Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59011] |
Fri, 09 November 2007 11:37  |
Originally posted by: dp-conde.criticalsoftware.com
Once again, I'm posting here to try and find a solution to my problem. I
have a RAP application and I'm trying to get the eclipse help system to
work without problems.
So far I've managed to get the help system to work, but the problem is
that the bundle org.eclipse.help.webapp is conflicting with something,
probably from RAP or equinox. At least it must be because when I start
the org.eclipse.help.webapp to be able to use the eclipse help system,
the application simply stops loading the pictures from the application's
resources.
If I don't start org.eclipse.help.webapp, then everything works fine,
but I can't use the eclipse help system.
Anyone having the same problem, or ideas on how to solve it?
Thanks in advance,
Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59683 is a reply to message #59011] |
Wed, 14 November 2007 05:06   |
Originally posted by: fappel.innoopract.com
could you provide a list of bundles you are using. As I have the help system
running without any problems we could compare the bundles to see if this
gives us any hint. Type ss into the console to get a trace of the bundle
state. Does it load none pictures of the application or only some?
Ciao
Frank
"Daniel Conde" <dp-conde@criticalsoftware.com> schrieb im Newsbeitrag
news:fh22dj$tao$1@build.eclipse.org...
> Hello,
> probably from RAP or equinox. At least it must be because when I start the
> org.eclipse.help.webapp to be able to use the eclipse help system, the
> resources.
> If I don't start org.eclipse.help.webapp, then everything works fine, but
> Thanks in advance,
> Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59878 is a reply to message #59683] |
Wed, 14 November 2007 12:57  |
Thanks Frank, but already solved the problem, it was indeed some
conflict between registry space.
Change the path of the help system registry in the plugin.xml for webapp
and it worked fine.
Daniel Conde.
Frank Appel wrote:
> Ciao
> Frank
>> Hello,
>> resources.
>> Thanks in advance,
>> Daniel Conde.
FUDForum. Page generated in 0.04798 seconds
