Home » Archived » XML Schema Definition (XSD) » How to get elemnts in a sequence ?
How to get elemnts in a sequence ? [message #59132] Tue, 19 April 2005 08:31 Go to next message
Originally posted by: ediouf.genigraph.fr
Hi every body,
I'm very new with xsd, i'm parsing a xsd document and have problems about
getting elemnts in a sequence; i have read the javadoc but i have not
found a method to do this.
How to acceed to the element in the sequence ?
And how to get the content of xs:documentation tag ie : "Informations
décrivant une demande d'acte" ?
Thanks for your reply!
Here's a portion of my code :
<xs:complexType name="DemandeActeNaissanceType">
<xs:annotation>
<xs:documentation>Informations décrivant une demande
d'acte</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="DateDemande" type="xs:date"/>
<xs:element name="TypeActeNaissance"
type="TypeActeNaissanceType"/>
<xs:element name="NombreExemplaires">
<xs:simpleType>
<xs:restriction base="xs:integer">
<xs:minInclusive value="1"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="MotifDemande" type="MotifDemandeType"/>
<xs:element name="Demandeur" type="DemandeurType"/>
<xs:element name="Titulaire" type="IndividuType"/>
</xs:sequence>
</xs:complexType>
Re: How to get elemnts in a sequence ? [message #59157 is a reply to message #59132] Tue, 19 April 2005 08:32 Go to previous message
Using XSDModelGroup.getParticles() and then XSDParticle.getTerm() for
each particle will get you the element declarations (model groups and
wildcards) within the sequence. Using
XSDAnnotation.getUserInformation() will get you the list of
<xs:documentation> elements within an annotation.
elhadji wrote:
> Hi every body,
> about getting elemnts in a sequence; i have read the javadoc but i
> have not found a method to do this.
> <xs:annotation>
> </xs:annotation>
> <xs:sequence>
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
Re: How to get elemnts in a sequence ? [message #594727 is a reply to message #59132] Tue, 19 April 2005 08:32 Go to previous message
elhadji wrote:
> Hi every body,
> <xs:annotation>
> </xs:annotation>
> <xs:sequence>
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
Previous Topic:How to get elemnts in a sequence ?
Next Topic:How to test if a type is a base type ?
Current Time: Thu May 08 03:39:54 EDT 2025
Powered by FUDForum. Page generated in 0.02072 seconds
