Re: Import directives [message #58953 is a reply to message #58928] |
Thu, 31 March 2005 11:46  |
Ray,
It's best to look through XSDSchema.getContents() to see if there are
things of type XSDImport. There might be additional prefixes for other
reasons, e.g., within annotations or for non-schema namespace attributes.
Ray wrote:
>Hi,
>Is there a simple method of determining whether a schema imports other
>schemas from an XSDSchema object?
>i.e. if i load a schema with this directive into an XSDSchema object:
><xs:schema xmlns="http://tempuri.org/MySchema.xsd"
>xmlns:xs="http://www.w3.org/2001/XMLSchema"
>targetNamespace="http://tempuri.org/MySchema.xsd"
>xmlns:id="http://tempuri.org/Identifiers.xsd"
>elementFormDefault="unqualified" attributeFormDefault="unqualified">
> <xs:import namespace="http://tempuri.org/Identifiers.xsd"
>schemaLocation="Identifiers.xsd"/>
></xs:schema>
>The only difference i've found is that the qNamePrefixToNamespaceMap there
>would be more entries in the qNamePrefixToNamespaceMap....is using this fact
>fair play?
>Many thanks for your help,
>Ray
Re: Import directives [message #594647 is a reply to message #58928] |
Ray,
Ray wrote:
>Hi,
></xs:schema>
>fair play?
>Ray
FUDForum. Page generated in 0.03925 seconds
