Home » Archived » BIRT » need more clarification on charts & images problem
need more clarification on charts & images problem [message #59044] Fri, 15 July 2005 10:01
Originally posted by: er.vikas.rediffmail.com
Hi jun
Thanks 4 ur reply.
Actually my module that use BIRT report engine is deployed in the sever in
the for of a jar file.This jar is used by some other module which is a
web-app.That's why i can't give the web app's root to set the image folder.
can i specify the absolute path like this
renderContext.setImageDirectory(c:/rr/jboss/server/default/d eploy/
jbossweb-tomcat50.sar/Root.war/report/images):)
moreover should i also set ImageHandler for the emitter configuration.
If yes HTMLCompleteImageHandler or HTMLServerImageHandler.
Also when i view the source code for the generated report it doesn't
contain the image source path. it only shows the image style etc.
Looking eagerly 4 ur feedback.
Thanks in advance.
Vikas
Previous Topic:PDF fonts not visible
Next Topic:Adding a Chart to a JSP Page
Current Time: Tue Jul 08 17:18:30 EDT 2025
Powered by FUDForum. Page generated in 0.05133 seconds
