Home » Eclipse Projects » Nebula » [GalleryTreeViewer] Now groups added via refresh() appear collapsed
[GalleryTreeViewer] Now groups added via refresh() appear collapsed [message #59181] Thu, 18 September 2008 09:35 Go to next message
GalleryTreeViewer is set to auto expand all levels. However when my
content updates with a new group and I call
GalleryTreeViewer.refresh(true) the new group appears in the collapsed
state rather than the expanded state I expect (and want!).
Not sure if anyone else has come across this or not. I'll try to provide a
snippet based on SnippetGalleryViewerTester that'll hopefully demonstrate
this.
Justin
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #59207 is a reply to message #59181] Thu, 18 September 2008 09:37 Go to previous messageGo to next message
Obviously the title should read "NEW groups added via refresh() appear
collapsed" 8)
Justin
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #59231 is a reply to message #59181] Fri, 19 September 2008 05:32 Go to previous messageGo to next message
Here's an example demostrating this. I've just modified the existing
snippet to add some new groups periodically.
* Copyright (c) 2007-2008 Peter Centgraf.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors :
* Peter Centgraf - initial implementation
package com.neckdiagrams.instruments.ui.internal;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.jface.layout.GridLayoutFactory;
import org.eclipse.jface.viewers.IColorProvider;
import org.eclipse.jface.viewers.IFontProvider;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerComparator;
import org.eclipse.jface.viewers.ViewerFilter;
import org.eclipse.nebula.jface.galleryviewer.GalleryTreeViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.program.Program;
import org.eclipse.swt.widgets.Shell;
* Simple visual test harness for GalleryTreeViewer.
* @author Peter Centgraf
* @since Dec 5, 2007
public class SnippetGalleryViewerTester {
protected static class GalleryTestContentProvider implements
ITreeContentProvider {
// implements IStructuredContentProvider { // Use this to test
// FlatTreeContentProvider
public static final int NUM_GROUPS = 1;
public static final int NUM_ITEMS = 9;
List<String> groups = new ArrayList<String>();
HashMap<String, List<String>> itemsByGroup = new HashMap<String,
List<String>>();
public GalleryTestContentProvider() {
for (int i = 0; i < NUM_GROUPS; i++) {
addNewGroup();
public Object[] getChildren(Object parentElement) {
return itemsByGroup.get(parentElement).toArray();
public Object getParent(Object element) {
return null;
public boolean hasChildren(Object element) {
return ((String) element).startsWith("Group");
public Object[] getElements(Object inputElement) {
return groups.toArray();
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
public void addNewGroup() {
List<String> items = new ArrayList<String>();
for (int j = 0; j < NUM_ITEMS; j++) {
items.add("Item " + (j + 1));
final String group = "Group " + (groups.size() + 1);
itemsByGroup.put(group, items);
groups.add(group);
protected static class GalleryTestLabelProvider extends LabelProvider
implements IColorProvider, IFontProvider {
protected static Image itemImage = new Image(Display.getCurrent(),
Program.findProgram("jpg").getImageData());
public Image getImage(Object element) {
return itemImage;
public Color getBackground(Object element) {
String label = (String) element;
if (Integer.parseInt(label.substring(label.indexOf(' ') + 1)) % 2 > 0) {
return Display.getCurrent().getSystemColor(SWT.COLOR_YELLOW);
} else {
return null;
public Color getForeground(Object element) {
return null;
} else {
return Display.getCurrent().getSystemColor(SWT.COLOR_BLUE);
public Font getFont(Object element) {
return null;
} else {
FontData sysFontData =
Display.getCurrent().getSystemFont().getFontData()[0];
sysFontData.setStyle(SWT.BOLD | SWT.ITALIC);
return new Font(Display.getCurrent(), sysFontData);
protected static class OddNumbersFilter extends ViewerFilter {
public boolean select(Viewer viewer, Object parentElement, Object
element) {
try {
return (Integer.parseInt(label.substring(label.indexOf(' ') + 1)) % 2
> 0);
} catch (Exception e) {
return true;
protected static final int WIDTH = 800;
protected static final int HEIGHT = 600;
protected Shell shell;
public SnippetGalleryViewerTester() {
// Initialize the containing Shell
final Display display = new Display();
shell = new Shell(display);
shell.setSize(WIDTH, HEIGHT);
shell.setBackground(display.getSystemColor(SWT.COLOR_RED));
GridLayoutFactory.fillDefaults().applyTo(shell);
final GalleryTreeViewer viewer = new GalleryTreeViewer(shell);
GridDataFactory.fillDefaults().grab(true,
true).applyTo(viewer.getGallery());
final GalleryTestContentProvider contentProvider = new
GalleryTestContentProvider();
viewer.setContentProvider(contentProvider);
viewer.setLabelProvider(new GalleryTestLabelProvider());
viewer.setComparator(new ViewerComparator());
// viewer.addFilter(new OddNumbersFilter());
viewer.setInput(new Object());
// Show the Shell
shell.open();
shell.layout();
final Runnable runnable = new Runnable() {
public void run() {
contentProvider.addNewGroup();
viewer.refresh();
if (contentProvider.groups.size() < 7) display.timerExec(3000, this);
display.timerExec(3000, runnable);
// Run the event loop
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* @param args
new SnippetGalleryViewerTester();
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #59391 is a reply to message #59231] Wed, 24 September 2008 12:02 Go to previous messageGo to next message
Hi Justin,
I'll take a look at your snippet as soon as I get some free time. Until
then, please open a bug for this.
