External JS libraries and JBoss deployment [message #59061] |
Fri, 09 November 2007 11:59  |
Originally posted by: cedric.gaillot.thalesraytheon-fr.com
I have begun to deploy my application on JBoss.
All seems to work fine until i insert my custom widget which use the
external js libraries (openlayers) to display a cartographic map. (It
works fine when run from eclipse environment)
I have defined a resource in my project to insert it : (The external
libraries is located at the root of my project)
package com.trs.rap.widgets.map.openlayers;
import org.eclipse.rwt.resources.IResource;
import org.eclipse.rwt.resources.IResourceManager.RegisterOptions;
import com.trs.rap.tools.HTMLConst;
public class OpenLayersAPIResource implements IResource {
* {@inheritDoc}
public String getCharset() {
return HTMLConst.CHARSET_NAME_ISO_8859_1;
* {@inheritDoc}
public ClassLoader getLoader() {
return this.getClass().getClassLoader();
* {@inheritDoc}
public RegisterOptions getOptions() {
return RegisterOptions.VERSION;
* {@inheritDoc}
public String getLocation() {
return "/OpenLayers.js";
* {@inheritDoc}
public boolean isJSLibrary() {
return true;
* {@inheritDoc}
public boolean isExternal() {
return true;
Then I have configured the plugin.xml file as below :
<?eclipse version="3.2"?>
<plugin>
<extension
id="com.trs.rap.ihm.themes"
point="org.eclipse.rap.ui.themes">
<theme
id="com.trs.rap.ihm.alttheme"
name="Alternative Demo Theme"
file="theme1/theme.properties"/>
</extension>
<extension
id="com.trs.rap.ihm.entrypoint"
point="org.eclipse.rap.ui.entrypoint">
<entrypoint
class="com.trs.rap.ihm.TestRAPWorkbench"
id="com.trs.rap.ihm.entrypoint1"
parameter="default">
</entrypoint>
</extension>
<extension
id="com.trs.rap.widgets.map.openlayers.OpenLayersMap"
point="org.eclipse.rap.ui.resources">
<resource
class="com.trs.rap.widgets.map.openlayers.OpenLayersAPIResource "/>
<resource
class="com.trs.rap.widgets.map.openlayers.OpenLayersResource "/>
<resource
class="com.trs.rap.widgets.map.openlayers.GeoToolsAPIResource "/>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
name="Perspective"
class="com.trs.rap.ihm.Perspective"
id="com.trs.rap.ihm.Perspective">
</perspective>
</extension>
<extension
point="org.eclipse.ui.views">
<view
category="one"
name="Map"
class="com.trs.rap.widgets.map.CartographyViewpart"
id="com.trs.rap.widgets.map.CartographyViewpart">
</view>
<view
category="one"
name="Filters"
class="com.trs.rap.widgets.map.CartographicFiltersViewpart"
id="com.trs.rap.widgets.map.CartographicFiltersViewpart">
</view>
<view
category="one"
name="Airbase"
class="com.trs.rap.ihm.resource.AirbaseViewpart"
id="com.trs.rap.ihm.resource.AirbaseViewpart">
</view>
<view
category="one"
name="Center"
class="com.trs.rap.ihm.c2.center.CenterViewpart"
id="com.trs.rap.ihm.c2.center.CenterViewpart">
</view>
<view
category="one"
name="ACO"
class="com.trs.rap.ihm.ACO.ACMViewpart"
id="com.trs.rap.ihm.ACO.ACMViewpart">
</view>
<view
category="one"
name="Track"
class="com.trs.rap.ihm.track.TrackViewPart"
id="com.trs.rap.ihm.track.TrackViewPart">
</view>
<category
id="one"
name="Category 1"/>
</extension>
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="com.trs.rap.ihm.perspectiveExtension1">
</perspectiveExtension>
</extension>
<extension
point="org.eclipse.rap.ui.branding">
<branding
body="body.html"
defaultEntrypointId="com.trs.rap.ihm.entrypoint1"
id="com.trs.rap.ihm.branding1"
servletName="trs"
title="TRS prototype">
</branding>
</extension>
<extension
point="org.eclipse.equinox.http.registry.resources">
<resource
alias="/lib"
base-name="/lib">
</resource>
</extension>
<extension
<resource
alias="/img"
base-name="/img">
</resource>
</extension>
<extension
<resource
alias="/"
base-name="/">
</resource>
</extension>
</plugin>
Then the build.properties file :
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
META-INF/,\
art/,\
icons/,\
img/,\
lib/,\
GeoTools.js,\
theme/,\
theme1/,\
body.html,\
OpenLayers.js
Then, I have followed the instructions in the deployment tutorial for RAP
application. The jar of my plugin seem to be correct and contains the
external js library.
After deploying the application on Jboss and typed the correct URL on a
browser, I got this javascript error :
Could not evaluate javascript response:
ReferenceError: OpenLayers is not defined -----> OpenLayers which is a
javascript class
It seems to be a path problem but I did'nt managed to find how to fix it.
Thanks for your help.
Cédric G.
FUDForum. Page generated in 0.70699 seconds
