Home » Archived » BIRT » Problem In BIRT Report Layout View
Problem In BIRT Report Layout View [message #59069] Fri, 15 July 2005 11:11 Go to next message
Originally posted by: romeo_123_op.yahoo.com
I have installed fresh
eclipse-SDK-3.1-win32,
GEF-all-3.1,
emf-sdo-xsd-SDK-2.1.0 ,
and birt-report-framework-1_0
on windows2000 machine,
However, I am unable to create a report.
Following instructions from the tutorial I create a new reports project,
Then create a new report.
Then created data source Classic Models Inc.
Then created Data Set.(entered query preview etc..)
When I choose the pallet and Drag drop a table element and Drag customer
Name from Data
Explorer and drop it in the first cell in the table's detail row.
PROBLEM COMES after clicking the preview tab Eclipse crashes when i switch
to Layout View.
I have included the log from the crash below.
I am running Eclipse 3.1,
And as I mentioned the GEF and EMF requirements were met.
Checked Installation Procedures also further i have tried with jdk1.5.0_04
also. Same
Problem is continuing.
I am So Much Interested In BIRT Please Help Me Regarding This Issue.
Thank you very Much for Your Detailed Replay.
with Regards
Riaz
Re: Problem In BIRT Report Layout View [message #59194 is a reply to message #59069] Fri, 15 July 2005 13:40 Go to previous messageGo to next message
BIRT does not support GEF 3.1 yet (support will be provided in the next
1.0.1 release). It would be best to use Eclipse 3.0.1 until then. Here are
the install instructions:
http://www.eclipse.org/birt/index.php?page=build/install.htm l
If you really want to use Eclipse 3.1, then you can try to get BIRT 1.0.1M1
and use GEF 3.0.x instead of GEF 3.1.
David
"RIAZ" <romeo_123_op@yahoo.com> wrote in message
news:fdc0c3daafa4e3594077fd1847fe6ab0$1@www.eclipse.org...
> eclipse-SDK-3.1-win32, GEF-all-3.1, emf-sdo-xsd-SDK-2.1.0 ,
> and birt-report-framework-1_0 on windows2000 machine,
> However, I am unable to create a report. Following instructions from the
> tutorial I create a new reports project, Then create a new report. Then
> Name from Data Explorer and drop it in the first cell in the table's
> detail row.
> to Layout View.
> I have included the log from the crash below. I am running Eclipse 3.1,
> also. Same Problem is continuing.
> with Regards
> Riaz
Re: Problem In BIRT Report Layout View [message #60496 is a reply to message #59069] Thu, 21 July 2005 05:09 Go to previous message
1.0.1 Final version will support GEF 3.1.
??????:fdc0c3daafa4e3594077fd1847fe6ab0$1@www.eclipse.org...
> detail row.
> to Layout View.
> with Regards
> Riaz
Previous Topic:Viewer and Run Servlet
Next Topic:1.0.1M1 question ?
Current Time: Sat Jul 26 07:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.07142 seconds
