ATNA logging date parsing is broken [message #584076] |
Thu, 03 January 2008 18:54 |
Sumedh Messages: 34 Registered: July 2009 |
Member |
Hey Matt,
Happy new year to you!
OK here's another issue. Single digit date parsing is not in the "MMM DD
HH:mm:ss" format. As soon as the year rolled over, the public ATNA syslog
gave me "malformed xml" failure messages. The XDS.b stored query I fired
executed perfectly. This is the date header on the xml:
<13>Jan 3 13:21:42 machine1 <?xml version="1.0"
encoding="ASCII"?><AuditMessage
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance".....
"Jan 3 13:21:42" is causing a problem here. As soon as I switched my
system date to Jan 10, 2008 this worked perfectly. I'm not sure I can
control this from the API exposed (can I?).
This could be a blocker for me pretty soon. Please let me know if I should
log this or its something you're already aware of and working on.
Thanks.
Sumedh
FUDForum. Page generated in 0.03107 seconds
