Home » Newcomers » Newcomers » Which newsgroup?
Which newsgroup? [message #58839] Thu, 28 April 2005 06:10 Go to next message
I have a question on migration from the plugin architecture of 2.1 to the
OSGi architecture of 3.0.
The question has to do with plugin/bundle class loaders...
Which newsgroup should I go to?
I have not found any eclipse.*.osgi or eclipse.*.plugin group...
Thanks in advance,
Luis.
Re: Which newsgroup? [message #58864 is a reply to message #58839] Thu, 28 April 2005 07:27 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Afaik the osgi-based runtime comes from the equinox sub-project so its
newsgroup may be the appropriate one.
Also, there is a migration guide from Eclipse 2.1 to 3.0 in the help under
'Platform plug-in developer guide'. Maybe that helps you as well.
HTH,
Csaba
> Thanks in advance,
> Luis.
Previous Topic:Is there a XML-editor for eclipse
Next Topic:using separate jdk compilers
Current Time: Sat Jul 26 00:12:07 EDT 2025
Powered by FUDForum. Page generated in 0.08426 seconds
