Plugin Dependencies [message #582842] |
Fri, 21 July 2006 12:17 |
Originally posted by: rosskopf.progroup-inc.com
Hello List,
using teneo in CVS faces with the following stack-trace caused by a call
to buildSessionFactory from Hibernates Configuration class:
<snip>
14:13:23,140 ERROR HbDataStore:469 - Unable to build session factory!
org.hibernate.MappingException: Could not determine type for:
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType,
for columns: [org.hibernate.mapping.Column(econtainer_class),
org.hibernate.mapping.Column(e_container)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 66)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Property.isValid(Property.java:185)
at org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:395)
at org.hibernate.mapping.RootClass.validate(RootClass.java:192)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 1026)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1211)
org.eclipse.emf.teneo.hibernate.HbDataStore.buildSessionFact ory(HbDataStore.java:467)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:188)
</snip>
I guess that is a problem with my plugin dependencies.
But I did not manage to find out what plugins dependant on each other.
Regards.
Joachim
FUDForum. Page generated in 0.02424 seconds
