkx b+WK2YbBoyIFyse0
/pRk7JjeqytTycQUnocniil0zIto0oWPRxyVkv0w4Et6MGv45PW/uHrUL68e +atrhv3hhpEPvTrz
qXcX/Ovh+Td2X3lj9zU3PLl24JhNlI0yV1ce4cZq0HyUUsr3MfMd/+qbXyd9 eUv66DMp4NUx+f8l
fXrK5M+uXPnJyWUjJH7NHnTSlI8vDZ5fOYMSv/bJf/CJ1KsIW6d8fPHmjSsm 9LuPnK/2USenfHfS
0gXj28Ov+4ocZc5x9Tuurl3xy1P+3ct2zyBbj9kr9hQGRBA9p2rQkAGfSLT+ 69RnNoRIEaD9HPvn
V0N0FrHbf9MBxUEGKGCkgMKv7rpjh7OqI2hUoeTW9bAmf/Qe/CoRasfhVyH+ NQR+LSytcrjrqpy1
VdXOSnvVrpSMI1lFM6d+/ctbhv7khiFL1m6fl7QzgvxKGJqavn/N1uQ1Wzdx S0ndS1icW3DkT4+s
+vOQCsWGVvzj3gnB8OsPP3w9dcq41CP7iVMzMw7Onzd9xvQJGRRI0OiaO2fa hvWrKJ1W0Yoqv9bV
1pPdcONttNTrgP7f3/fG9+/1/fbmJx68+dEX+vf/nhbVolMsT2T5lTYuYAED tEstx1YWOcBB1g+/
jho1yl5ZVVVZtWDuGkJYR7XDUe0cN3r+8MGTCFsbCvrQO8W/Gj5BpedX8pWK vh6OrTxRkyI+PiW4
SIPi14qSw19PWjpiya6Vewq2ppWvTzk6a8OhobPXDpy5aui8LT/MTp6wbPug WRv6DF344uejK0oO
6RFW48X0dFIAWZao4VoxMWx+ZetnrV2/9e4XJ/z8qsG/+ufgG7pP2bJ93659 6Y+8ue7qbhv+88TW
F3pvXpW0jbKtWDYt6vw6+8Pflo3/WfaQU5d8ePLk758gx+f0Ee/N/vDMg9+f XDX6pLkf/L/w+PXV
jP/et/8y4tecnAxyr9rt5RvXLmZLwG7fvj4Mfq071rbzaPOuo8cPF2dWVQxu W3X+c28/ZLv+a9u7
SbbB6ee9MWHWhszk9JpXR6879eu2y1a3/d+EtpNntV33YC8qwozmT38sJvI8 mkReSnPAshlWa1hV
eDk1Tfgai75yX835Gg7SoYBeAbrvyP9aU3c8NccZQaMKJbcu+FV5JL/j+l89 W9sH4axlmQlMabWs
rIKy1Oyi/Wn5Ow9kb96bfjir6C+3v3tq18EnXfvD0qRNEedXEUnXp2zliwmU lWWe/dzGP8879uf5
Tcwu6UYrd3p8t778rwMH9iN+dTkriFOJWYlfZ86YuHfPVjpevGjOurUrKH3b 1vXR41fmWKXX+edf
xfYvuHtmc6aj+r5ve/39tYFs/wI6xbNF0P9KlRPCimGvDGR79+5N7zwE1oOw 3v7XwYMGVVZWMYSt
sldXV1U7qiSEXbdiUemafgSv9soyyuNrBQCN/9X/igHM/yqY59l/CWRD979S zMDMOVP6j5s6Jzk1
+XBx0r781Xtyl27LnLvx0IiFW7+btvbjgWNmzp44ecrYYB7e13tMg3CmKi5b XjaIIor/lYr8MPBL
2p5g9boddz0/9rfXDvrPk9PXJh88cDj/rhc2XHHv9ufe27F45V7KQNlEeKXj 8P2vTleVL5s+qs/s
DztN+bTL+jWLpDxuyUrKCif2u5vgddL33T0F5VMe43XyRJfdKdv/xnoWIvBu V8nAssmmdkxXiZDH
PmDoZPod3VHQvLPgeGrp/rr0F4/PvPKvz0+w3T3C1i/FNjrPtrDBNtlpG5b1 akrbdZvabFNqfrug
7eQb+q7YXbwj/zgzuhD5Mf8YTKKmFP8fj1gzr0f8n5xho35y6ms27DlP1OTX NM1aZy9xCDiGAkEp
