Launching Eclipse Programmatically [message #59025] |
Mon, 02 June 2003 09:19  |
Is it possible to launch Eclipse from our application? Or does Eclipse
assume it is launched on its own and has full control? If it is possible,
could you please point me to the entry point for the program, as well as
properties we need to set before launching?
From reading previous messages I know that for now it is not possible to
strip off plugins, does this imply its not possible to launch just the
editor part from our (swing based) application?
Thank you for your time
Bella
Re: Launching Eclipse Programmatically [message #59519 is a reply to message #59470] |
Mon, 02 June 2003 14:06   |
Thank you for your quick reply.
While I do realize that I can execute Eclipse in a separate VM using exec,
I was wondering whether it was possible to have our application launch
Eclipse in the same VM.
Bella
Don Estberg wrote:
> > Hello,
> Sure, you can exec the same command like that Eclipse does.
> > Or does Eclipse
> * From: "Veronika Irvine" <veronika_irvine@xxxxxxx>
> * Date: Mon, 8 Jul 2002 11:07:25 -0400
> * Subject: Re: Howto run SWT application outside eclipse
> * Newsgroups: eclipse.tools
> * Organization: OTI
> When you run in Eclipse, go to the debug view, select the javaw process and
> from the pop up menu select Properties. This will give you the command
> line
> used by eclipse to launch your example.
> > Bella
Re: Launching Eclipse Programmatically [message #60939 is a reply to message #60440] |
Tue, 03 June 2003 10:15  |
Originally posted by: muelleimer.usenet.katzien.de
* Bella <bella_voldman@yahoo.com> wrote:
>> Eclipse has a main method like every other java program:
>> org.eclipse.core.launcher.Main in org.eclipse.sore.boot
> P.S. The file is actually located in startup.jar
Sorry, I looked at the source/CVS. Thats at least the project you
get, if you want to have a look at this file...
Jan
FUDForum. Page generated in 0.05323 seconds
