Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping
ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping [message #59108] Tue, 24 October 2006 15:59 Go to next message
Originally posted by: oliveros.cpqd.com.br
Hi there,
I've been trying to use Teneo EMF Persistence (SDK 0.7.5.v200610190709) to
generate the EMF-JDO/JPOX OR mapping, but I am getting the following
exception:
Exception in thread "main" java.lang.ArrayIndexOutOfBoundsException: 3 at
org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.main(GenerateJ DO.java:74)
Any guess ?
FYI I've added the following jar files to my classpath:
jdo2-api-2.0.jar
jpox-1.1.2.jar
jpox-enhancer-1.1.2.jar
org.eclipse.emf.teneo_0.7.5.v200610190709.jar
org.eclipse.emf.teneo.annotations_0.7.5.v200610190709.jar"
org.eclipse.emf.teneo.jpox.enhanced.jar
org.eclipse.emf.teneo.jpox.jar
mysql-connector-java-5.0.3-bin.jar
log4j-1.2.8.jar
bcel-5.2.jar
I would appreciate any help.
Dário
Re: ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping [message #59186 is a reply to message #59108] Wed, 25 October 2006 04:25 Go to previous messageGo to next message
Hi Dário,
This error (a bug) actually hides another error. The generation step is not able to instantiate the
EPackage instance. Are the ecore file and the sources of the model in the same project (they should be)?
I'll improve the error reporting, this will be in the next build (this week).
You can also programmatically create a jdo mapping by calling:
JpoxHelper.generateMapping(EPackage[] epackages, Properties props)
gr. Martin
Dário wrote:
> Hi there,
> to generate the EMF-JDO/JPOX OR mapping, but I am getting the following
> exception:
> 3 at
> Any guess ?
> jdo2-api-2.0.jar
> jpox-1.1.2.jar
> log4j-1.2.8.jar
> bcel-5.2.jar
> Dário
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping [message #59237 is a reply to message #59186] Wed, 25 October 2006 07:29 Go to previous message
Hi Martin,
Both ecore and source files are in the same project indeed.
I will generate the mapping as you suggested until next build is available.
Thanks a lot,
Dário
Re: ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping [message #594785 is a reply to message #59108] Wed, 25 October 2006 04:25 Go to previous message
Hi Dário,
gr. Martin
Dário wrote:
> Hi there,
> exception:
> 3 at
> Any guess ?
> jdo2-api-2.0.jar
> jpox-1.1.2.jar
> log4j-1.2.8.jar
> bcel-5.2.jar
> Dário
The Netherlands
Re: ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping [message #594804 is a reply to message #59186] Wed, 25 October 2006 07:29 Go to previous message
Hi Martin,
Thanks a lot,
Dário
Previous Topic:ArrayIndexOutOfBoundsException when generating EMF-JDO/JPOX OR mapping
Next Topic:Support EMF custom EDataTypes
Current Time: Tue Jul 22 01:35:33 EDT 2025
Powered by FUDForum. Page generated in 0.47967 seconds