UNBMdxzdd3T3EW5m5LkiaIxfndWFzByqef5kr0lXc/IiRn/clxd+UpdtclQf ZSakqA05jjpk06zx
xIsIZZW/1zuqC1ST66wqYObgpmbgcZy8iD5FqE2uVleJkCHfUZ3vqNIZ749a lvbeZKbN7Om5XJVx
bXmOatmU4nTgw1g2KaeX8efujQqyuEzPX/DVSE2pBh7/qiYqmQ0/shgA4lda cIDgNSUtf9fB7C17
09fvPHIos/B3139A8Hpq1wGcX33UKf353tt4o/pTLEX9w7095+HxPS6Zd93a fRsc9hzJqrJf7T3s
8memXfHiLLJ/Pj914PBJUn67YtX2bMWqsquZySkDB/Qjh2taKvlfXeR2pW23 aPOtZUvnJa1eMmni
qNmzJtMWXCNH/ED8So8fVavmWUlK/sN9dZVqQh6WmefkZTUHYlX0RBTj1+Eb Zp//zDWdH/+KPlJi
tT2TjHOk0A0lsboyUzE5Z1BWmUnBA2QMYZnP9e67737ppZcIXukje66LXvzB JqGVjGp7Rv/vv6+s
sFdW2lWErWII2+ud9yaOGGgvp8X1XJSHckpW6WXiryQ7ppWq9MazGZ4NKrEi vVo0WihKMam5ufOn
DZ67efjC7bRg1pSkfeOW7vh26pq+Y5a83X/qpKlj1ZxqkYq0amaeSqRjo7Gk VVVKVl2RyqxKNV62
qjKVGc/D+NXzUS1bXXFENc/ZQynr+335sbR/7PqtwyYmPfPu3P8+O+Pu5xc8 9+7GIeP3rF67Xdo/
9suPDqWsE4rzeo5UVSjGz1aV7WPmM37AD78qPGrAkTrkDZpffTcXPr/WHmvb nnd8W+7xI6W7j62/
asR716457Dqp68e2PltsE4v/tLHtoyNtbx1qu3RL26mL2i5e1Xbyf78es3Dn NipiEaNrMVJdjWBV
keoS6rGgAs3b85rpvpP+99jQnF1QE0GjCqla8KvCqR2YX3n8a0j8mpZTfCC9 YNfBnK37MjbsPLJ6
y4GDGUe73P/Rn+79gWxx0hbmf404vz489pmrd9xx/rhLL5jUZe2+NYxf7ZXZ xcXpxcUZZCUlGRUV
MuwG4tfRI38gSCVsZUbH5H+dNnXc5Emjx4+jfWWHjBg+kPh1zCjyI0adXw33 j40evzIeZRTLHtga
OXIkf5CLDhh6+uLX7775trSkvKxUsvLSivKyyvLyyopyeyVZRRW5ZouLyiiP Ib9KOGtPl8wIWyOZ
6Jdfx04a12/qmmHjxs6eN+WDYXNe/2r02Imjvvh+wMNv9584eXSQ/ErZPDCq om20+ZUwlxCWYlsp
QoCCXOk5LVpqgIwO6CMl0ilf8ErM2tH59VDRwZbllw/pfRsBwbRV+zrf9/FJ 76ywTa36zcq2ny5r
s43IO+nVBZ2f+H7mpnxrEUP7oZP/b8xaA0dvzaqAF7/mFdVF0MCvXi7YDsyv PP41eH4dOm5ekBZZ
fn1l1qv/mHrdxWP/9beJ11wyvesFAy5Pyd7h86H7QPxakJdCbEruVT9GGY7m 7Y8BvxKq0l/wx8ov
FjBAB9HmV0JJioKlp7jIC8t2LlDdt7Lf1C+/Ep76tx8GDDQzvxIoL14ys6z4 IB28/cWAp9//lmA0
O2vHuImjyGNqcn5lntoVS6f/0P9LWpGA1nklowP6uGLpNEO3q8fbGo7/1Vnh ZOZQzOGoYMZSHE7F
eAano1wxXtZZ7mSmlFIyOBzlzHgRfYpa0JNHrVypkxcxKOsop616apratuQc 35J7fFeevX7NzdvH
PD1r1ujM3UtL138y6uOrP/rs9ds/n3/rJzNfGbJy7rbSrTnNMCgABdqjgHS7 5Ryn+47uPsLNCMIr
