Files lost from context [message #58967] |
Wed, 01 October 2008 16:18  |
I really enjoy working with Mylyn and it helps me a lot in my daily work.
But, I think I've found an bug. I have a java-project which has javascript
files living inside the java-source directory:
projectA/src/main/java/com/acme/App/Main.java
projectA/src/main/java/com/acme/App/inc/acme/2.5.2/main.js
It seems these javascript files disappear from the Package Explorer (focus
on active task is on) when you de-activate and then re-activate a task.
The files are correctly opened in the editor tabs, but not in the Package
Explorer. Is this some setting I am missing or is it a bug?
Tnx
Spike
Re: Files lost from context [message #59414 is a reply to message #59141] |
Sat, 04 October 2008 14:58  |
Originally posted by: steffen.pingel.eclipse.org
It is likely that the JavaScript file has a lower interest and decay causes
it drop out of the context on task activation. This comment summarizes the
problems that were fixed in the latest weekly build:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245234#c14
It would be great if you could try the latest build and report back if that
fixes the problem you are seeing:
http://www.eclipse.org/mylyn/downloads/#weekly
Steffen
> Hi Steffen,
> It does seem to have some resemblance, except for the fact that I have a
> different reproduction path. I'm running Eclipse 3.4 on Ubuntu Hardy and
> only use Maven2 from the terminal (so no m2eclipse that generates files).
> Here's my way to reproduce:
> I activate a new task. I then open a java file and a javascript file. My
> PackageExplorer only shows me these two files and I can work clutter free.
> I then deactivate the task and go for some coffee. When I come back I
> reactive the same task and Mylyn will open the 2 files again (java and
> javascript editor) but, only the Java file shows up in the
> PackageExplorer.
> Spike
Re: Files lost from context [message #593791 is a reply to message #58967] |
Wed, 01 October 2008 18:23  |
This sounds similar to this bug which is currently being investigated:
232664: [context] constantly loosing context information
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232664
I will announce it here once there is a weekly build with a fix available.
Steffen
> Tnx
> Spike
Re: Files lost from context [message #593828 is a reply to message #59041] |
Thu, 02 October 2008 04:26  |
Hi Steffen,
javascript editor) but, only the Java file shows up in the PackageExplorer.
Spike
Re: Files lost from context [message #593949 is a reply to message #59141] |
Steffen
> Hi Steffen,
> PackageExplorer.
> Spike
FUDForum. Page generated in 0.06769 seconds
