Home » Eclipse Projects » Eclipse Platform » Eclipse & RedHat 9 startup problem
Eclipse & RedHat 9 startup problem [message #58848] Mon, 02 June 2003 08:23 Go to next message
Originally posted by: bojan.kraut.birostroj.com
Hi!
I've installed RedHat 9 and configured J2SE 1.4. I downloaded Eclipse
eclipse-SDK-2.1-linux-gtk.zip and extracted it to Desktop eclipse
directory.
Then I changet permissions with chmod and tried to start Eclipse.
I get following error:
[root@bojank eclipse]# eclipse
eclipse: error while loading shared libraries: ./libXm.so.2: file too short
If I look into error log i get following:
!SESSION May 30, 2003 16:32:28.508
java.version=1.4.1_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/root/Desktop/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 May 30, 2003 16:32:28.511
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 May 30, 2003 16:32:28.512
!MESSAGE Parsing error in "plugin.xml" [line -1, column -1]: "Premature
end of file.".
!STACK 0
org.xml.sax.SAXParseException: Premature end of file.
org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseExc eption(ErrorHandlerWrapper.java:232)
org.apache.xerces.util.ErrorHandlerWrapper.fatalError(ErrorH andlerWrapper.java:213)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:366)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:296)
org.apache.xerces.impl.XMLScanner.reportFatalError(XMLScanne r.java:1244)
org.apache.xerces.impl.XMLDocumentScannerImpl$XMLDeclDispatc her.dispatch(XMLDocumentScannerImpl.java:590)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(XMLDocumentFragmentScannerImpl.java:333)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:525)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:581)
at org.apache.xerces.parsers.XMLParser.parse(XMLParser.java:147 )
org.apache.xerces.parsers.AbstractSAXParser.parse(AbstractSA XParser.java:1158)
org.eclipse.core.internal.plugins.PluginParser.parsePlugin(P luginParser.java:472)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFile(RegistryLoader.java:89)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathFile(RegistryLoader.java:136)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathEntry(RegistryLoader.java:127)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFiles(RegistryLoader.java:104)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:63)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:71)
org.eclipse.core.internal.runtime.InternalPlatform.parsePlug ins(InternalPlatform.java:779)
org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlatform.java:723)
org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPlatform.java:574)
org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1011)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!SUBENTRY 1 org.eclipse.core.runtime 2 1 May 30, 2003 16:32:28.516
!MESSAGE Error while processing
" file:/root/Desktop/eclipse/plugins/org.eclipse.jdt_2.1.0/plu gin.xml ".
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 May 30, 2003 16:32:42.681
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
Caused by: java.lang.reflect.InvocationTargetException
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:848)
... 7 more
Caused by: org.eclipse.swt.SWTException: Unsupported or unrecognized format
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:311)
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:51)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etImage(ActionContributionItem.java:117)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:719)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:596)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:302)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :542)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :454)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 07)
org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:144)
org.eclipse.jface.window.ApplicationWindow.configureShell(Ap plicationWindow.java:244)
org.eclipse.ui.internal.WorkbenchWindow.configureShell(Workb enchWindow.java:578)
at org.eclipse.jface.window.Window.createShell(Window.java:350)
at org.eclipse.jface.window.Window.create(Window.java:301)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1068)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 May 30, 2003 16:35:21.521
!STACK
... 7 more
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 May 30, 2003 16:59:25.420
!STACK
... 7 more
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 10:34:07.980
!STACK
... 7 more
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 10:47:40.364
!STACK
... 7 more
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 10:47:42.985
!STACK
... 7 more
... 8 more
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 10:52:47.823
!STACK
... 7 more
... 8 more
!SESSION Jun 02, 2003 11:22:19.16
!ENTRY org.eclipse.core.runtime 2 1 Jun 02, 2003 11:22:19.18
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 02, 2003 11:22:19.19
end of file.".
!STACK 0
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 02, 2003 11:22:19.24
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 11:22:29.500
!STACK
... 7 more
... 8 more
!SESSION Jun 02, 2003 12:38:39.79
!ENTRY org.eclipse.core.runtime 2 1 Jun 02, 2003 12:38:39.85
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 02, 2003 12:38:39.85
end of file.".
!STACK 0
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 02, 2003 12:38:39.90
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 02, 2003 12:38:49.351
!STACK
... 7 more
... 8 more
Is there anything that I can do? I tried version of clipse with motif and
nothing. On W2K allways worked everithing perfectly, is there any simple
recipe to do the same here?
Greetings,
Bojan Kraut
Re: Eclipse & RedHat 9 startup problem [message #59620 is a reply to message #58848] Mon, 02 June 2003 14:29 Go to previous message
Uh,
why are you running as root? Try logging on as a regular user, using
root is very dangerous and might be part of your problem.
I am guessing that your root login is not actaully configured to use all
of the appropriate system resources ( i.e. libXm.so.2 ).
So, try running as not-root and re-post if it still doesn't work. FWIW
I had no trouble on my RH9 box.
--rowan
Bojan Kraut wrote:
> Hi!
> directory.
> end of file.".
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> end of file.".
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> end of file.".
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION
> !STACK
> at
> at
> at
> ... 7 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> Greetings,
> Bojan Kraut
Previous Topic:Where are task-list entries stored?
Next Topic:A cycle was detected in the classpath of project: StarList
Current Time: Sun Aug 31 23:06:35 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