VcX4tdpeoLWq/Gpmdtn4R006O6vJIyZKZfMUs+dVM9On8FPtPqiy5zFT2pIO ciNlVfYcZvoKjU5R
tjBNbUVbvMqerTHeRFVlNll1ZY5i6p/LWbp0iv8BXcrmsSp7lmJqTk+Kesrz J+/KrOrKrCrV6JiZ
PiWYU5qyvJKqykwfpjZUkVXFzNO0ryIZVZXM1AwV9OSGxjKqKmRT8vAiugOW Tcrpbfp0ntKug/Sq
CmasXf7Rz4Haw6Ay+68wraqCGc/GU4I/4H8691XE87d1/kf2oA+4H1FXSfmR KmaCr1E65un6A55T
U9ZXVWJtFYermHkys4+q8QyenL5PKVX5KXuoqpwZy6N+1FfOTwU6sJfuZeY7 fsDy/DrF2di2OatZ
tuOHcjdXTO9aOOXmVYP/s3zyk2u37KJEGBSAApFUIPv45uzjdN8NHDalobGl oKQ+gkYVEhaDX4ME
3ATmVx7/KsEuJ1rwa0BOZRnArwrp6iEV/CojJvhV8d3G0//qxa+R/JEG+EIB KGCogMivTa1F5Y0R
tIamVsJi8Cv4lce/gl+1vlURYeF/9cmpAd2rATOE4YiF/xX+Vwo5UJnYf/zA D8OnOBvaNmUe35TZ
nAyDAlAg+gpsyqB77Tjdd3T3NTa1llYei6BRhVQt+BX8yuNfwa/gVzVgAPED Mh8jfqBTT8fp3XKr
q0s0VlVdyqy6qkQ2OpDNk5OOmfGyXilV1SXM9JV7UpTK1ZxVxdWy+SurFqmu LpZMzk9L7Tga2jam
N29MPw6DAlAgBgpskG83uu/o7ms61lpRdTyCRhUOGj6lqjJXtZyqyqibvTKH GW+LnhwnE5pWQjZZ
unxKa77SeU4/ZasqssnsqnliKOV0ydTmeCX2yiwyntNekclMicLk4ZgVUjbR eKilUEQNvlQrtFdm
KsarZYGYBpGaSiKvzVOtdxF7RQYzHvfJU4SycgZPK8rfwT1lVXejUFap1lcK /0t68EX0OXnAZRCV
pNsrvK083U6mSaSPLN3wVEWanZkmQzmlaIzX453uqUFfJNVezoyf4inmOCg7 YmdWrpr8sVI1T7p3
BqUULy4dHGZWWa4YT/GcorOyKSnlh+2ysURPuvqRp/s5ZS87xMyoEko0MKGI cQZ9KV7EqOzByjJm
vmrjGXQHpQcrmSk1hJzBXnaQGa/Bk2JQ+YHKsgNKi9JZOpatZA8zn/GvVufX IaOmO+pPrE9r3pB2
nN5hUAAKRFuBDfKNRvcd3X3gVw1Z6rkW/Mp4FPxqzLXgVwWmBXQGv/qETi8Y Bb9a2P+6PnnX4hXJ
+VXgV4A7FIidAoxf6b6ju4/uwSpHSwTt2PETQ0ZOg/9VcazC/yo7XOF/VdgX /lfZBQv/K/OqdnR+
pb8AWtRGjp+zcu02e03LtuyWpMPNMCgABWKpAN13dPfRPUh3okW/Q9BtKAAF oAAUMLkCvuMHak9U
W9ayy1o2pzcnHTwOgwJQIPYK0N1H96B1v0DQcygABaAAFDC5Aj75ddXOBhgU gAJQAApAASgABaAA
FDCbAuBXYDoUgAJQAApAASgABaCAlRTwya9teEEBKAAFoAAUgAJQAApAAfMp AH4135ygR1AACkAB
KAAFoAAUgAK+FQC/4uqAAlAACkABKAAFoAAUsJIC4FcrzRb6CgWgABSAAlAA CkABKAB+xTUABaAA
FIACUAAKQAEoYCUFwK9Wmi30FQpAASgABaAAFIACUAD8imsACkABKAAFoAAU gAJQwEoKgF+tNFvo
KxSAAlAACkABKAAFoICWX0/vktGpp+P0brmQBgpAASgABaAAFIACUAAKmFAB iV//k2P70xTbGQNs