There are many changes from Peter that I need to commit so maybe the
problem is already solved.
Nicolas.
> * Contributors :
> import org.eclipse.swt.widgets.Display;
> * * @author Peter Centgraf
> List<String>>();
> addNewGroup();
> return null;
> newInput) {
> groups.add(group);
> LabelProvider implements IColorProvider, IFontProvider {
> Image(Display.getCurrent(), Program.findProgram("jpg").getImageData());
> return itemImage;
> 1)) % 2 > 0) {
> return
> } else {
> return null;
> 1)) % 2 > 0) {
> return null;
> } else {
> 1)) % 2 > 0) {
> return null;
> } else {
> Object element) {
> try {
> ') + 1)) % 2
>> 0);
> return true;
> // Show the Shell
> shell.open();
> shell.layout();
> public void run() {
> viewer.refresh();
> display.sleep();
> display.dispose();
> * @param args
> public static void main(String[] args) {
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #59416 is a reply to message #59231] Wed, 24 September 2008 14:50 Go to previous messageGo to next message
Hi Justin,
Nicolas.
> * Contributors :
> List<String>>();
> addNewGroup();
> return null;
> newInput) {
> groups.add(group);
> return itemImage;
> 1)) % 2 > 0) {
> return
> } else {
> return null;
> 1)) % 2 > 0) {
> return null;
> } else {
> 1)) % 2 > 0) {
> return null;
> } else {
> Object element) {
> try {
> ') + 1)) % 2
>> 0);
> return true;
> // Show the Shell
> shell.open();
> shell.layout();
> public void run() {
> viewer.refresh();
> display.sleep();
> display.dispose();
> * @param args
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #59513 is a reply to message #59391] Fri, 26 September 2008 05:30 Go to previous message
Salut Nicolas,
Bug raised: https://bugs.eclipse.org/bugs/show_bug.cgi?id=248700
Justin
Nicolas Richeton wrote:
> Hi Justin,
> Nicolas.
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #592250 is a reply to message #59181] Thu, 18 September 2008 09:37 Go to previous message
collapsed" 8)
Justin
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #592259 is a reply to message #59181] Fri, 19 September 2008 05:32 Go to previous message
* Contributors :
List<String>>();
addNewGroup();
return null;
newInput) {
groups.add(group);
return itemImage;
} else {
return null;
return null;
} else {
return null;
} else {
element) {
try {
> 0);
return true;
// Show the Shell
shell.open();
shell.layout();
public void run() {
viewer.refresh();
display.sleep();
display.dispose();
* @param args
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #592314 is a reply to message #59231] Wed, 24 September 2008 12:02 Go to previous message
Hi Justin,
Nicolas.
> * Contributors :
> List<String>>();
> addNewGroup();
> return null;
> newInput) {
> groups.add(group);
> return itemImage;
> 1)) % 2 > 0) {
> return
> } else {
> return null;
> 1)) % 2 > 0) {
> return null;
> } else {
> 1)) % 2 > 0) {
> return null;
> } else {
> Object element) {
> try {
> ') + 1)) % 2
>> 0);
> return true;
> // Show the Shell
> shell.open();
> shell.layout();
> public void run() {
> viewer.refresh();
> display.sleep();
> display.dispose();
> * @param args
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #592324 is a reply to message #59231] Wed, 24 September 2008 14:50 Go to previous message
Hi Justin,
Nicolas.
> * Contributors :
> List<String>>();
> addNewGroup();
> return null;
> newInput) {
> groups.add(group);
> return itemImage;
> 1)) % 2 > 0) {
> return
> } else {
> return null;
> 1)) % 2 > 0) {
> return null;
> } else {
> 1)) % 2 > 0) {
> return null;
> } else {
> Object element) {
> try {
> ') + 1)) % 2
>> 0);
> return true;
> // Show the Shell
> shell.open();
> shell.layout();
> public void run() {
> viewer.refresh();
> display.sleep();
> display.dispose();
> * @param args
Re: [GalleryTreeViewer] New groups added via refresh() appear collapsed [message #592354 is a reply to message #59391] Fri, 26 September 2008 05:30 Go to previous message
Salut Nicolas,
Justin
> Hi Justin,
> Nicolas.
Previous Topic:[Grid] DefaultCellRenderer and wordwrap
Next Topic:gantt charts synchronize
Current Time: Mon Jul 21 20:57:58 EDT 2025
Powered by FUDForum. Page generated in 0.30690 seconds
