Home » Archived » XML Schema Definition (XSD) » Import directives
Import directives [message #58928] Thu, 31 March 2005 11:07 Go to next message
Originally posted by: none.nonet.com
Is there a simple method of determining whether a schema imports other
schemas from an XSDSchema object?
i.e. if i load a schema with this directive into an XSDSchema object:
<xs:schema xmlns="http://tempuri.org/MySchema.xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://tempuri.org/MySchema.xsd"
xmlns:id="http://tempuri.org/Identifiers.xsd"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
<xs:import namespace="http://tempuri.org/Identifiers.xsd"
schemaLocation="Identifiers.xsd"/>
</xs:schema>
The only difference i've found is that the qNamePrefixToNamespaceMap there
would be more entries in the qNamePrefixToNamespaceMap....is using this fact
fair play?
Many thanks for your help,
Ray
Re: Import directives [message #58953 is a reply to message #58928] Thu, 31 March 2005 11:46 Go to previous message
Ray,
It's best to look through XSDSchema.getContents() to see if there are
things of type XSDImport. There might be additional prefixes for other
reasons, e.g., within annotations or for non-schema namespace attributes.
Ray wrote:
>Hi,
></xs:schema>
>fair play?
>Ray
Re: Import directives [message #594647 is a reply to message #58928] Thu, 31 March 2005 11:46 Go to previous message
Ray,
Ray wrote:
>Hi,
></xs:schema>
>fair play?
>Ray
Previous Topic:Import directives
Next Topic:How to get the XSDAttributeUse from a DOM-Node?
Current Time: Mon Jul 14 07:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.28481 seconds
