Home » Eclipse Projects » Nebula » Vertical text alignment in Grid (table viewer)?
Vertical text alignment in Grid (table viewer)? [message #58923] Sat, 06 September 2008 04:23 Go to next message
I need vertical text alignment in a column which has large images (~3 x
height of font) so that the text appears aligned with the middle of the
image.
Can't see standard provision for this, right?
I can achieve this by copying & editing DefaultCellRenderer, however I
would've thought other folks might also like a
setVerticalAlignment(SWT.TOP/CENTER/BOTTOM) method on GridColumn, no?!
Justin
Re: Vertical text alignment in Grid (table viewer)? [message #58950 is a reply to message #58923] Sat, 06 September 2008 07:32 Go to previous messageGo to next message
File a bugzilla and in the ideal case you provide a patch for
DefaultCellRenderer which has this feature.
Tom
Justin schrieb:
> image.
> Justin
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Vertical text alignment in Grid (table viewer)? [message #59029 is a reply to message #58950] Mon, 08 September 2008 11:14 Go to previous messageGo to next message
Hi Tom,
Sure will do, can supply a patch too. Guess I should raise an enhancement
request rather than a bug?
Justin
Tom Schindl wrote:
> Tom
> Justin schrieb:
>> image.
>> Thanks,
>> Justin
Re: Vertical text alignment in Grid (table viewer)? [message #59055 is a reply to message #59029] Mon, 08 September 2008 12:30 Go to previous message
Enhancement raised and patch added:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246608
Justin
Re: Vertical text alignment in Grid (table viewer)? [message #592163 is a reply to message #58923] Sat, 06 September 2008 07:32 Go to previous message
Tom
Justin schrieb:
> image.
> Justin
Re: Vertical text alignment in Grid (table viewer)? [message #592189 is a reply to message #58950] Mon, 08 September 2008 11:14 Go to previous message
Hi Tom,
Justin
Tom Schindl wrote:
> Tom
> Justin schrieb:
>> image.
>> Thanks,
>> Justin
Re: Vertical text alignment in Grid (table viewer)? [message #592199 is a reply to message #59029] Mon, 08 September 2008 12:30 Go to previous message
Justin
Previous Topic:Header-Controls available in CVS
Next Topic:Grid Row Groups
Current Time: Tue Jul 22 01:47:57 EDT 2025
Powered by FUDForum. Page generated in 0.25799 seconds
