Home » Eclipse Projects » Remote Application Platform (RAP) » Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox)
Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59011] Fri, 09 November 2007 11:37 Go to next message
Originally posted by: dp-conde.criticalsoftware.com
Once again, I'm posting here to try and find a solution to my problem. I
have a RAP application and I'm trying to get the eclipse help system to
work without problems.
So far I've managed to get the help system to work, but the problem is
that the bundle org.eclipse.help.webapp is conflicting with something,
probably from RAP or equinox. At least it must be because when I start
the org.eclipse.help.webapp to be able to use the eclipse help system,
the application simply stops loading the pictures from the application's
resources.
If I don't start org.eclipse.help.webapp, then everything works fine,
but I can't use the eclipse help system.
Anyone having the same problem, or ideas on how to solve it?
Thanks in advance,
Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59683 is a reply to message #59011] Wed, 14 November 2007 05:06 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
could you provide a list of bundles you are using. As I have the help system
running without any problems we could compare the bundles to see if this
gives us any hint. Type ss into the console to get a trace of the bundle
state. Does it load none pictures of the application or only some?
Ciao
Frank
"Daniel Conde" <dp-conde@criticalsoftware.com> schrieb im Newsbeitrag
news:fh22dj$tao$1@build.eclipse.org...
> Hello,
> probably from RAP or equinox. At least it must be because when I start the
> org.eclipse.help.webapp to be able to use the eclipse help system, the
> resources.
> If I don't start org.eclipse.help.webapp, then everything works fine, but
> Thanks in advance,
> Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #59878 is a reply to message #59683] Wed, 14 November 2007 12:57 Go to previous message
Thanks Frank, but already solved the problem, it was indeed some
conflict between registry space.
Change the path of the help system registry in the plugin.xml for webapp
and it worked fine.
Daniel Conde.
Frank Appel wrote:
> Ciao
> Frank
>> Hello,
>> resources.
>> Thanks in advance,
>> Daniel Conde.
Previous Topic:Problem with GMap widget
Next Topic:External JS libraries and JBoss deployment
Current Time: Tue Jul 22 22:09:36 EDT 2025
Powered by FUDForum. Page generated in 0.16818 seconds
