Log File For my Previous Mail [message #59122] |
Fri, 15 July 2005 11:23 |
Originally posted by: romeo_123_op.yahoo.com
!SESSION 2005-07-15 20:49:28.421
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 4 0 2005-07-15 20:49:48.625
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:151)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Widget.releaseWidget(Widget.java:755 )
at org.eclipse.swt.widgets.Control.releaseWidget(Control.java:1 574)
at org.eclipse.swt.widgets.Scrollable.releaseWidget(Scrollable. java:195)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:594)
at org.eclipse.swt.widgets.Widget.releaseResources(Widget.java: 720)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:588)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:593)
at org.eclipse.swt.widgets.Canvas.releaseWidget(Canvas.java:117 )
at org.eclipse.swt.widgets.Decorations.releaseWidget(Decoration s.java:782)
at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:868)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:382)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :441)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:499)
at org.eclipse.jface.window.Window.close(Window.java:321)
org.eclipse.jface.window.ApplicationWindow.close(Application Window.java:291)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1403)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:646)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2578)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 )
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 )
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1258)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui.workbench 4 0 2005-07-15 20:49:48.640
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2005-07-15 20:49:48.703
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2005-07-15 20:49:48.703
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:357)
Caused by: org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.graphics.Image.getBounds(Image.java:1087)
at org.eclipse.swt.custom.CTabItem.setImage(CTabItem.java:746)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabItem.setInfo(DefaultTabItem.java:76)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.initTab(PresentablePartFolder.java:344)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.childPropertyChanged(PresentablePartFolder.java:332)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.access$2(PresentablePartFolder.java:305)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder$3.propertyChanged(PresentablePartFolder.java:84)
org.eclipse.ui.internal.presentations.PresentablePart.firePr opertyChange(PresentablePart.java:91)
org.eclipse.ui.internal.presentations.PresentablePart$1.prop ertyChanged(PresentablePart.java:63)
org.eclipse.ui.internal.WorkbenchPartReference.immediateFire PropertyChange(WorkbenchPartReference.java:528)
org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReference.java:642)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1432)
org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchP age.java:1424)
at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory. java:237)
at org.eclipse.ui.internal.Perspective.dispose(Perspective.java :250)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1486)
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:763)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1392)
... 27 more
Root exception:
!ENTRY org.eclipse.ui 4 4 2005-07-15 20:49:48.781
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-15 20:49:48.781
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:297)
at org.eclipse.swt.widgets.Widget.getStyle(Widget.java:561)
org.eclipse.draw2d.LightweightSystem$RootFigure.isMirrored(L ightweightSystem.java:338)
at org.eclipse.draw2d.Figure.isMirrored(Figure.java:972)
org.eclipse.draw2d.text.BlockFlowLayout.createNewLine(BlockF lowLayout.java:120)
org.eclipse.draw2d.text.FlowContainerLayout.getCurrentLine(F lowContainerLayout.java:75)
org.eclipse.draw2d.text.FlowContainerLayout.getRemainingLine Width(FlowContainerLayout.java:83)
org.eclipse.draw2d.text.FlowUtilities.wrapFragmentInContext( FlowUtilities.java:210)
org.eclipse.draw2d.text.ParagraphTextLayout.layout(Paragraph TextLayout.java:181)
org.eclipse.draw2d.text.FlowFigureLayout.layout(FlowFigureLa yout.java:101)
at org.eclipse.draw2d.Figure.layout(Figure.java:1033)
at org.eclipse.draw2d.Figure.validate(Figure.java:1736)
org.eclipse.draw2d.text.FlowContainerLayout.layoutChildren(F lowContainerLayout.java:112)
org.eclipse.draw2d.text.FlowContainerLayout.layout(FlowConta inerLayout.java:98)
at org.eclipse.draw2d.text.BlockFlow.validate(BlockFlow.java:30 0)
at org.eclipse.draw2d.text.FlowPage.validate(FlowPage.java:132)
at org.eclipse.draw2d.text.FlowPage.getPreferredSize(FlowPage.j ava:78)
org.eclipse.draw2d.StackLayout.calculatePreferredSize(StackL ayout.java:71)
org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:93)
org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(Abstr actHintLayout.java:85)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:737)
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.LabelFigure.getPreferredSize(LabelFigure.java:127 )
org.eclipse.birt.report.designer.internal.ui.layout.ReportFl owLayout.getChildSize(ReportFlowLayout.java:540)
org.eclipse.birt.report.designer.internal.ui.layout.ReportFl owLayout.layout(ReportFlowLayout.java:243)
at org.eclipse.draw2d.Figure.validate(Figure.java:1738)
org.eclipse.draw2d.FreeformLayeredPane.validate(FreeformLaye redPane.java:122)
at org.eclipse.draw2d.Viewport.validate(Viewport.java:363)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:271)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:143)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:319)
org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:59)
org.eclipse.ui.internal.Workbench$17.handleException(Workben ch.java:1385)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:715)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1046)
!ENTRY org.eclipse.ui 4 0 2005-07-15 20:49:48.796
!STACK 0
at org.eclipse.draw2d.text.BlockFlow.getOrientation(BlockFlow.j ava:161)
at org.eclipse.draw2d.text.BlockFlow.validate(BlockFlow.java:29 3)
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.AreaFigure.getPreferredSize(AreaFigure.java:119)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:727)
org.eclipse.birt.report.designer.internal.ui.layout.MasterPa geLayout.layout(MasterPageLayout.java:82)
!ENTRY org.eclipse.ui 4 4 2005-07-15 20:49:48.796
!STACK 0
at org.eclipse.swt.widgets.Scrollable.getVerticalBar(Scrollable .java:187)
at org.eclipse.draw2d.FigureCanvas$2.propertyChange(FigureCanva s.java:72)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
org.eclipse.draw2d.DefaultRangeModel.firePropertyChange(Defa ultRangeModel.java:60)
at org.eclipse.draw2d.DefaultRangeModel.setAll(DefaultRangeMode l.java:118)
at org.eclipse.draw2d.Viewport.readjustScrollBars(Viewport.java :203)
at org.eclipse.draw2d.Viewport.validate(Viewport.java:364)
!ENTRY org.eclipse.jface 4 2 2005-07-15 20:49:59.812
"org.eclipse.jface".
