Home » Archived » Test and Performance Tools Platform (TPTP) » Does any one have the basic steps to setup TPTP with Eclipse
Re: Does any one have the basic steps to setup TPTP with Eclipse [message #59200 is a reply to message #59176] |
Sat, 18 March 2006 20:01   |
That looks suspiciously like a bug in our 4.1.0.1 configuration
information somewhere (01 instead of 0.1 at end of version). Looking at
the download release of that runtime shows me no files with 4.1.01 in
the name (still, such could be in a jarfile somewhere). Something
POSSIBLY has been built with incorrect information somewhere.
So you went to the TPTP site, then to its downloads, the latest release
shows as 4.1.0.1, you made sure the Requirements at the bottom of the
page were met (versions of Java, Eclipse, and EMF/XSD)?
If so, I'd file a bugzilla, as I'm sure we want the "Latest Release" not
to be DOA!
If, on the other hand, you don't have all the requirements set up as
specified, tell me where you deviated. (E.g., I'm not expecting any
problems if you're using Java 1.5 instead of 1.4 ... but I'd expect such
problems if you have a 3.2 Eclipse or the wrong EMF/XSD package.)
RDS
Praveen Mohanan wrote:
> Actually, here the error messages when I run the test :
> Missing :
> org.eclipse.hyades.logging.core_4.1.01.\nl1.jar
> org.eclipse.hyades.logging.core_4.1.01.\nl2.jar
> org.eclipse.hyades.logging.core_4.1.01.\nlBidi.jar
>> Hi...All,
>> Does anyone have the basic steps to configure the eclipse with
>> TPTP? I tried following the instructions as per the website , but
>> finally end up some of the components not working.
>> Rehards.
Re: Does any one have the basic steps to setup TPTP with Eclipse [message #59224 is a reply to message #59200] |
Sun, 19 March 2006 20:48   |
Originally posted by: nospam.nospam.com
Hi..Randy,
I just followed the steps provided at this URL :
http://eclipse.org/tptp/home/downloads/installguide/InstallG uide41.html
I will erase all the current installations & try once again & note down
the steps this time. If it still fails. I will post it here.
Secondly, do I have to start the agent controller to record the tests?
> to be DOA!
> RDS
>> Missing :
>>> Hi...All,
>>> Rehards.
Re: Does any one have the basic steps to setup TPTP with Eclipse [message #59248 is a reply to message #59224] |
Sun, 19 March 2006 23:32   |
The agent controller is generally only needed for remote tasks... but by
"record the tests" if you mean the automated GUI recorder... that's a
bit out of my experience so I can't really comment on that specifically
.... sorry. I'm an AC person, who mostly pops up for monitoring and
profiling if I pop up higher at all!
RDS
> Hi..Randy,
>> at the download release of that runtime shows me no files with 4.1.01
>> in the name (still, such could be in a jarfile somewhere). Something
>> release shows as 4.1.0.1, you made sure the Requirements at the bottom
>> of the page were met (versions of Java, Eclipse, and EMF/XSD)?
>> not to be DOA!
>> such problems if you have a 3.2 Eclipse or the wrong EMF/XSD package.)
>> RDS
>>> Missing :
>>>> Hi...All,
>>>> Rehards.
Re: Does any one have the basic steps to setup TPTP with Eclipse [message #59348 is a reply to message #59248] |
Mon, 20 March 2006 10:46  |
Hi..Randy,
I redid the whole installation& now this is the error message I get
once I stop recording,
org.eclipse.ui.PartInitException: Invalid editor input.
org.eclipse.hyades.test.ui.internal.editor.BaseEditorPart.id entifyEditorDescriptor(BaseEditorPart.java:121)
org.eclipse.hyades.ui.internal.editor.HyadesEditorPart.init( HyadesEditorPart.java:388)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:572)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:212)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:753)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2323)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2212)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
org.eclipse.hyades.internal.execution.testgen.ui.TestgenUIUt ility.openEditor(TestgenUIUtility.java:331)
org.eclipse.hyades.test.internal.testgen.ui.TestgenUIWrapper $2.run(TestgenUIWrapper.java:116)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
> RDS
>> Hi..Randy,
>> down the steps this time. If it still fails. I will post it here.
>>> bottom of the page were met (versions of Java, Eclipse, and EMF/XSD)?
>>> not to be DOA!
>>> RDS
>>>> Missing :
>>>>> Hi...All,
>>>>> Rehards.
Current Time: Fri Jul 25 14:02:52 EDT 2025
Powered by FUDForum. Page generated in 0.07814 seconds
