Home » Language IDEs » ServerTools (WTP) » Cannot open certain xml file with xml editor
Cannot open certain xml file with xml editor [message #59279] Thu, 30 December 2004 17:47 Go to next message
Originally posted by: will70.gmail.com
I'm having this strange behaviour when I open an xml file with a certain
tag. I did some research and found some related bugs to my problem in the
eclipse bug database (Bug 78340).
I created a simple xml file that looks like the following:
<project>
<parent>
<child>
<property></property>
</child>
</parent>
</project>
and I get the following error message when I reopen it in the XML Source
Page Editor:
Cannot open default editor on Sample.xml. Editor could not be initialized.
The culprit is the <project> tag and it has to be the first tag in the xml
file.
On the other hand the following xml file opens correctly in the XML Source
Page Editor:
<parent>
<child>
<property>
<project></project>
</property>
</child>
</parent>
Here the <project> tag is nested.
I just want to know if this is a bug or it's just happening to me.
thxs,
Will
Re: Cannot open certain xml file with xml editor [message #59304 is a reply to message #59279] Thu, 30 December 2004 21:12 Go to previous messageGo to next message
On Thu, 30 Dec 2004 22:47:58 +0000 (UTC), Will Lopez <will70@gmail.com> wrote:
> <project>
> <parent>
> <child>
> </child>
> </parent>
> </project>
An interesting test case. It is similar to the bug you reference.
In this case, the "eclipse system" is recognizing this as an "ant build file"
(due to the initial 'project' tag) so does not create the structuredDocument
our editor is expecting.
We (WTP editors) do have some work to do to allow/enable this kind of use,
but I'm wondering ... is it really an ant file you are creating? If so, you could use
the ant editor in the short term. (guess you'd have to "manually" associate your
file to the ant editor, for now, since another bug 37688 is still not fixed/enhanced.
I'll add these remarks to bug 78340.
Re: Cannot open certain xml file with xml editor [message #59387 is a reply to message #59304] Thu, 30 December 2004 22:56 Go to previous messageGo to next message
I noticed this problem when I was trying to open a maven.xml file.
Re: Cannot open certain xml file with xml editor [message #59412 is a reply to message #59279] Thu, 30 December 2004 23:14 Go to previous messageGo to next message
I'd like to add that even after I removed the initial <project> tag with
the text editor, I was still unable to open the file with the XML Source
Page Editor. Only after I restarted eclipse was I able to open the file.
Will
Will Lopez wrote:
> Hello,
> <project>
> <parent>
> <child>
> </child>
> </parent>
> </project>
> Page Editor:
> file.
> Page Editor:
> <parent>
> <child>
> <property>
> <project></project>
> </property>
> </child>
> </parent>
> thxs,
> Will
Re: Cannot open certain xml file with xml editor [message #59435 is a reply to message #59304] Fri, 31 December 2004 00:05 Go to previous message
> wrote:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <project>
>> <parent>
>> <child>
>> </child>
>> </parent>
>> </project>
> file"
> structuredDocument
> you could use
> associate your
> fixed/enhanced.
What happens if you add a DOCTYPE before the <project> tag or a
namespace to it? Will the Ant editor still take preference?
Frank Sauer
Previous Topic:Access Violation from Tomcat
Next Topic:lost setup jndi/jdbc
Current Time: Sat Jul 26 18:43:07 EDT 2025
Powered by FUDForum. Page generated in 0.03407 seconds
