Home » Eclipse Projects » Plugin Development Environment (PDE) » Do we need different update sites for Windows and MacOSX?
Do we need different update sites for Windows and MacOSX? [message #58882] Wed, 29 April 2009 14:47 Go to next message
Dear All,
I am building update websites for windows, macosx and linux plug-ins. In
the feature definition, we have os specific fragment plug-ins. For example:
org.eclipse.core.filesystem.macosx
org.eclipse.core.filesystem.win32.x86
But, when I click "Build All" in update site project, it only builds and
copy win32 plug-ins. All non-win32 plug-ins are left out. Is there any
further setting to make it works? Or do you need different update sites
for Windows and MacOS X?
Thank you so much! Have a nice day!
Best Regards,
Frank Du
Re: Do we need different update sites for Windows and MacOSX? [message #59080 is a reply to message #58882] Thu, 30 April 2009 15:43 Go to previous messageGo to next message
Frank Du wrote:
> Dear All,
You've hit this issue:
196556: [Update Site Editor]Building feature from site.xml editor does
not build fragments
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196556
Is there a reason you don't have a headless build going where this isn't
an issue ;)?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Do we need different update sites for Windows and MacOSX? [message #59451 is a reply to message #59080] Mon, 04 May 2009 11:01 Go to previous messageGo to next message
Hi Chris,
Thank you so much! I finally set up headless build last Friday. So far it
works pretty well, except the generation of p2 artifact metadata.
Best Regards,
Frank Du
> not build fragments
> an issue ;)?
> Cheers,
Re: Do we need different update sites for Windows and MacOSX? [message #59475 is a reply to message #59451] Mon, 04 May 2009 11:27 Go to previous message
Frank Du wrote:
> Hi Chris,
> it works pretty well, except the generation of p2 artifact metadata.
Cool. If you need help with the p2 side of things, check out Andrew's
blog entry:
http://aniefer.blogspot.com/2009/03/building-p2-rcp-products -in-eclipse.html
Re: Do we need different update sites for Windows and MacOSX? [message #596602 is a reply to message #58882] Thu, 30 April 2009 15:43 Go to previous message
Frank Du wrote:
> Dear All,
not build fragments
an issue ;)?
Re: Do we need different update sites for Windows and MacOSX? [message #596739 is a reply to message #59080] Mon, 04 May 2009 11:01 Go to previous message
Hi Chris,
Best Regards,
Frank Du
> not build fragments
> an issue ;)?
> Cheers,
Re: Do we need different update sites for Windows and MacOSX? [message #596745 is a reply to message #59451] Mon, 04 May 2009 11:27 Go to previous message
Frank Du wrote:
> Hi Chris,
blog entry:
Previous Topic:"Build site" debugging
Next Topic:3.5M7 - Problem setting transform start levels
Current Time: Mon May 12 05:03:30 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