ts4p4FcTThK6BAWgABSAAlAACkABKMAVAL/iYoACUAAKQAEoAAWgABSwkgLg VyvNFvoKBaAAFIAC
UAAKQAEoAH7FNQAFoAAUgAJQAApAAShgJQXAr1aaLfQVCkABKAAFoAAUgAJQ APyKawAKQAEoAAWg
ABSAAlDASgqAX600W+grFIACUAAKQAEoAAWgAPgV1wAUgAJQAApAASgABaCA lRQAv1ppttBXKAAF
oAAUgAJQAApAAfArrgEoAAWgABSAAlAACkABKykAfrXSbKGvUAAKQAEoAAWg ABSAAuBXXANQAApA
ASgABaAAFIACVlIA/Gql2UJfoQAUgAJQAApAASgABcCvuAagABSAAlAACkAB KAAFrKQA+NVKs4W+
QgEoAAWgABSAAlAACoBfcQ1AASgABaAAFIACUAAKWEmBDsSvOfnFMCgABaAA FIACUAAKQIFIKdDv
mwFxwd6Oxa9xkRiNQgEoAAWgABSAAlAg8RSYNXMu+DXq00r/1aA2bJ8nw6AA FIACUAAKQAEoAAXa
qQD4NerwSg2AX9t5maI4FIACUAAKQAEoAAW4AuBX8Cu8wlAACkABKAAFoAAU sJIC4Ffwq5WuV/zX
EwpAASgABaAAFIAC4FfwK/gVCkABKAAFoAAUgAJWUgD8amF+ZV3X/CfMMLE9 /1GLeIXt6QzKQgEo
AAWgABSAAlAA/BoffhWh0NdxwKvTDPyqkS9gn5EBCkABKAAFoAAUgALtVMBE /Hpal4xOPR2nd8uN
BVHGtg39+gMJxq/sKoSntp13I4pDASgABaAAFIACwSgQZ37tmms7a4rtjAE2 W+cU8KsGAUXG1gAi
CxswhGBfDlFftfF0frlocvr3sGqYVd8lXyniEMQoCH0/g7mOkQcKQAEoAAWg ABToOAqAX2PhiTVc
/5WDnf4gGDYV8wT05vohXT0Za2Jq/Yc3+OLX4FsMZiAd54bESKEAFIACUAAK QIGACoBf48yv+uY1
QOkL73h6QA+oJqd/XNbHALSHXw1duUEOENEIAe9eZIACUAAKQAEo0DEVAL/G n19FnuO+z4D+yzD4
VXOJB9OEL08wryoY/6th5oCtg1875lcSRg0FoAAUgAJQIKAC4Ne48at/NAyI d778ssEUDNID6idb
8EgqXoLhxTkEv
Re: RAP controls demo doesn't work as expected - NullPointerException... [message #59317 is a reply to message #59292] |
Mon, 12 November 2007 05:36   |
Hi Michael,
this is a very annoying scenario but it's ok as you just have a typo in
your url. Everything after the servletname is just a parameter and has
to be delimited with a ? (or with a & for all following parameters).
Use
localhost:8000/rap?startup=controls instead of
localhost:8000/rap/startup=controls .
This should work for you.
Greets
Benny
> I get faulty displays, both in IE7.0 as well as in Firefox.
> screenshots).
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> this?
> Michael
FUDForum. Page generated in 0.03390 seconds
