Home » Language IDEs » AspectJ » AspectJ project does not clean-build on library change?
AspectJ project does not clean-build on library change? [message #58784] Mon, 21 November 2005 13:52 Go to next message
Just curious.
In Eclipse 3.0, AspectJ project will do a rebuild on library change if
auto-build is enabled. In Eclipse 3.1, a library change does not trigger a
rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
need to click the "clean ..." menu item to trigger a clean-build to clean
all those library related compile error marks.
Re: AspectJ project does not clean-build on library change? [message #58809 is a reply to message #58784] Tue, 22 November 2005 09:52 Go to previous message
Hi Harry,
This looks like a bug I just fixed -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420. It should work in
the latest development builds of AJDT.
Sian
harry sheng wrote:
> Just curious.
> a rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
> clean all those library related compile error marks.
Re: AspectJ project does not clean-build on library change? [message #591002 is a reply to message #58784] Tue, 22 November 2005 09:52 Go to previous message
Hi Harry,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420 It should work in
Sian
harry sheng wrote:
> Just curious.
Previous Topic:AspectJ project does not clean-build on library change?
Next Topic:Library aspectrt.jar with Internet Explorer JVM : compatible or not ?
Current Time: Sun Jul 27 01:33:08 EDT 2025
Powered by FUDForum. Page generated in 0.04319 seconds