!STACK 0
java.lang.IllegalAccessError: tried to access field
org.eclipse.draw2d.text.FlowBox.x from class
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.LabelFigure$1
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.LabelFigure$1.postValidate(LabelFigure.java:84)
org.eclipse.draw2d.text.BlockFlowLayout.endBlock(BlockFlowLa yout.java:142)
at org.eclipse.draw2d.text.BlockFlowLayout.flush(BlockFlowLayou t.java:161)
org.eclipse.draw2d.text.FlowContainerLayout.layout(FlowConta inerLayout.java:99)
at org.eclipse.draw2d.text.FlowPage.getMinimumSize(FlowPage.jav a:48)
org.eclipse.draw2d.StackLayout.calculateMinimumSize(StackLay out.java:44)
org.eclipse.draw2d.AbstractHintLayout.getMinimumSize(Abstrac tHintLayout.java:68)
at org.eclipse.draw2d.Figure.getMinimumSize(Figure.java:709)
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.LabelFigure.getMinimumSize(LabelFigure.java:170)
org.eclipse.birt.report.designer.internal.ui.layout.ReportFl owLayout.calculateMinimumSize(ReportFlowLayout.java:719)
org.eclipse.birt.report.designer.internal.ui.layout.TableLay out.initRowMinSize(TableLayout.java:339)
org.eclipse.birt.report.designer.internal.ui.layout.TableLay out.layout(TableLayout.java:166)
org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.c alculatePreferredSize(FreeformViewport.java:28)
at org.eclipse.draw2d.ScrollPaneSolver.solve(ScrollPaneSolver.j ava:75)
at org.eclipse.draw2d.FigureCanvas.layoutViewport(FigureCanvas. java:237)
at org.eclipse.draw2d.FigureCanvas.access$4(FigureCanvas.java:2 35)
org.eclipse.draw2d.FigureCanvas$3.notifyValidating(FigureCan vas.java:200)
at org.eclipse.draw2d.UpdateManager.fireValidating(UpdateManage r.java:109)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:267)
org.eclipse.birt.report.designer.internal.ui.editors.notific ation.ReportDeferredUpdateManager.performUpdate(ReportDeferr edUpdateManager.java:33)
org.eclipse.draw2d.LightweightSystem.controlResized(Lightwei ghtSystem.java:147)
org.eclipse.draw2d.LightweightSystem$3.controlResized(Lightw eightSystem.java:123)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:149)
at org.eclipse.swt.widgets.Control.WM_SIZE(Control.java:3650)
at org.eclipse.swt.widgets.Scrollable.WM_SIZE(Scrollable.java:3 19)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:123 7)
at org.eclipse.swt.widgets.Canvas.WM_SIZE(Canvas.java:253)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3107 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1140 )
at org.eclipse.swt.widgets.Control.forceResize(Control.java:674 )
at org.eclipse.swt.widgets.Control.getLocation(Control.java:891 )
org.eclipse.birt.report.designer.internal.ui.editors.rulers. EditorRulerComposite.doLayout(EditorRulerComposite.java:316)
org.eclipse.birt.report.designer.internal.ui.editors.rulers. EditorRulerComposite.layout(EditorRulerComposite.java:499)
org.eclipse.birt.report.designer.internal.ui.editors.rulers. EditorRulerComposite$5.handleEvent(EditorRulerComposite.java :546)
at org.eclipse.swt.internal.win32.OS.EndDeferWindowPos(Native Method)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:653)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:619)
at org.eclipse.swt.widgets.Composite.setResizeChildren(Composit e.java:786)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:125 2)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1952)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1933)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1929)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:198 )
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:869)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:124 8)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1999)
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java :299)
org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(PresentablePart.java:118)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layoutContent(PresentablePartFolder.java:131)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layout(PresentablePartFolder.java:405)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:289)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:212)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:753)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2323)
org.eclip
FUDForum. Page generated in 0.28357 seconds
