Home » Archived » BIRT » PDF fonts not visible
PDF fonts not visible [message #58916] Fri, 15 July 2005 06:35 Go to next message
Originally posted by: vinunair.crimsonlogic.co.in
I have a problem viewing the report in PDF file.The report has
arabic characters.Please any one show me how to configure FOP set up.
I know it is given in FOP site,but i didnt follow it.
Please help.
Thanks.
Re: PDF fonts not visible [message #58941 is a reply to message #58916] Fri, 15 July 2005 07:02 Go to previous messageGo to next message
Originally posted by: berni_hofer.aon.at
i had the same problem with the fonts in pdf ...
you have to make a file like: fop.xml and put it in your
"<directory>:\<eclipse plugin
folder> \org.eclipse.birt.report.viewer_1.0.0\birt\WEB-INF\plugins\o rg.eclipse.birt.report.engine.emitter.fo "
folder ... in this case the preview in birt will load this fop.xml file.
if you have a own application which creats the report with the report
engine, than you have to put the fop.xml file into plugin folder from
"org.eclipse.birt.report.engine.emitter.fo" in your workspace!!
fop xml looks like:
----- begin example fop.xml --------
<configuration>
<entry>
<key>version</key>
<value>org.eclipse.birt.report.engine.ermitter.fo FOP 0.20.5</value>
</entry>
<entry>
<key>baseDir</key>
<value>... put here your directory were the fonts are copied ...</value>
</entry>
<entry>
<key>fontBaseDir</key>
</entry>
<fonts>
<font metrics-file="fonts\ttfcm.xml" embed-file="winfonts\ARIAL.TTF"
kerning="yes">
<font-triplet name="arial" style="normal" weight="normal"/>
<font-triplet name="arial" style="normal" weight="bold"/>
</font>
<font metrics-file="fonts\univers.xml" embed-file="winfonts\unvr55w.TTF"
kerning="yes">
<font-triplet name="univers" style="normal" weight="normal"/>
<font-triplet name="univers" style="italic" weight="bold"/>
</font>
<font metrics-file="fonts\universbolditalic.xml"
embed-file="winfonts\unvr66w.TTF" kerning="yes">
</font>
<font metrics-file="fonts\courier.xml" embed-file="winfonts\cour.TTF"
kerning="yes">
<font-triplet name="courier new" style="normal" weight="normal"/>
<font-triplet name="courier new" style="normal" weight="bold"/>
<font-triplet name="courier new" style="italic" weight="normal"/>
<font-triplet name="courier new" style="italic" weight="bold"/>
</font>
</fonts>
</configuration>
----- end example fop.xml --------
to get the metrics-file you have to download fop and put it in a folder on
your hard disc, afterwards open the command line and make your metric-file
like this command-line command:
----- begin example to make your own metric-file --------
// this example takes the windows font courier and put it into the folder:
// "C:\fop\myfonts\" named courier.xml
C:\>java -cp
C:\fop\build\fop.jar;C:\fop\lib\avalon-framework.jar;C:\fop\ lib\xml
-apis.jar;C:\fop\lib\xercesImpl.jar;C:\fop\lib\xalan.jar
org.apache.fop.fonts.ap
ps.TTFReader -enc ansi C:\WINNT\Fonts\cour.ttf C:\fop\myfonts\courier.xml
----- end example to make your own metric-file --------
i hope this can help you ... it seems to be complicated, but it isn't!!
please excuse my bad english, it's not my native language!
bernhard
Re: PDF fonts not visible [message #59019 is a reply to message #58941] Fri, 15 July 2005 09:15 Go to previous message
it will be usefull for you take a look at foop web[1] for more info about
metric fonts creation
[1]http://xml.apache.org/fop/fonts.html#truetype-metrics
regards
stavros
"bernhard" <berni_hofer@aon.at> wrote in message
news:9fbcddde8294a4d738a5b32dc16fef74$1@www.eclipse.org...
> fop xml looks like:
> <configuration>
> <entry>
> <key>version</key>
> </entry>
> <entry>
> <key>baseDir</key>
> </entry>
> <entry>
> </entry>
> <fonts>
> kerning="yes">
> </font>
> kerning="yes">
> </font>
> </font>
> kerning="yes">
> </font>
> </fonts>
> </configuration>
> C:\>java -cp
> bernhard
Stavros S. Kounis
Osmosis networks & consulting http://www.osmosis.gr
Read my weblog at http://tools.osmosis.gr/blog
Previous Topic:Any support for: Scripted Reports with Drilldowns over SDO DataGraph Object ?
Next Topic:need more clarification on charts & images problem
Current Time: Sun Jul 27 02:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.03467 seconds
