Home » Eclipse Projects » Eclipse Platform » Launching Eclipse Programmatically
Launching Eclipse Programmatically [message #59025] Mon, 02 June 2003 09:19 Go to next message
Is it possible to launch Eclipse from our application? Or does Eclipse
assume it is launched on its own and has full control? If it is possible,
could you please point me to the entry point for the program, as well as
properties we need to set before launching?
From reading previous messages I know that for now it is not possible to
strip off plugins, does this imply it’s not possible to launch just the
editor part from our (swing based) application?
Thank you for your time
Bella
Re: Launching Eclipse Programmatically [message #59470 is a reply to message #59025] Mon, 02 June 2003 13:00 Go to previous messageGo to next message
> Hello,
Sure, you can exec the same command like that Eclipse does.
> Or does Eclipse
* Date: Mon, 8 Jul 2002 11:07:25 -0400
* Subject: Re: Howto run SWT application outside eclipse
* Newsgroups: eclipse.tools
* Organization: OTI
When you run in Eclipse, go to the debug view, select the javaw process and
from the pop up menu select Properties. This will give you the command
line
used by eclipse to launch your example.
> Bella
Re: Launching Eclipse Programmatically [message #59519 is a reply to message #59470] Mon, 02 June 2003 14:06 Go to previous messageGo to next message
Thank you for your quick reply.
While I do realize that I can execute Eclipse in a separate VM using exec,
I was wondering whether it was possible to have our application launch
Eclipse in the same VM.
Bella
Don Estberg wrote:
> > Hello,
> > Or does Eclipse
> * From: "Veronika Irvine" <veronika_irvine@xxxxxxx>
> * Organization: OTI
> line
> > Bella
Re: Launching Eclipse Programmatically [message #60132 is a reply to message #59519] Mon, 02 June 2003 16:42 Go to previous messageGo to next message
Eclipse has a main method like every other java program:
org.eclipse.core.launcher.Main in org.eclipse.sore.boot
Jan
Re: Launching Eclipse Programmatically [message #60440 is a reply to message #60132] Tue, 03 June 2003 09:51 Go to previous messageGo to next message
That works. Thank you.
Bella
P.S. The file is actually located in startup.jar
> Jan
Re: Launching Eclipse Programmatically [message #60939 is a reply to message #60440] Tue, 03 June 2003 10:15 Go to previous message
Sorry, I looked at the source/CVS. Thats at least the project you
get, if you want to have a look at this file...
Jan
Previous Topic:Different folder for plug-ins
Next Topic:jface packaging in 2.0 vs. 2.1
Current Time: Wed Jul 30 20:37:19 EDT 2025
Powered by FUDForum. Page generated in 0.03899 seconds
