Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP AGR with Stand-alone Applications
TPTP AGR with Stand-alone Applications [message #59091] Fri, 17 March 2006 16:24 Go to next message
Originally posted by: ffejbrown.yahoo.com
Hi Everyone,
I am trying to test a stand-alone RCP product with TPTP AGR and I am
running into some issues. I can record test cases against the application
if I have the jar dropped into the Eclipse plugins folder and use the
plugin perspective as the Starting Point. I can record tests this way.
If I try to run the test using the path to the startup.jar for the
plugin/stand alone application, I see the application launch and Eclipse
seems to pause for a while at 60% then the test stops running and I'm
returned to Eclipse. There is no .execution file created so I'm not sure
if the test cases ran at all.
Has anyone had any success running tests against stand-alone apps? Any
suggestions?
Thanks in advance!
-Jeff
Re: TPTP AGR with Stand-alone Applications [message #60828 is a reply to message #59091] Mon, 27 March 2006 15:18 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006F85228525713E_=
Content-Type: text/plain; charset="US-ASCII"
AGR currently doesn't support RCP applications. This was the number one
request from our users in EclipseCon so it will very likely be supported
soon.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">AGR currently doesn't support RCP applications.
&nbsp;This was the number one request from our users in EclipseCon so it
will very likely be supported soon.<br>
</font>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 006F85228525713E_=--
Previous Topic:Heap Usage Graph
Next Topic:HTTPRecorder not recording anything
Current Time: Sun Jul 13 16:20:01 EDT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
