Declare an extension as optional? [message #59128] |
Thu, 30 April 2009 18:31  |
Hey all,
i have an UML profile (don't panic, it is no UML-specific questions),
which i want to reuse for several IDE's (Papyrus, RSM, etc.), but every
IDE has its own internal registration mechanism via an Extension Point.
Is it possible to declare in one plugin, several extension and set these
extensions to a kind of "optional"? The problem is, that if the required
plugin was not found in the environment, the whole plugin will not be
registered! But, i didn't want to duplicate the Profile/Resource/What
ever for every new IDE.
Thanks a lot
Timothy
Re: Declare an extension as optional? [message #59278 is a reply to message #59228] |
Sat, 02 May 2009 09:32  |
> what do you want to say with this fragment? Was this an additional
> question or an answer? :)
Hey Timothy. Sorry. I wanted to say: If it is possible to
programatically register an extension at runtime, then you could do:
if (plugin1 is present){
register extension for plugin1
Now we just need someone who can answer my question. Then yours would be
answered too :-)
Felix
Re: Declare an extension as optional? [message #596652 is a reply to message #59128] |
Fri, 01 May 2009 18:17  |
Hey Timothy, > Is it possible to declare in one plugin, several
> registered!
Is it possible to programatically register an extension at runtime?
Felix
Re: Declare an extension as optional? [message #596662 is a reply to message #59203] |
Sat, 02 May 2009 05:57  |
Felix,
Timothy
>> required plugin was not found in the environment, the whole plugin
>> will not be registered!
> Felix
Re: Declare an extension as optional? [message #596680 is a reply to message #59228] |
answered too :-)
Felix
FUDForum. Page generated in 0.03475 seconds
