cdo and linux error [message #586507] |
Mon, 28 August 2006 16:19 |
Chris Lenz Messages: 214 Registered: July 2009 |
Hi all
My problem I have one eclipse in windows and one in linux
I use the same launcher skript, but in linux I get the following error:
[ERROR] at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin: Startup error
org.eclipse.net4j.spring.ContainerCreationException:
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'serverCDOProtocol' defined in file
[/usr/people/space/local/eclipse/workspace/at.ac.uibk.qe.squ am.cdo.server/META-INF/server.xml]:
Cannot resolve reference to bean 'mapper' while setting bean property
'mapper'; nested exception is
bean with name 'mapper' defined in file
Instantiation of bean failed; nested exception is
java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/EObject
org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:59)
org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:70)
at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin.getServerCont ainer(CDOServerPlugin.java:96)
at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin.doStart(CDOSe rverPlugin.java:56)
org.eclipse.net4j.util.eclipse.AbstractPlugin.start(Abstract Plugin.java:98)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.net4j.util.eclipse.ExecutableElement.createExecu tableExtension(ExecutableElement.java:34)
at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.createInitializer(ExampleServerPlugin.java:224)
at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.initializeBackend(ExampleServerPlugin.java:204)
at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin.doStart (ExampleServerPlugin.java:93)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:74)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'serverCDOProtocol' defined in file
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 190)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:106)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.applyPropertyValues(AbstractAutowireCapable BeanFactory.java:1046)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.populateBean(AbstractAutowireCapableBeanFac tory.java:857)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:378)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:233)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:145)
org.springframework.beans.factory.support.DefaultListableBea nFactory.getBeansOfType(DefaultListableBeanFactory.java:211)
org.springframework.context.support.AbstractApplicationConte xt.getBeansOfType(AbstractApplicationContext.java:596)
org.springframework.context.support.AbstractApplicationConte xt.registerListeners(AbstractApplicationContext.java:478)
org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:310)
org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:55)
... 64 more
Error creating bean with name 'mapper' defined in file
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:403)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 186)
... 75 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/EObject
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2365)
at java.lang.Class.getDeclaredMethods(Class.java:1763)
at java.beans.Introspector$1.run(Introspector.java:1265)
at java.beans.Introspector.getPublicDeclaredMethods(Introspecto r.java:1263)
at java.beans.Introspector.getTargetMethodInfo(Introspector.jav a:1129)
at java.beans.Introspector.getBeanInfo(Introspector.java:387)
at java.beans.Introspector.getBeanInfo(Introspector.java:159)
org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:150)
org.springframework.beans.CachedIntrospectionResults.forClas s(CachedIntrospectionResults.java:87)
org.springframework.beans.BeanWrapperImpl.setIntrospectionCl ass(BeanWrapperImpl.java:237)
org.springframework.beans.BeanWrapperImpl.setWrappedInstance (BeanWrapperImpl.java:195)
org.springframework.beans.BeanWrapperImpl.setWrappedInstance (BeanWrapperImpl.java:179)
org.springframework.beans.BeanWrapperImpl.<init>(BeanWrapperImpl.java:132)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.instantiateBean(AbstractAutowireCapableBean Factory.java:487)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:362)
... 78 more
Initializing container SQUAMcdo (net4j)
[ERROR] at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin: Startup error
at.ac.uibk.qe.squam.cdo.server.CDOServerBackendInitializer.i nitialize(CDOServerBackendInitializer.java:26)
at.ac.uibk.qe.squam.net4j.server.AbstractBackendInitializer. initializeContainer(AbstractBackendInitializer.java:34)
at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.initializeBackend(ExampleServerPlugin.java:205)
... 41 more
... 52 more
... 55 more
SQUAM QE NET4J Server started!!!
HIT ENTER FOR SHUTDOWN!!!
FUDForum. Page generated in 0.03028 seconds
